Keresés
  • riki12
    válasz bishopx2 #1 üzenetére
    hali mindenki lenn egy kérdésem vedtem most egy GALAXY 9800 gt xtreme tuner videokarit
    és kaptam hozá egy cd amivel lehet huzni a video karit
    és az lenne a kérdésem vele nem tom manualisra rakni a ventilátor sebbeségét
    és auto meg naon felmelegszik és meg lehet vele csinálni
    és angolulezt irja ki amikor maunalra akarom rakni
    :::, Flash BIOS
    - How does the Flash BIOS works:
    Flash BIOS is a handy tool that comes along with backup BIOS. In case the working BIOS is failed, you could be easily and safely to re-flash the failed BIOS with a few steps.
    How to flash the BIOS file:
    When the working BIOS is corrupted, you will need to restart your computer and follow the steps at below to restore a new BIOS:
    1. When the system boot up, press the “Restart” button or “ctrl+alt+del” within 10 seconds, then it will start up with working under the “Backup BIOS” mode of the graphics card.
    2. Under Windows platform, go to download the “update BIOS” from http://www.galaxytech.com/support_drs.asp to your PC.
    3. Open the windows of Xtreme Tuner software
    4. Press the “Flash BIOS” button and locate the directory that you have saved the “New BIOS”, then run it. (We highly suggest you read the readme file that comes along with the update BIOS first).
    nem értem mit akar ez jelenteni
    HA TUD VALAKI AKKO SEGITSEN
