mumu
ezeket az adatokat, a netről szedtem, sajnos a hiteleségét nem tudtam ellenőrizni,
és a puding próbája az evés, és akinek nincs 100k egy lapcserére, vagy már nem is érné meg, annak lehet hogy ad egy kis reményt -
mumu
Remove BIOS passwords - IBM ThinkPad
Please also see this homepage for more information regarding removing passwords from IBM ThinkPads.
IBM ThinkPad 240 [2609]
Short the jumper JP1.
IBM ThinkPad 310/310D/310E/310ED [2600]
Use switch SW2 near CPU socket (second bit switch counting from the lowest side).
IBM ThinkPad ??? [2610]
IBM ThinkPad 365C/365CD/365CS/365CSD/365E/365ED [2625]
The following procedure disables user and supervisor passwords:
Power-off the computer.
Disconnect the AC-Adaptor.
Open the keyboard and remove the battery pack.
Remove the Mylar cover. See FRU Removals and Replacements.
Locate the S2 switch block on the system board.
Set Switch 1 to OFF.
Wait 30 seconds.
Set Switch 1 to ON.
Replace the Mylar cover.
Replace the battery.
Connect the AC-Adaptor.
Power-on the computer.
Go to a DOS full screen.
Press Ctrl+Alt+F11 to access the setup screen and reset the passwords.
IBM ThinkPad 355x [2619]
IBM ThinkPad 360x [2620]
IBM ThinkPad 370C/750x/755C/755CS [9545]
How to disable the power-on password:
Open the keyboard and remove the battery pack and the diskette drive.
Remove the attachment holder.
For models 355x and 360x, see '1115 Standby Battery'.
For models 370C, 750x, 755C and 755CS, see '2105 Standby Battery'.
Install a jumper on the power-on password connector -1- at bottom left side of the system board.
Reinstall the diskette drive and battery pack.
Power-on the computer and wait until the POST ends.
Verify that the password prompt does not appear.
After service check is completed, remove the jumper.
IBM ThinkPad 710T [2523]
To disable the power-on password:
Remove backup-battery cover.
Locate the security switch beside the backup battery.
Move the slide switch to the opposite side.
Thinkpad 730TE [2524]
Use the following procedure to disable the power-on password if needed.
Power off the system.
Remove the Pen Compartment Cover and the Sub Battery cover.
Identify the security pin wich is located beside the sub battery.
Power on the system while making a short-circuit between the two security pins with a regular screwdriver's flat tip.
Thinkpad ??? [9546, 9547]
Open the keyboard, and remove the diskette drive or CD-ROM drive and the battery pack.
Install a jumper on the power-on password connector on the left side of the FDD connector.
(See 'Password Connector' for location.)
Reinstall the battery pack and the diskette drive/CD-ROM drive.
After the service check is completed, remove the jumper.
Thinkpad 300 [2615]
To override a password , do the following.
Remove the access panel.
Remove the battery pack.
Remove the top assembly (do not disconnect any cables).
Connect a jumper to the two pads (R39) at the side of the math coprocessor socket.
Reinstall the battery pack.
Power-on the computer. Keep the computer on until the LEDs blink and the system locks.
Remove the jumper.
Press and hold the reset switch, then power-on the computer.
Replace the top assembly and the access panel.
Thinkpad 350, PS/Note 425 [2618]
Remove the cmos battery 5 minutes
Thinkpad 365X, 365XD [2625]
Power off the computer.
Open the keyboard and lift the right-most section of the insulator sheet.
Push out the small door on the right side of the base cover.
Apply a short across the Power-On Password Jumper Pads.
With the jumper tool in place, power on the computer to clear the password.
Remove the jumper and power off the computer.
Power on the computer and verify that the password has been cleared.
Thinkpad 380-385 [2635]
Turn the computer upside down, loosen the DIMM cover screw, remove the DIMM cover.
Then power-on the computer by applying a short across the power-on password jumper pads 315
Thinkpad 380XD, 385XD, 380Z [2635]
Turn the computer upside down, loosen the memory-slot cover screw, and remove the memory-slot cover.
Short across the power-on password jumper pads
Power on the computer and wait until the POST ends.
Reinstall the memory-slot cover, and turn the computer right side up.
ThinkPad i-Series 1400 [2611]
Turn off the computer.
Unplug the AC Adapter and remove the battery.
Remove the keyboard and the thermal plate.
Move the password switch (SW2, switch 2) from OFF to ON to bypass the password.
Note: SW2 has four switches, the second upper switch (switch 2) is the password bypass/check switch.
Turning the switch to the left (ON position) is ''bypass password'', the right (OFF position) is ''check password''.
Plug in the AC adapter and turn on the system.
While the ThinkPad logo is being displayed, wait for a beep before pressing F1 to enter the BIOS Utility.
Select ''System Security'' from the BIOS Utility main menu and press Enter.
Set the ''Power-On Password'' setting to ''None'' to clear the password.
Save and exit the BIOS Utility.
Turn off the system and unplug the AC Adapter.
Move the password switch from ON to OFF to enable the password function.
Reinstall the thermal plate and keyboard.
Reinstall the battery pack and plug in the AC Adapter.
ThinkPad i-Series 1400/1500 [2621]
If only the power-on pasword is set, do the following to remove it:
Remove the battery and the AC Adapter.
Remove the backup battery (RTC) 20 minutes or use the screw driver to touch the backup battery (RTC) 1 sec.
Put back the backup battery (RTC).
Thinkpad 390/i Series 1700 [2626, 2627]
Thinkpad 390E [2626]
Thinkpad 390X / i 1700 [2624, 2627]
Remove the battery pack and AC Adapter.
Remove the backup battery (RTC) for 20 minutes or use a screwdriver to touch the backup battery (RTC) for 1 second.
Power on the computer and wait until POST ends.
ThinkPad 500 [2603]
Disconnect all cables attached to the computer.
Remove the memory card access panel and memory card (if installed).
Locate the two pins labeled PAD1-2 on the system board (in the memory card access area).
Short the two pins together.
Press Ctrl+Alt+F3 to access the System Parameters Setup Menu.
Press Esc.
Press F5 to reset the parameter to their default values.
The System Time, System Date, and Password (if required) parameters need to be set manually.
Press Esc, then F4 to save the values, exit the Setup program, and reboot the computer.
If a memory card was removed, power-off the computer and install the memory card.
Install the memory card access panel.
ThinkPad 510 [2604]
Remove the memory card access panel and DRAM card (if installed).
Locate the two pins labeled PAD1-2 on the system board (see 'System Board Connectors').
Press Esc.
If a DRAM card was removed, power-off the computer and install the DRAM card.
ThinkPad 560, 560E [2640]
Remove the frame
Flip the keyboard over as shown in the figure
Jumper the two password jumper pads (R364 or R39) located on the system board
Power on the computer to clear the password
Replace the keyboard and the frame
When replacing the frame, make sure that the frame fits correctly in place.
If it is not in place, the click buttons of the TrackPoint III cannot be pressed.
Replace the screws
The hard disk password is stored on the hard disk.
ThinkPad 560x [2640-560 - 60x, 70x]
Remove the frame
Position the keyboard over as shown in the figure
Jumper the two password jumper pads (BIT-X) on the system board
If it is not in place, the click buttons of the TrackPoint III will not work.
Replace the screws.
ThinkPad 560Z [2640]
Turn the computer upside down.
Loosen the DIMM socket lid screw -1- , and remove the DIMM socket lid.
Short the power-on password jumper pads (R522).
Power on the computer and wait until the POST ends. The password is cleared.
Reinstall the DIMM socket lid, and turn the computer right side up.
Verify that the password promp does not appear.
To reactivate the password, set the password again.
ThinkPad 570 [2644]
Remove the DIMM cover on the bottom side of the computer.
Short-circuit the two password pads.
Under the short-circuit condition, power on the computer and wait until the POST ends.
After the POST ends, the password prompt does not appear. The power-on password is removed.
Reinstall the DIMM cover.
Thinkpad 765D [9546]
Thinkpad 765L [9547]
Open the keyboard, and remove the battery pack and the diskette or CD-ROM drive.
Instal a jumper on the power-on Password connector on the left side of the FDD connector.
Thinkpad 770 [9548/49]
Remove the DIMM cover.
Short-circuit the two password pads or put the jumper (pads near the top of the cover).
Under the short-circuit condition, power on the computer and wait until POST ends.
If a jumper has been used for short the password pads, then remove the jumper.
- Új, Gamer félgép - ASUS B860M-A WIFI + Intel Ultra 5 245KF + Patriot Viper 2x16GB DDR5 6000MHz CL30
- DDR5 Gamer PC - I5 12400f, RTX 3070, 16gb RAM
- Gamer PC - i5 11400f, RTX 2060 SUPER, 16gb RAM
- karcos Lenovo M920q Mini PC - Core i5 8500T - 16Gb ram - 256GB NVMe - számla + gar
- HP ProDesk 400 G6 mini - Core i3 10100T -16GB ram 256Gb NVMe SSD -gyári WIFI - számla is -1 év gari
- HIBÁTLAN iPhone 13 Pro 128GB Graphite -1 ÉV GARANCIA - Kártyafüggetlen, MS3747, 100% Akkumulátor
- HIBÁTLAN iPhone 13 mini 128GB Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS3139, 100% Akkumulátor
- AKCIÓ! iMac Pro Intel Xeon W2150B 64GB 1TB VEGA 64 16GB!!! 1 év garancia!
- BESZÁMÍTÁS! Sony Playstation 4 Slim 500GB játékkonzol garanciával hibátlan működéssel
