e-biza
Hogy rövidre zárjuk a ''melyik a jobb témát''
Bővebben: link
''This Program was used on that Film''
This is a very commonly-said thing on the internet and around CG school campuses, but it really is one of the worst things that anyone can use as a basis of deciding which software they should begin learning on.
The people who insist of using this bit of ''logic'' often tend to forget:
that it takes a massive team of highly skilled and experienced artists to take the software and create anything seen in a blockbuster film like Lord of the Rings or The Matrix ;
that the software used in films has (more often than not) been altered with many proprietary codes;
and lastly, that many different software companies boast that their software was used on the same films (and often is - many large VFX houses use a number of packages to get their work done).
So basically this line of thinking is not really worth wasting time on if you were thinking of taking it into account when deciding what package to settle on. Just because someone on the web tells you that you should learn Maya because it was used on blah blah blah film, doesn't mean that you'll be able to take the program and make exactly the same kind of stuff'' -
e-biza
Bővebben: link
Bővebben: link
Bővebben: link
Videokártya tesztek
[Szerkesztve]
- Viber: ingyen telefonálás a mobilodon
- Milyen monitort vegyek?
- Elektromos autók - motorok
- Parfüm topik
- mefistofeles: Az elhízás nem akaratgyengeség 3. Végszó.
- Gyúrósok ide!
- OnePlus Nord CE5 128GB, Kártyafüggetlen, 1 Év Garanciával
- Dell Precision 5530 15,6" FHD, i7 8850H, 16GB RAM, Quadro 4GB VGA, 512GB SSD, jó akku, számla, gar
- Lenovo ThinkPad T14S Gen1 Ryzen5 4650U Refurbished - Garancia
- Eladó Dell Latitude 7440 Új állapotban i7-1365U 32 GB DDR5 RAM 1TB SSD Dell pro support garancia
- HIBÁTLAN iPhone 15 128GB Pink-1 ÉV GARANCIA - Kártyafüggetlen, MS4635
