- Hivatalos: ekkor mutatkozik be a vivo X300 Ultra, és így néz ki hátulról
Bogyi007
roberto211
#38709
Így jó lesz szerintetek?
Welcome!
My name is Zoltan Krisztin, I play in your Xbox 360 console with games including COD MW2 with as well. My Gamertag is Hun Bogyi007In yesterday Modern Warfare 2 game with a friend (Gamertag: mokyboy HUN) by the Free For All mode, when we played one of the strange things we experienced entering lobby. One opponent (Gamertag: Toni Shooter) attack helicopter ever killed us in the game several times at the moment as we revived.
Even this was strange but most of all is that after you hit someone I was not the usual 200 to 300 points for shooting down enemy but more than two million points. Quickly exited the game but it was too late!
I have the previous 23 as the maximum level was changed to 70 and the multiplayer levels also showed a 100%.
My friend did not happen, he values the Spec Ops, written in over 100%.We want to know now what to do at this time? Can be restored to the previous result it is now, or my left? I would like to see a fair way under its own power in the game, the maximum level of 70 and not in that way.
If there is no other option is to reset my results so far and then re-start the collection points.
Even if the friend could Spec Ops mode should be set back to the previous results, or it can be reset.Thanks in advance for your help!
Sincerely, Zoltan Krisztin
Bogyi007
Gebriel
#38688
Beszéltem supporttal, szerintük ez a liveos profilomra nem lesz kihatással, de javasolták hogy az Activision-nal vegyem fel a kapcsolatot, kaptam egy telefonszámot de az a szegényes angolom miatt nem lesz járható út.
Ìgy szerintem megfogalmazom magyarul a történteket majd google fordìtóval lefordítom angolra s elküldöm az Actisok supportjának.
Így jó lesz vagy valami más menete van ennek? -
Bogyi007
Gebriel
#38675
Az nem, az nagyon nem.... Ez a főprofilom 10 hónap liveom van még rajta egy rakás játékom Godról. Ne legyen már ilyen egy joinolás miatt amit nem is tudok irányítani. A gép dobott bele abba a lobbyba nem is én választottam. Ha tudom hogy ilyen van akkor el sem indítottam volna a játékot.....
Bogyi007
Játszottunk Mw2-ben egy cimbivel free for allt és az egyik join alkalmával egy booster lobbyba kerültünk egy olyan userhez (Toni Shooter) aki állandóan heliről lelőtt amint respawnoltam és ami különösen furcsah hogy találatonként több millió vagy milliárd pontokat kaptam ami azt eredményezte hogy teljesen kimaxolta a multiplayeremet 100%-ra. Cimbinek meg a Spec Ops-át tette 100%-ra..
Én a 23-as szintemet szeretném visszakapni és az 1400000-es helyezéseimet és nem a 10 óra alatt elért 70-es szintemet és a 478482-met....
Bogyi007
Barátnőm öccse kontrollerrel akarná bekapcsolni a boxot de a kontrolleren a ledek csak villognak nem pedig körbe-körbe futnak (mind a négy) a boxon meg egyik sem villog - csak a bekapcsolt állapot látszódik. És nincs kép a tv-n pedig ugyanúgy AV-ra van állítva mint korábban - más eszközt rádugva a tv-re van kép.
Mi lehet a gond? Rossz a box AV kábele vagy a boxnak a Gpu-ja vagy videókarija szállhatott el? Vagy valami más ötlet esetleg?
Bogyi007
molnarpeter
#35680
Okés bár még aki akar még most is tud új Fat gépet venni. Leendő sógim is azt vett pár hónapja garisan számlásan.
Bogyi007
Sziasztok! nincs valakinek véletlenül egy fölös 10%-os kódja zavvira?
Csak megköszönni tudnám. -
Bogyi007
Petya2900XT
#30525
Nagyon nagy köszönet ezért a listáért!
Rég kerestem már ilyet.
Bogyi007
WhiteWalker
#26967
Nekem a boxhoz van 23"-as FullHd monitorom, akkor az is gáz szerinted?!
Bogyi007
Van két kütyüm aminek van optikai kimenete. Az egyik a fat boxom amihez van az átalakítóm amin rajta van az optikai csati és van egy humax digi + c Hd set top boxom.
Ezeket eddig külön-külön csatlakoztattam hifihez egy dekóderen át hogy legyen DD 5.1 hangom. csak hát macerás dolog mindig ki-be húzni a kábeleket s nem is jó a csatlakozóknak sem ez így vettem cimbi segítségével Hongkongból egy elosztót aminek két optikai bemenete és egy kimenete van.
A szitu az hogy bárhogy is kötöm rá a boxot az elosztóra - akár a jobb akár a bal felére s akár a Digis set top boxal együtt vagy nélküle a box nem ad hangot, míg a Diginek persze van hangja. Ha kihagyom az elosztót a játékból akkor mindkettőnek van hangja.Miért van ez? Talán a box letiltja automatikusan a hangot ha megosztást érzékel vagy mi a rák van?
Bogyi007
Valami gebasz van mert a boxom nem akarja látni a pendriveaimat. Egyet ismer csak fel amin van tartalom de az is csak úgy ha konfigurálnám rajta.
Más nem találkozott ilyen problémával mostanság? Kb egy-másfél hete még minden okés volt e téren a géppel.
Bogyi007
Tegyük fel hogy az Elite X360 amit kinéztünk vadonásúj, kihozza a futár s utána beregeljük a supportnál. Akkor én most mennyi garit kapnék rá? Ugyanúgy megkapnánk rá a 3 év/3led garit rá vagy figyelembe vennék azt hogy mikor lett legyártva a masina a szériaszáma alapján és abból számítanák ki a gari idejét?
Viszonyításként az én mostani Jasperes Arcade gépem (a vinyót később vettem hozzá így nem gyári Elite) 2009,11,19-én lett gyártva és a normál garancia lejárati dátuma március 15, 2012.
A gépet tavaly márciusban vásárolta meg az előző tulajdonosa akitől megvettem s a support átírta a nevemre a garit (s ott azt mondták nekem hogy a normál gari dacára a 3ledes garim +1 évvel több azaz 2013 márciusáig érvényes rá) -
Bogyi007
Te hol látod azt hogy ez használt? Mert szerintem nem az, akkor meg nincs semmi para a garival. Beregeleljük az Ms-nél és kapjuk a szokásos 3éves 3ledes garit rá. Kinectet nem tervezünk hozzá venni, de amikor meg veszel dobozosat akkor meg jár hozzá átalakító egyébként is.
Ha meg mégis használt akkor vesszük a Holiday packos gépet.
Bogyi007
Akkor tehát a KonzolStudió egy megbízható bolt? Mert ha igen akkor valszeg ezt az Elite gépet vesszük meg s így marad még lé egy éves Gold karit is venni ( játékokat meg a "kisöccs" kap tőlem is használatra.
Bogyi007
Bogyi007
Barátnőm öccsének tervezünk gépet venni, a néhai Multiformat (mostani nevén Konzolgame) mennyire ajánlott hely mostanság?
Konzolokszervize a másik hely amiben gondolkodom 1 hónapon belül 3 premierjátékot vettem tőlük és minden rendben volt velük de a multiformat is korrekt volt régen mivel első boxomat tőlük vettem, csak látom mostanra új nevük lett.
Bogyi007
Weißturul
#23551
Azért gondolom például egy ME2 során ha belekezd az ember néha el kell mennie az embernek egyéb dolgokat is végezni (wc kaja pia stb) egy lemezcserénél kimegy s cserél egy lemezt is, ne legyen már ez akkora probléma mint amit kreáltok itt neki. Vagy a te géped olyan messze van tőled hogy nem tudod a lemeztálcát kinyitni?
Bogyi007
Nem tudom mi lett volna veletek ha lett volna kb 10 éve Amigátok ott volt hogy egy játék akár 4 lemezes is volt (Mortal kombat 2 de a Rise of the robots 11 lemeze sem volt piskóta
)A Battlefield 3 esetében is elkelhet a lemezcsere ha a kampány után multizni akarsz....
Bogyi007
Van egy megoldás arra ha valakinek még nem sikerült belépni a Battlelogra a BF3 kapcsán.
Mint ismert minden egyes EA games vagy Sports játék esetében használunk egy email címet s hozzá egy jelszót. ez volt a régi EA Account s mostanra Origin néven ismerjük.
A legegyszerűbb megoldás az hogy megtudjuk hogy mik a saját adataink akkor azt kell tenni hogy az xbox.com oldalon belépünk a profilunkba és a keresőbe beírjuk azt hogy EA SPORTS, erre kapunk majd pár találatot s azt kell kiválasztani amelyik egy kb 40 megás APP ami ingyenes s ha a pc-n kiválasztjuk a megvásárlását akkor a boxunkra letöltődik a háttérben a kliensprogi. Egyébként sok hasznos dologra jó progi ( de erre most nem térnék ki hogy pontosan mikre) a lényeg az hogy amikor a Boxon letöltődik akkor a Game Library menüben keressük meg az EA Sports "játékot" és indítsuk el (Y gombbal).
Miután betöltődik a képernyő kövessük az utasításokat s menjünk az EA Account Management fülreés nyomjunk A-t.Itt az EA Account email Adressnél láthatjuk azt az email címet amit az EA játékoknál használunk valamint van egy Update email Address/Password rész is itt megint nyomjunk egy A-t s itt tudjuk módosítani minden gond nélkül bármire jelszavunkat akár akkor is ha már elfelejtettük a régit.
Ha mindezzel megvagyunk akkor lépjünk ki a programmból s innen elvileg egyenes út visz minket a Battlelog felé.... -
Bogyi007
Anno a Bc2 bétája meggyőzött hogy az a játék kell nekem, pedig nem is ismertem egyáltalán a Battlefield játékokat. Azóta megvettem az első részét is a rossz társaságnak valamint mentem pár kört az 1943-al és most kipróbáltam a bétát.
Hát röviden: szutyok, optimalizálatlan sz*r. A pálya 98%-án senki nincs csak a metróalagútban de ott meg amikor bemásztam az egyik kocsiba akkor nem tudtam kimászni mert mindenbe beleakadtam, máskor meg a legszűkebb kocsiba velem együtt még két ember volt és nem tudtunk kijönni onnan.
Ez nem hogy megerősített abban hogy kell a játék hanem egyenes eltántorít tőle egyenlőre.....
Bogyi007
bLaCkDoGoNe
#13997
Még jó hogy az EU-ban vagyunk és ebből adódóan bármit bárhonnan megvehetünk...
Egyébként ami hátrány az 576-nál az valamilyen szinten előny is. Lehet olcsón is találni használt játékokat náluk jó állapotban (Szegeden), 1000 forintért találtam náluk Burnout Revange-t és adtak egy 1000-t a Top Spin 2 lemezemért, amit máshol be sem akartak venni.
Bogyi007
Mennék én is az első hz-ba.
Bogyi007
szpal17
#10551
De a 960 Ms pont még jobban hangzik szerintem mert ha Iceakostól veszünk pontot akkor még kevesebből is ki lehet így hozni a játékot.
más:
BC2-ben ezt az üzenetet kaptam:
Skill Level: 0
Your recent form has degraded your skill level. Now get back to the battlefield and start working on your improvement!A Skill Level 76-ról ment le 0-ra.
Ez mit jelent pontosan?
Bogyi007
Van egy Halo ODST lemezem s mellé a Halo 3 multilemeze is, csak nem vágom hogyan is kellene beállítanom hogy mások ellen tudjak játszani Liveon vele.
Bogyi007
Bogyi007
No beszéltem a supporttal a gépemmel való hibaüzenettel kapcsolatban. És miután említettem neki hogy a hibák megoldódtak a vinyók levétele után s mozgattam is róla telepített adatokat ezt javasolta:
A cache törlés és annak menete:
1) Töltsd be az Xbox 360 dashboardot.
2) Válaszd ki a System Settings menüpontot.
3) Válaszd ki a Memory almenüt.
4) Jelöld ki a meghajtót.
5) Nyomd meg az Y gombot a meghajtó opcióinak megjelenítéséhez.
6) Válaszd ki a „clear system cache-t”.
Azt is mondta ha ez nem segít akkor mehet a vinyók nélküli játékfuttatások majd legvégső esetben a support megint hogy a gépet beküldjem a szervízbe.
Nos ezt pedig már tegnap is lejátszottam és akkor vinyó nélkül mentek is a lemezek mint a kisangyal. De most megcsináltam a cache törlést is a vinyókon s a játékok le is vették a saját kis update-ikat és futnak is tökéletesen megint. -
Bogyi007
Silent77
#9751
Elsőre az F1-nél csinálta, akkor levettem a külső vincsit ment is rendesen.majd átraktam a lemez telepítését a gyári 20-as vincsire és akkor sem volt gond.
Kicsit később a Bc2-vel játszottam ami szintén a gyári vincsire volt rakva, egy sq dm-et letoltunk aztán töltöttem be az új pályát és akkor megint bejött a hibaüzenet, ekkor levettem a vincsit majd visszaraktam s megint elindítottam a játékot s ezt a lemezt is megtörölgettem, utána ment minden rendben ahogyan szokott. -
Bogyi007
This disc is unreadable.
1. clean the disc with a soft cloth.
2. Restart the console.for more help, visit www.xbox.com/support
Ez a felirat fogad mikor már el van indítva a játék Bc2-ben és már indulna a multis meccsem amihez joinoltam. A lemez fel van telepítve. a Boxom 2009-es decemberi Jasperes arcade és egy 20 gigás vinyüm van hozzá.
de ugyanezt csinálta ma az F1 2010 lemezével is, ott is játék közben amikor edzésbe kezdtem bele akkor dobta ezt ki.
Mi lehet a gond? A gépet kikapcsoltam majd vissza s a vincsit is levettem majd visszaraktam és a hiba megmaradt ugyanígy.
Mondjuk mindkét esetben két külön vinyón volt a játék (egyiknél a külsőn a másiknál meg a gyárin) és mindkétszer újraraktam a játékokat, a lemezeket megtörölgettem, s leválasztottam és visszaraktam őket. Ez után nem jött elő a probléma. És az is fura hogy akkor jelentkeztek a hibák amikor a lemezolvasónak elvileg nem kellett volna működnie hanem a vinyóról futottak már a játékok (tudtommal a Box installált játékoknál csak az indításkor olvas a lemezről utána már nem) jóval az indításuk után.
Mindenesetre a gép 2009.11.17-én került le a gyártósorról s idén márciusban emelték le a polcról s a normál garancia lejárati dátuma 2012. március 15, így ha gond is lenne vele akkor hívom a Supportot és viszik a gépet.
Bogyi007
Nekem egy hasonlóm van (Labtec arena 685) és úgy kötöttem a Boxhoz hogy anno teszveszen találtam egy Dolby pro logicos dekódert (Jazz márkájút). Amikor nem volt monitorom akkor a boxhoz adott rca kábelt rugtam a dekóderbe amit meg a hangfalszettel kötöttem össze és kaptam Pro logicos hangot (a hátsó hangszórók monóban szóltak, de a térhangzás subbal megvan), amióta megvan a monitorom azóta a boxból Hdmi-n keresztül viszem át a hangot is bele és a jack kimenetén keresztül kötöttem össze a dekóderrel a többi ugyanúgy maradt.
Szóval lehetséges a dolog.
Bogyi007
Karira kaptam egy Assassin's Creed II Game of the Year lemezt. A játék bontatlan s szeretnék kapni érte cserébe egy Gears 2 Goty vagy F1 2010-et.
Ha valakit érdekel esetleg az dobjon egy privit. -
Bogyi007
Kellemes karácsonyi ünnepeket és jó halléfogyasztást!
Bogyi007
Monster Army
#8359
Közelemben Kiskunhalason is van ilyen bolt, de a tulaj védelmében elmondhatom hogy ő legalább vesz be és ad el eredeti játékokat is. Szoktam is tőle venni néha játékokat ha van számomra érdekes darab.
Bogyi007
Nekem is ilyen kombóm van és elférek rajta (igaz van egy külső vinyóm is amin a 16 giga fel van használva.
De ha nem volna akkor sem volna gáz, egy játékot felrakok amit éppen sűrűn játszok + a letöltött MP anyagok, dlc-k és ha más játékra váltok akkor felmásolom azt a korábbi helyett.N64 mekkora masina volt már. Sw shadow of the Empire hatalmas volt rajta a Goldeneye nemkülönben és az első játék amit láttam rajta a Wave Race ami egy jetski játék volt. Akkoriban ami effektet tudott a játék az nagy szó volt. Volt egy ködös tavi pálya benne ami a második körben felszállt és kitisztult a légkör benne. Amikor láttuk első ízben azt kiejtettük a joyt a kezünkből.
Jó dolog is a nosztalgia.
Bogyi007
576 mai akció: Medal of honor tier 1 edition 8059 ft.
Ez biztosan kimarad. Nekem még ennyit sem érne meg a játék. -
Bogyi007
20 gigás vinyóval megspékelt Jasperes Arcade-om van. Kevésnek tűnik a vinyó, de van itthon egy külső vincsim amit meg is formáztam a boxnak és így kaptam 16 giga plusz helyet (meg maradt még sima pc-s parinnak kb 8).
A kérdésem az lenne ha ez a külső vincsi is használva volna a boxhoz úgy hogy a játékokat erre is felinstallálnám az mennyire terhelné meg a gépet hűtés szempontjából? Rizikósabb-e a gép egy esetleges RROD-ra vagy nem befolyásolja a működését a gépnek ez a plusz rádugott usb-s vinyó?
Bogyi007
MeszarosB.
#7818
Regelted a Microsoftnál a gépet? Mert ha igen akkor egyértelmű hogy nekik szólj.
Bogyi007
heihachi
#7787
Együtt lesz majd annyi elvileg péntektől.
És itt egy másik akciós ajánlat is. -
Bogyi007
Bogyi007
Ha nincs VIP kódod akkor BC2-ben. Már 7 pályacsomag variáció van, nem rossz az ha megvan a jogosultság. És a profilod emlékezik is rá ha megvetted. Nekem miután eladtam az első boxot elvileg nem volt szükségem már a profilomra, de ugye újra vettem egy gépet és a BC2-t nelég volt használtan vennem mivel a profilomban már aktiválva volt korábban a kód s mivel limited editiont vettem anno a fegyók is megvoltak.
Bogyi007
NAGYON FONTOS! BÁRKI HA HASONLÓ ÜZENETET KAP VISSZA NE ÍRJON ÉS NE KÜLDJÖN EL SEMMIT VÁLASZKÉNT!!!!!
Üdvözletem!
Látjuk maga még nem használta fel az ajándék Microsoft pontot amit a migrálásáért kapott!
Most az eheti ajándékunk a Microsoft Hungary-nél hogy ha vissza küldöd itt válaszként a kódot (csak 1db 800pontosat) akkor cserébe 1200-asat kapsz! Ez az akció csak November 25.-éig érvényes!
Gondolja át és ha igényt tart erre akkor jelezze felénk!
Üdvözlettel
Microsoft team.ÁTVERÉS!!!!!
Bogyi007
Pickle Rick
#7721
Live üzenet volt amiben írták is hogy free pontokat kapok ha beírom a kódot, s így is lett.
Korábban nem vásároltam a migrálás után vettem 2100 pontot Iceakosnál és használtam fel 20 pont híján.Az üzenet kimondottan a gépre jött és angol nyelven íródott. Ja és mindjárt 10.-én reggel nyolc körül migráltam talán ez is számíthatott.
Bogyi007
Megkaptam a migrációért a 800 pontot.
Bogyi007
Crazyman33
#7556
Mikor regeltél át?
Én a migráció napján amikor indult a magyar Live reggel 8 körül. De egyenlőre annyi pontom van amit ma vettem. Ezzel kapcsolatban egyébként bemásolnám egy másik fórumban írt kérdéseimet is:
Vettem Iceakostol Ms pontot európait (köszi!) és az xbox.comon írtam be a magyar profilomba ami sikerült is. Innentől jönnének a kérdések:
Valaki vásárolt-e már magyar jogosultsággal a magyar marketplaceről?
Aztán ha sikeres a vásárlás akkor milyen jogaim vannak? Korlátlanul letörölhetem a gépemről és letölthetem újra vagy csak egyszer?
Esetlegesen megosztható-e a letöltött tartalom - ha igen csak ugyanazon a gépen csak más profillal bejhelentkezve vagy más gépen bejelentkezve saját profillal és használná más is a gépen s utána a saját gépre is letöltve.
Van-e most valami akció? Egy hete írtatok arról hogy aki most vásárol a héten az később viszakaphat pontokat. Ilyen tényleg van-e most és magyarok is elérhetik-e?
Én mondjuk most hiába mentem a Trials HD megvételére. Ezt kaptam üzenetnek: Can't retrive information from Xbox Live. Please try again later. Status code: 80153422
Érdekes módön a trial verziót ellenben engedi leszedni. Fura.
Az xbox.com oldalon elvileg engedné, de mi a garancia hogy magára a boxra tényleg le fogom tudni szedni? Jó lenne ha valaki írna valami megerősítést vagy cáfolatot. nem akarom bebukni a pontokat.
Bogyi007
Ha bemegyek a Customize Avatarba akkor kapok egy feliratot:
Avatars have changed and all clothing needs to be updated.
Ezt elfogadva elindul az update majd kapom ezt:
There was a problem changing your avatar's clothes.
Status code: 80004005
Valami ötlet erre?
Bogyi007
Hát ha igaz lesz tényleg ez az ajándék pulikutya és min 800 pont akkor én vagy megtoldom még Iceakostól a pontot és megveszem a Trials HD-t a kiegészítőjével együtt vagy elköltöm a Tomb Raider Underworld kiegészítőire esetleg a Gears of war 2 kiegészítőjére.
Bogyi007
Egy dolgot ne tegyetek ilyenkor, a profilokat ne töröljétek most semmiképpen mert akkor nem fogtok tudni recoveryzni vissza a gépre. Veerminaar cimbim ezt tette.....
Bogyi007
Pickle Rick
#7127
Ez nálam is megvolt, vagy másik böngészővel menj az oldalra vagy töröld a böngésződ előzményeit és catch-ét.
Nekem sikerült a migráció, ellenben Veerminaar cimborámnak az országban eddig egyetlenként elszállt a profilja is, megvan valahol de nem tudja vissza recoveryzni a gépére és a support sem tud egyenlőre tenni semmit vele.
Bogyi007
5oultrain
#7067
Nekem 2009 novemberi a Boxom ami Arcade + 20-as vincsi + 1 kontroller és 11 játék gari 2012 márciusig. Ezt kaptam a Fat 40-es Ps3-amért aminek idén decemberben járt volna le a méltányossági garija és egy dual 3-as kontroller + 12 játék volt hozzá.
Te talán egy használt Slim Ps3-ra is jó lehetsz szerintem.
Bogyi007
Más is tapasztalta azt hogy monitor esetén ha a felbontást 1080p-re teszi akkor sötétebbek a játékok? A Tom Raider Underworld-el játszok és 720p-ről átállítottam a boxot 1080p-re és sötétebb lett az egész játék mintha le lenne véve a fényereje a monitornak. Ez mitől lehet?
Bogyi007
K: Hogyan honosíthatom a fiókomat?
1. Jelentkezz be az Xbox LIVE hálózatába, és tallózz a My Account page oldalra
2. Kattints az Account Region opcióra
3. Válaszd ki Magyarországot
4. Kövesd a megjelenő utasításokat! Ne feledd újra letölteni tartalmaidat egy USB flash meghajtóra vagy merevlemezedre, mielőtt továbblépnél!
5. Olvasd el és fogadd el a Felhasználási feltételeket
6. Fiókodat ezt követően honosítja a hazádban kínált LIVE szolgáltatás
7. Válaszd ki a tagsági fokozatot (Ezüst vagy Arany)
8. Ha Arany tagságot szeretnél, hitelkártyaadataidat is meg kell adnod
9. Immár a magyarországi LIVE hálózat hivatalos tagja vagy. Gratulálunk!Ezeket végig is zongoráztam de én nekem sehol sem jött be olyan ahol az angol címemet át kellett volna írnom magyarra. Vagy azt nem is kell?
Bogyi007
Megtaláltam ezt a topicot is végre!
Már jó ideje látogatom a fórumot, főleg a Voda845 teló miatt, de mostanra visszatértem a Boxhoz is némi ps3 kitérő után, így aktuális hogy itt is aktív legyek. Gamertagem Hun Bogyi007 (első hz-ba berakhattok esetleg engemet is). ha esetleg tudok segítek pár dologban majd de sokszor fogok kérdezni is.
Első kérdés, holnapután indul a magyar live: nekem angol címen van egyenlőre, pontosan hogyan kell hazahozni majd a profilt?
valamint nincs valakinek egy fölösleges 48 órás Live kódja? Szerdán élesítem a goldot de addig jó volna kicsit bemelegíteni. Csak megköszönni tudnám de azt nagyon!
- Linux kezdőknek
- Xbox Series X|S
- Motoros topic
- Bluetooth hangszórók
- Lenovo Thinkpad E595 Ryzen 5 pro 3500U, Radeon Vega 8, 8-16GB RAM, SSD, jó akku, számla, gar
- ÁRGARANCIA! Épített KomPhone Ultra 9 285K 64GB RAM RTX 5090 32GB GAMER PC termékbeszámítással
- HIBÁTLAN iPhone 14 Pro Max 256GB Space Black -1 ÉV GARANCIA - Kártyafüggetlen, MS4370
- Apple iPhone 15 Black 128GB használt szép állapot 100% akku 6 hónap garancia
- Lenovo ThinkPad L13 Gen 3 13,3" - i5 1235U, 16GB RAM, SSD, jó akku, magyar bill. - számla, 6 hó gar
