scart
Performance Improvements
As with most CATALYST™ releases performance has increased in various situations. The following performance gains are noticed:
The Pixel Shader performance of our DX9-class products has improved considerably with Catalyst 4.3.
Halo and Tomb Raider framerates are up 3-7%.
Shader-specific technology tests such as ShaderMark show gains in the region of 10-20% or more.
3DMark03's Mother Nature scene runs 2-5% faster across the entire DX9 product line. Our 3DMark03 Pixel Shader 2.0 framerate improves 7-15%.
Aquamark 3 performance has also improved slightly, at higher resolutions.
Far Cry Demo - some textures may be missing
This issue affects the following configurations:
CATALYST 4.3
Radeon Series Product
Far Cry Demo
Upon launching Far Cry, some textures may be missing in-game.
ATI Engineering is aware of the issue and is investigating.
This issue is under investigation. There is no solution available at this time.
Ezen nem csodalkozok leven hogy nv logos game.. :o
[Szerkesztve] -
scart
''Fixed in this driver:
Setting the video resolution to 1280x1024 in the game Medal of Honor: Spearhead, along with Anti-Aliasing set to 2x no longer results in the main menu of the game not displaying properly
Display corruption is no longer noticed when playing the game Aquanox under Windows XP with an ATI RADEON™ 9100 IGP series installed. This issue is was known to occur when specific video options have been customized
Running the game Hegemonia under Windows XP with an ATI RADEON 8500 series installed no longer results in all of the main menu options and the 3D textures in the background not being available
The operating system no longer fails to respond when launching the game TrackMania with a RADEON 7000 series installed
Background colour corruption is no longer seen when playing the game Armed and Dangerous
Poor performance is no longer noticed when playing the game Homeworld 2 with extended desktop enabled or when Anti-Aliasing is set to 4x
Visual corruption is no longer seen when playing the game Spy Hunter
Setting the resolution in the game Enclave to 1024x768 or higher no longer results in display corruption
The Windows operating system no longer intermittently fails to respond when playing the game Jedi Knight 2 with the display set to 1024x768 32bpp and the game option set to High Quality
Windows problems are no longer noticed when playing the game Homeworld 2 in single player mode
Texture corruption is no longer seen when playing the game Battlefield 1942
Connecting an HDTV as the primary display with the display resolution set to 1920x1080 followed by playing a Macrovision protected DVD with the ATI DVD player no longer results in the HDTV not providing a display image when exiting the ATI DVD player
A fullscreen DOS session now appears properly on the Primary display
Playing an MPEG2 file with the MediaPlayer and Overlay Theater Mode enabled no longer results in the display refresh rate not being correct
Enabling large desktop mode no longer results in the overlay not properly switching from one display to another
Creating a scene using 3DStudio MAX no longer results in the OpenGL window not displaying correctly when opening a context menu within the OpenGL window
Dragging the Solidworks 2004 window over to the secondary display adapter no longer results in the primary display adapter displaying a hightlighted image''
Megjelent az uj catalyst lehet tolteni, es kiprobalni, majd tapasztalatokat megosztani :)
[L]http://www.ati.com/support/driver.html[/L]
- Panasonic CF-XZ6 AIO all-in-one laptop tablet 2k touch i5-7300u speciális ütésálló rugged
- Apple iPhone 16 Pro Max 256GB - Kártyafüggetlen, Sivatagszín, 91% Akku - 1 Év Garanciával
- OnePlus Nord 2T 128GB, Kártyafüggetlen, 1 Év Garanciával
- Apple iPhone 12 Pro Max 128GB, Kártyafüggetlen, 1 Év Garanciával
- Eladó Samsung A53 5G 6/128GB / 12 hó jótállás
