Norbyte
Mai kártya, mai mérés.
Catalyst 3.2, minden alapon. C3D R9700
http://service.futuremark.com/compare?2k1=6185687 -
Norbyte
És a Duron DDR-rel nem összehasonlítható egy SD-s Cerka-val.
Norbyte
Nyomtam egyet 230/470-en. Az a 300 pont nem éri meg úgy hajtani mindig, akkor inkább veszek egy GF4 Ti4200-at vagy majd egy Radeon 9700-at.
3DMARK2001 PROJECT FILE
PROJECT
Name My Benchmark
Description
Registration Name Tom Solen
Registration Key
3DMark Version 330
DISPLAY
Platform NVIDIA GeForce3 Ti 200
CPU Optimization D3D Pure Hardware T&L
Width 1024
Height 768
Depth 32 bit
Z-Buffering 24 bit
Texture Format Compressed
Buffering Double
Refresh Rate Default
FSAA Mode None
OPTIONS
Show Title Screens Yes
Continuous Benchmark No
Benchmark Run Count 1
Demo Sounds Enabled Yes
Continuous Demo No
Game Sound Effects Enabled Yes
Game Music Enabled Yes
Game Detail Level Low
RESULTS
3DMark Score 5763
Game 1 - Car Chase - Low Detail 87.2 fps
Game 1 - Car Chase - High Detail 29.9 fps
Game 2 - Dragothic - Low Detail 89.9 fps
Game 2 - Dragothic - High Detail 50.5 fps
Game 3 - Lobby - Low Detail 86.8 fps
Game 3 - Lobby - High Detail 38.7 fps
Game 4 - Nature 37.1 fps
Fill Rate (Single-Texturing) 718.0 MTexels/s
Fill Rate (Multi-Texturing) 1531.3 MTexels/s
High Polygon Count (1 Light) 20.3 MTriangles/s
High Polygon Count (8 Lights) 5.6 MTriangles/s
Environment Bump Mapping 101.8 fps
DOT3 Bump Mapping 122.4 fps
Vertex Shader 47.9 fps
Pixel Shader 87.9 fps
Advanced Pixel Shader 68.3 fps
Point Sprites 16.9 MSprites/s
SYSTEM INFO
System Info Version 2.2
Installation ID 0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer Intel
Family Celeron
Internal Clock 1.42 GHz
Internal Clock Maximum 1.42 GHz
External Clock 100 MHz
Socket Designation Socket 370
Type <unknown>
Upgrade ZIF Socket
Capabilities MMX, CMov, RDTSC, SSE
Version Intel Celeron(TM)
CPUID 0x000006b1
CACHES
Level 1
Capacity 32 KB
Type Internal
Type Details Synchronous
Error Correction Type <unknown>
Associativity <unknown>
Level 2
Capacity 256 KB
Type External
DIRECTX INFO
DirectX Version 8.1
DIRECTDRAW INFO
DirectDraw Version 5.1.2600.29
DISPLAY DEVICES
Description Elsődleges képernyőillesztő
Manufacturer NVIDIA
Name NVIDIA GeForce3 Ti 200
Total Local Video Memory 64 MB
Total Local Texture Memory 64 MB
Total AGP Memory 62 MB
Display Driver nv4_disp.dll
Display Driver Version 6.13.10.4072
Driver WHQL Certified No
Max Texture Width 4096
Max Texture Height 4096
Max User Clipping Planes 0
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Textures In Single Pass 4
Vertex Shader Version 1.1
Pixel Shader Version 1.1
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
Vendor ID 0x10de
Device ID 0x0201
Sub-System ID 0x610d147b
Revision 0xa3 -
Norbyte
Abit ST6+1.4 TuaCel
512 PC133 Xerox
Abit GF3Ti200
Minden alapon, 23.11-essel 3DMark2k1 SE 330: 5486.
- LÉZEREZÉS! külföldi billentyűzet magyarra kb. 20-30p alatt!
- BESZÁMÍTÁS! HP Elitedesk 800 G4 SFF számítógép - i5 8500 16GB DDR4 256GB SSD Intel UHD 630 250W W11
- Samsung Galaxy A52s 5G / 6/128GB / Kártyafüggetlen / 12Hó Garancia
- Apple iPhone 12 Pro / 128GB / Kártyafüggetlen / 12Hó Garancia
- MacBook Pro 14" 2023 M3 Pro 12/18 mag, 36 GB RAM, 512GB SSD - 27% ÁFA 0372AB
