Speeedfire
Speeedfire
#2388
Most nézem, hogy csak 15"-t ír ki nekem...mikor 17"-os.
Speeedfire
[speeedfire@localhost ~]$ sudo monitor-edid
EISA ID: SAM01ac
EDID version: 1.3
EDID extension blocks: 0
Screen size: 31.2 cm x 23.4 cm (15.35 inches, aspect ratio 4/3 = 1.33)
Gamma: 2.2
Analog signal
Max video bandwidth: 180 MHz
HorizSync 30-85
VertRefresh 50-160
# Monitor preferred modeline (85.0 Hz vsync, 68.7 kHz hsync, ratio 4/3, 83 dpi)
ModeLine "1024x768" 94.5 1024 1072 1168 1376 768 769 772 808 +hsync +vsync
[speeedfire@localhost ~]$ -
Speeedfire
csendes
#2385
Anno én is arra gondoltam, mivel mintha az xorg feliírta volna. Legalább is a logban az volt.
mmap /dev/mem: Permission denied
[speeedfire@localhost ~]$Sosincs szerencsém a linux desktopokkal.
Kisebb felbontáson is csak 85Hz a max, valami miatt mintha le lenne korlátozva az egész...
Speeedfire
csendes
#2382
[speeedfire@localhost ~]$ sudo xrandr
[sudo] password for speeedfire:
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 1600 x 1600
DFP1 disconnected (normal left inverted right x axis y axis)
DFP2 disconnected (normal left inverted right x axis y axis)
CRT1 connected 1024x768+0+0 (normal left inverted right x axis y axis) 312mm x 234mm
1024x768 85.0*+ 75.0 70.1 60.0
1280x1024 75.0 60.0
1280x960 75.0 60.0
1280x800 75.0 60.0
1152x864 75.0 60.0
1280x768 74.9 59.9
1280x720 60.0
800x600 85.1 72.2 75.0 70.0 60.3 56.2
720x480 60.0
640x480 85.0 75.0 72.8 60.0
CRT2 disconnected (normal left inverted right x axis y axis)
TV disconnected (normal left inverted right x axis y axis)
CV disconnected (normal left inverted right x axis y axis)
[speeedfire@localhost ~]$[speeedfire@localhost ~]$ cat /etc/X11/xorg.conf
# Xorg configuration created by livna-config-display
Section "ServerLayout"
Identifier "single head configuration"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules/extensions/catalyst"
ModulePath "/usr/lib/xorg/modules"
EndSection
Section "ServerFlags"
Option "AIGLX" "on"
EndSection
Section "InputDevice"
# keyboard added by system-config-display
Identifier "Keyboard0"
Driver "kbd"
Option "XkbModel" "pc105"
Option "XkbLayout" "hu"
EndSection
Section "Monitor"
Identifier "Monitor0"
ModelName "Samsung SyncMaster 796MB/796MBplus"
HorizSync 30.0 - 85.0
VertRefresh 50.0 - 160.0
ModeLine "1024x768_100.00" 113.3 1024 1096 1208 1392 768 769 772 814 -hsync +vsync
Option "dpms"
# 1024x768@100.00 Hz (GTF) hsync: 81.40 kHz; pclk: 113.31 MHz
EndSection
Section "Device"
Identifier "Videocard0"
Driver "fglrx"
Option "OpenGLOverlay" "off"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
Modes "1024x768_100.00"
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
Speeedfire
csendes
#2379
Nekem KS17CNJBK van. Nekem 85hz-en enyhén vibrál, de mint fentebb is írtam lehet azért érzem úgy mert már hozzászoktam a 100hz-hez. A modlinemat anno valami programmal generáltam. Fentebb már Vladi linkelte az ubis próbálkozásomat akkor sem jött össze mindig visszaállt 85hz-re. [link]
Hivatalosan a monitorom 1024@104Hz-et bír.
Nekem modline-nal sem megy.
B@ldrick: Úgy néz ki csak én vagyok akkor ennyire szerencsétlen...
Nekem is 3 csík versenyzik mióta fent van az ati driver.
Speeedfire
Látom te sem nagyon tudsz rá mit mondani, tényleg az van amit Kendek is mondott itt az ideje venni egy lcd-t!
Speeedfire
Speeedfire
#2370
Utólag is elnézést a sok post miatt.
Innen beszereztem a rendes verziót.
[speeedfire@localhost system-config-display]$ sudo yum install python
Loaded plugins: langpacks, presto, refresh-packagekit
Adding hu_HU to language list
Setting up Install Process
Package python-2.7-8.fc14.1.i686 already installed and latest version
Nothing to do
[speeedfire@localhost system-config-display]$ sudo system-config-display --set-vsync=100 -v
/etc/X11/xorg.conf beállítás fájl beolvasása
Próbálkozás u'ATI Technologies Inc RV670PRO [Radeon HD 3850]' kártyával
/etc/X11/xorg.conf fájlt mentem mint /etc/X11/xorg.conf.backup
A beállítást mentem mint /etc/X11/xorg.conf
Törlöm a régi /etc/X11/X hivatkozást
Csinálok új /etc/X11/X hivatkozást
[speeedfire@localhost system-config-display]$ sudo init 6cd system-config-display
sudo make
gcc nincs fent
yum install gcc
sudoa make
nincs python...holott van[speeedfire@localhost system-config-display]$ sudo make
running build
running build_ext
building '_pyrandr' extension
gcc -pthread -fno-strict-aliasing -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m32 -march=i686 -mtune=atom -fasynchronous-unwind-tables -D_GNU_SOURCE -fPIC -fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m32 -march=i686 -mtune=atom -fasynchronous-unwind-tables -D_GNU_SOURCE -fPIC -fwrapv -fPIC -I/usr/include/python2.7 -c pyrandr/_pyrandr.c -o build/temp.linux-i686-2.7/pyrandr/_pyrandr.o
pyrandr/_pyrandr.c:4:20: fatal error: Python.h: Nincs ilyen fájl vagy könyvtár
compilation terminated.
error: command 'gcc' failed with exit status 1
make: *** [pyrandr] Error 1
Nothing to do[speeedfire@localhost ~]$ system-config-display --set-vsync=100 -v
[speeedfire@localhost ~]$ system-config-display: command not found
[speeedfire@localhost ~]$ sudo yum search system-config-display
Warning: No matches found for: system-config-display
No Matches found
[speeedfire@localhost ~]$ sudo yum install git
[speeedfire@localhost ~]$ sudo git clone git://git.fedorahosted.org/git/system-config-display.git
[speeedfire@localhost ~]$ sudo system-config-display --set-vsync=100 -v
sudo: system-config-display: command not foundMost akkor mi van? Még sem rakta fel?
Elvileg megvan, ha sikerül a 100hz tényleg megyek felétek a sörrel. Vagy rokonomat megkérem keressen meg téged.
Ez nem jött be.
[ Módosította: Grafiqs ]
Speeedfire
Speeedfire
#2366
Elvileg sikerült a művelet minden parancsot megevett most.
A glxgear szépen prögeti a fogaskerekeket és a vga venti sem süvít már.
A 100hz-et megint megpróbálom, remélem most már fedora alatt sikerül majd.
Speeedfire
Boot.log-ban ez van:
Checking for module fglrx.ko: [ OK ]
Enabling the catalyst driver: Traceback (most recent call last):
File "/usr/sbin/catalyst-config-display", line 29, in <module>
import livnaConfigDisplay.ConfigDisplay
File "/usr/lib/python2.7/site-packages/livnaConfigDisplay/ConfigDisplay.py", line 29, in <module>
import xf86config
File "/usr/lib/python2.7/site-packages/xf86config.py", line 1, in <module>
import ixf86config
ImportError: /usr/lib/python2.7/site-packages/ixf86configmodule.so: undefined symbol: xstrtokenize
[FAILED]Kernelből a legfrisebb van fent. Sima kmod lett telepítve rá.
Mondjuk mióta a repo-ba beraktam az rpmfusion-t még nem frissítettem, gyors frissítem aztán kiderül, hogy segít-e rajta.Más: Mitől lehet, hogy ha rá van dugva a vga-ra a tv-out akkor csak villog a kép? Ha nincs akkor megfelelően megjelenik minden a monitoron?
Esetleg fedora alatt van lehetőség 100hz-en hajtani a monitort? Eddig még 1 distro alatt sem sikerült nekem.
Speeedfire
rokefeller
#2362
Msi 3850 lenne a kicsike.
Vladi: Kms-t, hogy tudom kikapcsolani, egyáltalán mi az?
Azóta már fent van az rpmfusion-ös repo meg minden. Utána csinálta azt, hogy az egyik modulban gondot jelzett. -
Speeedfire
rokefeller
#2360
Live-ról raktam fel. Azt hiszem anno nem is találtam mást.
Egyelőre nem jött össze az ati, majd holnap nekiesek még. Ott van a bibi mikor engedélyezni akarom a catalyst drivet, valami nem stimmel neki az egyik fájlban....
Speeedfire
rokefeller
#2358
És már fent is van.
Mostmár kicsit több beállítás van gui alatt is, remélem összejön az ati driver is.
Speeedfire
rokefeller
#2356
Repo folyamatban...
A másikat viszont nem találom.
system-config-services -
Speeedfire
rokefeller
#2353
Hát nekem az admin rész alatt ilyen nincs, ezt neked alapból berakta?
Ellenben sikerült teljesen gallyra vágni a rendszert.
/usr/share/ati alatt lévő fglrx_uninstall.sh fájllal leszedtem a drivert, majd az /etc/X11 alatt az xorg fájlt töröltem. Reboot után meg kernel pánic volt.
Speeedfire
rokefeller
#2351
Ezt a gui-t merre találom meg?
Más:
Ma nagyon nekiestem az asztali gépnek is. Mondom ideje lenne már felrakni rá az ati drivert is. Le is szedtem a legújabbat, felraktam, majd reboot után. Alul ment 3 csík, sötét kék, világos kék, meg fehér. Majd villogott párszor a monitor és megállt a kép itt. Átmentem másik "munkaterületere" beléptem root-ként majd az xorg fájlt visszaállítottam, ismét reboot, most viszont meg színes csíkos minden. Mit lehetne kezdeni vele? Illetve hogyan lehetne megfelelően felrakni a megfelelő ati drivert? -
Speeedfire
[speeedfire@localhost ~]$ sudo iptables -L -v
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
pkts bytes target prot opt in out source destination
21 10082 ACCEPT all -- any any anywhere anywhere state RELATED,ESTABLISHED
0 0 ACCEPT icmp -- any any anywhere anywhere
2 120 ACCEPT all -- lo any anywhere anywhere
0 0 ACCEPT tcp -- any any anywhere anywhere state NEW tcp dpt:ssh
38 8591 REJECT all -- any any anywhere anywhere reject-with icmp-host-prohibited
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
0 0 REJECT all -- any any anywhere anywhere reject-with icmp-host-prohibited
Chain OUTPUT (policy ACCEPT 41 packets, 5560 bytes)
Vladi: Felraktam az openssh-server-t majd gondoltam alapból engedi is majd a portot, mint debian alatt, de nem.
Se win, se linux alól nem tudok csatlakozni rá, mindig visszadob. -
Speeedfire
Lehet én vagyok a béna, de a beépített tűzfal programmal nem tudok sokmindent kezdeni.
Hiába engedélyezem rajta az ssh-t, nem alkalmazza pedig elvileg kellene. Iptables-ben meg is jelenik, de nincs portszám és mindenhova engedélyezni.[speeedfire@localhost ~]$ sudo iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
ACCEPT icmp -- anywhere anywhere
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:ssh
REJECT all -- anywhere anywhere reject-with icmp-host-prohibited
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
- Asztalos klub
- Milyen routert?
- Seed szerver topic
- Apple iPhone 13 Pro Max - őnagysága
- AliExpress tapasztalatok
- Csillagfelhő áztatná el Elon Musk űrkarneválját
- BESZÁMÍTÁS! ASRock B760 i5 14600KF 32GB DDR5 500GB SSD RX 9070 16GB be quiet! Pure Base 500DX 750W
- AKCIÓ! Sony PlayStation 4 PRO 1TB fekete játékkonzol garanciával hibátlan működéssel
- Zotac / Inno3D RTX 3080 Ti // Számla // Garancia //
- MacBook Neo 512GB Indigó (3év Garancia) - Bontatlan
- 2019 MacBook Air Retina 13" i5 8GB 128GB Rose Gold
