OpenWrt topic
SirAlo
Hello, ha az openwrt privat ipt oszt ki, nem tudom kivulrol elerni a rotert (szerintem nem a szolgaltato csinalja) hogyan tudnam átállitni a routerbe hogy publikus ipt osszon ?
SirAlo
Hat most elvileg a szerver megvan, ha connectelni akarok PC-rol ezt adja ki (nem vagyok biztos abba se hogy a szervert jol allitottam-e be
Valami jo magyar leiras nincs hozza? (egy van de az is regi)Sun Aug 14 17:21:30 2016 OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on May 10 2016
Sun Aug 14 17:21:30 2016 Windows version 6.2 (Windows 8 or greater) 64bit
Sun Aug 14 17:21:30 2016 library versions: OpenSSL 1.0.1t 3 May 2016, LZO 2.09
Enter Management Password:
Sun Aug 14 17:21:30 2016 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Sun Aug 14 17:21:30 2016 Need hold release from management interface, waiting...
Sun Aug 14 17:21:30 2016 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Sun Aug 14 17:21:30 2016 MANAGEMENT: CMD 'state on'
Sun Aug 14 17:21:30 2016 MANAGEMENT: CMD 'log all on'
Sun Aug 14 17:21:30 2016 MANAGEMENT: CMD 'hold off'
Sun Aug 14 17:21:30 2016 MANAGEMENT: CMD 'hold release'
Sun Aug 14 17:21:30 2016 Socket Buffers: R=[65536->65536] S=[65536->65536]
Sun Aug 14 17:21:30 2016 MANAGEMENT: >STATE:1471184490,RESOLVE,,,
Sun Aug 14 17:21:31 2016 UDPv4 link local (bound): [undef]
Sun Aug 14 17:21:31 2016 UDPv4 link remote: [AF_INET]79.113.44.***:1194
Sun Aug 14 17:21:31 2016 MANAGEMENT: >STATE:1471184491,WAIT,,, -
SirAlo
Vagy mar nincs is openvpn csomag ? Elotte toltam opkg updatet
root@OpenWrt:~# opkg install openvpn
Unknown package 'openvpn'.
Collected errors:
* opkg_install_cmd: Cannot install package openvpn. -
SirAlo
Hello megint en vagok
most vpn szervert szeretnek futtatni a routerrol, viszont elakadtam egy resznel : Ezt a leirast probalom kovetni5.Copy the important files to the /etc/openvpn directory, so that they are duplicated:
cd /etc/easy-rsa/keys
cp dh1024.pem server.crt server.key /etc/openvpn/szoval nalam nincs /etc/openvpn mappa , es igy ezt kapom (en rontottam el valamit vagy elotte letre kell hozni siman egy ilyen mappat? )
cp: can't create '/etc/openvpn/dh2048.pem': No such file or directory
cp: can't create '/etc/openvpn/server.crt': No such file or directory
cp: can't create '/etc/openvpn/server.key': No such file or directory -
SirAlo
ujra formáztam a pendrivot, most sda1 , vegigmentem most Exen a leirason , most a block Mountba felcsatolta az sda1-et viszont az overlay csak nem lett a pendrive merete vagyis valami csak nem jo
A leirasba amúgy volt egy block-extroot csomag is amit nekem nem talalt az opkg
Valaki nem tudna esetleg team viewerrel segitni ? Sehogy se jon ossze...
SirAlo
Win alol partition wizard professional-al formáztam ext4-re es swap-ra
Amúgy ha meglessz ez az exroot akkor csak akkor fog mukodni a router ha hozza van csatlakoztatva a pendrive ? Es olyankor mi van ha mondjuk a pendrive behal ? Akkor tud meg futni a rendszer a belso tarolorol ? -
SirAlo
vargalex
#9279
Most talaltam ezt: [link] a leirast, vegigvittem, aztán luciba ha ramegyek a Mount Points-ra ez a hiba fogad (Sda5 az egy 3.3 gigas particio, es sda6 egy 500 megas amit swap-nak szantam ) :
/usr/lib/lua/luci/dispatcher.lua:448: Failed to execute cbi dispatcher target for entry '/admin/system/fstab'.
The called action terminated with an exception:
/usr/lib/lua/luci/cbi.lua:334: Unable to read UCI data: fstab
stack traceback:
: in function 'assert'
/usr/lib/lua/luci/dispatcher.lua:448: in function 'dispatch'
/usr/lib/lua/luci/dispatcher.lua:195: in function </usr/lib/lua/luci/dispatcher.lua:194> -
SirAlo
Elvileg most fel van csatolva , Use as root filesystem
Configures this mount as overlay storage for block-extrootezt bepipaltam, igy overlay-nak teszi a mount pointot, viszont ha csomagot akarok telepitni csak azt irja hogy nincs eleg hely:
SirAlo
Ja es kmod-fs-ext3 e2fsprogs helyett libext2fs csomagot telepitettem fajlrendszer kezelésnek, ez igy megfelelo ? libext2fs kevesebb helyet foglal es elvileg kezeli az ext3 es ext2 ot is
SirAlo
Na azthiszem most sikerult felrakni mindent ami kell, itt miket kell beallitni, hogy az usb-re telepitse ezentúl a csomagokat ? (500 mega swapot mar sikerult beallitsak)
use as root filesystem az kellene?Illetve Mount pointhoz irjak / -t ?
SirAlo
Na
opkg install kmod-usb2 kmod-usb-storage kmod-usb-core kmod-scsi-core
opkg install block-mountezek rafertek, viszont opkg install kmod-fs-ext3 e2fsprogs
ez az ext3 nem fert el, letoltotte de telepiteni nem tudta, viszont most nincs semmi hely , letoltott fájlokat hol tudom torolni ? Megprobalnak masik fajlrendszert hatha az nem foglal ennyit
SirAlo
Sikerult felrakni, valoban van webes felulet alapbol, viszont usb tamogatas azthiszem nem fert bele a 3.7 mb-ba, azt valahogy meg lehetne oldani hogy egy pendriveot hasznaljon extra tarhelynek mondjuk ?
Annyi a gond, hogy ez igy elegge paradox
amig nincs usb tamogatas nem tudom gondolom beallitni extra tarhelynek, ahoz meg hogy az usb csomagot telepits kell az extra tarhely
SirAlo
Hello, TP-LINK TL-MR3420 routeren megoldhato egy kulso hard vagy pendrive csatlakoztatasaval a Nas halozat ? Gyari softverrel tudom hogy csak 3G/4G modemmel lehet hasznalni az usb portot rajta, viszont Openwrt-t feloldja ezt, vagy hardveresen nem kepes tarolot fogadni usbn?
- Tőzsde és gazdaság
- Milyen légkondit a lakásba?
- Akciókamerák
- Apple MacBook
- Hobby rádiós topik
- iPhone 15 Pro Max 256GB 100% (1év Garancia)- ÚJ EREDETI AKKUMULÁTOR - AKCIÓ
- Gyümölcstartó hibátlan állapotban eladó
- Akciós kisWorkstation! Dell Precision 3570 i7-1255U 4.7GHz / 32GB / 1000GB / Quadro T550 4GB FHD 15"
- BESZÁMÍTÁS! Apple MacBook Pro 14 M4 Max 48GB RAM 1TB SSD notebook garanciával hibátlan működéssel
- Raktáron levő AM4 garanciás alaplapok!!!
