Xiaomi AX3600 WiFi 6 AIoT Router
galizoli70
Írtam a Xiaomi-nak hogy a globál verzióban miért gyenge a wifi. Ime a válasz:
Dear Sir/Madam,
Hello, Greetings from Xiaomi Customer Support! This is Mia.
We at Xiaomi value your trust and we apologize for the inconvenience. Rest assured that we'll assist you on this.
Regarding your weak WiFi singal requirement, please follow the following steps:
(1) Place the router at an appropriate height and position to ensure signal coverage, and keep the router away from induction cookers, microwave ovens, refrigerators, Bluetooth devices and other devices (more than 3 meters) to prevent signal interference.
(2) Adjust the WiFi signal intensity to the through-wall mode.
(3) If the router hasn't updated ROM for a long time, please try to check the update ROM first.
(4) Try to manually change the channel. Channel 1,6,11, 13 can be tried for 2.4G WIFI.
(5) Try to update the driver of the wireless network card.
(6) You can adjust the MTU value of PPPOE. The default value is 1480, but you can change it to 1412. (Note: If normal websites can be opened, so there is no need to change the MTU value).
(7) If the QoS function is enabled, please check whether the speed measurement results accord with the network bandwidth of your home;If you know the broadband product rate at home, you can directly set the upstream and downstream speed.
(8) If there is problem of DNS, the non-continental region can be set to Google DNS: 8.8.8.8.
(9) The mobile phone can surf the Internet while the computer web page cannot be opened: Repair the network by LSP.
(10) If it is dial-up Internet access, you can restart the router; If you are in a complex office network, I would suggest you ask your maintenance staff if you have restrictions on your router.
Hope this information can help you. Sorry again for the inconvenience. We would appreciate your patience and understanding.
Please believe that Xiaomi takes every product and every user seriously and will not lower its quality because of the export region.
If you have any other questions, welcome to visit again. Always believe that something wonderful is about to happen!
Follow Twitter@XiaomiSupport to get latest product tips and service information. https://twitter.com/XiaomiSupport
Best Regards
Mia -
galizoli70
trance89
#2359
Köszönöm. Igen közben megtaláltam. Eddig arra jutottam hogy inkább rendeltem volna kínából. De még ez is megeshet ,ha másnak nem ez marad mesh-nak. Még barátkozom a leírással. Vagy veszem a bátorságot és belekezdek....vagy hátha találok valakit aki némi ellenértékért megteszi helyettem. Köszönöm !!!!!
galizoli70
enginev3.0
#2357
Köszönöm. Csak sajnos eddig nem találtam általam értelmezhetó leírást.
galizoli70
Bár kértem már segítséget de megpróbálom mégegyszer.
Volt egy Xiaomi router 3G és most vettem egy AX 3600 mivel nagyon jó a tesztje és reméltem jobb lesz. Edigital vásárlás. 3.0.22. FW. A 3G router kínai régión volt mivel azt kínából rendeltem az ax 3600 Germany régióval megy. A kérdésem az lenne hogy moért gyenge a wifi. HP laptop i5 intel procival. A régi routerrel 17-190Mbps sebességet mértem. A 3600 valamivel jobb 220-230Mbps. A laptop kb 3-4m a routertől. A konyhában ami már kicsit messzebb van már gyenge a jel igaz már van pár fal. Látom itt milyen jó sebességeket mérnek. Már napokm óta próbálgatom de nem sikerül. Nagyon szívesen vennék minden tanácsot és segítséget.
Előre is köszönöm.
galizoli70
Szaisztok!
Egy kis tanács kellene. Volt xiaomi router 3G. Most vettem egy ax3600-ot. Itt olvasom milyen wifi sebességet mérnek ezzel a roterrel. Nekem nem lett gyorsabb. Sokszor az 5G wifi is elindul 200MB/s és gyorsan csökken a sebesség....a mérés végére már alig 5-6Mb/s. HP i5 laptop és Xiaomi redmi note 7 Pro telefon. Előre is köszönöm.
- Okos Otthon / Smart Home
- Víz- gáz- és fűtésszerelés
- Milyen videókártyát?
- Milyen notebookot vegyek?
- Íme az év legszebb játékai - a Digital Foundry szerint
- OLED TV topic
- HDTV HD010 kül/beltéri FULL HD/4K tv antenna / 12 hó jótállás
- 183 - Lenovo Legion Pro 7 (16IAX10H) - Intel Core U9 275HX, RTX 5090
- Apple iPhone 13 Pro Max / 128GB / Kártyafüggetlen / 12Hó Garancia / Akku:87%
- BESZÁMÍTÁS! SAPPHIRE B650M R7 8700F 16GB DDR5 512GB SSD RTX 4060Ti 8GB Zalman S2 TG ADATA 600W
- GYÖNYÖRŰ iPhone 13 Pro 128GB Graphite -1 ÉV GARANCIA - Kártyafüggetlen, MS3962, 100% Akkumulátor
