rog
''Upon boot up, the driver first initializes the ASIC, sets up the screen resolution, and is then able to issue graphics rendering commands and direct the frame buffer access. At this point SMARTGART will test the functionality of each AGP command and determine if your system is capable of supporting each one, and will only enable it if system stability can be maintained. SMARTGART does not disable or turn off AGP support in your actual hardware; SMARTGART only ensures that the ATI CATALYST driver will not use an AGP function that has been deemed to be unstable
In the specific case of fast writes, if any issues are detected when testing a fast write transfer, fast writes will be disabled, as a faulty fast write could cause a system crash. Please note that fast writes must also be supported on the motherboard you are using and be enabled in the system BIOS.''
- Doky586: SecureBoot kulcsok frissítése (2026 nyara)
- Házimozi haladó szinten
- Micro Four Thirds
- EAFC 26
- Sütés, főzés és konyhai praktikák
- GoodSpeed: Daikin FTXF35E / RXF35F Sensira 3,3 kW Inverteres klíma - a Sztori
- Eredeti játékok OFF topik
- Asus Dual RTX 4070 SUPER EVO + FirstShop garancia 2027.04.09-ig
- PNY RTX 5080 16GB GDDR7 Triple Fan OC - Garis 2028.10.01. -ig - Eladó!
- Gigabyte GTX 1050 Ti Windforce OC 4GB / Nem kell hozzá tápcsatlakozó!
- RTX 4060 Ti 16GB GARANCIÁS (Alza) + Kingston Fury RAM keveset használt
- Sapphire Nitro+ RX 5700 XT 8GB Garanciával!
- iPhone 17 256 GB Levander - Bontatlan !! www.stylebolt.hu - Apple eszközök és tartozékok - Számlás
- Dell Precision 5520 15,6" FHD, Xeon E3-1505M v5, 16GB RAM, Quadro 4GB VGA, SSD, jó akku, számla, gar
- ÁRGARANCIA! Épített KomPhone i5 12400F 16/32/64GB RAM RTX 3060 12GB GAMER PC termékbeszámítással
- Apple iPhone 15 256GB,Átlagos,Adatkabel,12 hónap garanciával
- BESZÁMÍTÁS! Gigabyte B760 i5 12600KF 16GB DDR4 512GB SSD RTX 3080 10GB Asus A31 PLUS TG ARGB 750W
