tierbatyo
Erre valaki?
* Caching service dependencies ...
* Service 'firehol' already provided by 'firewall'!;
* Not adding service 'shorewall'... [ ok ]
Feltettem a firehol-t, meg a shorewallt próbának, aztán leszedtem, viszont itt még látja őket. Ezeket hol ellenőrzi? -
tierbatyo
Parancsolj:
# === ATI device section ===
Section ''Device''
Identifier ''ATI Graphics Adapter''
Driver ''fglrx''
# ### generic DRI settings ###
# === disable PnP Monitor ===
#Option ''NoDDC''
# === disable/enable XAA/DRI ===
Option ''no_accel'' ''no''
Option ''no_dri'' ''no''
# Option ''RenderAccel'' ''yes''
# === misc DRI settings ===
Option ''mtrr'' ''off'' # disable DRI mtrr mapper, driver has its ow
n code for mtrr
# ### FireGL DDX driver module specific settings ###
# === Screen Management ===
Option ''DesktopSetup'' ''0x00000000''
Option ''MonitorLayout'' ''AUTO, AUTO''
Option ''IgnoreEDID'' ''off''
Option ''HSync2'' ''unspecified''
Option ''VRefresh2'' ''unspecified''
Option ''ScreenOverlap'' ''0''
# === TV-out Management ===
Option ''NoTV'' ''yes''
Option ''TVStandard'' ''NTSC-M''
Option ''TVHSizeAdj'' ''0''
Option ''TVVSizeAdj'' ''0''
Option ''TVHPosAdj'' ''0''
Option ''TVVPosAdj'' ''0''
Option ''TVHStartAdj'' ''0''
Option ''TVColorAdj'' ''0''
Option ''GammaCorrectionI'' ''0x05715c57''
Option ''GammaCorrectionII'' ''0x00b0000b''
# === OpenGL specific profiles/settings ===
Option ''Capabilities'' ''0x00000000''
# === Video Overlay for the Xv extension ===
Option ''VideoOverlay'' ''on''
# === OpenGL Overlay ===
# Note: When OpenGL Overlay is enabled, Video Overlay
# will be disabled automatically
Option ''OpenGLOverlay'' ''off''
# === Center Mode (Laptops only) ===
Option ''CenterMode'' ''off''
# === Pseudo Color Visuals (8-bit visuals) ===
Option ''PseudoColorVisuals'' ''off''
# === QBS Management ===
Option ''Stereo'' ''off''
Option ''StereoSyncEnable'' ''1''
# === FSAA Management ===
Option ''FSAAEnable'' ''no''
Option ''FSAAScale'' ''1''
Option ''FSAADisableGamma'' ''no''
Option ''FSAACustomizeMSPos'' ''no''
Option ''FSAAMSPosX0'' ''0.000000''
Option ''FSAAMSPosY0'' ''0.000000''
Option ''FSAAMSPosX1'' ''0.000000''
Option ''FSAAMSPosY1'' ''0.000000''
Option ''FSAAMSPosX2'' ''0.000000''
Option ''FSAAMSPosY2'' ''0.000000''
Option ''FSAAMSPosX3'' ''0.000000''
Option ''FSAAMSPosY3'' ''0.000000''
Option ''FSAAMSPosX4'' ''0.000000''
Option ''FSAAMSPosY4'' ''0.000000''
Option ''FSAAMSPosX5'' ''0.000000''
Option ''FSAAMSPosY5'' ''0.000000''
Option ''KernelModuleParm'' ''agplock=0''
# === Misc Options ===
Option ''UseFastTLS'' ''0''
Option ''BlockSignalsOnLock'' ''on''
Option ''UseInternalAGPGART'' ''yes''
Option ''ForceGenericCPU'' ''no''
BusID ''PCI:1:0:0'' # vendor=1002, device=4e48
Screen 0
EndSection -
tierbatyo
Szerintem azért az ATI driver mizéria kicsit túl van misztifikálva.
Én egyszer beállítottam és azóta megy. Mondjuk érdekes módon 7.0-s Xorg-gal eddig minden ATI driver ment, 6.8-assal meg csak a régebbiek. -
tierbatyo
kerti008
#1391
Én nem ajánlanám így az emerge-t, mert a make.conf-ban attól még x86 a keywords és a legközelebbi emerge -uD world-nél újra a stabilat teszi fel. Ha így teszel fel valamit, akkor szerintem emerge -pvt csomagnév és amiket kiír, hogy emergelné, azokat be kell tenni az /etc/portage/packages.keywords-be, így csomagnév ~x86. Én anno írtam erre scriptet, de már nem találom.
[Szerkesztve] -
tierbatyo
Nekem /dev/hdc van az fstab-ban. Egyébként van össz-vissz egy /dev/cdrom bejegyzés, ami a /dev/hdc-re mutat. cat /proc/sys/dev/cdrom/info mit mond? Egyébként nekem volt már olyan, igaz Debian alatt, hogy bármit csináltam, nem volt hajlandó cd-nek device-t csinálni. Kernelt frissítettem, udev-et frissítettem és utána egyszer csak megjavult.
tierbatyo
kerti008
#1348
fglrxinfo mit mond? Ha nem ATI-t, hanem Mesa-t akkor nincs 3D-s gyorsításod.
xorg.conf ATI-s része:
Section ''Device''
Driver ''fglrx''
#Option ''NoDDC''
Option ''mtrr'' ''off'' # disable DRI mtrr mapper, driver has its own code for mtrr
Screen 0
EndSection -
tierbatyo
Igen. A /etc/genkernel.conf-ot nézegesd. Ott van egy olyan opció, hogy DEFAULT_KERNEL_CONFIG. De érdekes módon csak akkor hajlandó használni, ha új kernel source-szal dolgozom. Ha nem azzal, akkor az /etc/kernels-ben levőt használja, igaz nekem be van állítva SAVE_CONFIG=''yes'' . Úgyhogy ha változtatni akarsz a meglevő kernel configján, akkor --menuconfig-gal kell meghívni a genkernel-t és úgy változtatni. Ha azt csináltam, hogy simán make menuconfig és elmentettem a configot, a genkernel akkor is felülírta az /etc/kernels-belivel, ha nem mondtam make mrproper-t neki.
tierbatyo
tierbatyo
#1272
Megoldva.
Nem ártott a kernelbe beleforgatni a támogatást. ;)
kerti008: Nekem ez van az xorg.conf-ban:
Section ''InputDevice''
Identifier ''Mouse2''
Driver ''mouse''
Option ''Protocol'' ''ImPS/2''
Option ''ZAxisMapping'' ''4 5''
Option ''Name'' ''Razer Diamondback Plasma''
Option ''Buttons'' ''7''
Option ''Device'' ''/dev/input/mice''
EndSection
A görgőhöz az imps/2 protocol kell, meg a ZAxismapping-os rész. -
tierbatyo
Please help me! Nem tudom beizzítani az USB-s egeret gpm-mel. A MOUSEDEV=/dev/input/mice, a MOUSE=imps2, de nem reagál semmit. Elvileg fut a gpm hiba nélkül. Ráadásul az expat frissítés után egy csomó csomagot revdep-elni kell. Jelenleg egy félig meddig szétesett Gentoo-m van.
tierbatyo
Hm... Elindítom a startxgl scriptet: compiz cannot open DISPLAY 1. Egyenként elindítva a benne levő parancsokat: működik! ?????
tierbatyo
Én egyszeűen csak betettem USE flag-nek az aiglx-et és szokásos módon futtattam az Xgl-t. Nem néztem utána mi ez a flag.
Másik:1. Kiveszed a gconf-ot a pluginok közül a startxgl scriptben, gconf után nem töltődnek be a pluginok. Ezt valami fórumon találtam. Ekkor menni fog rendesen minden, de nem lesz autoraise, meg ilyesmik.
2. Be kell állítani a pluginok sorrendjét. gconf-editor : [link] Ekkor vissza lehet tenni a gconf-ot a start scriptbe és megy minden gyönyörűen. Különben ez utóbbi nem működött nekem sokáig, nem volt semmi effeket, ezért kellett az elsőt alkalmaznom.
[Szerkesztve] -
tierbatyo
Nem tudom, hogy alapból van-e ilyen file. Az biztos, hogy nem én hoztam létre. Mondjuk én testing hal-t használok.
Más: feltettem új compiz-t, meg engedélyeztem a theme_plain és aiglx flag-eket. Nem tudom melyik, de nekem olyan tükrözéseket csinált a desktopra, meg a betűkre, hogy öröm volt nézni.
tierbatyo
unmountol-ni tudod userként? Ha nem, akkor lehet ezzel van összefüggésben a probléma:
What has worked for most people to unmount drives as a regular user is to edit the file /usr/share/hal/fdi/policy/10osvendor/10-storage-policy.fdi, and change user to users in the line with <merge key=''storage.policy.default.mount_option.user'' type=''bool''>true</merge>. If you don't have that exact file, look for a similar file under the /usr/share/hal hierarchy. -
tierbatyo
Unmaskolták a modular X-et. Remélem ez azt jelenti, hogy az Xgl, compiz meg a többi is bekerül lassan a támogatott programok közé.
tierbatyo
Nektek megy a Direct Rendering Xgl alatt? Nekem ATI kártyával nem.
tierbatyo
Ha vazze! Nekem is a gconf volt a baj. AAAAAA. Mar ket hete jo valojaban ay egesz!
tierbatyo
Nekem is volt hasonló problémám. Legújabb glproto-t unmaskolni kell. Benne van a howto-ban is, nem túlságosan feltűntetve. If using CoffeeBuzz's overlay and >=xgl-0.0.1_alpha20060312 you must emerge glproto-1.4.6_alpha20060312 first!
Egyébként már írják is, hogy a másik overlay out of date, szerintem azt töröld és menj végig a howto-n még egyszer. -
tierbatyo
Körülnéztem és ezt találtam Nem tudom Magyarhonban hol lehet ilyesmiket kapni, de léteznek ilyenek. [link] Linux hogy állna hozzá. Nekem egy ideig a SATA vinyómat egy ideig a régi SATA driverrel kezelte és akkor mintha PATA vinyót kezelt volna /dev/hda volt. De szerintem mennie kell libata modullall is.
tierbatyo
Volt mersze valakinek feltenni a glibc 2.4-et. Annyi problémát láttam neten, hogy még nem volt merszem.
tierbatyo
dr_strange
#965
Én már csináltam a sync helyett, amikor nem volt netem, hogy a snapshotot csomagoltam ki és bizony nem gyorsabb kicsomagolni ennyi file-t, mint letölteni a sync során.
tierbatyo
Még mindig küzdök Xgl-lel és compizzal. Egyelőre ők a nyerők.
Most elvileg minden hibaüzenet nélkül indulnak, de nincs az ablakoknak fejléce. [link] Találkoztam már ilyennel régebben is, de nem emlékszem mi segített ezt megoldani. Erre valaki valami javaslatot esetleg? -
tierbatyo
Egyszer csak jó lesz mar az Xgl. Küzdök nagyon..
Most nincs hibaüzenet végre. Basszus mire rájöttem, hogy a nem CVS-ből van fenn a Mesa.... Most úgy tűnik minden jó, de ha indítok bármit nincs kerete az ablakoknak. -
tierbatyo
Nektek normálisan megy az új Mplayer. Nekem a GUI-n levő betűknél az ő, ű-t nem írja ki, meg az utánuk levő karaktereket sem. Gondolom ez is azzal lehet összefüggésben, hogy nekem nem megy az unicode-ra való átállás.
tierbatyo
Na én is felküzdöttem a 7.0-ás xorg-ot. Majd jön az XGL, meg a Compiz is. Viszont nekem nem megy az unicode. Locale:
LANG=hu_HU.iso88592
LC_CTYPE=''hu_HU.UTF-8''
LC_NUMERIC=''hu_HU.UTF-8''
LC_TIME=''hu_HU.UTF-8''
LC_COLLATE=''hu_HU.UTF-8''
LC_MONETARY=''hu_HU.UTF-8''
LC_MESSAGES=''hu_HU.UTF-8''
LC_PAPER=''hu_HU.UTF-8''
LC_NAME=''hu_HU.UTF-8''
LC_ADDRESS=''hu_HU.UTF-8''
LC_TELEPHONE=''hu_HU.UTF-8''
LC_MEASUREMENT=''hu_HU.UTF-8''
LC_IDENTIFICATION=''hu_HU.UTF-8''
LC_ALL=hu_HU.UTF-8
Normális az, hogy ot van egy iso is? Nem megy az ő betű, viszont érdekes módon az ű igen.
Konzolon még zsrabb a helyzet, az teljesen szét van esve. Ott iso-kat ír ki a locale, nem egészen értem miért. Az egészet a WIKI-s leírás alapján csináltam. -
tierbatyo
Ha gnome-t használsz, akkor ne használj ivman-t, mert összeakad a gnome automounterével a gnome-volume-manager-rel. De próbálj egy revdep-rebuild-et is, ez a gentoolkit csomagban van, ez rendbe teszi az automounter (gnome-volume-manager,ivman, stb), hal, dbus függőségeket, ha probléma lenne velük.
tierbatyo
Splash mellett nem logolja bootot.
tierbatyo
dr_strange
#775
Most nem vagyok a közelében, hogy belenézzek. De ha serial portokhoz kell, akkor lényegtelen, mert nincs eszközöm rajta. De gyanús, hogy alapból a boot-ban van. Megnbéztem tényleg a serial porthoz kell.
[Szerkesztve] -
tierbatyo
tierbatyo
#771
Kell meg az app-admin/showconsole package is. Nekem mondjuk üres a log file, még nem volt reggel időm nézegetni. Viszont ez a parallel boot az rc-ben figyelemre méltó gyorsulást eredményez. A probléma csak az, hogy a serial nem indul el. Ez pontosan micsoda, fontos? Vagy ez az a script az, ami a szokásos indulásért felel?
tierbatyo
dr_strange
#755
Igen igazából pont ezért írtam példának, mert tapasztalatom szerint nem szokott elég lenni az adott package unmaszkolása, hanem a függőségeit is kell.
tierbatyo
Pl.: gnome-ból szeretnél testing-et. echo ''gnome-base/gnome'' >> /etc/portage/packages.keywords Ez persze nem biztos, hogy elég, mert a függőségei is lehetnek testing-ben (ennél biztos), akkor azokat is be kell tenni a packages.keywords-be. Ezt kiírja az emerge gnome-nál, ha szükség van rá. Ja, és nem árt egy revdep-rebuild sem, ha testing-re állsz át, főleg udev, dbus, hal esetén.
tierbatyo
Viszont eddigi Gentoo pályafutásom alatt először sikerült maketest-tel feltenni a glibc-et.
tierbatyo
dr_strange
#736
Megnéztem egy két csomagra equery uses-t és iuse flagekként jelzi a bekapcsolt új flageket. Ezek elvileg már ott kellett lennie előbb is, cdb használattal szerintem nem stimmel valami.
tierbatyo
Fura dolgot tapasztaltam. Eddig 2.0.54-es portage-t használtam cdb-vel. Most gondoltam felteszem a 2.1-prex. Ezután emerge -uDN-re kb 60 csomagot újra akar fordítani, mondván uj USE flag van bekapcsolva.
tierbatyo
Amint hazaérek én meg is próbálom feltenni ez alapján: [link] Mi baj történhet, legfeljebb megborul a rendszer, már úgyis régen volt ilyen.
tierbatyo
Nekem baromi furcsan működik a dbus, hal, gnome-volume-manager trio. Alapból ha bejelentkezem, akkor a windows-os partícióknak nem csinál ikont és most ha bedugom az usb-t, akkor nem mountolja fel, csak ha arra kattintok, hogy usb csatlakoztatasa, ez ha jol müködik, akkor kitesz egy ikont. /etc/init.d/dbus restart utan meg kiteszi a win-es ikonokat, de az usbt meg mindig nem kezeli jol, nem tesz ki ikont, hanem egybol megnyitja az usb tartalmat. Igazabol nem is tudom, hogy melyik a helyes működés.
Egyébként ~x86 a rendszer. -
tierbatyo
Igazából csak azért zavar, mert ez a verzió volt jó az 6.8.2-r6-os xorg-hoz és lusta vagyok visszatérni az r4-esre.
tierbatyo
Miért van az, hogy a portage-ból kivesznek egy stable csomagot és csak a testing-ek maradnak benne. Kicsit furának tűnik. Egyébként ati-drivers-extra-ról van szó. Ati drivers-ben még ott a stable, extra-ban meg már nincs benne. Ha meg két különböző verzió van fenn ezekből, akkor oda vissza upgradelne, meg downgradelne.
tierbatyo
Rosszul emlékszem, hogy shutdownkor az udev kiüríti a /dev -t? Mert ez devfs mellett elég gáz akkor.
tierbatyo
Livecd-vel be tudsz bootolni még mindig. Aztán:
mkdir /mnt/gentoo
mount -t ext3 /dev/hda3 /mnt/gentoo
mount -t proc proc /mnt/gentoo/proc
chroot /mnt/gentoo /bin/bash
env-update
source /etc/profile
Ezután mennie kell az emerge-nek. Csak éppen azt kellene kitalálni, hogy mit frissítettél. -
tierbatyo
6.8.2-r4-el nekem ment az összes ATI driver szépen, 6.8.2-r6-tal a 8.14.13 a legutolsó, ami megy. A frissebb drivereknél egyszerűen lekapcsolja a monitort.
tierbatyo
Használ valaki etc-update helyett cfg-update-t? Most tettem fel, első használatra jobbnak tűnik.
tierbatyo
Érdekes dolgot vettem észre a Gentoo-mon. Nagyobb frissítések után nem mindig hajlandó elindulni reboot után. Eléggé változatos helyeken akad ki boot során. Ilyenkor muszáj bebootolnom Debianra és chroot-olni, majd kiadni a depscan.sh-t meg az env-update-t. Azt nem tudom, hogy melyik javítja meg, depscan-re tippelek, de utána megy szépen.
tierbatyo
dr_strange
#499
Már csak keyword masked. Akkor írok egy scriptet az emerge -pv gnome kimenetéből, ami megcsinálja a package.keywords file-t.
- iKing.hu Apple iPhone 12 Pro Max 128GB Gold használt, megkímélt 100% akku 6 hónap garancia
- Apple iPhone 13 Pro Max 256GB - ÚJSZERŰ, Kártyafüggetlen, Ezüst, 100% Akku - 1 Év Garanciával
- Apple iPhone 14 Pro / 128GB / Kártyafüggetlen / 12Hó Garancia / Akku: 86%
- HIBÁTLAN iPhone 14 Plus 256GB Red-1 ÉV GARANCIA - Kártyafüggetlen, MS4561, 100% AKKSI
- Bomba áron eladó Asus Vivobook S433EA /i7-1165G7/16GB/512 GB SSD/FHD/IPS
