Magisk
root jogosultság
Android rendszereken
janakbacsi
valaki javasolta itt a wallet helyett a curve payt. feltelepitettem, de nem fejeződik be a folyamat. hosszú percek óta forog egy színes kártya jel a kijelzőn, azt írja, hogy we are verifying you de innen nem lép tovább.
janakbacsi
llaszlo
#8066
bootloader_unlock_new:
endermans_bl_unlock_guide:
🔓 Xiaomi Bootloader Unlock
✅ Condensed & Corrected Guide
📅 Preparation Time:
Perform the method around 9:20 PM IST.Apply exactly at 9:29:59 IST.
✅ Step-by-Step Guide:
1. Start at 9:20 PM IST.Power on your phone around this time.
2. Sign out and sign back into your Xiaomi account:
Go to Settings > Xiaomi Account.
Sign out, then immediately sign in again.
3. Enable OEM Unlocking:
Go to Developer Options.
Turn on OEM Unlocking.
4. Set up VPN (choose one):
Download Turbo VPN (or Power VPN, as EndarMan used) from the Play Store.
Select United States – Washington server (choose low ms server if using Power VPN).
Run the VPN in floating window mode.
5. Install Mi Community (Clean state):
Reinstall the Mi Community app (or clear app data if already installed).
Open the app while connected to VPN.
Login and navigate to the Unlock Bootloader section under settings.
Stay on that screen.
6. At 9:28–9:29 PM IST:
Disconnect the VPN at 9:28-9:29 for reduce ping (while still inside the Mi Community app).
Then click apply at exactly at 9:29:59 IST.
Quickly go to Settings > Developer Options > Mi Unlock Status.
Tap "Add account and device"
7. Important tips :
Don’t click at 21:29:58 — it may not work.
If you see 403 Forbidden, do not try again — it locks your next chance.
If you see “Quota limit reached”, don’t panic — just proceed to the next steps quickly.
✅ Result:
If done correctly, the account will be linked successfully to the device.
⚠️ Notes:
Use floating mode for VPN to switch quickly.
Speed and timing are crucial — prepare ahead.
Avoid multiple attempts on the same day.
-This is from Enderman -
janakbacsi
energiezolee
#8062
azt próbáltan.
janakbacsi
energiezolee
#8053
nekem van basic integrity, de a dap nem megyen.
janakbacsi
van strong integrity de a granit bank app látja a rootot és nem megyen. hogyan kell elrejteni? ezek a modulok vannak: play integrity fix inject 4.3, tricky store 1.3.0, yuri keybox manager 2.10, zygisk next 1.2.91.
janakbacsi
dilajoska1
#7832
ezzel a yurikey-el működik a wallet?
janakbacsi
akkor a wallet-et végül nem lehet semmilyen modullal működésre bírni. nekem van strong integrity, gránit bank és revolut megy, de a walletben nem lehet fizető kártyát hozzáadni.
janakbacsi
energiezolee
#7784
feltettem egy másik custom rom-ot. a play store "certified", van strong integrity, működik a revolut, csak a walletben nem tudok kártyát hozzáadni. holnap kipróbálom a curve-vel az nfc-s fizetést. valószínűleg magisk-et is fel fogom tenni majd.
janakbacsi
energiezolee
#7778
gránit, revolut. 3 zöld pipa van az integrity check-ben. ksu next roottal.
janakbacsi
energiezolee
#7775
nem működnek a banki appok sajnos.
janakbacsi
az nfc beállítások között nincs curve opció. csak sim pénztárca és wallet.
janakbacsi
energiezolee
#7771
ez a bajom. nem hagyja beállítani alapértelmezettnek. a végén mindig ezt a hibát adja sajnos.
janakbacsi
energiezolee
#7769
most már hozzá tudtam adni a bankkártyát, de a fizetés nem működött a terminálnál sajnos. megpróbálom azokat a modulokat feltenni amiket megírtál.
janakbacsi
energiezolee
#7765
kicsit összezavarodtam. most akkor mely modulok szükségesek ahhoz, hogy a curve pay működjön? a modulokon belül milyen beállítások szükségesek? köszönöm.
janakbacsi
norbert1998
#7686
Akkor csak kamu?
janakbacsi
Ez volt már?
janakbacsi
energiezolee
#7676
Nekem működik normálisan.
janakbacsi
energiezolee
#5941
nincs magisk nálam. helyette van a kernelsu. a kettő együtt nem javasolt.
janakbacsi
sixtybi
#5933
hiába rejtem el, így sem működik. pedig biztos van valamilyen megoldás rá, hogy ne ismerje fel a zygisk és lsposed kernelsu modulokat a gránit bank alkalmazás, mert ezelőtt valamikor működött a screenshot a banki alkalmazásban, de már elfelejtettem sajnos, hogy pontosan mit kell csinálni. emiatt a kettő miatt nem indul el.
janakbacsi
janakbacsi
#5921
device integrity nem jó.
janakbacsi
erre van valami megoldás? poco f5 custom rom.
janakbacsi
evolution rom-ot készítők megcsinálták a strong integrity-t?
janakbacsi
janakbacsi
#5539
ezt találtam, de idegen nyelven van. videó alapján nagyjából érthető.
janakbacsi
ez a kernel su mennyiben másabb (jobb/rosszabb) mint a magisk?
janakbacsi
telefonomon nincs magisk és root, revanced youtube-ot használtam rajta, de sajnos már nem működik. valamit biztos baszakodott megint a google. xiaomi.eu rom van rajta, az nfc-s fizetés működik kiválóan. hiába csinálom meg az itt leírtakat, sajnos ennek ellenére sem akar működni a yt. [link]
janakbacsi
át kell nevezni pif.json-ra? vagy maradhat így? csak basic integrity van meg vele.
janakbacsi
Nekem is megy a gránit bank app és az nfc s fizetés is. Crdroid rommal.
janakbacsi
Nekem a 15.1 van fent. Akkor azt cserélni kellene 14.6 ra?
janakbacsi
a crock által megosztott 4 fájlból egyet betettem én is a megfelelő helyre, így most működik. kíváncsi leszek, hogy meddig lesz életképes.
janakbacsi
nálam is elhasalt a 15.1-es pif. tegnap még tudtam vele fizetni, ma meg már nem.
janakbacsi
Csak akkor bukja a gesztus vezérlést.
janakbacsi
Ezt nem lehet nem jól csinálni. A google fiókba való belépés után meg kellene hogy jelenjenek a kontaktok, de nem jelennek meg. Pc ről exportáltam a vcf fájlt, majd azt importáltam a telefonba. Így már vannak kontaktok is.
janakbacsi
micafighter
#4677
töröltem mindent, többször is.
janakbacsi
valami nem jó.
janakbacsi
kréta alkalmazást hogyan lehetne működésre bírni?
janakbacsi
telefonom bootloadere nyitva, de magisk/root nincs. banki alkalmazások (gránit, revolut) működnek, de a kártyát nem lehet hozzáadni a wallet-hez. mitévő legyek?
janakbacsi
energiezolee
#4628
az az első, hogy kikapcsolom az auto update-et én is. megnéztem, tényleg nem szerepel a youtube az appok között.
janakbacsi
janakbacsi
#4548
ez is kell mellé? [link]
janakbacsi
az vajon miért lehet, hogy az ázsia centerben egy boltban és egy orlen benzinkúton nem tudtam fizetni a telefonnal, de a lidl-ben igen. lehet terminál függő a dolog?
janakbacsi
Ha pl. Evolution X custom romot rakok a redmi note 8 pro ra, akkor fog müködni a walletes fizetés buherálás nélkül? Illetve létezik normálisan működő magisk modul hivásrögzitéshez?
janakbacsi
14.5 máris bukó.
janakbacsi
energiezolee
#4303
Amióta megy ez a mizéria, viszem magammal a fizikai kártyát is.
janakbacsi
1-2 nap után sajnos megint nem működik a telefonos fizetés. kezdem elveszteni a reményt. vagy én csinálok valamit rosszul?
janakbacsi
a 13.9 elhasalása után akkor most még nincs működő verzió, ugye?
janakbacsi
the radish
#4029
így lett. este már nem működött sajnos.
janakbacsi
the radish
#3996
én most fizettem a spar-ban 13.9-el, nem volt probléma.
janakbacsi
12.3-al újra működik a wallet.
hiába erőlködik a google, pár nap után úgyis jön a megoldás a hülyeségeire. nem tudom, hogy miért nem engedik el. -
janakbacsi
Feltettem ezt az új 12.1 es dolgot. Közvetlen ezután probáltam fizenti a snack autománál vele és sikerült.
Az előbb bementem a spar ba és ott már nem működött sajnos. Egyelőre akkor nincs biztos megoldás ha jól gondolom. -
janakbacsi
A helyzet az, hogy látszik hogy sok energiát fektetsz a leírásokba, de a javasolt helyen számomra nagyon körülményes megkeresnem és kiválasztanom azt a linket, ami nekem szükséges az adott helyzetben. Szerintem a felhasználók többsége így van ezzel. Narxis kolléga egyszerűbb, "hülye biztosabb" megoldása véleményem szerint célravezetőbb. Kérlek, ne tekintsd ezt támadásnak, ill. az általad elkészített összefoglalók lekicsinylésének. Tudomásul kell vennünk, hogy ma ilyen világban élünk, mindenki az egyszerűbb, kevésbé időt rabló megoldásokat keresi.
janakbacsi
janakbacsi
#3198
- HIBÁTLAN iPhone 13 Pro 128GB Gold -1 ÉV GARANCIA -Kártyafüggetlen- MS4674, 100% AKKSI
- Lenovo Legion 5 RYZEN 5 6600H RTX 3050Ti 4GB 16 GB DDR5 512 GB SSD FHD 165 Hz Magyar bill Gari
- Apple iPhone 16 Pro Max 256GB,Újszerű,Dobozaval,12 hónap garanciával
- Lenovo ThinkPad // T - Széria // X1 carbon // X1 Yoga 2-in-1 // és a többiek... 3-12. gen.
- 27% ÁFÁS DELL Alienware 16X Aurora AC16251 RTX5070 Részletfizetés megoldható. Beszámítás lehetséges
