Keresés
  • Toma1974
    válasz bambano #5609 üzenetére
    Ezzel sokat segítenél,vagy is semmit nem értek így
  • Toma1974
    --] Data in PERFORMANCE_SCHEMA tables: 0B (Tables: 17)
    [!!] Total fragmented tables: 441
    -------- Security Recommendations -------------------------------------------
    [OK] All database users have passwords assigned
    -------- Performance Metrics -------------------------------------------------
    [--] Up for: 8h 51m 25s (781K q [24.510 qps], 5K conn, TX: 319M, RX: 97M)
    [--] Reads / Writes: 10% / 90%
    [--] Total buffers: 382.0M global + 52.5M per thread (500 max threads)
    [!!] Maximum possible memory usage: 26.0G (265% of installed RAM)
    [OK] Slow queries: 0% (0/781K)
    [OK] Highest usage of available connections: 4% (20/500)
    [OK] Key buffer size / total MyISAM indexes: 100.0M/78.2M
    [OK] Key buffer hit rate: 99.9% (1M cached / 1K reads)
    [OK] Query cache efficiency: 43.8% (49K cached / 113K selects)
    [OK] Query cache prunes per day: 0
    [OK] Sorts requiring temporary tables: 0% (1 temp sorts / 2K sorts)
    [OK] Temporary tables created on disk: 1% (54 on disk / 2K total)
    [OK] Thread cache hit rate: 99% (31 created / 5K connections)
    [!!] Table cache hit rate: 5% (1K open / 19K opened)
    [OK] Open file limit used: 48% (1K/2K)
    [OK] Table locks acquired immediately: 100% (637K immediate / 637K locks)
    [!!] Connections aborted: 26%
    [!!] InnoDB data size / buffer pool: 11.8G/150.0M
    -------- Recommendations -----------------------------------------------------
    General recommendations:
    Run OPTIMIZE TABLE to defragment tables for better performance
    MySQL started within last 24 hours - recommendations may be inaccurate
    Reduce your overall MySQL memory footprint for system stability
    Enable the slow query log to troubleshoot bad queries
    Increase table_cache gradually to avoid file descriptor limits
    Your applications are not closing MySQL connections properly
    Variables to adjust:
    *** MySQL's maximum memory usage is dangerously high ***
    *** Add RAM before increasing MySQL buffer variables ***
    table_cache (> 1000)
    innodb_buffer_pool_size (>= 11G)
    Aki tud segítsen a pontos beállításban,mert lag van a szerveren, és pontosan mit mire kell állítani my.cnf-be
  • Toma1974
