emre33
Fontos kérdés:
Van bárkinek infója arról hogy 2x2GB DDR2 KIT-eknek hol van a stabil 24/7 végük CL 4-4-4-12 -el -
emre33
RAM oldalára felraktam a Zalman előlapi kijelzőm hőmérsékletérzékelőjét.
Hány fokig nem kell aggódnom memóriam elegedés miatt? (4 modul egymás melett, felette 2db 6cm FAN)
emre33
*** Enhancements in v2.01 : ***
New Features
Added support for 45 nm Mobile Core 2 w/ 3 Mo L2
Added support for i945GM/PM/GME & i946PL/GZ
Added support for iGM965/iGL960/iPM965/iGME965/iGLE960
Added detection for SiS 649/656/671/672
Added detection for i430MX/i430TX
Added an optional beep mode (pass completed w/o error)
Pass duration 20% reduced
Removed the blinking cursor
Reverted Test #0 to cachedBug Fixes
Solved a major bug in Memory Address Errors Reporting
Patched for Intel-Powered Mac
Corrected Intel 3-Series (P35/X38) chipset init
Corrected a bug with SPD Display and ESB6300
Correct a detection bug on P965/G965 C-Stepping
Solved a incoherency with pass progress indicator
Patched Makefile to compile on x86_64
Bootable Memtest86+ ISO more compatibleEnhancements in v2.00 :
Major Architectures changes
Modulo test now use random pattern for better accuracy
Added Advanced DMI Errors Reporting Mode
Added support for bus ratio changes on Intel Core CPU
Added support for non-integer bus ratio on latest Intel CPU
Added SPD Data Display for all Intel Chipsets (more to come)
Added serial support as a linux boot parameter (Thanks to Michal S.)
Added preliminary support for VIA CN Isaiah CPU
Added preliminary support for Intel Nehalem
Added support for VIA C7/C7-D/C7-M/Eden on Esther Core
Added support for AMD K10 (Phenom) CPU w/ timings detection
Added support for Intel Pentium E w/ 1 MB L2 Cache
Added support for Intel Core 2 45nm (Penryn)
Added support for FSB1333/FSB1600 Intel CPU
Added support for Intel 5400A/5400B w/ timings detection
Added support for Intel Q35/P35/G33/Q33 w/ timings detection
Added support for Intel X38/X48 w/ timings detection
Added preliminary support for Intel 5000P/V/Z
Removed on-fly memory timings change (unstable)
Numerous (really) bug fixes -
emre33
2x2 GB Crucial Tracer megrendelve.
Remélem jó párosítás lesz az alábbi lap+cpu+tuning párosításhoz -
emre33
Szerintetek melyik lenne a jobb választás:
4 darab 1GB modulVagy:
2x CSX Hűtőbordás 2GB OC Kit (2x1GB, 1066Mhz)Vagy:
Tracer (LED) 2x1GB 1066 5-5-5-151100Mhz (max 1140Mhz) környékén futna (ocz xtc memory cooler társaságában)
(tracer elvileg 1080 környékén tudja még a CL4-et)
köszi
emre33
emre33
Crucial Ballistix 1148 Mhz, és 4 modul
Szóval nem lehetetlen a 4 modulos tuning
emre33
most találtam:
emre33
Hamarosan 4 darab 1GB Crucial Ballistix lesz párosítva egy Gigabyte X48 lappal és egy Scythe Ninja hütővel
Crucial Ballistix reméyneim szerint huzva lesz, és mivel 4 modul lesz, így szerintem melegedni fognak!
Milyen hütést javasoltok hozzá?
Én a OCZ XTC Memory cooler-re gondoltam. Van ennél jobb?
Ezzel egy gondom van: Ninja és a OCZ XTC Memory cooler között nem fog elférni egy 12cm-es ventilátor.
Ha megforditom a ventilátort, akkor a 12cm venti szívni fogja a ninja felől a levegőt. ami nem olyan hatásos.
ötlet?
emre33
Ballistix 2x1GB 1066 5-5-5-15
Ez a ram, ha 4 darab 1GB modul van egy P35 vagy X38 (vagy X48) alaplapban, stabilan mehet 1140Mhz-et? (esetleg van hátránya a 4. modulos tuningnak?)
Milyen feszültség melett, melegszik? Esetleg szükséges másik hütés?Köszi
emre33
Üdv
Szerintetek milyen 4GB kit-et vegyek?
RAM DDR2 800MHz 4GB GEIL BLACK DRAGON KIT4 4- 29,8k
Ez meddig birja a kiképzést?
Jól néztem hogy nincs rajta gyárilag hütőborda?
- HP üzleti laptopok Elitebook, Probook 4-12. gen gar.
- Számlás!Windows 10 Pro 11 Pro,Windows 10 Home 11 Home, Office 2016,2019,2021 ,Vírusirtok,Mac
- Dell Latitude 7290,12.5",FHD,i5-7300U,8GB DDR4,256GB SSD,WIN11
- GYÖNYÖRŰ iPhone 13 mini 128GB Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS4062
