qdak
Kis frissítés:
@echo off
chcp 65001 >nul
cls
:menu
echo ------------------------------
echo Network Devices Online
arp -a
echo.
echo Valassz egy IP-cimet, amelyre uzenetet szeretnel kuldeni:
echo 0. Szukseges beallitasok!
echo.
setlocal enabledelayedexpansion
set count=0
for /f "tokens=1" %%A in ('arp -a ^| find "dynamic"') do (
ping -n 1 -w 1000 %%A >nul
if not errorlevel 1 (
set /a count+=1
for /f "tokens=1,* delims= " %%B in ('nbtstat -A %%A ^| find "<00>"') do (
set Name=%%C
set Name=!Name:~0,-1!
set IP_!count!=%%A
set Name_!count!=!Name!
echo !count!. %%A (!Name!)
if %count% equ 0 (
echo Nincs online gep talalva.
pause
goto exit
set /a count+=1
echo %count%. Kilepes
echo.
set /p choice=Kerlek add meg a valasztott szamot (0-%count%):
if %choice% equ 0 goto settings
if %choice% equ %count% goto exit
if %choice% lss 1 goto menu
if %choice% gtr %count% goto menu
set IP=!IP_%choice%!
set Name=!Name_%choice%!
goto sendmsg
:sendmsg
cls
set /p message=Kerlek ird be az uzenetet, amit kuldeni szeretnel:
msg /SERVER:%IP% * %message%
echo.
echo Uzenet elkuldve a kovetkezo IP-cimre: %IP% (!Name!)
echo.
echo 1. Uj uzenet kuldese ugyanarra a gepre
echo 2. Vissza a gepek valasztasahoz
echo 3. Kilepes
echo.
set /p nextchoice=Kerlek add meg a valasztott szamot (1-3):
if "%nextchoice%"=="1" goto sendmsg
if "%nextchoice%"=="2" goto menu
if "%nextchoice%"=="3" goto exit
:settings
cls
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Terminal Server" /v AllowRemoteRPC /t REG_DWORD /d 1 /f >nul
echo AllowRemoteRPC = 1
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Terminal Server" /v fDenyTSConnections /t REG_DWORD /d 0 /f >nul
echo fDenyTSConnections = 0
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System" /v LocalAccountTokenFilterPolicy /t REG_DWORD /d 1 /f >nul
echo LocalAccountTokenFilterPolicy = 1
dism /online /Enable-Feature /FeatureName:"SMB1Protocol" /All
echo SMB1Protocol
netsh advfirewall firewall add rule name="TCP Port 445" dir=in action=allow protocol=TCP localport=445
echo TCP Port 445 = Open
echo Beallitasok befejezve.
pause
goto menu
:exit
exitígy csak a 0 pontot választva állítja be a beállításokat.
[link] msg windows network 1.1.bat
qdak
@echo off
chcp 65001 >nul
cls
echo Registry, SMB1, TCP Port 445, beállítások
::dism /online /Enable-Feature /FeatureName:"SMB1Protocol" /All
::netsh advfirewall firewall add rule name="TCP Port 445" dir=in action=allow protocol=TCP localport=445
:menu
arp -a
echo.
set count=0
set /a count+=1
set Name=%%C
set IP_!count!=%%A
if %count% equ 0 (
pause
goto exit
set /a count+=1
echo.
set /p choice=Kerlek add meg a valasztott szamot (1-%count%):
goto sendmsg
:sendmsg
cls
echo.
echo.
echo 3. Kilepes
echo.
:exit
exitEgy üzenet küldő hálózaton belül
qdak
Egy kis robocopy.bat:
echo :
echo : ROBOCOPY Batch Process Started
echo :
ROBOCOPY.EXE E:\ "\\HEDOSERVER\Server Save (E)" /J /DCOPY:DAT /PURGE /E /MIR /FFT /XC /XO /IT /R:1 /W:1 /X /V /TS /TEE
echo :
echo : ROBOCOPY Batch Process Complete
echo :
pauseEzeket cseréld:
honnan: E:\
hova: \\HEDOSERVER\Server Save (E)Teszteltem, működik a tükrözés, ha forrás nem változik, nem másol feleslegesen,
ha változik a forrás, felülirja az eredeti cél filet.
Ha törölsz a forrás meghajtóról, a cél meghajtóról is törli.
Ütemezni lehet W10 ben. -
qdak
qdak
qdak
Sziasztok, a 11 (MTU) beállítgatást végig próbálnátok
Ötletek jöhetnek. -
qdak
Hiába indítom adminból, nem jó, amit irtatok, le tudjátok írni "kell admin jog a command line-on"
Mit változtassak ?Köszi.
qdak
start "" /high /D "C:\Program Files (x86)\Mozilla Firefox\" "firefox.exe"
Miért nem indul high-on ? -
qdak
Köszi, de sajna nem jó, vagy nem indul el ,vagy ugyanúgy ékezet hibás.
(Win 10 en viszont alapból jó)Viszont, a force admin mód, csak az én gépemen működik (Win 7) míg másik gépeken próbálva, folyamatosan újraindult a cmd ki sem tudom kapcsolni? (azóta ki is szedtem belőle)
qdak
Hello,
Ezt meg lehet úgy csinálni, hogy normálisan legyenek ékezetek, vagy szedjem ki simán "á->a" stb...
@echo off
REM --> Check for permissions
>nul 2>&1 "%SYSTEMROOT%\system32\cacls.exe" "%SYSTEMROOT%\system32\config\system"
REM --> If error flag set, we do not have admin.
if '%errorlevel%' NEQ '0' (
echo Requesting administrative privileges...
goto UACPrompt
) else ( goto gotAdmin )
:UACPrompt
echo Set UAC = CreateObject^("Shell.Application"^) > "%temp%\getadmin.vbs"
echo UAC.ShellExecute "cmd.exe", "/C """"%~f0""""", , "runas", 1 >> "%temp%\getadmin.vbs"
cscript "%temp%\getadmin.vbs"
exit /B
:gotAdmin
if exist "%temp%\getadmin.vbs" ( del "%temp%\getadmin.vbs" )
pushd "%CD%"
CD /D "%~dp0"
color 0e
chcp 1250
cls
:start
echo.
ECHO -------------------------------------------------------------------------------
echo. Run Programs Script by Hedo
echo 0. Programok és szolgáltatások
echo 1. Felügyeleti eszközök
echo 2. Fájlkezelő beállításai
echo 3. Számítógép-kezelés
echo 4. Helyicsoportházirend-szerkesztő
echo 5. Helyi biztonsági házirend
echo 6. Helyi felhasználók és csoportok
echo 7. Szolgáltatások
echo 8. Rendszerkonfiguráció
echo 9. Exit.
echo.
echo.
set /p x=Use Number:
IF '%x%' == '%x%' GOTO Item_%x%
:Item_0
cls
echo.
echo Programok és szolgáltatások
echo.
appwiz.cpl
pause
GOTO Item_99
:Item_1
cls
echo.
echo Felügyeleti eszközök
echo.
control admintools
pause
GOTO Item_99
:Item_2
cls
echo.
echo Fájlkezelő beállításai
echo.
control folders
pause
GOTO Item_99
:Item_3
cls
echo.
echo Számítógép-kezelés
echo.
compmgmt.msc
pause
GOTO Item_99
:Item_4
cls
echo.
echo Helyicsoportházirend-szerkesztő
echo.
gpedit.msc
pause
GOTO Item_99
:Item_5
cls
echo.
echo Helyi biztonsági házirend
echo.
secpol.msc
pause
GOTO Item_99
:Item_6
cls
echo.
echo Helyi felhasználók és csoportok
echo.
lusrmgr.msc
pause
GOTO Item_99
:Item_7
cls
echo.
echo Szolgáltatások
echo.
services.msc
pause
GOTO Item_99
:Item_8
cls
echo.
echo Rendszerkonfiguráció
echo.
msconfig
pause
GOTO Item_99
:Item_9
exit
:Item_99
cls
GOTO Start -
qdak
tud vki 1 oyan progit nekem irni: v segiteni h 32 betu után nyirja le a zeneszám nevét megorit h várok hmásolja a telora a zenét
ez a vacak meg megál mert hosszu file név
help vki
- Google Pixel topik
- Crimson Desert
- Milyen TV-t vegyek?
- Luck Dragon: Óraátállítás
- iPhone 17 Pro Max 256GB 100% (Apple Care+ 2027.November 16)
- ÚJRA! 256GB NVMe SSD, 1 év gar
- Asus 15.6,core i3 8145U(4x3,9Ghz)IntelUHD VGA,MAGYAR Vil.bill.,8-20GB RAM,SSD,,Win.11
- HP 15,6"FullHD ,8.gen. Core i5(8X3,6Ghz)R5 2/4GB VGA,8-32GB DDR4 RAM,SSD+HDD?,jó akku,szép áll.
- Asus Phoenix NVIDIA GeForce RTX 3060 12 GB
- Hp 440 G8 i5-1135G7 16Gb, 256 Gb NVMe, számla, 1 év garancia
- HP ProBook 450 G8 15,6" i5 1135 G7, 8-16GB RAM, SSD, jó akku, számla, 6 hó gar
- Samsung Galaxy S24 5G 128GB, Kártyafüggetlen, 1 Év Garanciával
- AKCIÓ! Apple MacBook Pro 14 M4 Max 48GB RAM 1TB SSD notebook garanciával hibátlan működéssel
- 156 - Lenovo LOQ (15IRH8) - Intel Core i5-13505H, RTX 4060 (ELKELT)
help vki
