deepwell
· Missing Game Sounds
If you experience missing game sounds throughout Freelancer then a different audio codec is probably being used rather that the one provided by Freelancer.
· Please follow these steps if some sounds and speech are still missing after installation:
· Uninstall any 3rd party codec pack or the Nimo Codec pack from your system.
· Uninstall Freelancer.
· Go to the following directory, C:WINDOWSsystem32 and delete the file “l3codecp.acm”. If there happens to be another file named “l3codeca.acm”, delete this too.
· If your system is Windows 98 or ME, open the system.ini file located in your system folder; C:WINDOWSSYSTEM. Delete ONLY the line that starts with “msacm.l3acm=”. In the case of the Nimo codec pack, this will read “msacm.l3acm=l3codecp.acm”
· If your system is Windows 2000 or XP, open the system registry editor (regedit) from the RUN command window.
· Locate and delete the following key: HKLMSOFTWAREMicrosoftWindowsNTCurrentVersionDrivers32msacm.l3acm
· Load the Freelancer installation CD and locate the REDIST folder. Within the REDIST folder, double click on the file named “WMFADist.exe” and follow on-screen instructions.
· Install Freelancer. -
deepwell
- Futás, futópályák
- Pedzegeti az új Xbox irányát a Microsoft
- Motoros topic
- Óra topik
- Horgász topik
- Projektor topic
- ÁRGARANCIA!Épített KomPhone i7 14700KF 32/64GB RAM RTX 5070 Ti 16GB GAMER PC termékbeszámítással
- Lenovo Thinkcentre M920t Tower/ M920s SFF / számla, garancia
- Honor 200 / 8/256GB / Kártyafüggetlen / 12Hó Garancia
- Lenovo T14S Thinkpad FHD IPS i5-1135G7 16GB RAM 256GB SSD Intel Iris XE Graphics Win11 Pro Garancia
- Beszámítás! Apple Mac Mini 2020 M1 8GB 512GB számítógép garanciával, hibátlan működéssel
