- Fórumok
- OS, alkalmazások
- Debian GNU/Linux
- (kiemelt téma)
Fórumok
LOGOUT - lépj ki, lépj be!
Frissítve: 2023-12-13 04:47 Téma összefoglaló
Archttila
Archttila
Archttila
Archttila
Archttila
Igen, a COMMIT után kellett egy enter!
Esetleg valami hozzáfűznivaló ehhez a samba és DLNA rulre-hoz?
-A RH-Firewall-1-INPUT -p udp -m udp -s 192.168.0.10/32 --dport 137 -j ACCEPT
-A RH-Firewall-1-INPUT -p udp -m udp -s 192.168.0.10/32 --dport 138 -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp -s 192.168.0.10/32 --dport 139 -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp -s 192.168.0.10/32 --dport 445 -j ACCEPT-A INPUT -s 192.168.1.203/24 -p tcp -m tcp --dport 8200 -j ACCEPT
-A INPUT -s 192.168.1.203/24 -p udp -m udp --dport 1900 -j ACCEPT -
Archttila
Szerintetek miért dobja el amikor aktiválni akarom?
*filter
# Allow all loopback (lo0) traffic and drop all traffic to 127/8 that doesn't use lo0
-A INPUT -i lo -j ACCEPT
-A INPUT -d 127.0.0.0/8 -j REJECT
# Accept all established inbound connections
-A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
# Allow all outbound traffic - you can modify this to only allow certain traffic
-A OUTPUT -j ACCEPT
# Allow HTTP and HTTPS connections from anywhere (the normal ports for websites and SSL).
-A INPUT -p tcp --dport 80 -j ACCEPT
-A INPUT -p tcp --dport 443 -j ACCEPT
# Allow SSH connections
# The -dport number should be the same port number you set in sshd_config
-A INPUT -p tcp -m state --state NEW --dport 22 -j ACCEPT
# Allow ping
-A INPUT -p icmp --icmp-type echo-request -j ACCEPT
# Log iptables denied calls
-A INPUT -m limit --limit 5/min -j LOG --log-prefix "iptables denied: " --log-level 7
# Drop all other inbound - default deny unless explicitly allowed policy
-A INPUT -j DROP
-A FORWARD -j DROP
COMMITsudo iptables-restore < /etc/iptables.firewall.rulesiptables-restore v1.4.21: no command specified
Error occurred at line: 31 -
Archttila
Időközben mindent megoldottam:
fdisk
mkfs
samba
minidlna
transmissonMost már minden működik!
(#7974) bambano
Igen 777-tel működik, köszönöm!
Archttila
Nos a probléma az volt, hogy a rendszer egy összefüggő particióként kezelte a pidrive-ot. (sda)
A kérdésem az lenne, hogy miként tudok ebből sda1 -et létrehozni?sudo mount /dev/sda /mnt/pidriveegyelőre így működik.
Bocsánat a sok láma kérdésért de csak emiatt már nem szeretnék felrakni egy grafikus felület tele számomra sok felesleges dologgal!
(főleg ha már eddig eljutottam) -
Archttila
# <file system> <dir> <type> <options> <dump> <pass>
UUID=ad8f979b-e1d3-4b7f-b04b-4567c8ec1b20 /mnt/pidrive ext4 nofail,defaults 0 0hmm tuti, hogy valamelyik options nem jó vagy hiányos. Senkinek semmi ötlete?
ahány oldal annyiféle megvalósítás:
/dev/disk/by-uuid/0562789e-5f04-44c6-b36e-c64bb4e340bf /mnt/data ext4 defaults,noatime,nofail 0 0
az is lehet, hogy a mnt alatt létrehozott pidrive jogosultsága nem tetszik neki.
chown -R pi:pi /mnt/pidrive
chmod -R 775 /mnt/pidrive -
Archttila
Köszönöm időközben megoldódott a samba probléma viszont valamit nagyon benézhettem mert nem csatolja fel az fstab tartalmát. (az lenne az 1TB pidrive)
UUID=ad8f979b-e1d3-4b7f-b04b-4567c8ec1b20 /mnt/pidrive ext4 nofail,defaults 0 0valami hiányzik belőle? mert a transmission szépen elkezdte memóriakártyára pakolni a cuccost...
Archttila
Van nekem egy kis 1TB-os tenyérnyi RPI3 NAS-om viszont valami nem kerek a samba conf körül mert sajnos a Windows bár látja, írni nem tud rá. Mi rontottam el?
smb.conf
workgroup = HOME
wins support = yescomment=pidrive
path=/mnt/pidrive
browseable=yes
writeable=yes
only guest=no
create mask=0775
directory mask=0775
public=yesrestart megvolt... dlna érdekes módon OK, a TV látja egyedül a samba szívat
Archttila
Azt hiszem ehhez nincs is mit hozzáfűzni
tökéletesen összefoglaltad a lényeget
Talán ennyi: Security support for testing
Archttila
Semmi ertelme Desktopon a Debian Stable-et eroltetni
de en mar nem irom le ujra, hogy miert
Archttila
Archttila
"Az iwlwifi meg önmagában nem működik, az interfaces-be eddig simán beírtam a kellő datát, és már ment is a wifi, most meg kénytelen voltam felrakni a wicd-t is."
A wpasupplicant csomag telepitve van? Nekem is csak siman az /etc/network/interfaces fajlba van bevesve az aldas, es mukodik. (LAN, Wi-Fi, DSL)
Archttila
Igen, tanulni is nagyon jok ezek a distrok. Ubuntu alatt hajlamos "elkenyelmesedni" az ember...
Tegnap peldaul talaltam a ThinkWiki-n egy bejegyzest, ami alapjan at lehet hidalni a CPU frekvencia korlatozast ThinkPad-eknel. Vehettem volna egy 90 wattos toltot a laptophoz, de inkabb befirkaltam GRUB-ba az alabbi sort:processor.ignore_ppc=1
Archttila
Archttila
Valoszinuleg te meg vilagra sem jottel amikor en mar szamitegep elott ultem es rendszerfajlokat turkaltam
Windows?
En megjartam a rangletrat te kis oktondi
dolgoztam korabban cegnel DOS alatt es hasonlo dolgok teccikerteni? Egyebkent a mostani Windows egy kanaan a korabbi Windows verziokhoz kepest. Telepitettel te Win 95 alatt drivert?
ketlem! Tudod mi az a napi 10-15 BSoD?
Itt van inkabb egy kis aptitude
(hatha tanulsz valamit)
Archttila
"mert nekem elegge durva hogy ennyit kll szarakodni egy driver telepitesevel."
Neked valo disztron 1-2 katt. Most irtak par hozzaszolassal lejjebb... es azt is, hogy a Debian NEM a te rendszered egyelore. (bar valoszinuleg a jovoben sem lesz az)
Mas hozzaallast igenyel ez az egesz...
Mondanam, hogy bizotsan fiatal vagy de...
Archttila
"debian kezdoknek"
mokas egy figura maga
Egyebkent ahogy a kollega is tanacsolta "ismerkedos" disztroval erdemes kezdeni, mert igy ugy is csak "szaralinux" lesz a vege
Archttila
Archttila
Szerintem a stable nem kifejezetten jo Desktop-ra, backports ide vagy-oda. En mar hosszu evek ota testinget hasznalok, naponta frissirtem es az eg vilagon semmi gondom nem volt meg vele. Gondolom az tiszta, hogy az Ubi LTS is testing, de a jelenlegi legfrissebb 14.10 az unstable agra epul!
A legfrissebb Gnome 3.14 pedig most kerult be a testingbe... (tegnapelott)
Debian stable: 3.4
Ubuntu stable: 3.8
Elotte 1.5 evig az unstable agat hasznaltam, es a legnagyobb hiba az volt, amikor az egyik frissites utan az Xfce compozitor nem mukodott. Nyilvan megvoltam nelkule, de ugye SID-be hamar jon a fix, igy 2 nap mulva javitva is lett.Nem kell felni a testing-tol
folyamotasan friss csomagok, stabil mukodes Desktop-on. -
Archttila
Archttila
Archttila
Archttila
GNOME 3 flashback? apt-get install gnome-session-flashback
(igaz csak testing es sid)
Mondjuk en XFCE-t hasznalok mar egy ideje, es batran merem ajanlani... halas, konnyen testreszabhato, nagyon porgos kis asztali kornyezet. Millio plug, applet mindenhez...
Archttila
En anno irtam egy rovid kis scriptet, mival akkoriban az aktualis Ubuntu verzio alaposan bugzott ICC-t illetoen (is).
No de a lenyeg:Szoval letrehozol mondjuk home alatt egy startup.sh fajlt, amibe elhelyezed a kovetkezo 2 sort:
#!/bin/bash
xcalib /home/alucard/.icc/dell_u2311h_custom.iccMentes utan futtathatova teszed:
chmod +x /home/alucard/.icc/startup.sh
Ertelemszeruen elotte apt-get install xcalib
Archttila
Elnezest elirtam az fstab tartalmat
mtpfs /media/nexus7 fuse user,noauto,allow_other 0 0
Archttila
Debian testing ala szeretnem felmountolni a Nexus 7-es tabletem, de sehogysem akar osszejonni. Feltettem a jmtpfs-t, es fstab-ba bejegyeztem a kovetkezo sort:
https://packages.debian.org/jessie/jmtpfs
Thunarba megjelenik a nexus7 ikon, viosznt No such file or directory-t kapok
update: fdisk -l sem lat semmit. (kiveve persze a HDD-m)
Archttila
Archttila
Archttila
wpa_supplicant (+ GUI) miert nem latja a WIFI adaptert? lspci-n ott van, led vilagit... command line-ba is probaltam, de hiaba scannelem iwlist wlan0-at semmi.
Archttila
Archttila
Archttila
Archttila
Archttila
Tudtam, hogy nem vagyok egy nagy halo guru, de ezt akkor sem vagom.
Vettem egy (Intel) wireless card-ot a regi laptopba. Beleraktam mukodik (vilagit a led) viszont iwlist scan-re nem dob semmit, es WICD alatt sem talal halozatot. Kilottem a vezetekes kapcsolatot de akkor sem. etc/network/interfaces-be tovabbra is csak eth0, lo van wlan0 nincs. Tudom, hogy mit kellene bejegyezni, viszont egy scan mindenkepp kellene, mert itt nem ismerem az SSID-t...
WICD-be wireless interface-nek wlan0-t irtam.
Archttila
(nem teszteltem)
Mondjuk ezt wheezy ala nem tudod bekalapalni... -
Archttila
Archttila
Archttila
Archttila
Ma egy erdekes jelensegre lettem figyelmes. Ujrainditottam a Transmission klienst, es bizony elfelejti a beallitasokat
mindig default beallitasokkal indul ujra... toroltem a config fajlokat de semmi. Volt reinstall is de nem segitett. Eddig tokeletesen megvoltunk.transmission-gtk 2.77 (14031)
Persze valszeg ez: Debian Sid
Archttila
Archttila
Archttila
Archttila
Archttila
Archttila
Felment szepen!
Mar csak le kellene valahogy ellenoriznem, hogy az altalam telepitett verziot hasznalja...
Archttila
Felraktam meg par dev csomagot (libdrm-dev libx11-dev x11proto-xf86dri-dev libxext-dev libxvmc-dev x11proto-gl-dev mesa-common-dev) de meg mindig lehal
viaXvMC.c:39:20: fatal error: fourcc.h: No such file or directory
compilation terminated.
make[4]: *** [libchromeXvMC_la-viaXvMC.lo] Error 1
make[4]: Leaving directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2/src/xvmc'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2/src'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2'
make: *** [all] Error 2hmm ugy latom a fourcc.h benne van az xserver-xorg-dev csomagban. Na utolso proba...
Archttila
Altalaban aptitude-be rakeresek es felrakom, de ugy nez ki ez most kifogott rajtam:
viaXvMCPriv.h:29:33: fatal error: X11/extensions/XvMC.h: No such file or directory
make[4]: *** [libchromeXvMC_la-viaLowLevel.lo] Error 1
make: *** [all] Error 2 -
Archttila
make
root@debian:/home/alucard/Downloads/xf86-video-openchrome-0.3.2# make
make all-recursive
make[1]: Entering directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2'
Making all in src
make[2]: Entering directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2/src'
make all-recursive
make[3]: Entering directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2/src'
Making all in xvmc
make[4]: Entering directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2/src/xvmc'
/bin/bash ../../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../.. -fvisibility=hidden -I/usr/include/pixman-1 -I/usr/include/libdrm -I/usr/include/xorg -fvisibility=hidden -I/usr/include/pixman-1 -I/usr/include/libdrm -I/usr/include/xorg -I/usr/include/libdrm -I/usr/include/X11/dri -I../../src -I../../src/xvmc -DTRUE=1 -DFALSE=0 -g -O2 -MT libchromeXvMC_la-viaLowLevel.lo -MD -MP -MF .deps/libchromeXvMC_la-viaLowLevel.Tpo -c -o libchromeXvMC_la-viaLowLevel.lo `test -f 'viaLowLevel.c' || echo './'`viaLowLevel.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../.. -fvisibility=hidden -I/usr/include/pixman-1 -I/usr/include/libdrm -I/usr/include/xorg -fvisibility=hidden -I/usr/include/pixman-1 -I/usr/include/libdrm -I/usr/include/xorg -I/usr/include/libdrm -I/usr/include/X11/dri -I../../src -I../../src/xvmc -DTRUE=1 -DFALSE=0 -g -O2 -MT libchromeXvMC_la-viaLowLevel.lo -MD -MP -MF .deps/libchromeXvMC_la-viaLowLevel.Tpo -c viaLowLevel.c -fPIC -DPIC -o .libs/libchromeXvMC_la-viaLowLevel.o
In file included from viaLowLevel.c:34:0:
viaXvMCPriv.h:28:25: fatal error: X11/Xlibint.h: No such file or directory
Archttila
Most mar igen de ujra elhasal:
libtool: link: ( cd ".libs" && rm -f "openchrome_drv.la" && ln -s "../openchrome_drv.la" "openchrome_drv.la" )
make[4]: Leaving directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2/src'
Making all in man
make[2]: Entering directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2/man'
sed -e 's|__vendorversion__|"xf86-video-openchrome 0.3.2" "X Version 11"|' -e 's|__xorgversion__|"xf86-video-openchrome 0.3.2" "X Version 11"|' -e 's|__xservername__|Xorg|g' -e 's|__xconfigfile__|xorg.conf|g' -e 's|__projectroot__|/usr|g' -e 's|__appmansuffix__|1|g' -e 's|__drivermansuffix__|4|g' -e 's|__adminmansuffix__|8|g' -e 's|__miscmansuffix__|7|g' -e 's|__filemansuffix__|5|g' < openchrome.man > openchrome.4
make[2]: Leaving directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2/man'
Making all in tools
make[2]: Entering directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2/tools'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2/tools'
make[2]: Entering directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2'
make[2]: Leaving directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2'
make[1]: Leaving directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2' -
Archttila
A latest openchrome driver-t forgatom forrasbol ami egy kis nyuglodes utan le is futott hiba nelkul.
De a make megorjit
via_exa.c:39:19: fatal error: GL/gl.h: No such file or directory
make[3]: *** [via_exa.lo] Error 1
make[2]: *** [install-recursive] Error 1
make[1]: *** [install] Error 2
make[1]: Leaving directory `/home/alucard/Downloads/xf86-video-openchrome-0.3.2/src'
make: *** [install-recursive] Error 1.../src alatt valoban nincs via_exa.lo file
Archttila
Archttila
En mart tobb mint egy eve SID-et hasznalok, es nincs semmi gond a rendszerrel. Sot, fel van veve az experimental is, mert egy ket app. miatt szuksegem van ra. A Debian telepitojen egyebkent van egy nagyon erdekes iromany, ahol az egyik fejleszto kifejti miert jobb a sid a testingnel. Eleg hosszan levezeti, kiterve egy tetszoleges soft. verziojara is, de tomoren az a lenyeg, hogy sid-be sokkal hamarabb (par nap max) erkezik a javitas mint testingbe. Ha stabil kell akkor ott a stable, ha pedig frissebb csomagokat akar az ember gorditeni
akkor okosabb valasztas lehet a sid.
Erdemes elolvasni. -
Archttila
Az Iceweasel Firefox forrasbol van forgatva, es vele egy idobe kerul be a taroloba, szoval igazabol mind1 meyiket hasznalom...
Egy oreg Medion laptopon van rendszer igy a 64 bit felejtos. De azert koszi!
Korabban Chromium volt fent, de egy ilyen gepen bizony erezni, hogy lassabb mint a roka es tarsai... -
Archttila
Debian Sid rendszeremhez hozza van adva az Experimental tarolo, mivel 3-4 altalam hasznalt program igen regi, meg unstable-be is. (Iceweasel, mousepad ristretto...)
A lenyeg: azt szeretnem elerni, hogy amikor rendszert dist-upgrade-elek, akkor automatikusan frissuljenek az Experimental tarolobol telepitett programok is, mert jelenleg ezt mindig manualisan kell elvegeznem.Aptitude-be szoktam elleneorizgetni jott-e xy programbol uj verzio...
Tudtok ra vmi megoldast?
Archttila
Szia
Boot flag van a Pendrive-on, BIOS-ban boot sorrend megfeleloen be van allitva... ?
Udv
Archttila
Archttila
Archttila
Netinst/Base system. Full alaprendszert telepit, mindenfele utiliti nelkul... ha jol emlekszem mindossze 200 csomag az egesz. Ennel kisebb rendszert nem tudsz osszebarkacsolni.
Meg tomoriteni sem tudsz alatta
A netinst mellett letezik egy kisebb telepito is a business card, de mindossze annyi a kulonbseg a ketto kozt, hogy a business card meg az alaprendszert is a netrol szedi. (ezert olyan pici)http://www.debian.org/CD/netinst/
Archttila
Verbose hatha mond valamit:
clamscan -r -v /
Vagy:
clamscan -r -v --remove=yes /
Esetleg:
clamscan -r -v --remove=yes --detect-pua=yes --heuristic-scan-precedence --algorithmic-detection=yes --scan-pe=yes --scan-ole2=yes --scan-pdf=yes --scan-html=yes --scan-archive=yes /
A szokozokre figyelj
Archttila
Archttila
Nálam is. Igaz én a SID ágat használom, de eddig még nem volt vele problémám...
Fórumok
- Fórumok
- OS, alkalmazások
- Debian GNU/Linux
- (kiemelt téma)
- Trollok komolyan
- Androidos tablet topic
- Samsung Galaxy A37 – régi ismerős új formában
- Dupla telefotót kaphat a Mate 90 Pro Max
- Megújult mobilos felület, fórumos ráncfelvarrás a PROHARDVER! lapcsaládon
- Yettel topik
- Android szakmai topik
- BESZÁMÍTÁS! 2TB Samsung 990 Pro Heatsink NVMe SSD meghajtó garanciával hibátlan működéssel
- Apple iPhone 14 Pro Max 128GB Purple - Megkímélt állapot - 100% akku
- Samsung Galaxy S22 Plus 256GB,Újszerű,Dobozaval,12 hónap garanciával
- REFURBISHED és ÚJ - Lenovo ThinkPad Ultra Docking Station (40AJ)
- Asus STRIX RTX 3090 24GB GDDR6X Videokártya! BeszámítOK
Én most vele ismerkedem
