qwertly
Sikerült leszedegetnem a libeket de az egyikkel nem boldogulok ez lenne az amúgy most ezt írja a,amikor kiadom a add packettracer7 parancsot
[root@localhost bin]# ldd PacketTracer7
linux-vdso.so.1 => (0x00007ffe413df000)
libcrypto.so.1.0.0 => not found
libQtWebKit.so.4 => /lib64/libQtWebKit.so.4 (0x00007faa87cf8000)
libQtScriptTools.so.4 => /lib64/libQtScriptTools.so.4 (0x00007faa87a36000)
libQtScript.so.4 => /lib64/libQtScript.so.4 (0x00007faa875f2000)
libQtSvg.so.4 => /lib64/libQtSvg.so.4 (0x00007faa87399000)
libQtXml.so.4 => /lib64/libQtXml.so.4 (0x00007faa87155000)
libQtGui.so.4 => /lib64/libQtGui.so.4 (0x00007faa8647a000)
libQtNetwork.so.4 => /lib64/libQtNetwork.so.4 (0x00007faa86133000)
libQtCore.so.4 => /lib64/libQtCore.so.4 (0x00007faa85c48000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007faa85a2c000)
libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007faa85723000)
libm.so.6 => /lib64/libm.so.6 (0x00007faa85421000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007faa8520b000)
libc.so.6 => /lib64/libc.so.6 (0x00007faa84e48000)
libXrender.so.1 => /lib64/libXrender.so.1 (0x00007faa84c3e000)
libjpeg.so.62 => /lib64/libjpeg.so.62 (0x00007faa849e9000)
libpng15.so.15 => /lib64/libpng15.so.15 (0x00007faa847bd000)
libwebp.so.4 => /lib64/libwebp.so.4 (0x00007faa8456d000)
libxslt.so.1 => /lib64/libxslt.so.1 (0x00007faa8432e000)
libz.so.1 => /lib64/libz.so.1 (0x00007faa84117000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007faa83f13000)
libgio-2.0.so.0 => /lib64/libgio-2.0.so.0 (0x00007faa83b9d000)
libgstapp-0.10.so.0 => /lib64/libgstapp-0.10.so.0 (0x00007faa83990000)
libgstinterfaces-0.10.so.0 => /lib64/libgstinterfaces-0.10.so.0 (0x00007faa8377e000)
libgstpbutils-0.10.so.0 => /lib64/libgstpbutils-0.10.so.0 (0x00007faa8355a000)
libgstvideo-0.10.so.0 => /lib64/libgstvideo-0.10.so.0 (0x00007faa8333c000)
libgstbase-0.10.so.0 => /lib64/libgstbase-0.10.so.0 (0x00007faa830e8000)
libgstreamer-0.10.so.0 => /lib64/libgstreamer-0.10.so.0 (0x00007faa82dff000)
libgobject-2.0.so.0 => /lib64/libgobject-2.0.so.0 (0x00007faa82bae000)
libgmodule-2.0.so.0 => /lib64/libgmodule-2.0.so.0 (0x00007faa829aa000)
libgthread-2.0.so.0 => /lib64/libgthread-2.0.so.0 (0x00007faa827a8000)
libxml2.so.2 => /lib64/libxml2.so.2 (0x00007faa8243e000)
libglib-2.0.so.0 => /lib64/libglib-2.0.so.0 (0x00007faa82107000)
libsqlite3.so.0 => /lib64/libsqlite3.so.0 (0x00007faa81e52000)
libfontconfig.so.1 => /lib64/libfontconfig.so.1 (0x00007faa81c15000)
libfreetype.so.6 => /lib64/libfreetype.so.6 (0x00007faa8196f000)
libQtOpenGL.so.4 => /lib64/libQtOpenGL.so.4 (0x00007faa8166f000)
libGL.so.1 => /lib64/libGL.so.1 (0x00007faa813d7000)
libXext.so.6 => /lib64/libXext.so.6 (0x00007faa811c5000)
libX11.so.6 => /lib64/libX11.so.6 (0x00007faa80e87000)
libSM.so.6 => /lib64/libSM.so.6 (0x00007faa80c7e000)
libICE.so.6 => /lib64/libICE.so.6 (0x00007faa80a62000)
libXi.so.6 => /lib64/libXi.so.6 (0x00007faa80851000)
libXrandr.so.2 => /lib64/libXrandr.so.2 (0x00007faa80647000)
libXfixes.so.3 => /lib64/libXfixes.so.3 (0x00007faa80441000)
libXcursor.so.1 => /lib64/libXcursor.so.1 (0x00007faa80235000)
libXinerama.so.1 => /lib64/libXinerama.so.1 (0x00007faa80032000)
libssl.so.10 => /lib64/libssl.so.10 (0x00007faa7fdc5000)
libcrypto.so.10 => /lib64/libcrypto.so.10 (0x00007faa7f9dc000)
librt.so.1 => /lib64/librt.so.1 (0x00007faa7f7d4000)
/lib64/ld-linux-x86-64.so.2 (0x00007faa8a0f8000)
libffi.so.6 => /lib64/libffi.so.6 (0x00007faa7f5cb000)
libselinux.so.1 => /lib64/libselinux.so.1 (0x00007faa7f3a6000)
libresolv.so.2 => /lib64/libresolv.so.2 (0x00007faa7f18c000)
liborc-0.4.so.0 => /lib64/liborc-0.4.so.0 (0x00007faa7ef09000)
liblzma.so.5 => /lib64/liblzma.so.5 (0x00007faa7ece4000)
libexpat.so.1 => /lib64/libexpat.so.1 (0x00007faa7eab9000)
libglapi.so.0 => /lib64/libglapi.so.0 (0x00007faa7e88b000)
libXdamage.so.1 => /lib64/libXdamage.so.1 (0x00007faa7e687000)
libX11-xcb.so.1 => /lib64/libX11-xcb.so.1 (0x00007faa7e485000)
libxcb-glx.so.0 => /lib64/libxcb-glx.so.0 (0x00007faa7e26b000)
libxcb-dri2.so.0 => /lib64/libxcb-dri2.so.0 (0x00007faa7e066000)
libxcb-dri3.so.0 => /lib64/libxcb-dri3.so.0 (0x00007faa7de62000)
libxcb-present.so.0 => /lib64/libxcb-present.so.0 (0x00007faa7dc5f000)
libxcb-randr.so.0 => /lib64/libxcb-randr.so.0 (0x00007faa7da51000)
libxcb-xfixes.so.0 => /lib64/libxcb-xfixes.so.0 (0x00007faa7d848000)
libxcb-render.so.0 => /lib64/libxcb-render.so.0 (0x00007faa7d63e000)
libxcb-shape.so.0 => /lib64/libxcb-shape.so.0 (0x00007faa7d43a000)
libxcb-sync.so.1 => /lib64/libxcb-sync.so.1 (0x00007faa7d232000)
libxcb.so.1 => /lib64/libxcb.so.1 (0x00007faa7d010000)
libxshmfence.so.1 => /lib64/libxshmfence.so.1 (0x00007faa7ce0d000)
libXxf86vm.so.1 => /lib64/libXxf86vm.so.1 (0x00007faa7cc06000)
libdrm.so.2 => /lib64/libdrm.so.2 (0x00007faa7c9f9000)
libuuid.so.1 => /lib64/libuuid.so.1 (0x00007faa7c7f3000)
libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007faa7c5a7000)
libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007faa7c2c1000)
libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007faa7c0bd000)
libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007faa7be8b000)
libpcre.so.1 => /lib64/libpcre.so.1 (0x00007faa7bc29000)
libXau.so.6 => /lib64/libXau.so.6 (0x00007faa7ba25000)
libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007faa7b815000)
libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007faa7b611000)
[root@localhost bin]#A második lib amelyet nem tudok feltelepíteni,mert nem tudom letölteni.
qwertly
Tényleg igazad van így már teljesen más
látni milyen libeket hiányol a rendszerből.
Köszönöm is az eddigi segítségedet
itt már csak azt szeretném megkérdezni
,hogy vannak ilyen libeket gyűjtő oldalak ahova felmenve és keresőjükbe beírva a mi kell nekem felkínálja nekem a kereset libeket.UI: én ezt az oldalt találtam
qwertly
qwertly
qwertly
Kedves Vladi!
Sejtetem,hogy te fogsz jelentkezni
már amúgy futottam egy kört a fedora topikban de ott beletört a bicska.De ott még csak 32-bites létezett de azóta a cisco kiadott 64-bit linux verziót és ezt akartam felrakni centos 7 64-bit linuxra.Azért erre mert a SuliX 8 erre épül.Hogy hogyan telepítettem nem linux guru módon
innen letöltöttem és kitömörítettem a utána beléptem a kitömörített mappába majd kiadtam ./install parancsot pár y és szóköz lenyomása után fel is települt az opt mappába és ott pt mappába beléptem majd kiadta terminálba packettracer látszólag elindul de mégsem.Hát ennyit tudtam csinálni nagyon szépen megköszönöm ha megnéznéd mi a gond.Üdv: qwertly
qwertly
Esetleg valaki aki linux guru rá tudna nézni erre a kérdésemre? Mert nálam elfogyott a tudomány. -
qwertly
Próbálom erre a rendszere felimádkozni a Cisco Packet Tracker 7 és 64-bit
programot fel is települ de nem indul el.Esetleg van elképzelésetek mi a gond? -
qwertly
Adott Sulix Professional 8 sajnos központilag minden repo le van tiltva,még a 7 kiadáson ment a packet tracker itt már nem működik.Fedora topikba azt a tanácsot kaptam hogy a deafult CentOs repó vegyem fel.Így meglesznek azok a függőségek amelyek kellenének a program futtatásához.Így az lenne a kérdésem miképpen tudnám hozzá adni azokat a repoket a sulixhoz?
- PC Game Pass előfizetés
- AKCIÓ! Apple iPhone 12 Mini 64GB mobiltelefon garanciával hibátlan működéssel
- Xbox Series S 512 GB + kontroller 6 hó garancia, számlával!
- GYÖNYÖRŰ iPhone 13 Pro Max 128GB Alpine Green -1 ÉV GARANCIA - Kártyafüggetlen, MS4599, 100% Akksi
- Dell Latitude 5430 14" Touchscreen i5-1235U 16GB 512GB 1 év garancia
- Apple iPhone 16 Pro 128GB, Kártyafüggetlen, 1 Év Garanciával
de folyamatosan nézzem a blogokat hátha valaki nálam okosabb megoldja.De úgy vettem észre,hogy a főként spanyol nyelvű fórumokon vannak linux okosságok.
nem megy tovább.
