Fórumtársak szimulátor komponenseinek/hardvereinek/játék preferenciájának táblázata és annak 2023-as konklúziója majd 2024-as konklúziója GalaHU tollából, illetve itt található a fórumtársak cockpitjeinek galériája.
Itt egy nagyon hasznos setup guide, mindenre kiterjedően, angol nyelven.
thedriver
sztamas65
#17038
DFGT dupla váltás problémára az alábbi megoldás is működik: (A lényeg, hogy be lehet állítani a profiler-ben, hogy minimálisan mennyi idő teljen el két váltás között)
The following example/guide is for the Logitech DFP "stick shifter forward" (for downshifts) but notice that this can also be done for the "stick shifter backward" (for upshifts) and/or for each of the two paddles, if you wish. You just have to reassign a different key for the command, for each of these.
So, here we go:
1 - Open Logitech profiler
2 - Create a game profile (click "Profile", then "new", browse to the specific game executable, and give a name to this new profile).
3 - You'll now see a picture of the wheel with all buttons, paddles and stick-shifter.
This "fix" works for any of its buttons, paddles, stick-shifter, even pedals.
Just to illustrate this for an example in the DFP, we'll use the "stick shifter forward" (generally used for downshift).3.1 - Now mouse over and LMB click the "stick shifter forward", a little menu pops up.
Now select the option "Select Command", then "New Command".3.2 - A new window pops up... you'll now have to assign a key and a name for the new command.
We'll use the key "M" just for this example. So, for the name, you can put "M" (without the quote marks), same as the key you'll be selecting. Though you may put whatever name you wish ("downshift", etc, etc).3.3 - Now click in "options" and put a check on the "record pauses", and click "OK" (this is so you can see how long it takes, in seconds, to press and release the key/button).
3.4 - Now, click "Record", and press then release the desired key in your keyboard (for this example it's "M").
You'll want your "press and release" exercise to be between 0.2 and 0.4 seconds (no more, no less).
After this is done, click "OK".3.5 - All you have to do now is to re-run the game for which you've set the new Logitech profile, and reassign the downshift command again (in that specific game options).
You'll see that, in game, while reassigning your stick-shifter-forward for the downshift, that it is now recognized as "M".
The end result... no more double-downshifts issues, just smooth and precise downshifts! -
thedriver
Brain75 kollégától kérdezném elsősorban, hogy mit lehet kezdeni egy DFGT fékpedáljával, ha lenyomás után nem áll vissza teljesen, hanem befog egy kicsit?
thedriver
Új Thrustmaster kormány hamarosan:
thedriver
neko18
#14861
Én ezért vágtam bele az Iracing-be, és nem bántam meg. Untam a sok barkács/félkész szimulátort, meg az állandó várakozást.
Nem olcsó, (legalábbis amíg a tartalmakat nem veszi meg az ember), de pillanatnyilag ez messze a legjobb szerintem.
Időjárás már van (hőmérséklet, páratartalom, szél, stb.), eső még nincs, de gondolom ez is lesz hamarosan. -
thedriver
thedriver
Rolesz92
#12924
Ha a beállításoknál az animációban, ill. a bal alsó sarokban lévő kis kormány is 900 fokot fordul, akkor jól van beállítva. A problémád az lehet, hogy nincs megcsináva 900 fokra a kéz animáció a játékban még mindig (vannak ennél fontosabb dolgok is egy HC simben
). Kapcsold ki a kéz animácót, hogy csak a kormányt mutassa, rögtön látni fogod, hogy a játékban is pont ugyanannyit forog a kormány, mint a Fanatec-ed.
thedriver
thedriver
--Lorant--
#12596
Ha nem zavar, hogy ez csak 270 fokot tud, akkor nem rosszabb, mint a DFGT, bár a pedálja ennek törik állítólag.
Arcade játékokhoz jó, szimulátorozáshoz szerintem kevés. -
thedriver
fagy53
#11527
A DFGT pedáljának a felbontása megegyezik a G25/G27 pedáljának a felbontásával, ahogy a kormányé is:
Típus: kormány; pedál
DFP: 14 bit (16.384); 8 bit (255)
DFGT: 14 bit (16.384); 8 bit (255)
G25: 14 bit (16.384); 8 bit (255)
G27: 14 bit (16.384); 8 bit (255)
GT3 RS: 14 bit (16.384); 10 bit (1024)
T500RS: 16 bit (65.536); 10 bit (1024) -
thedriver
Mennyire bonyolult dolog egy DFGT-ben a váltófül alatti mikrókapcsoló cseréje?
thedriver
Great_Muta
#9745
DFGT az egyik legstrapabíróbb darab a piacon, nagyon ritkán hallani meghibásodott példányról, pedig elég sokan nyúzzák kis hazánkban is.
thedriver
Kephamos
#9701
Szerintem páran biztos.
Ha minden igaz, még mindig tart a Cadillac akció, ami annyit jelent, hogy ingyen kapsz fél év Iracing előfizetést + 3 pályát az alapcsomagon túl. Ennél jobb ajánlat nem nagyon van egy kezdőnek. Bankkártya, vagy paypal azért kell hozzá a regisztrációnál. Ha jól tudom, legalább 1 dollárnak kell rajta lenni, de ezt visszaadja. -
thedriver
seawolf570
#9427
"Sajnos a jó grafika és a jó szimulátor páros egyenlőre nem létezik."
Szerintem meg igen, az Iracing pont ilyen. Szerintem a fizikája messze a legjobb, és grafikailag is ott van a szeren. Arról nem is beszélve, hogy lézerszkenneltek a pályák. Egyetlen hátránya, hogy kicsit drága. Érdemes figyelni az akciókat, gondolom lesz most karácsony előtt is valami kedvezmény...
thedriver
krisztian000
#9379
Genius-t én messzire kerülném... Az említett típust meg különösen.
thedriver
seawolf570
#8245
Van saját tapasztalatod is a Fanatec-kel, vagy csak ajánlod?
Sok jót sajnos nem hallottam még róluk, a megbízhatóságuk nem túl magas szintű... -
thedriver
ricshard444
#6339
Egy tesztben azt mondták, hogy a G27 gyerekjátéknak tűnik a T500 rs-hez képest.
Szóval óriási lehet a különbség. -
thedriver
Szerintem nincsenek. Jót legalábbis még nem hallottam senkitől a kormányaikról, rosszat annál inkább.
thedriver
Ha valakit érdekel az új Thrustmaster zászlóshajó...
thedriver
Ujjheggyel lehet elérni?
Nem tudom, szerintem egy átlagos kézmérettel rendelkező ember simán eléri, és egyáltalán nem mondanám nehéznek a lenyomásukat. Teljesen kényelmes szerintem.Egyébként ha minden igaz, az alábbi linken 28500-ért van DFGT, érdemes rákérdezni telefonon:
thedriver
werszomjas
#5403
Szerintem senki nem válna meg tőle szívesen egyelőre.
Én sem. -
thedriver
Arról esetleg hallott valaki valamit, hogy múlt héten leállították a DFGT gyártását, ezért ment fel az ára hirtelen 20k környékéről 30K fölé? Én csak egy hozzászólásban olvastam ezt egy másik fórumon, szóval nem tudom, hogy mennyi a valóságalapja...
- OLED TV topic
- Veszprém és környéke adok-veszek-beszélgetek
- Projektor topic
- Mesébe illő csodakábelt tervezett a GeForce-ok leégése ellen a Segotep?
- Filmvilág
- Több száz játékban kezdi meg karrierjét az FSR Redstone
- Melyik tápegységet vegyem?
- Videó stream letöltése
- Battlefield 6
- ÁRGARANCIA!Épített KomPhone i5 12400F 16/32/64GB RAM RX 9060 XT 8GB GAMER PC termékbeszámítással
- iKing - Apple iPhone 15 Pro Natural Titanium ProMotion 120 Hz, A17 Pro, USB-C 128 GB
- BESZÁMÍTÁS! MSI B450M R7 5700X 32GB DDR4 500GB SSD RTX 4060 Ti 8GB Zalman Z1 PLUS Cooler Master 700W
- LG 25GR75FG - E-Sport Monitor - FHD 360Hz 1ms - NVIDIA Reflex + G-sync - AMD FreeSync - HDR 400
- 0% THM 4 havi részlet beszámítás! RX 9060 XT / 9070 / 9070 XT videokártyák készletről KAMATMENTESEN
tome0001
