Keresés
  • MaUser
    válasz XeeN #7 üzenetére
    Találtam egy ilyen leírást:
    Whao, you guys want FarCry game to support COOP Multiplay? Well I wanted that to, and maybe CryTec does not know it, but They Do support Coop, you only have to make some smaller changes to you FarCry game to get it!
    If you don´t already know it, its kind of easy to make
    FarCry to support COOP (COOPERRATIVE play).
    I done it, so, now when I want to host a MultiPlayer game,
    I can select ASSULT, TDM, FFA, and COOP.
    How to do this?
    1: First of all, you need to do some updates in your ''Scripts1.pak''
    in the ''FarCryFCData'' directory.
    a) Open the Scripts1.pak file with your WinRar.
    b) Open the Multiplayer directory in the file.
    c) Find the file ''AvailableMods.lua'' and doubleclick it to open.
    d) Make changes to it, so it looks like this:
    AvailableMODList=
    ASSAULT={ team=1, respawntime=1, mission=''ASSAULT'', },
    FFA= { team=0, respawntime=0, mission=''FFA'', },
    TDM= { team=1, respawntime=0, mission=''TDM'', },
    COOP= { team=0, respawntime=0, mission=''COOP'', },
    e) Save it in the Scripts1.pak
    f) NOW, next time you start MultiPlayer, you CAN select COOP!
    2: To REMAKE (original singelplayer) maps for COOP, this is how I did it!
    a) Make a new folder in your ''FarCryLevels'' directory for this COOP map.
    b) Copy the Singelplayer map files (include everything) to your COOP map folder.
    Example: I want to make FarCry singelmission called PIER to get ready for COOP play.
    a) I make a folder called: Coop_PIER
    b) I copy all files and folders from original FarCryLevelsPier to my new Coop_Pier folder
    3: NOW, time to open your FarCry Sandbox editor!
    a) Open the ''FarCryLevelsCoop_Pierpier.cry'' for editing.
    b) Next, click the topmeny option ''Mission'', select ''Properties'' in the pulldown meny.
    c) The Script file is still pointing to the original ''PIER.LUA'' in ''LevelsPIER''..select Browse.
    d) Browse to your ''Coop_Pier'' folder, select the ''Pier.lua'' file there.
    4: Select topmeny option ''Mission'' again, in the pulldown list, select ''RENAME''
    a) Rename the mission to ''COOP''
    b) SAVE the map!
    5: NOW, you can start your FarCry game, go MultiPlay, select COOP, and run
    mission PIER, in COOP mode!
    Comments: I hope this is understandable, my English typing sucks..
    Problems: a) I had to take away ALL exept ONE or Two Respawn points in the Coop Map, because
    in Mulitplay, the other player, respawned at a point where he could not go anywere
    because of locked doors, or other objects in the way.
    b) The map, called Swamp, were Valeri is involved I could NOT make work in Multiplayer
    at all, dont know why, mabe its because Valerie is that much involved.
    Ebből, csak azt nem értem miért kell átnevezni a pályát, ha már úgyis máshol van:F
  • MaUser
    válasz XeeN #2 üzenetére
    Coop-ot hogyan és milyen megszorításokkal lehet?
