PsycHo88
Rendben !
Köszönöm a segítséget ! -
PsycHo88
Már megcsinálta 3-szor ! De sajna nem működik :/
PsycHo88
Újraindítottam a gépet , most pedig ugyan az a hiba, mint a (#3112) kép .
PsycHo88
Lehet hogy igazad volt ! Most valami 8gb-ot tölt lefelé
PsycHo88
Rendben !! Már is csinálom
PsycHo88
A gépemben semmit nem oc-ztam !
PsycHo88
ITT AZ ÖSSZES INFÓ AMIT KI ÍR !!
Configured log listener print-redirect tags
Added structured log listener print-redirect
Added structured log listener mp-cloud-gobbler
2017-03-30T02:10:49.330+02:00 LOG: Process started
Winsock Initialized
------ Initializing File System ------
Current search path:
- C:/Users/johnny/Saved Games/id Software/DOOM/base/
- G:/steam/steamapps/common/DOOM/base/
------ File System initialized.
------ Command Line ------
G:\steam\steamapps\common\DOOM\DOOMx64.exe "+com_gameMode 1"
2017-03-30T02:10:49.340+02:00 LOG: Command Line: G:\steam\steamapps\common\DOOM\DOOMx64.exe "+com_gameMode 1"
------ CPU Information ------
1 CPU package, 4 physical cores, 8 logical cores
3410 MHz Intel CPU with MMX & SSE & SSE2 & SSE3 & SSSE3 & SSE41 & SSE42 & AVX & HTT
32768 kB 1st level cache, 262144 kB 2nd level cache, 8388608 kB 3rd level cache
12240 MB System Memory
initializing resource container gameresources.resources
initializing resource container gameresources.patch
initializing resource container gameresources_002.patch
initializing resource container gameresources_003.patch
initializing resource container gameresources_004.patch
initializing resource container gameresources_005.patch
idLib::SetProduction( PROD_PRODUCTION )
------- Initializing renderSystem --------
PreliminaryRenderSetup
---registered window class
---registered fake window class
---registered context window class
created OpenGL 4.3 context
----- GL_Init -----
----- GPU Details -----
Vendor : ATI Technologies Inc.
GPU : Radeon(TM) RX 460 Graphics
Driver : 4.3.13469 Compatibility Profile Context 21.19.519.2
dedicated video memory : 3596MB
total video memory : 3596MB
available video memory : 3596MB
OpenGL version 4.3
GLSL version 4.5
X..GL_ARB_shader_clock not found
X..GL_NVX_multigpu_info not found
Number of GPUs : 1
RENDER THREAD STACK SIZE: 4194304
Initializing OpenGL subsystem
ShowGameWindow: (0, 0) 1920 x 1080, full screen
Using mega2 chunk file G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr_sq9.mega2
Using mega2 chunk file G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr_sq10.mega2
Using mega2 chunk file G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr_sq13.mega2
Using mega2 chunk file G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr_sq14.mega2
Using mega2 chunk file G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr_q1.mega2
Using mega2 chunk file G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr_q2.mega2
Using mega2 chunk file G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr_q3.mega2
Using mega2 chunk file G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr_q4.mega2
Read vmtrs from G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr.vmtr
Read vmtrs from G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr_dlc1.vmtr
Read vmtrs from G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr_dlc2.vmtr
Read vmtrs from G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr_dlc3.vmtr
Read vmtrs from G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr_dlc4.vmtr
Could not open G:\steam\steamapps\common\DOOM/virtualtextures/_vmtr_dlc5.vmtr, all vmtrs will be re-created
Read a total of 6824 vmtrs
Executing default.cfg for device #0...
Executing default.cfg for device #1...
Executing default.cfg for device #2...
Executing default.cfg for device #3...
Unknown command 'build_packageParent'
Unknown command 'build_packageBranch'
Unknown command 'build_candidateURL'
Unknown command 'build_candidateRecipeDescription'
Unknown command 'build_binaryBranch'
Unknown command 'build_binaryChange'
------ Build Information ------
Cheat Mode: OFF
Host Name: JOHNNY-PC
Binary Build:
Version: 6.1.1
Target: shippingretail
Requestor: user:ben.miles:c4c76
URL: http://www.eden.idsoftware.com/builds/binaries/20161219-101605-purple-viridian
Relevant CLs: 467688
Package:
Map Set: BFG Playtest, SP Campaign back up, SP Campaign, Demo, sp_min_unified, SP Playtest, sp_campaign, Unified IHV SP, First 3, Arcade Mode
Requestor: user:pipeline:forge
URL: http://www.eden.idsoftware.com/builds/packages/20161122-000011-granite-countersink
Relevant CLs: 466266
Disc Layout:
Candidate:
Disc Number: 1
2017-03-30T02:11:02.273+02:00 LOG: Retrieved build information
reading 7641 sound events
reading 59 sound busses
reading 57 sound states
reading 6 sound switches
done reading 6 sound events longest is 64
----- Initializing Decls -----
349 types, 0 declSource in 0 ms
Failed to read remaplist.md6remap
Reading strings/english.lang as UTF-8
28341 strings read
Initializing class hierarchy------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
EnumerateDownloadableContent: G:\steam\steamapps\common\DOOM\dlc
NetGetVersionChecksum - checksum : 3051714094
DownloadPlatformTitleStorage: Loaded
NetGetVersionChecksum - no change
idMPServerCloudInstance is disabled
0: Hangszórók (Realtek High Definition Audio)
2 channels, 48000 Hz
Default Console Device, Multimedia Device, Communications Device, and Game Device
1: Realtek Digital Output (Realtek High Definition Audio)
2: Realtek Digital Output(Optical) (Realtek High Definition Audio)
Using audio device for voice 0
----- Initializing Sound System ------
initial.pck stream package loaded
audio bank 'doom_mp.bnk' excluded based on game mode SP
audio bank 'doom_weapon_mp.bnk' excluded based on game mode SP
streamed_sfx.pck stream package loaded
streamed_sfx_dlc1.pck stream package loaded
streamed_sfx_dlc2.pck stream package loaded
streamed_sfx_dlc3.pck stream package loaded
English(US)/streamed_vo.pck stream package loaded
English(US)/streamed_vo_dlc1.pck stream package loaded
English(US)/streamed_vo_dlc2.pck stream package loaded
English(US)/streamed_vo_dlc3.pck stream package loaded
sound system initialized.
---------- ResetPersistHeap ----------
Global heap: Can't HeapWalk() in this configuration
Map heap : GlobalMemoryStatus: 11.96GB dwTotalPhys
GlobalMemoryStatus: 7.73GB dwAvailPhys
GlobalMemoryStatus: 4.23GB used phys
GlobalMemoryStatus: 2.41GB used virtual
0.0 seconds to start load screen video
0.0 seconds to init the hdc
0.0 seconds to prep vts
0.0 seconds to figure out container
0.4 seconds to read 12612k table header
Resources skipped by layer tests: 0
0.0 seconds to determine and prepare 1266 resources need loaded
0.0 seconds was durango PLM Events
0.0 seconds to allocate and defer load 1311 resources
Load 1266 resources using 1311 of 76928 total resource files, 1 streamed
0.0 seconds to start the BGL
async load success id -2103502525 : doom_initial.bnk
--------- EndBackgroundLoads() ----------
IO: 28 seeks, 16 reads, 67MB, 20.6MB/s
Buffers recalled: 14
Read sleep msec: 0
Decompress sleep msec: 0
Foreground sleep msec: 3050
Total msec: 3259
0.0 seconds spent updating the progress bar
0.0 seconds spent loading resources
0.1 seconds spent skipping and waiting
3.7 seconds to preload resources
0 : preload model count
------- Initializing renderSystem parm states --------
Start time of bink video video\Boot_Sequence.bik in ms: 23779
LOAD VIDEO
0.7 seconds to start load screen video
0.0 seconds to read 12612k table header
0.0 seconds to determine and prepare 26476 resources need loaded
0.2 seconds to allocate and defer load 34704 resources
Load 26476 resources using 34704 of 76928 total resource files, 0 streamed
async load success id -1012987315 : doom_ambience.bnk
hair: Could not get fragment uniform _fa_freqHigh while loading renderProg:hair
hairtrans: Could not get fragment uniform _fa_freqHigh while loading renderProg:hairtrans
async load success id 1182951009 : doom_dlc1_sfx.bnk
particle/hud/magicglassnoflicker: Could not get fragment uniform _fa_freqHigh while loading renderProg:particle/hud/magicglassnoflicker
particle/screen/slomosurfacedistort: Could not get vertex uniform _va_freqLow while loading renderProg:particle/screen/slomosurfacedistort
particle/screen/slomosurfacetrans: Could not get vertex uniform _va_freqLow while loading renderProg:particle/screen/slomosurfacetrans
async load success id -468562510 : doom_dlc2_sfx.bnk
async load success id 754387463 : doom_dlc3_sfx.bnk
async load success id -270827267 : doom_effects.bnk
snaplaserbeam: Could not get fragment uniform _fa_freqHigh while loading renderProg:snaplaserbeam
async load success id -832717006 : doom_footsteps.bnk
G:\steam\steamapps\common\DOOM\base\generated\decls\renderProg\snapmaplitglassskybox_triplanar.decl(8): warning : Bad term 'sortBackground' while loading renderProg:snapmaplitglassskybox_triplanar
G:\steam\steamapps\common\DOOM\base\generated\decls\renderProg\snapmaplitglassskybox_triplanar.decl(8): warning : Unknown program type: + while loading renderProg:snapmaplitglassskybox_triplanar
parse error while loading renderProg:snapmaplitglassskybox_triplanar
sobelfilter_scan: Could not get fragment uniform _fa_freqLow while loading renderProg:sobelfilter_scan
transsortglare: Could not get fragment uniform _fa_freqHigh while loading renderProg:transsortglare
async load success id -178982497 : doom_items.bnk
No address, error: 487
DOOMx64.exe @ 0x40ebad1d( ) + bytes () : GetGameSystemInterface( )
DOOMx64.exe @ 0x40e22fc1( ) + bytes () : GetGameSystemInterface( )
DOOMx64.exe @ 0x40e13b4d( ) + bytes () : GetGameSystemInterface( )
DOOMx64.exe @ 0x40e870e7( ) + bytes () : GetGameSystemInterface( )
DOOMx64.exe @ 0x40c4ab98( ) + bytes () : GetGameSystemInterface( )
DOOMx64.exe @ 0x40c36c8d( ) + bytes () : GetGameSystemInterface( )
DOOMx64.exe @ 0x40bf9381( ) + bytes () : GetGameSystemInterface( )
DOOMx64.exe @ 0x40c1ce35( ) + bytes () : GetGameSystemInterface( )
DOOMx64.exe @ 0x40c40ede( ) + bytes () : GetGameSystemInterface( )
DOOMx64.exe @ 0x40c3c9b8( ) + bytes () : GetGameSystemInterface( )
DOOMx64.exe @ 0x40c0b00f( ) + bytes () : GetGameSystemInterface( )
DOOMx64.exe @ 0x3f8cf1a9( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
DOOMx64.exe @ 0x40e70b9b( ) + bytes () : GetGameSystemInterface( )
kernel32.dll @ 0x76f059cd( ) + bytes () : BaseThreadInitThunk( )
ntdll.dll @ 0x7713a2e1( ) + bytes () : RtlUserThreadStart( )
FATAL ERROR: Loading unverified resource. Verify files with Steam or set 'devMode_enable' to allow unverified resources: resource file G:\steam\steamapps\common\DOOM\base\gameresources.resources
Set cvar 'devMode_enable' to enable Dev Mode.
Dumped console text to C:\Users\johnny\Saved Games\id Software\DOOM\base\ErrorLog_03-30-2017__02-11-38am.txt.idRenderSystem::Shutdown()
Shutting down OpenGL subsystem***************************
Set cvar 'devMode_enable' to enable Dev Mode.***************************
Callstack Function(desc) Line Bytes File Process Address
GetGameSystemInterface() ... + 0x40d5ae84 DOOMx64.exe
GetGameSystemInterface() ... + 0x40326a9c DOOMx64.exe
GetGameSystemInterface() ... + 0x403348be DOOMx64.exe
GetGameSystemInterface() ... + 0x4033aca8 DOOMx64.exe
GetGameSystemInterface() ... + 0x4033b7b1 DOOMx64.exe
GetGameSystemInterface() ... + 0x40e70b4d DOOMx64.exe
BaseThreadInitThunk() ... + 0x76f059cd kernel32.dll
RtlUserThreadStart() ... + 0x7713a2e1 ntdll.dllRegister Info
EDI: 0x0000000000000780 ESI: 0x0000000013910620 EAX: 0x0000000000000001
EBX: 0x0000000000000000 ECX: 0x0000000002699AB0 EDX: 0x000000005AE531C0
EIP: 0x0000000140D5AE84 EBP: 0x0000000000000000 SegCs: 0x0000000000000033
EFlags: 0x0000000000010206 ESP: 0x000000002D27F650 SegSs: 0x000000000000002BException Info
ExpCode: 0xC0000005 (Access Violation)
ExpFlags: 0
ExpAddress: 0x0000000140D5AE84Build & Runtime Info
User: johnny
Version: 20161219-101605-purple-viridian
File Path: G:\steam\steamapps\common\DOOM\DOOMx64.exe
System Time: 3/30/2017 02:11:40
Build String: 20161219-101605-purple-viridian
VT File Path:
VMTR Override: generated/pagefiles
Launch Command: G:\steam\steamapps\common\DOOM\DOOMx64.exe "+com_gameMode 1"Memory Info
In Use: 38%
MB Physical RAM: 12248
MB Physical Free: 7534
MB Paging File: 24494
MB Paging Free: 17225
MB User Address: 8388608
MB User Free: 8385818CPU Info
Num Packages: 1
Num Cores: 4
Num Logical: 8
CPU ID: Generic
CPU MHz: 3410 -
PsycHo88
Nekem meg van már egy ideje a játék de még jóformán el sem tudtam kezdeni !
Hál istennek nagyon segítő készek vagytok !!
Remélem hamarosan ki derül mi a hiba !
PsycHo88
Rendben !! Köszönöm szépen!! Haza értem meg nézem !
PsycHo88
Nagyon sok infó van !! Ki fotózom n3ked majd !!
Sajnos én nem tudok írni az id-nek
Nem tudom hogy hol kell és nem tudok olyan jól angolul írni !
PsycHo88
Rendesen kiléptem a játékból és utána még Bf1-eztm . de nem néztem hogy a steam szinkronizált e vagy sem :S
Hogy tudom meg nézni ?
PsycHo88
Meg nézem ! Ezt hova másoljam be ?
"+com_gameMode 1"
PsycHo88
Nekem a cod bo2 volt olyan hogy csak a c-re tudtam telepíteni más hol nem indult el !
PsycHo88
Gondoltam arra is hogy mivel még nekem z68 as lapom van nem kompatibilis a win10 és ezért küld annyi hiba üzenetet !
De utánna gondolkodtam hogy win7 nél kezdte el .
PsycHo88
Akkor csinálok egy vírus keresést a vinyókon !
És szortírozok ! Ami nem kell azt törlöm !
És az egyik vinyón csak a steam és az origin lesz rajta plus a játékok . meg nézem így !
Érdekes hogy a bechmarkok végig mennek hiba nélkül :\
PsycHo88
Ezt már meg csintáltam de semmi !
Most azt fogom csinálni , hogy az ssd helyett a vinyóra rakok egy win10 és arra telepítem a játékot ! A vinyó 1 tb ráfér ! Már kíváncsi vagyok hogy mi fog történni !
Kb 2 hete vettem a játékot ! Akkor szépen ment 2 napig !
Win 7 64bit volt fent aztán egyszer csak ki írta a bibánt amit be raktam ide . -
PsycHo88
Köszönöm !! Nézem !
PsycHo88
Az a baj hogy az SSD-re nem tudom fel rakni a doom-ot mert csak 128gb. amit a win10 van .
PsycHo88
Persze ! Teljes win 10 formázással !
nem wifin van a gép !
PsycHo88
Meg csináltam de semmi nem jó sötét kép aztán megint az a hiba.
PsycHo88
Köszönöm este amit haza érek meg nézem !
PsycHo88
Igen már az meg volt fríss telepítés !
Fel rakom indítom és ez fogad !
PsycHo88
Köszönöm !!
Magyaron van ! És ugyan az fel megy 57mb/s és egyszer csak 0mb/s
Utánna ki írja hogy Várakozik !?
PsycHo88
Köszönöm !
És az mitől lehet hogy elindítom a letöltést tölti egy darabig utána hirtelen leáll ! de ha újra indítóm a letöltés megy tovább
PsycHo88
Szóval ezt írja :
FATAL ERROR: Loading unverified resource. Verify files with Steam or set 'devMode_enable' to allow unverified resources: resource file G:\Játékok !!!\doom\steamapps\common\DOOM\base\gameresources_003.patch
- Kicombosította az M5-ös SoC-családot az Apple
- E-roller topik
- PayPal
- AI, GitHub Copilot, Claude, Gemini
- Telefon felvásárlás!! Honor 200 Lite, Honor 200, Honor 200 Pro, Honor 200 Smart
- Lenovo ThinkPad X1 Carbon Gen 10 - 27% ÁFÁS (0332)
- 227 - Lenovo LOQ (15IRX10) - Intel Core i7-13650HX, RTX 5060
- BESZÁMÍTÁS! 64GB G.Skill Trident Z Neo 3600Mhz DDR4 memória garanciával hibátlan működéssel
- ÁRGARANCIA! Épített KomPhone i5 12400F 16/32/64GB RAM RTX 5050 8GB GAMER PC termékbeszámítással
