A Linux Mint bemutatása
edari
0xmilan
#10326
ez sokat segített, msotmár nem az a baja.
● winbind.service - Samba Winbind Daemon
Loaded: loaded (/lib/systemd/system/winbind.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2018-12-03 20:42:44 CET; 7s ago
Docs: man:winbindd(8)
man:samba(7)
man:smb.conf(5)
Main PID: 30053 (code=exited, status=1/FAILURE)
Dec 03 20:42:44 HP-EliteBook-840-G1 systemd[1]: Starting Samba Winbind Daemon...
Dec 03 20:42:44 HP-EliteBook-840-G1 systemd[1]: winbind.service: Main process exited, code=exited, status=1/FAILURE
Dec 03 20:42:44 HP-EliteBook-840-G1 systemd[1]: winbind.service: Failed with result 'exit-code'.
Dec 03 20:42:44 HP-EliteBook-840-G1 systemd[1]: Failed to start Samba Winbind Daemon.ubyegon2: mint mindig neked is köszi a segítséget.
edari
ubyegon2
#10322
Ezt dobta a gép:
Active: failed (Result: exit-code) since Mon 2018-12-03 19:03:17 CET; 31min ago
man:samba(7)
man:smb.conf(5)
Main PID: 18847 (code=exited, status=1/FAILURE)
Dec 03 19:03:16 HP-EliteBook-840-G1 systemd[1]: Starting Samba Winbind Daemon...
Dec 03 19:03:17 HP-EliteBook-840-G1 winbindd[18847]: invalid permissions on directory '/var/log/samba/cores': has 0775 should be 0700
Dec 03 19:03:17 HP-EliteBook-840-G1 winbindd[18847]: Failed to create /var/log/samba/cores for user 0 with mode 0700
Dec 03 19:03:17 HP-EliteBook-840-G1 winbindd[18847]: Unable to setup corepath for winbindd: No such file or directory
Dec 03 19:03:17 HP-EliteBook-840-G1 systemd[1]: winbind.service: Main process exited, code=exited, status=1/FAILURE
Dec 03 19:03:17 HP-EliteBook-840-G1 systemd[1]: winbind.service: Failed with result 'exit-code'.
Dec 03 19:03:17 HP-EliteBook-840-G1 systemd[1]: Failed to start Samba Winbind Daemon.Csak jogosultsági hiba?
edari
Mostanában minden update-re hibát kapok, most konkrétan ezt:
E: winbind: installed winbind package post-installation script subprocess returned error exit status 1
E: libpam-winbind: 53.4483:dependency problems - leaving unconfigured
E: samba: installed samba package post-installation script subprocess returned error exit status 1
E: libnss-winbind: 63.7931:dependency problems - leaving unconfiguredA winbindet már láttam más hibakódokban is. Az mihez kell, vagy mit csinál?
edari
ubyegon2
#10113
Úgy nézzük, mert úgy jó (mmint pendrive).
De akkor elkezdem túrni a netet, de végülis az se gáz a így marad, végülis nem sokat használom filmezésre úgy hogy tv-re/monitorra van kötve a gép. Csak néha-néha.Köszi az újabb segítséget.
Szerk: kiterjesztetten van, de ha megy a film, akkor a laptop kijelzője le van hajtva.
edari
ubyegon2
#10109
Igen mindegyik: alap, vlc, smplayer.
X264-eseket nézünk per pill, ezek akadnak.
Amit eddig elfelejtettem mondani, hogy dp->hdmi alakítóval van a gép a tv-re kötve.
Megpróbáltam felrakni ai965-va-drivermellé felrakni ai965-va-driver-shaders-t, de a kettő együtt nem lehet fent.Esetleg vga monitorozásra van valami mód? Ha valóban az a probléma, és nem esetleg codec vagy valami más szoftveres.
edari
Valamikor ránézek majd ezekre a monitorozó programokra, egyelőre elég a beépített system monitor.
edari
ubyegon2
#10096
Most így netezés alatt már nem hűt. Csak filmezés alatt kezdett el pörögni. Mindegy, filmezés alatt úgy se ezt fogom figyelni.
Tlp-vel most még nem próbálkoznék. Majd egyszer valamikor.
"A Wint ne sajnáld, Office helyett ott a LibreOffice, persze itt lehetnek kompatibilitási gondok...."
Office alatt itthonra csináltam magamnak 1-2 komoly Excelt, illetve dolgozok is vele (év végéig), és azokat megse mertem vele nyitni. Lehet majd teszek egy próbát, de sok jóra nem számítok."Ha ennyi minden működik alapból, nem lesz vele gondod, túl nagy és sok biztosan nem! "
Ez a laptop kb csak torrentre/médiafogyasztásra van, illetve néha webdevelopingra.Laptopon könnyű volt átállni Linuxra, asztalin már nehezebb lenne, így most leginkább csak ismerkedek a Win mentes élettel (kiváltó ok: meguntam a Windows baromságait, főleg a 10-nek, az a rendszer egy merő szánalom).
Köszönöm a segítséget.
edari
ubyegon2
#10094
Nem éppen a proci használatot érzem, hanem hogy nem áll le a hűtés.
"Nem ez a legegyszerűbb része a desktop Linuxoknak, ha valami VGA probléma van akármivel is."
Ettől is féltem, de legjobban attól hogy a wifi nem lesz jó. De meglepődtem amikor minden ment, még a billentyűzet fn funkciói is. Igazából kicsit féltem váltani winről, de nem tudok olyat mondani amiért kár (na jó, egyedül az office).vainfo:
libva info: VA-API version 1.1.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_1_1
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.1 (libva 2.1.0)
vainfo: Driver version: Intel i965 driver for Intel(R) Haswell Mobile - 2.1.0
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264MultiviewHigh : VAEntrypointVLD
VAProfileH264MultiviewHigh : VAEntrypointEncSlice
VAProfileH264StereoHigh : VAEntrypointVLD
VAProfileH264StereoHigh : VAEntrypointEncSlice
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
VAProfileJPEGBaseline : VAEntrypointVLD"Szerintem a Synaptic még használatban volt nálad, mivel az az apt csomagkezelő frontend programja, így terminalból értelemszerűen nem tudtad használni az apt-ot!"
Csak megvolt nyitva...
edari
ubyegon2
#10089
i965-va-driverfelrakása úgy látom megoldotta problémát, most nem vettem észre akadást se böngészőben, se az alap lejátszóval, ezért ai965-va-driver-shaders-t most nem raktam fel. Ha esetleg mégis akadna, csak most nem jött elő, akkor majd felrakom ezt is.
Egyébként az lehet hogy most jobban hajtva van a proci? Vagy véletlen egybeesés? Szerk.: véletlen lesz, szerintem valami települt/frissült.Egyébként ez azt akarja jelenteni hogy a vga-hoz nem rakott fel drivert alapból?
inxi -Gxxxeredménye:Graphics: Card: Intel Haswell-ULT Integrated Graphics Controller
bus-ID: 00:02.0 chip-ID: 8086:0a16
Display Server: x11 (X.Org 1.19.6 )
drivers: modesetting (unloaded: fbdev,vesa)
Resolution: 1920x1080@60.00hz
OpenGL: renderer: Mesa DRI Intel Haswell Mobile
version: 4.5 Mesa 18.0.5 (compat-v: 3.0) Direct Render: Yesgstreamer1.0-vaapifent van.sudo apt install vainfohatására pedig ezt az üzenetet kapom:E: Could not get lock /var/lib/dpkg/lock-frontend - open (11: Resource temporarily unavailable)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?sudo lshw -c video-ra pedig:*-display
description: VGA compatible controller
product: Haswell-ULT Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:49 memory:d0000000-d03fffff memory:c0000000-cfffffff ioport:3000(size=64) memory:c0000-dffff -
edari
ubyegon2
#10086
inxi -Fxxx eredménye:
System: Host: HP-EliteBook-840-G1 Kernel: 4.15.0-38-generic x86_64
bits: 64 gcc: 7.3.0
Desktop: Cinnamon 3.8.9 (Gtk 3.22.30-1ubuntu1) dm: lightdm
Distro: Linux Mint 19 Tara
Machine: Device: laptop System: Hewlett-Packard product: HP EliteBook 840 G1 v: A3009DD10203 serial: N/A
Mobo: Hewlett-Packard model: 198F v: KBC Version 15.59 serial: N/A
BIOS: Hewlett-Packard v: L71 Ver. 01.44 date: 04/12/2018
Chassis: type: 10 serial: N/A
Battery BAT0: charge: 42.7 Wh 100.0% condition: 42.7/42.7 Wh (100%)
volts: 12.9/11.4
model: Hewlett-Packard Primary Li-ion serial: 07137 2014/05/03 status: Full cycles: 0
CPU: Dual core Intel Core i5-4300U (-MT-MCP-)
arch: Haswell rev.1 cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9977
clock speeds: min/max: 800/2900 MHz 1: 1077 MHz 2: 1797 MHz
3: 1610 MHz 4: 1305 MHz
Audio: Card-1 Intel 8 Series HD Audio Controller
driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:9c20
Card-2 Intel Haswell-ULT HD Audio Controller
driver: snd_hda_intel bus-ID: 00:03.0 chip-ID: 8086:0a0c
Sound: Advanced Linux Sound Architecture v: k4.15.0-38-generic
Network: Card-1: Intel Ethernet Connection I218-LM
driver: e1000e v: 3.2.6-k port: 3080
bus-ID: 00:19.0 chip-ID: 8086:155a
IF: enp0s25 state: down mac: 14:58:d0:b9:dc:2e
Card-2: Intel Wireless 7260
driver: iwlwifi bus-ID: 02:00.0 chip-ID: 8086:08b1
IF: wlo1 state: up mac: f8:16:54:7b:7a:5fEgyébként nem csak a videózás alatt akad, hanem még youtube alatt is.
edari
Tapasztalta még valaki azt jelenséget, hogy a videók megakadnak néha? Legfrissebb mint.
Gép: HP elitebook 840 g1
A topik célja: Segítségnyújtás a Linux Mint-et használó kezdők és haladók valamint a még csak azzal ismerkedők számára.
Kérdés előtt olvasd el a topik összefoglalóját! -> [link]
- Nintendo Switch
- Samsung kuponkunyeráló
- Milyen okostelefont vegyek?
- LEGO klub
- Kutya topik
- Amit látnod kell 80’ – 90’ évek, egész estét betöltő mozi filmjei.
- iPhone Ultra néven jöhet az Apple első foldja, nem lesz olcsó mulatság
- Hyundai, Kia topik
- MINDENFÉLE Laptop jó áron nézz körül! 60+ hirdetés Üzleti,Gamer, Multimédiás,Tervező
- Xbox One S All Digital 1 TB + kontroller 6 hó garancia, számlával!
- Razer Iskur V2 Black gamer szék
- BESZÁMÍTÁS! ASRock B550 R5 5600 16GB DDR4 512GB SSD RTX 4060 8GB Zalman S2 TG be quiet! 500W
- AKCIÓ! MSI Thin A15 B7VE FHD Gamer notebook - R5 7535HS 16GB DDR5 512GB SSD RTX 4050 6GB W11
Rowon
