Keresés
  • guest
    Bocs kicsit egybe csuszott! az elso 4 ev gar utan az mar a 995F!
  • guest
    Hello!
    Ha van vkinek tapasztalata velemenye kerem irja meg mert epp ilyet keszulok venni. Amit technikai infok amiket talaltam roluk:
    Model SCOTT 995
    Picture Tube 19'' Color CDT
    0,26 mm Dot Pitch
    Flat Square Screen
    ORION CRT
    Max. Viewable 18'' (45,8 cm)
    Image Size
    Normal Display Size 366 mm x 275 mm
    Full Scan
    Max. Resolution 800 x 600, 150 Hz (NI)
    (Preset Timing) 1024 x 768, 110 Hz (NI)
    1280 x 1024, 85 Hz (NI)
    1600 x 1200, 75 Hz (NI)
    Max. Pixel-Frequency 202 MHz
    H-sync. Frequency 30-96 KHz
    V-sync. Frequency 50-160 Hz
    Scanning Mode Auto
    User Control Type Multi-Language OSD,
    Brightness, Contrast,
    H-Phase, V-Center,
    H-Width, V-Size, Pincushion,
    Trapezoid, Parallelogram,
    Tilt Correction, RGB-Control,
    Recall, Pin Balance,
    Moire Control
    Preset Color 9300 K / 6500 K
    Temperature
    Preset Modes 12
    User Modes 10
    Degauss Yes
    Power Management Power On / Manual
    DPMS / NUTEK / EPA
    TCO '99 Yes
    Dimension Package 570 x 565 x 565
    (W x H x D) mm
    Dimension Monitor 458 x 490 x 481
    (W x H x D) mm
    Weight (GW) 24 Kg
    Container Loading 288 / 144
    (40ft / 20ft)
    Agency Approval UL, UL-C, FCC-B, DHHS,
    TÜV / GS,CE, TCO '99,
    Nordic
    Warranty 4 years Pick-Up
    Illetve a 995F
    Model SCOTT 995F Flat Line
    0,26 mm Dot Pitch
    100% Flat Line
    LG CRT
    Image Size
    Full Scan
    Scanning Mode Auto
    H-Phase, V-Center,
    Moire Control
    Temperature
    Preset Modes 12
    User Modes 10
    Degauss Yes
    DPMS / NUTEK / EPA
    TCO '99 Yes
    (W x H x D) mm
    (W x H x D) mm
    Weight (GW) 24 Kg
    (40ft / 20ft)
    Nordic
    Előre is kösz!
