Keresés
  • frame>24
    válasz Zsotie #753 üzenetére
    ''Wireless communication:
    - Supports IrDA 1.0 (SIR) and IrDA 1.1 (FIR)'' - vmi infra port-beállítási lehetőség lehet... de mélyülj bele a keresőbe (!) ;)
    sőt:
    ''The original IrDA standard, called IrDA 1.0, allowed for the transfer of data at up to 115.2kbps (kilobits per second) at a range of up to 1 meter (about 3 feet) plus or minus 15 degrees. In 1996 an extension to this standard was adopted (called IrDA 1.1) which allowed for data transfers up to 35 times faster than the original specification. This extension calls for data rates up to 4Mbps (megabits per second) but retains compatibility with the original (115.2kbps) specification. Achieving the 4Mbps transfer rate not only requires all hardware involved to be IrDA 1.1 complaint, but the software that is running to facilitate the data transfer may need to be modified to support the extension.''
    [Szerkesztve]
