OpenWrt topic
szponzor
Nem találok megoldást a transmission által befejezett torrent-eknél a script indításra.
Barrier Breaker a rendszer, 2.84-es a Transmission.
Ez a /etc/config/transmission:
config transmission
option enabled 1
option config_dir '/home/Download'
option user 'root'
option alt_speed_down 50
option alt_speed_enabled false
option alt_speed_time_begin 540
option alt_speed_time_day 127
option alt_speed_time_enabled false
option alt_speed_time_end 1020
option alt_speed_up 50
option bind_address_ipv4 '0.0.0.0'
option bind_address_ipv6 '::'
option blocklist_enabled false
option blocklist_url ''
option cache_size_mb 2
option dht_enabled 'false'
option download_dir '/home/Download'
option download_queue_enabled true
option download_queue_size 5
option encryption 1
option idle_seeding_limit 30
option idle_seeding_limit_enabled false
option incomplete_dir '/tmp/transmission/incomplete'
option incomplete_dir_enabled false
option lazy_bitfield_enabled true
option lpd_enabled false
option message_level 1
option peer_congestion_algorithm ''
option peer_limit_global 240
option peer_limit_per_torrent 60
option peer_port 51413
option peer_port_random_high 65535
option peer_port_random_low 49152
option peer_port_random_on_start false
option peer_socket_tos 'default'
option pex_enabled true
option port_forwarding_enabled true
option preallocation 1
option prefetch_enabled true
option queue_stalled_enabled true
option queue_stalled_minutes 30
option ratio_limit 2.0000
option ratio_limit_enabled true
option rename_partial_files true
option rpc_authentication_required true
option rpc_bind_address '0.0.0.0'
option rpc_enabled true
option rpc_password 'password'
option rpc_port 9091
option rpc_url '/transmission/'
option rpc_username 'usernamei'
option rpc_whitelist '127.0.0.1,192.168.1.*'
option rpc_whitelist_enabled false
option scrape_paused_torrents_enabled true
option script_torrent_done_enabled true
option script_torrent_done_filename '/home/user/complete.sh'
option seed_queue_enabled false
option seed_queue_size 10
option speed_limit_down 100
option speed_limit_down_enabled false
option speed_limit_up 20
option speed_limit_up_enabled false
option start_added_torrents true
option trash_original_torrent_files false
option umask 18
option upload_slots_per_torrent 14
option utp_enabled true
option scrape_paused_torrents true
option watch_dir_enabled false
option watch_dir ''Ez indítaná elvileg a /home/user/complete.sh -t, aminek ez a tartalma:
#!/bin/bashTR_USERNAME="username"
TR_PASSWORD="password"
logger -t complete "Torrent_dir: $TR_TORRENT_DIR, Torrent name: $TR_TORRENT_NAME"
echo "Downloaded torrent: $TR_TORRENT_NAME" | sendmail myemailaddress@gmail.comA complete.sh-ra 777 jogot adtam a tesztelés miatt. Ha kézzel futtatom, akkor kiküldi nekem az e-mail-t, de automatikusan újraindítás után sem küld, ha letöltött egy torrent-et.
Valamit rosszul konfigoltam? Van valakinek ötlete?
szponzor
szponzor
szponzor
Van OpenWRT-re denyhosts vagy fail2ban? Nem találom egyik csomagot sem, pedig nem jönne rosszul a dropbear-hez.
szponzor
Gondolom egy Linux-os PC-ről van szó, és a PC-n lévő root felhasználó jelszavát kéri.
Én még nem láttam ilyen parancsküldést, én először be szoktam jelentkezni és utána a shutdown -h now -t használom. PC-n az sshd.conf-ban még lehet állítani, hogy root-ként be tudsz-e jelentkezni vagy sem.Amúgy ajánlom Android-ra a JuiceSSH-t, elég jó kis program, főleg a saját billentyűztével.
szponzor
Van egy 1043ND-m, de amikor elkezdtem próbálgatni az OpenWrt lehetőségeit, akkor elég sok csomagot felraktam és csak pár napja vettem észre, hogy abszolút megtelt a tárhely. Most Backfire van rajta, de szeretnék rá egy alap AA-t. Ennek a menete az, hogy failsafe módban indítom a routert és utána LuCin keresztül upgrade-elem? Upgrade-hez a sysupgrade.bin végű fájl kell, ugye?
szponzor
vargalex
#1697
Köszi a segítséget! Még annyi kérdésem lenne, hogy az általad készített AA-t használom egy WDR3600-ason...itt nem találom a cron fájlját, csak egy üres crontabs mappát. Ha ide írok egy cron fájlt, akkor a cron daemon automatikusan itt keresi a beállítófájlt?
Van olyan beállítás a transmission-ben, hogy x ratio-nál állítsa le a torrent-et. Megoldható, hogy ne csak leállítsa, hanem törölje is a listából? -
szponzor
Lehet írni olyan script-et, esetleg van olyan beállítás a Transmission-ben, ami pl. éjfélkor elindítja az összes torrentet? A scheduled time nem jó, olyan kellene, hogy ha pause-olom a torrentet, de elfelejtem visszaindítani, akkor éjfélkor automatán indítsa (ha script, akkor gondolom cron-nal lehetne futtatni).
szponzor
A VNC-vel nekem is gondom van. Helyi hálón belül működik, de távolról nem érem el. 5900-as porton bejövő kapcsolatot szeretném a helyi háló 192.168.1.100-as cím 5900-as portjára küldeni.
Ez van az /etc/config/firewall-ban:
config 'rule'
option 'name' 'Allow VNC'
option 'target' 'ACCEPT'
option 'proto' 'tcp'
option 'src' 'wan'
option 'dest_port' '5900'
option 'dest_ip' '192.168.1.100'Amúgy ezeket a szabályokat jó ide írni vagy inkább valami másik iptables által beolvasott fájlba kellene?
szponzor
Mi miatt tud nem működni az etherwake? Egyszer működött, azóta nem.
Az lehet a baj, hogy kihagy egy 0-t a MAC-ből?
/usr/bin/etherwake -D "XX:XX:XX:XX:03:XX"The target station address is XX:XX:XX:XX:3:XX.
szerk.: Semmi, még is megy
szponzor
vargalex
#1379
Köszönöm, így jó is lett, de az src_port nem azt jelenti, hogy én milyen portról indítom? Tehát ha az src_port 8080 a dest_port pedig 80, akkor ez nem azt jelentené, hogy én beütöm a böngészőbe,hogy dinamikus.dns:8080 és ő rácsatlakozik a router-en lévő webszerver 80-as portjára?
szponzor
Valami miatt nem érem el távolról a router webes felületét dinamikus DNS-en keresztül. SSH-n tudok csatlakozni, de a webes UI-ra nem. Ez is van az /etc/config/firewall fájlban:
config 'rule'
option 'name' 'Allow Remote Web'
option 'src' 'wan'
option 'src_port' '80'
option 'dest_port' '80'Mi lehet a gond?
szponzor
Próbáltad már letörölni és újra felrakni, hátha behúz valami függőséget?
Az én problémám viszont, hogy nem érem el távolról a gépet. SSH megy, de a web nem a következő konfiggal:
config 'rule'
option 'src' 'wan'
option 'src_port' '80'Ezt dobja csatlakozáskor a browser: Rejected request from RFC1918 IP to public server address.
szponzor
szponzor
SSH-n így tudsz full jogot adni neki: chmod -R 777 /mappa/elérési/útja/ .
Majdnem biztos, hogy ez lesz a gond.szerk.: biztos, hogy fel van csatolva a fájlrendszer /overlay-be, ugye? df -h paranccsal tudod ellenőrizni. Nehogy az legyen, hogy fullon van a tárhely és nem menti el a konfigfájlokat.
szponzor
vargalex
#1242
Köszi, meg is csináltam, de...Míg otthon teljesen jól működött minden, elhoztam a végleges helyére, ahol először nem csatolta fel a HDD-t, de ezt betudtam kontakthibának, elég laza csatlakozása van a HDD-nek. Viszont ami nagy baj, hogy nem tud WAN-ra kapcsolódni. Az előző router sima dinamikus IP-vel csatlakozott WAN-ra, itt a DHCP-t választva nem csatlakozik. Széttúrtam a konfig fájlját és gondoltam jó lenne 0-ról kezdeni, felraktam az általad készített verziót is (konfigfájlokat felülírva) és ugyanúgy nem tud kapcsolódni. Volt már modem újraindítás többször, network és az egész router újraindítása is többször megvolt, de ugyanúgy nem képes hálózatra csatlakozni, míg otthon ment. Mindkettő T-Home-os kábelnet, bár a modem nem egyforma. A Luci-nál a WAN uptime-ja 00:00:00, hiába reconnect-elek.
szponzor
Ha külső HDD-re szeretném átrakni a telepített programokat, akkor melyik mappát kell a külső vinyóról becsatolni? Megtudom növelni a / méretét is?
szponzor
TP-Link WDR-3600-hoz az openwrt.org-on egy tavaly júliusi trunk build van. Van ennél frissebb build, akár vargalex féle?
szponzor
Ha van két OpenWRT-s routerem, akkor hogy lehet megoldani azt, hogy az egyikkel kibővítsem a másik hatósugarát, kvázi repeaterként használni azt? Kábellel tudom, hogy meg lehet, de megoldható ez wireless módon is? (mindkét routeren Backfire megy)
szponzor
vargalex
#1078
Még mindig vacilálok én is a router-ek között. A WDR3600-tól csak az tántorít el, hogy OpenWRT-ből csak trunk verzió van rá. Mennyire stabil ez napi használatra?
Ami még képben van az a 1043ND, amire van is Backfire, de árban 3E Ft a különbség és processzorban és memóriában is visszalépés a 3600-hoz képest. Ha a 1043ND specifikációval meg tudnék barátkozni, akkor pedig inkább 842ND-t vennék, ami hardveresen nagyon hasonló, de közel 5E Ft-tal olcsóbb (ott, ahol én tudom beszerezni). Viszont a 842ND-re is csak trunk van
Ezek közül szerinted melyik a megfelelő választás? (a cél, hogy torrentezzen külső HDD-re és miniDLNA-val ossza SmartTV-nek) -
szponzor
Peter789
#1003
Nekem egy TL-1043ND-m van és most szeretnék barátnőmnek venni egy router-t, hogy az MiniDLNA-val külső HDD-ről ossza a filmeket. Ezek szerint van már a 1043ND tudásának megfelelő router 6-7E Ft-ért? Az MR3420 akkor jobb választásnak tűnik, bár 3G megosztás sem kell nekem. Ez tud kezelni HDD-t az USB portján, ugye (természetesen megfelelő áramellátás mellett)?
szponzor
Brown ügynök
#182
Webszervernek lighttpd, adatbázisszervernek SQLite. Ha nagyobb méretű az oldal, akkor csatolj fel egy pendrive-ot.
szponzor
vargalex
#142
Közben megoldódott a probléma. Valószínűleg a Windows-os AppServ csomagjában volt úgy beállítva az Apache, hogy nem lehetett elérni kívülről, de most már Linux-on futtatok egy Apache-ot, azzal megy minden tökéletesen, továbbá a WakeOnLAN-t is most állítottam be.
Köszönöm a segítséget!
szponzor
vargalex
#135
config 'defaults'
option 'syn_flood' '1'
option 'input' 'ACCEPT'
option 'output' 'ACCEPT'
option 'forward' 'REJECT'
option 'drop_invalid' '1'
config 'zone'
option 'name' 'lan'
option 'network' 'lan'
config 'zone'
option 'name' 'wan'
option 'network' 'wan'
option 'input' 'DROP'
option 'masq' '1'
option 'mtu_fix' '1'
config 'forwarding'
option 'src' 'lan'
option 'dest' 'wan'
config 'rule'
option 'src' 'wan'
option 'proto' 'udp'
option 'dest_port' '68'
option 'family' 'ipv4'
config 'rule'
option 'src' 'wan'
option 'proto' 'icmp'
option 'icmp_type' 'echo-request'
config 'rule'
option 'src' 'wan'
option 'src_ip' 'fe80::/10'
option 'src_port' '547'
option 'dest_ip' 'fe80::/10'
option 'dest_port' '546'
option 'family' 'ipv6'
config 'rule'
option 'src' 'wan'
list 'icmp_type' 'echo-request'
list 'icmp_type' 'destination-unreachable'
list 'icmp_type' 'packet-too-big'
list 'icmp_type' 'time-exceeded'
list 'icmp_type' 'bad-header'
list 'icmp_type' 'unknown-header-type'
list 'icmp_type' 'router-solicitation'
list 'icmp_type' 'neighbour-solicitation'
option 'limit' '1000/sec'
config 'rule'
option 'src' 'wan'
option 'dest' '*'
config 'include'
option 'path' '/etc/firewall.user'
config 'rule' 'transmission_web'
option '_name' 'transmission_web'
option 'src' 'wan'
option 'dest_port' '9091'
config 'redirect'
option '_name' 'ssh_WAN'
option 'src' 'wan'
option 'src_dport' '2222'
option 'dest_ip' '192.168.1.1'
option 'dest_port' '22'
option 'target' 'DNAT'
option 'dest' 'lan'
config 'rule'
option 'src' 'wan'
config 'redirect'
option '_name' 'ftp_WAN'
option 'src' 'wan'
option 'src_dport' '2221'
option 'dest_port' '21'
option 'dest' 'lan'
config 'rule'
option 'src' 'wan'
config 'rule'
option '_name' 'Transmission'
option 'src' 'wan'
option 'proto' 'tcpudp'
option 'dest_port' '21234'
config 'rule'
option '_name' 'Luci_HTTPS'
option 'src' 'wan'
option 'dest_port' '443'
config 'redirect'
option '_name' 'bsw'
option 'src' 'wan'
option 'dest' 'lan'
option 'src_dport' '8080'
option 'dest_port' '80' -
szponzor
vargalex
#131
Köszönöm a segítséget, de valami még mindig jó. Amit írtál, azt beállítottam, 8080-as porton jön be, 80-ason megy a belső átirányítás, mert ott figyel az Apache.
Ennek ellenére ha beírom a böngészőbe, hogy http://[USERNAME].no-ip.org:8080/ , akkor kiírja a böngésző, hogy nem tudott csatlakozni.
Ha így írom a címsorba: http://[USERNAME].no-ip.org/[www-ben lévő mappa]/index.php:8080, akkor meg kiírja, hogy "No such file or directory". -
szponzor
Nekem egy olyan kérdésem lenne, hogy hogyan tudom jól beállítani a dinamikus dns-es szolgáltatást, hogy egy adott fájlt érjen el.
Regisztráltam a no-ip.com-ra, beállítottam a LuCi-ban a DynDNS-es részt. Amikor beírom a no-ip-s címet a böngészőbe, akkor be is dobja a LuCi-t. Ami nekem kellene az viszont az, hogy távolról el tudjak érni egy saját gépemen lévő weboldalt. A Windows 7-es oprendszeren egy AppServ csomagon belül fut az Apache és a MySQL szerver, és távolról szeretnék egy weboldalt elérni. Ez megoldható valahogy? (Plusz más portra, pl. 8080-ra átrakni ezt a kapcsolatot?)
szponzor
Intruder2k5
#52
Értem, köszönöm a segítséged!
szponzor
Még annyi kérdésem lenne, hogy a HT mode mit befolyásol? Inkább legyen ez kisebb (20MHz) és a Transmit Power nagyobb(24dBm) vagy inkább legyen 40+ -os a HT és kisebb (21-22) a Transmit Power?
szponzor
Intruder2k5
#49
Vadi új konfiggal, de most kicsit utánaolvasva megtaláltam én is, hogy kizárja a két érték egymást. Átállítottam 20 MHz-re, most van már hálózat, csak éppen 0%-os. Kicsit még szórakozok vele, hátha jó lesz. Köszönöm a segítséged!
szponzor
Intruder2k5
#46
Most valami gond van a Wi-Fi-vel: Wireless is disabled or not associated...Ha rányomom az Enable-re, akkor kicsit dolgozik, újraindítja a wireless-t, de semmi. 2-3 reboot sem oldja meg.
szerk.: esélyes, hogy újra kell húzni a firmware-t? Szabad csatornákat telefonnal kerestem, az US 10-es megfelelőnek tűnne.
szponzor
Intruder2k5
#42
OK, köszönöm, feltettem, kicsit javult is a helyzet.
Ez alapján a mostani config fájl:
config 'wifi-device' 'radio0'
option 'type' 'mac80211'
option 'channel' '5'
option 'macaddr' 'b0:48:7a:96:ee:ac'
option 'hwmode' '11ng'
list 'ht_capab' 'SHORT-GI-40'
list 'ht_capab' 'DSSS_CCK-40'
option 'txpower' '23'
option 'htmode' 'HT40+'
option 'country' 'HU'config 'wifi-iface'
option 'device' 'radio0'
option 'mode' 'ap'
option 'ssid' 'OpenWrt'
option 'encryption' 'psk-mixed'
option 'key' '****'Lehet még javítani valahogy a távolságot? Csatornát nem kell átállítani auto-ra? Tx-power mit befolyásol?
Router ezt a státuszt írja:
Mode: Master | SSID: OpenWrt
BSSID: B0:48:7A:96:EE:AC | Encryption: mixed WPA/WPA2 PSK (TKIP, CCMP)
Channel: 5 (2.432 GHz) | Tx-Power: 20 dBm
Signal: -55 dBm | Noise: -95 dBm
Bit Rate: 13.0 MBit/s | Country: HURánézésre minden rendben van szerinted/szerintetek?
szponzor
Volt egy TP-Link 642G router-em, aminek a gyári 3dbi-s antennáját egy 8dbi-s TP-Link antennára cseréltem. Ez egy G-s router volt, de mivel egyre több Wi-Fi képes eszközünk lett, ezért gondoltam ideje, hogy lecseréljük egy N-es router-re a régit, bízva a nagyobb sebességben és hatótávolságban. A választás a TP-Link 1043ND-re esett, amire rögtön került is fel az Open-WRT. Annyi bajom van vele, hogy a régi router-rel egy adott helyen még tudtam fogni a Wi-Fi-t, ezzel a router-rel már nem (ugyanazzal a telefonnal). Megnéznétek a Wi-Fi beállításaimat, hogy esetleg rosszul van-e beállítva? Létezhet, hogy egy N-es router-rel nincs akkora hatótáv, mint egy G-ssel?
/etc/config/wireless:config 'wifi-device' 'radio0'
option 'htmode' 'HT40+'config 'wifi-iface'
option 'mode' 'ap'
option 'key' '*********'
- Gaming notebook topik
- Xbox Series X|S
- Szolnok és környéke adok-veszek-beszélgetek
- GYÖNYÖRŰ iPhone 13 128GB Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS4681
- Lenovo L14 Ryzen 5 4500U Refurbished - Garancia!
- Telefon felvásárlás!! Apple iPhone SE (2016), Apple iPhone SE2 (2020), Apple iPhone SE3 (2022)
- HIBÁTLAN iPhone 13 128GB Blue-1 ÉV GARANCIA - Kártyafüggetlen, MS4453, 100% Akksi
- Lenovo IdeaPad Slim 3 Ryzen 7 8840HS 15" FHD+ 16GB 1000GB Teljeskörű garancia
