A Linux Mint bemutatása
jézusom
jézusom
ubyegon2
#11497
System:Host: peti-linux Kernel: 4.15.0-54-generic x86_64 bits: 64 compiler: gccv: 7.4.0 Desktop: Cinnamon 4.2.3 wm: muffin 4.2.2 dm: LightDM 1.26.0Distro: Linux Mint 19.2 Tina base: Ubuntu 18.04 bionicMachine:Type: Desktop Mobo: MSI model: H87-G41 PC Mate(MS-7850) v: 1.0serial: <root required> UEFI: American Megatrends v: 3.9 date: 07/17/2014CPU:Topology: Dual Core model: Intel Pentium G3420 bits: 64 type: MCParch: Haswell rev: 3 L2 cache: 3072 KiBflags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12799Speed: 800 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 800 2: 800Graphics:Device-1: AMD Bonaire XTX [Radeon R7 260X/360] vendor: PC Partner Limiteddriver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:6658Display: x11 server: X.Org 1.19.6 driver: ati,radeonunloaded: fbdev,modesetting,vesa resolution: 1920x1080~60HzOpenGL: renderer: AMD BONAIRE (DRM 2.50.0 4.15.0-54-generic LLVM 8.0.0)v: 4.5 Mesa 19.0.2 direct render: YesAudio:Device-1: Intel 8 Series/C220 Series High Definition Audiovendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0chip ID: 8086:8c20Device-2: AMD Tobago HDMI Audio [Radeon R7 360 / R9 360 OEM]vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus ID: 01:00.1chip ID: 1002:aac0Device-3: Creative Labs EMU20k1 [Sound Blaster X-Fi Series]driver: snd_ctxfi v: kernel bus ID: 05:01.0 chip ID: 1102:0005Sound Server: ALSA v: k4.15.0-54-genericNetwork:Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernetvendor: Micro-Star MSI driver: r8169 v: 2.3LK-NAPI port: d000bus ID: 03:00.0 chip ID: 10ec:8168IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: 44:8a:5b:85:4e:9fDrives:Local Storage: total: 931.51 GiB used: 20.51 GiB (2.2%)ID-1: /dev/sda vendor: Western Digital model: WD10PURX-64D85Y0size: 931.51 GiB speed: 6.0 Gb/s rotation: 5400 rpmserial: WD-WCC4JPLADZZN rev: 1A01 scheme: GPTPartition:ID-1: / size: 49.51 GiB used: 20.48 GiB (41.4%) fs: ext4 dev: /dev/sda6Sensors:System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 37 CFan Speeds (RPM): N/AInfo:Processes: 197 Uptime: 1h 17m Memory: 7.72 GiB used: 1.91 GiB (24.8%)Init: systemd v: 237 runlevel: 5 target: graphical.target Compilers:gcc: 7.4.0 alt: 7 Shell: bash v: 4.4.19 running in: gnome-terminalinxi: 3.0.32remélem erre gondoltál, fogalmam sincs mi ez a programkód. Ja jó színes lett -
jézusom
De írtam, hogy cinnamon
Machine:
CPU:
Speed: 2140 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 3200 2: 3200
Graphics:
Audio:
chip ID: 8086:8c20
chip ID: 1002:aac0
Network:
Drives:
Local Storage: total: 931.51 GiB used: 10.98 GiB (1.2%)
Partition:
ID-1: / size: 49.51 GiB used: 10.95 GiB (22.1%) fs: ext4 dev: /dev/sda6
Sensors:
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 33 C
Info:
Processes: 199 Uptime: 2m Memory: 7.72 GiB used: 1.24 GiB (16.0%)
inxi: 3.0.32„lsb” parancs nem található, erre gondolt:
„lsh” parancs lsh-client deb csomagból
„lsc” parancs livescript deb csomagból
„lb” parancs live-build deb csomagból
„lb” parancs open-infrastructure-system-build deb csomagból
„msb” parancs mysql-sandbox deb csomagból
„ls” parancs coreutils deb csomagból
„lsw” parancs suckless-tools deb csomagból
„sb” parancs lrzsz deb csomagból
„lsm” parancs lsm deb csomagból
Próbálja ki ezt: sudo apt install <deb_neve> -
jézusom
#11482
Azt hiszem értem. Szóval githubról mindig fordítani kell.
Milyen szofvercsatornán találtad? Én a synapticot meg a szoftverkezelőt néztem.
CPU: Dual Core Intel Pentium G3420 (-MCP-) speed/min/max: 800/800/3200 MHz
Kernel: 4.15.0-54-generic x86_64 Up: 1h 13m Mem: 1662.6/7903.5 MiB (21.0%)
Storage: 931.51 GiB (1.2% used) Procs: 193 Shell: bash 4.4.19 inxi: 3.0.32 -
jézusom
cinnamont raktam fel.
De miért van úgy a githubon, hogy ne lehessen egyből felrakni?
Én kerestem amúgy, de akkor lehet hogy rossz helyen. Ezt se értem minek ez a githubos link, ha egy paranccsal fel lehet telepíteni. A pyton is úgy ment fel.
jézusom
#11467
Köszi! Tetszik amúgy ez a mint. A lényeg, hogy ezt a pyflashert el kell indítanom. Van pár flashelő kábelem bizonyos projektekhez, és windózon eléggé sz@rakodnak. Rendeltem még, ami remélhetőleg windózon is menni fog, de közben mondták, hogy linuxot gond nélkül menne, és így belevágtam. Hát a gond nélkül az már bukta
Szóval letöltöm a zip állományt, meg ki is tudom bontani, eddig oké. De semmi nem indul rajta, és leírás sincs. Elvileg valami pytont feltettem mert parancssorba bemásoltam valamit és akkor feltelepült, ez kell hozzá. -
jézusom
Felraktam egy linux mintet, 64 bites verziót. Megy, pár dolog működik.
Szeretnék egy programot elindítani. Letöltöm, kicsomagolni tudom, de semmi több. Tudom google a barátom, hát rohadtul nincs sehol leírva hogyan lehet elindítani, csak ilyen szoftvercsomagogkból töltsek le... Ez ilyen githubos cucc. Azt már kiderítettem, hogy nem telepíteni kell, de többet nem tudok
A topik célja: Segítségnyújtás a Linux Mint-et használó kezdők és haladók valamint a még csak azzal ismerkedők számára.
Kérdés előtt olvasd el a topik összefoglalóját! -> [link]
- Nintendo Switch
- Samsung kuponkunyeráló
- Milyen okostelefont vegyek?
- LEGO klub
- Kutya topik
- Amit látnod kell 80’ – 90’ évek, egész estét betöltő mozi filmjei.
- iPhone Ultra néven jöhet az Apple első foldja, nem lesz olcsó mulatság
- Hyundai, Kia topik
- Dell USB-C dokkolók: (K20A) WD19/ WD19S/ WD19DC + 130W, 180W, 240W töltők
- Game Pass Ultimate előfizetés azonnal, problémamentesen, méghozzá OLCSÓN! Immáron 8 éve!
- Lenovo ThinkPad X240,12.5",HD,i5-4300U,4GB RAM,128GB SSD,WIN10
- 239 - Lenovo Legion Pro 5 (16IRX9) - Intel Core i9-14900HX, RTX 4070 (ELKELT)
Rowon
