Fórumok
LOGOUT - lépj ki, lépj be!
Frissítve: 2014-04-25 14:12 Téma összefoglaló
chabeee
chabeee
chabeee
chabeee
chabeee
hello agian,
a printback-nél mit rontok el? egyszerüen nem akarja kiírni pedig sztem hiba nincs benne, lessétek meg please:
#include <stdio.h>
#include <stdlib.h>
typedef struct Node {
int data;
int nev;
struct Node *next;
struct Node *prev;
} node;
void insert_after(node *nodee, int data, int nev){
node *start = nodee;
while(nodee->next != start) {
nodee = nodee->next;
nodee->next = (node*)malloc(sizeof(node));
nodee->prev = nodee;
nodee->data = data;
nodee->nev = nev;
nodee->next = start;
void insert_before(node *nodee, int data, int nev){
node *newNode = (node *) malloc(sizeof(node));
newNode->data = data;
newNode->nev = nev;
newNode->next = nodee->next;
newNode->prev = nodee;
nodee->next = newNode;
(nodee->next)->prev = newNode;
int find(node *nodee, int key){
while(nodee != start) {
if(nodee->data == key) {
return 1; //Element Found!
//Element Not Found!
return 0;
void delete(node *nodee,int data){
while(nodee->next != start && (nodee->next)->data != data) {
if(nodee->next == start) {
printf("Element %d is not presented in the list \n", data);
return;
node *temp;
temp = nodee->next;
nodee->next = temp->next;
free(temp);
return;
void print(node* start, node* nodee){
if(nodee == start) {
return;
printf("%d %d ", nodee->data, nodee->nev);
print(start,nodee->next);
void printBack(node* start, node* nodee){
return;
print(start,nodee->prev);
int main() {
int query;
node *start = (node*)malloc(sizeof(node));
start->next = start;
start->prev = start;
printf("1 - Insert_after\n");
printf("2 - Insert_before\n");
printf("3 - Delete\n");
printf("4 - Print\n");
printf("5 - Print Back\n");
printf("6 - Find\n");
while(1) {
printf("query: ");
scanf("%d", &query);
//insert_to_the_end
if(query == 1) {
int data;
int nev;
scanf("%d", &data);
scanf("%d", &nev);
insert_after(start, data,nev);
//insert_to_the_begginning
if(query == 2) {
int data;
int nev;
scanf("%d", &data);
scanf("%d", &nev);
insert_before(start, data,nev);
//delete
else if(query == 3) {
int data;
scanf("%d", &data);
delete(start, data);
//print
else if(query == 4) {
printf("The list is: ");
print(start,start->next);
printf("\n");
//printback
else if(query == 5) {
printBack(start,start->prev);
printf("\n");
//find
else if(query == 6) {
int data;
scanf("%d",&data);
int status = find(start,data);
if(status) {
printf("Elements Found\n");
} else {
printf("Elements Not Found\n");
return 0;
chabeee
chabeee
chabeee
chabeee
Biztos cirkulált listánál akarsz beszúrni az elejére végére?
Lehet én vagyok a buta most, de a cirkulált lista, az egy olyan lista, amelynek nincs eleje se vége... mert körbe láncoltak az elemek... "utolsó" elem az "első" elemre hivatkozik, mint egy népi körtánc... én legalábbis mindig azt hittem ez a cikrulált lista.
ez áll a feladatban:
Készíts menüvezérelt programot, amely egy kétirányban láncolt fejes, cirkulált listát valósít meg.
és ehhez jönnek, hogy miket kell megvalósítani vele. -
chabeee
hello,
3 feladatot nem tudok megoldani cirkuláris láncolt listákkal, valaki tudna ebben segíteni?- a lista elemeinek listázása visszafelé;
- elem felvitele a lista elejére
- elem felvitele rendezetten (a lista legyen kulcs szerint növekvő sorrendben).
Megjegyzés: a program a felvitelt csak egyféleképpen engedje meg. Ha az első felvitel rendezett módon történik, akkor ne lehessen később már a lista elejére vagy végére felfűzni. És fordítva, ha az első felvitel nem rendezetten történik, akkor ezt a funkciót később már ne lehessen kiválasztani.main.c
előre is köszönöm
üdv csabi. -
chabeee
Angol weboldalon a teljeség igénye nélkül a forráskód C-ben a duplán láncolt listához.
Angol, ha nem tudod, akkor fordítsd le magadnak, bőven jó. Ha nem megy, akkor rajzolád le.
Vagy a könyvtár és a Számítógép programozás című könyveket tanulmányozd ezügyben, vagy egy másik magyar nyelvű könyvet, viccen kívül
Ha meg megy az angol, akkor mehet a google keresés
linked list animation. És láss csodát
mint itt (csak várni kell az animácóra
)nekilátok, köszönöm
chabeee
Tudna-e valaki egy forráskódot adni ami egy kétirányban láncolt fejes, cirkulált listát valósít meg, amiben lehet új elemet felvenni és törölni. Megértés és tanulás érdekében kellene. Ha magyarázatot is tudtok adni hozzá, az lenne a legjobb számomra, de az nem feltétlenül szükséges. Előre is köszönöm!
Üdv. Csabi. -
chabeee
chabeee
hali!
dog kutya
donkey szamar
content tartalom
apple alma
good jo
diamond gyemantEzeket a szópárokat szeretném abc sorrendbe rendezni angol szavak alapján, milyen módon lehetne ezt véghez vinni?
chabeee
Megnéztem a feladatot, el is olvastam, és elég a mátrixban boolt tárolni.
igen ennel a feladatsornal jo
chabeee
Nálam először -1 hibakódot dobott a Code::Blocks, aztán rájöttem, hogy nincs bemenet.txt fájl. Erre nem írsz egy ellenőrzést, hogy ilyenkor se hibával lépjen ki? Ha jól gondolom ez iskolai feladat, oda nem árt ilyesmit beleírni, hátha beleköt a tanár (persze lehet nem, te ismered jobban). De egyébként is jobb (főleg később), ha az ember úgy írja a programjait, hogy hibánál (már amelyiket előre meg lehet jósolni) figyelmeztessen rá, "szóljon", hogy mi a gond.
@lordfreyr
igen a bemenet.txt-t odaírtam megjegyzésbe. igazából szoktam írni rá, de ez csak egy gyors gyak volt.@WonderCSabo
más feladatoknál ezt írtam és ez maradt bennem, meg ugye nem mindegyiknél 0 és 1 a fájl tartalma.amúgy itt a feladat: [link]
chabeee
chabeee
@szkorhetz> nalam jo, lehet azert nem megy mert linuxon irtam. igaz ezzel nem kene problema lenni
valaki nem tud mondani egy string to int konvertal fuggvenyt?
megvan mar!
a fv neve > atoi -
chabeee
chabeee
chabeee
köszi ezt akartam valahogy már nem ment a végére
chabeee
sziasztok!
lenne egy menüm aminek az a feladata, hogy ha nem a kilépésre megyek akkor hozza vissza magát.
tehát:
1 - jegyfoglalas
2 - hozzaadas
3 - kilépés
1
lefut a jegyfoglalas utána :
1 - jegyfoglalas
2 - hozzaadas
3 - kilépésés csak akkor hagyja abba amikor a kilépésre megyek.
a válaszokat előre is köszi
üdv csabi -
chabeee
Ezekkel mit akartál megvalósítani?
for(i=0;i<n1;i++) {
counter++;
for(i=0;i<n2;i++) {
counter++;
}Szerintem ez ugyanaz és nagyságrendekkel gyorsabb:
counter = n1 + n2;
A t3-at, ha csak a kiíratáshoz használod, akkor fölösleges a másolás. Ha ez egy visszatérő paraméter akarna lenni, akkor az fv végén lévő free(*(t3)); törli és ha ezután használni szerednéd (a törölt elemeket), csúnya dolgok történ(het)nek.
ebbe a fv-be lesz más művelet is ezért kell a t3-ba helyezni, pl rendezésre gondolok, meg ilyenek.
a counter-es az ilyen egyéni hülyeség : D
chabeee
jaj, köszönöm!
chabeee
végül is tök mindegy csak kíváncsi voltam rá írtam helyette 2 ciklust!
chabeee
A feltételben rakj &&-t a , helyett.
próbáltam már, ezt írja:
../main.c:115:15: error: lvalue required as left operand of assignment
../main.c:115:42: warning: value computed is not used [-Wunused-value]
make: *** [main.o] Error 1
for(i=n1 && j=0; i<counter && j<n2; i++ && j++) { -
chabeee
Sziasztok! Lenne egy ilyen függvényem:
void masol (int** t1, int** t2, int** t3, const int n1, const int n2)
int i,j, counter = 0;
for(i=0;i<n1;i++) {
counter++;
for(i=0;i<n2;i++) {
counter++;
*(t3) = (int*)malloc(sizeof(int)*counter);
for(i=0;i<n1;i++) {
*(*(t3)+i) = *(*(t1)+i);
for(i=n1, j=0; i<counter,j<n2; i++, j++) {
*(*(t3)+i) = *(*(t2)+j);
for(i=0;i<counter;i++) {
printf("3.%d: %d\n", i+1, *(*(t3)+i));
free(*(t3));
}annyit csinál hogy a t1 és a t2 dinamikus tömb elemeit belemásolja egy t3 nevű dinamikus tömbbe, viszont warningel ennél a sornál:
ezt írja: ../main.c:113:26: warning: left-hand operand of comma expression has no effect [-Wunused-value]
ha van valakinek valami ötlete, hogy miért írja ezt, annak megköszönném a segítséget!
üdv csabi
chabeee
chabeee
Jester1 köszönöm a segítséget - remekül fut a program mostmár
- a végtelen ciklust elkerültem úgy hogy index-1 - de köszönöm hogy figyelmeztettél valószinüleg elég sokat kellett volna rajt agyalnom
...kingabo: megfogadom a tanácsot
- próbáltam spacekkal tagolni - de nem engedte...
- nemtudtam ill. nem figyeltem hogy így megy ... Köszönöm!Comrade92: Pontosan PE
- elsőéves vagyok most.progalap házi HAHAHA
amúgy itt egy megoldás hozzá:
#include <stdio.h>
#include <string.h>
int main () {
char nev[30];
char tomb[100][30];
int i=0;
int counter=0;
int max=0;
int hossz;
int tomb2[100];
do{
printf("%d. name: ",i+1);
scanf("%s",nev);
if(nev[0] != '*') {
strcpy(tomb[i], nev);
printf("length: ");
scanf("%d", &hossz);
tomb2[i] = hossz;
i++;
counter++;
}while(nev[0] != '*' && i<100);
for(i=1; i<counter-1; i++){
if(tomb2[i]>tomb2[max]){
max=i;
printf("A leghosszabb kigyo %s, aki %d meteres. \n",tomb[max],tomb2[max]);
return 0;
chabeee
chabeee
igen ez utólagos próbálkozás volt, és ez kimaradt, de közben én is észre vettem, de még sajnos mindig kifagy.
@jester
másolási hiba,amugy nekem a fordító nem ir ki semmilyen fajta segítséget, lehet a mingw helyett vmit mást kéne feldobni ha egyáltalán ez okozza ezt a hibát -
chabeee
sziasztok
eclipse után code::blocksban próbálok programozni, de nem tudom hogy miért fagy ki a progi már az első adatbevitelnél:#include <stdio.h>
typedef struct mystruct {
unsigned int gyev;
int all; //1 - uj, 2 - jo allopotu, 3 - hibas, 4 - totalkaros
double mkm;
}data;
void beolvas (data t[], int n)
int i;
printf("BEKERES: \n\n");
for (i=0;i<n;i++)
printf("kerem a(z) %d. auto adatait: \n",i+1);
printf("gyartasi ev: \n");
scanf("%d",(unsigned int)t[i].gyev);
printf("megtett kilometer: ");
scanf("%lf",t[i].mkm);
//_flushall();
printf("allapot: ");
scanf("%d",t[i].all);
//_flushall();
printf("--------------\n");
void kiirat (data t[], int n)
int i;
printf("KIIRATAS: \n\n");
for(i=0;i<n;i++)
printf("A(z) %d. auto adatai: \n\n",i+1);
printf("gyartasi ev: %d\n", t[i].gyev);
printf("megtett kilometer: %lf\n", t[i].mkm);
printf("allapot: %d\n", t[i].all);
int main(){
const int n=10;
data tomb[n];
beolvas(tomb,n);
kiirat(tomb,n);
return 0
}a választ előre is köszi
üdv. Csabi -
chabeee
chabeee
hali
ubuntu alatt valgrindelni szeretnék terminálban, csak nem tudom a megfelelő szintaktikáját valaki tudna ebben segíteni? -
chabeee
chabeee
az a baj hidd el, én eclipseben "tanultam" meg programozni, és kipróbáltam mind kettőt, mingw forditót használsz? mert elvileg annál fordul elő.
amúgy egy jó ötlet: csinálj egy 20gb-os particiót arra dobj fel az új ubuntut, tökéletesen működik alatta, és felhasználó barát is -
chabeee
köszi
chabeee
sziasztok
hibakeresésnél egyszerűen nem találom a hibát kérlek segítsetekprintf("6.: %s", (((a<b)&&(a>c)&&((b>c)||(c>b)))?"a and b" : ((b>a)&&(c>a)&&((b>c)||(c>b)))?"b and c" : ((c>a)&&(a>b)&&((c>a)||(a>c)))?"a and c"));
error message: ../main.c:44:140: error: expected ‘:’ before ‘)’ token
a feladat amúgy: 2 legnagyobb számot 3 változóból ki kell kaparni
chabeee
chabeee
chabeee
programozás közben szükségem lett volna pár matematikai függvényre, de sajnos ezt nem tette lehetőve a progi amit használok. Ubuntu alatt használok eclipset!
egyetemen még mutatták hogy vmi "-m"-et kell beírni csak nem tudom hova.
konkrétan az sqrt kellene!
üdv
Fórumok
● ha kódot szúrsz be, használd a PROGRAMKÓD formázási funkciót!
- Autós kamerák
- Filmvilág
- Óra vagy karperec? Egészségügyi mindenes!
- BestBuy topik
- Xbox tulajok OFF topicja
- Ford topik
- Marathon: PVE-mód jön, a Bungie vázolta a következő szezont
- A Linux megnégyszerezte magát a Steamen — a Microsoft ismét ígérget
- playseat evolution black actifit
- Precision 3560 27% 15.6" FHD IPS i7-1165G7 T500 16GB 512GB NVMe magyar vbill IR kam gar
- Gamer Gép - MSI H610, Intel I5 13600, 16GB DDR4, RTX 3070 Ti, 1TB M.2 SSD, 750W 80+ Gold
- Asztali PC i7 6700 1650 16GB DDR4 512GB SSD
- ASUS TUF Gaming A17 Gamer laptop , R7 6800H , 16GB DDR5 , RTX 3050 Ti
- Dell Precision 7720,17.3",FHD,i7-7820HQ,16GB DDR4,256GB SSD,P3000 6GB VGA,WIN11
- BESZÁMÍTÁS! Asus ROG Strix RX 6600XT 8GB videókártya garanciával hibátlan működéssel
- 27% - Minisforum UM690L Slim Ryzen 9 6900HX / 32GB DDR5 / 1TB SSD / 680M MiniPC
- BESZÁMÍTÁS! 8TB WD RED WD80EFAX HDD meghajtó garanciával hibátlan működéssel
- Infinix Hot 11s / 4/128GB / Kártyafüggetlen / 12Hó Garancia
