Ubuntu Linux Összefoglaló
Hivatalos Ubuntu dokumentáció
lspci
lsusb
PazsitZ
PazsitZ
Úgy tűnik, nem ismeri ezt a paramétert.
pazsitz@Pazsit:~$ sudo modprobe atl1c nohwcrypt
FATAL: Error inserting atl1c (/lib/modules/3.2.0-27-generic/kernel/drivers/net/ethernet/atheros/atl1c/atl1c.ko): Unknown symbol in module, or unknown parameter (see dmesg)
pazsitz@Pazsit:~$ dmesg
[ 4590.403190] atl1c 0000:02:00.0: atl1c: eth0 NIC Link is Up<100 Mbps Full Duplex>
[ 4590.404876] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 4595.833850] atl1c 0000:02:00.0: irq 44 for MSI/MSI-X
[ 4595.834121] atl1c 0000:02:00.0: atl1c: eth0 NIC Link is Up<100 Mbps Full Duplex>
[ 4600.608110] eth0: no IPv6 routers present
[ 4694.860482] atl1c 0000:02:00.0: PCI INT A disabled
[ 4706.526523] atl1c: Unknown parameter `nohwcrypt'
[ 4780.267571] atl1c: Unknown parameter `nohwcrypt' -
PazsitZ
ip címek, def. gw jónak tűnnek.
eth0 Link encap:Ethernet HWaddr e8:9a:8f:9c:b0:2b
inet addr:192.168.1.3 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1320 Metric:1
RX packets:312 errors:0 dropped:0 overruns:0 frame:0
TX packets:438 errors:0 dropped:0 overruns:0 carrier:3
collisions:0 txqueuelen:1000
RX bytes:53854 (53.8 KB) TX bytes:56529 (56.5 KB)
Interrupt:44DNS ugye pont az, ami működik, alapvetően.
lspci -vv:
02:00.0 Ethernet controller: Atheros Communications Inc. AR8151 v2.0 Gigabit Ethernet (rev c0)
Subsystem: Lenovo Device 21ec
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 44
Region 0: Memory at f0100000 (64-bit, non-prefetchable) [size=256K]
Region 2: I/O ports at 2000 [size=128]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [48] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee0100c Data: 4189
Capabilities: [58] Express (v1) Endpoint, MSI 00
DevCap: MaxPayload 4096 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn+ AttnInd+ PwrInd+ RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr+ FatalErr- UnsuppReq+ AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 unlimited, L1 unlimited
ClockPM+ Surprise- LLActRep- BwNot-
LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes Disabled- Retrain- CommClk+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Capabilities: [6c] Vital Product Data
pcilib: sysfs_read_vpd: read failed: Connection timed out
Not readable
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP- SDES+ TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP+ Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 14, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [180 v1] Device Serial Number ff-9c-b0-2b-e8-9a-8f-ff
Kernel driver in use: atl1c
Kernel modules: atl1c -
PazsitZ
Sziasztok! Segítségeteket kérném.
Van egy routerem, ami DHCP-vel osztja a netet. A netbook-om a korábbi 11.10-es verzióval is gondja volt és most az új 12.04-essel is ugyanaz a tünet.
Rádugom a routerre rögtön kapcsolódik. A névfeloldás tökéletesen működik. Pingel bármit, de ezen túl se http, se ftp kapcsolat nincs.
(Továbbá a belső hálózaton szépen látom és elérem a másik gépet is. Az egy xp-s gép, nincs ip, név ütközés vagy ilyesmi...)
Egyszerű timeout-al száll el mind a böngésző, mind sima wget.
Valami ötlet, hogy ezt mi okozhatja, miként lehet megoldani?
- Vélemény Ubuntu 20.04 LTS
- Milyen notebookot vegyek?
- Fogyjunk le!
- Crimson Desert
- Vicces képek
- BESZÁMÍTÁS! MSI A320M R7 2700 8GB DDR4 256GB SSD RX 6500 XT 4GB Zalman T3 Plus DeepCool 400W
- DJI mini 3 drón display unit
- HP ZBook Studio G8 i7 32GB RAM 1TB SSD RTX A3000/Garancia
- Yoga Pro 9 - RTX 5070 - 64GB - multitouch laptopok! - LENOVO GAMER BAZÁR - új lista (2026.03.03)
- Magyarország piacvezető szoftver webáruháza
