Phobos
Gond van a 8x AGP -nél?? Ez új..
Más is tapasztalt ilyet?? -
Phobos
fress
senki? -
Phobos
fress
Phobos
ha a főoldalon az Ameikaira mész, akkor csak az első tehát nf7d14.exe van
http://fae.abit.com.tw/eng/download/bios/i_new.htm#AMD
ha a németekhez, ott meg csak a másik....
http://www.abit.com.tw/abitweb/webjsp/german/download_content.jsp?pTITLE=NF7V2.0 -
Phobos
ja lehet ezért fagynak mert rosszat töltenek bele, most melyik a jó ???
Phobos
http://www.abit.com.tw/abitweb/webjsp/english/download_search_process.jsp?pTYPE=Bios
Phobos
NF-7V2.0
nf7d14.exe Bios Issue Date: 2003/05/14
Please use AWDFLASH 8.23D or later to update NF7 series BIOS. With incorrect AWDFLASH version, the GUID will be erased, and leads toIEEE1394 peer to peer function failure. AWDFLASH 8.23K is included in this BIOS package.
Fixed CPU temperature too high issue.
Raised highest CPU FSB up to 300 MHz for ''user define mode'' in
SoftMenu.
Fixed SATA RAID-0 data corruption issue by adding a new option
''EXT-P2P's Discard Time'' in ''integrated Peripherals''. The default
setting is ''30 us'' ; which is recommended by NVidia. In case the problem is still there, try ''1 ms'' please.
Changed DDR400 DRAM timing according to NVidia's recommendation.
Updated BPL to v3.01 according to NVidia's recommendation.
BIOS Compile Date: 5/14/2003.
NF7V2.0
nf7d11.exe Bios Issue Date: 2003/03/27
IEEE1394 peer to peer function failed. AWDFLASH 8.23D is included in
this BIOS package.
Fixes incorrectly detect Thorton 2600+ (166x12.5) CPU in Softmenu III.
Fixes DRAM hang up at POST code EFh for specific memory module.
Fix the problem that if used CPU 400FSB without User Define, it would not show DDR xxx (xxx=200,266,333,400).
The default value of CPU FSB/DRAM freq revises to ''Auto''.
Adds''CPU Disconnect Function'' to adjust C1 disconnects. The Chipset does not support C2 disconnect; thus, disable C2 function.
Fixes DMI Pool data to be Socket A, Product Name: NF7-S/NF7 (nVidia-nForce2), Version: 2X.
The frequency of CPU 1917Mhz revised to 1916MHz.
Update SIP table to solve systems crashed issue while using 400FSB CPU+DDR 333, and revise the SIP Table of 266FSB CPU.
The default value of ''Memory Timings'' revises to ''Optimal''.
Updates BPL to be 2.94.
Fix system can not show fan speed in PC Health Status while using lower speed FAN.
Add''IDE Bus Master'' function to improve transfer speed of GHOST, and default value set up to disabled.
Fix the problem that systems can not detect USB Drvice under WinME resume from S3,S4 mode, and lead to usb connector failed.
Fine tune the OC ability of 333FSB CPU.
BIOS Compile Date: 3/27/2003. -
Phobos
azt tudom, hogy külön lap, de az ott is van külön, leírtam, hogy ott az oldalon az egyiket kötőjellel írták a másikat nem
Phobos
és az a két bios az Abit oldalon?
Phobos
fress
Phobos
ja meg még egy kérdés az ABIT oldalon a bios letöltésnél van ehy olyan választás, hogy NF-7V2.0 meg egy NF7V2.0 és mindegyiknél más bios van... hogy van ez?
Phobos
Most akarok rendelni lapot.. Eddig egy ABIT NF7 2.0 -át akartam, mert jó tuningolható, de egy csomó fórumban olvasom, hogy bios gondok vannak vele...
Érdemes venni, vagy melyik lapot javasoljátok???
- Videó stream letöltése
- Vicces képek
- í kilenc! AKCIÓS PRECÍZIÓS KÉSZÜLÉK! 7560 i9-11950H 32GB RAM 1TB SSD Nvidia RTX A3000 6GB 1 év gar
- Amazfit Active okosóra
- Apple iPad Air 2 128GB, Wi-fi, 1 Év Garanciával
- ÁRGARANCIA! Épített KomPhone i5 12400F 16/32/64GB RAM RX 9060 XT 16GB GAMER PC termékbeszámítással
- GYÖNYÖRŰ iPhone 14 Pro Max 256GB Space Black-1 ÉV GARANCIA - Kártyafüggetlen, MS4143
