npera
Nova, szerintem ez lesz a következő goggle, ami számodra egy valós előrelépés lenne.
HDZero dolgozik egy saját fejlesztésű rendszeren.Carl Zhou
Divimath HDZero GroupI am working on a goggle with an integrated HDZero:
- Unprecedented 4ms optimized glass-to-glass fixed latency
- Next generation ultra-thin optical engine (0.8in thick)
- 1920x1080p 2000 nits OLED
- 43° FOV (16:9), 38° FOV (4:3), software scalable to lower FOV
- HDMI Input
. Compatible with all alternative HDMI-based digital systems
. Excellent sharpness for simulator use
. So sharp, it works well as a PC monitor HMD (it's been fun to test with)
. Use as mobile phone external display for portable cinema
- HDMI Output to share HDZero feed with others
- Analog Input to be compatible with all existing analog modules
- Modular accessory mounting rail system
. Mount antennas
. Mount analog modules
. Use your imagination to customize the goggle for your use
- Power button (EDITED)
- ELRS Backpack support (EDITED)
- Microphone to record ambient sound in DVR (EDITED)
- DC (2S-6S)The first batch will be ready for beta testers in May.
As I usually ask for, I need your input to make the best it can be. I am proud that HDZero is backed by the community. We make this goggle because we care about the FPV community deeply. This will be YOUR goggle.
Thank you.
- Apple iPhone 12 Pro 256GB, Kártyafüggetlen, 1 Év Garanciával
- Hatalmas Akció a Készlet Erejéig & Ingyenes Szállítás - Új, Bontatlan AMD Ryzen 9 7950X3D - Cégtől
- Xiaomi Redmi Note 12 Pro+ 5G 256GB, Kártyafüggetlen, 1 Év Garanciával
- Eladó egy ballagási ajándéknak szánt iPhone 12 purple 64 Gb telefon.
- Sony KD-55X80KAEP 55" 4K Ultra HD Smart LED TV - Bontott Csomagolás
