Mozilla Firefox
BullZeye
WonderCSabo
#14650
Hiba az ön készülékében van :\ nálam tökéleten megy mindegyik linken. Átrakja 720p-re őket.
BullZeye
WonderCSabo
#14629
Ezzel még megy tutira. Most néztem meg.
// ==UserScript==
// @name Youtube Embed HD
// @version 1.4
// @namespace Youtube
// @include *
// ==/UserScript==
trim = function(str) {
return str.replace(/^\s\s*/, '').replace(/\s\s*$/, '');
var YTEmbedHD = {
//Array of youtube embedded videos
ytEmbeds : new Array(),
//Searches the page for youtube players
findPlayers : function() {
var embeds = document.body.getElementsByTagName("embed");
for(i in embeds) {
if(embeds[i].src.indexOf("youtube") > -1) {
YTEmbedHD.ytEmbeds.push(embeds[i]);
var objects = document.body.getElementsByTagName("object");
for(i in objects) {
if(objects[ i ].getElementsByTagName("embed").length == 0 && objects[ i ].innerHTML.indexOf("youtube") > -1) {
YTEmbedHD.ytEmbeds.push(objects[ i ]);
//alert(embeds.length)
//If we have youtube elements, run the script!
if(YTEmbedHD.ytEmbeds.length > 0) {
YTEmbedHD.run();
//Loads the required SWFObject
run : function() {
var waitForLibs, loadLibary;
//Wait for libraries to load then call the libLoaded function
waitForLibs = function() {
if (typeof unsafeWindow.swfobject == 'undefined') {
window.setTimeout(waitForLibs, 100);
} else {
YTEmbedHD.libLoaded();
//Add a javascript libary to the page
loadLibary = function(url, fn) {
var head = document.getElementsByTagName('head')[0] || document.documentElement;
var script = document.createElement('script');
script.src = url;
script.type = 'text/javascript';
script.async = true;
head.insertBefore(script, head.firstChild);
if (typeof fn == 'function') {
fn();
//Check if the libary is already loaded on page
loadLibary('http://ajax.googleapis.com/ajax/libs/swfobject/2.2/swfobject_src.js', waitForLibs);
else
waitForLibs();
//Write a script element to the page
addScript : function(str, fn) {
script.innerHTML = str + "\n" + fn;
//Called after the SWFObj lib has loaded
libLoaded : function() {
YTEmbedHD.swfobject = unsafeWindow.swfobject;
//Function that is called when the youtube player has been replaced sucessfully
function onYouTubePlayerReady() {
//Get the current player and add the correct onstatechange event hander for it
var yt = document.getElementById("ytPlayer" + YTEmbedHD.cID);
yt.addEventListener("onStateChange", "onStateChange" + YTEmbedHD.cID);
if(YTEmbedHD.cID == YTEmbedHD.ytEmbeds.length-1) {
//alert("COMPLETED")
} else {
//alert("NEXT")
YTEmbedHD.cID++;
YTEmbedHD.replacePlayer();
//Write this object to the page and the ready function
YTEmbedHD.addScript("var YTEmbedHD = {}; var YT_EMBED_QUALTIY = '" + GM_getValue("qualityOrder", "1080p,720p,480p,360p,small") + "'", onYouTubePlayerReady);
unsafeWindow.YTEmbedHD = YTEmbedHD;
YTEmbedHD.cID = 0;
//Start replacing players on the page
//Replaces the current embed element with a SWFObject to use the YoutubeAPI
replacePlayer : function() {
var embed = YTEmbedHD.ytEmbeds[YTEmbedHD.cID];
var src = embed.src;
if (src == null)
var params = embed.getElementsByTagName("param");
for (var n = 0; n < params.length; n++)
var param = params[n];
if (param.name == "src" || param.name == "movie")
src = param.value;
break;
if (src == null)
return;
var ytDiv = document.createElement("div");
var _w, _h;
_h = embed.clientHeight;
_w = embed.clientWidth;
if(_w == "" || _w <= "0") _w = embed.parentNode.clientWidth;
if(_h == "" || _h <= "0") _w = embed.parentNode.clientHeight;
ytDiv.id = "ytDiv" + YTEmbedHD.cID;
ytDiv.style.width = _w + "px";
ytDiv.style.height = _h + "px";
var embedToReplace = embed.tagName == "EMBED" ? embed.parentNode : embed;
embedToReplace.parentNode.replaceChild(ytDiv, embedToReplace);
//Ugh crazy thing to select the quality in the order the user specified-
//needs re coding, like most of this. Ill do it at some point.
function selectQuality(q) {
var p = 0;
var f = false;
var pref = YT_EMBED_QUALTIY.split(",");
for(px in pref) {
if(pref[px] == "1080p")
pref[px] = "hd1080";
else if(pref[px] == "720p")
pref[px] = "hd720"
else if(pref[px] == "480p")
pref[px] = "large"
else if(pref[px] == "360p")
pref[px] = "medium"
var find = function() {
for(j in q) {
if(q[j] == pref[p]) {
f = true;
p = j;
break;
for(c = 0; c < pref.length; c++) {
find();
if(f == true) {
break;
p++;
return q[p];
//Create a onStateChange function for this specific player
"var qualitySet" + YTEmbedHD.cID + " = false;" +
"\nfunction onStateChange" + YTEmbedHD.cID + "(newState) {" +
"\n if(qualitySet" + YTEmbedHD.cID + "==false) {" +
"\n var yt = document.getElementById('ytPlayer" + YTEmbedHD.cID + "');" +
"\n var q = yt.getAvailableQualityLevels();" +
"\n var sq = ''" +
"\n for(j in q) {" +
"\n sq = q[j]; break;" +
"\n }" +
"\n if(sq != '' && qualitySet" + YTEmbedHD.cID + "==false) {" +
"\n qualitySet" + YTEmbedHD.cID + "=true;" +
"\n yt.setPlaybackQuality(selectQuality(q));" +
"\n }" +
"\n }" +
"\n}", selectQuality);
var params = { allowScriptAccess: "always", wmode: "transparent", allowFullScreen: "true" };
var atts = { id: "ytPlayer" + YTEmbedHD.cID };
//Embed the video player
YTEmbedHD.swfobject.embedSWF(src + "&enablejsapi=1&playerapiid=ytplayer", ytDiv.id, _w, _h, "8", null, null, params, atts);
createStuff = function() {
var fill = document.createElement("div");
fill.setAttribute("style", "position: fixed; top: 0; width: 100%; height: 100%; z-index: 2147483645; background: black; opacity: 0.6; cursor: pointer");
var cel = function(p, elm) {
var el = document.createElement(elm);
p.appendChild(el);
return el;
var addCSS = function(text) {
var css = document.createElement('style');
css.type = 'text/css';
css.innerHTML = text;
head.insertBefore(css, head.firstChild);
var settings = document.createElement("div");
settings.setAttribute("style", "width: 250px; border: 2px solid white;z-index: 2147483646; position: fixed; top: 0; margin-top: 100px; left: 50%;" +
"margin-left: -150px; background: #333; -moz-border-radius: 10px; font-size: 11px; color: white; padding: 10px; font-family: Arial;" +
"line-height: 13px;");
var head = cel(settings, "h1");
head.setAttribute("style", "font-size: 15px; color: white; font-family: Arial; margin: 0; padding: 5px; border: 0; border-bottom: 1px solid white; margin-bottom: 10px;");
head.appendChild(document.createTextNode("Youtube Embed HD Settings"));
settings.appendChild(head);
var ctn = function(elem, text) {
elem.appendChild(document.createTextNode(text));
ctn(settings, "Default video quality (Enter in order you wish them to be selected");
addCSS("#ytEmbedHDList { padding: 10px; }" +
"#ytEmbedHDList > div { border:1px solid white; padding: 3px; margin: 2px; width: 70px; float: left; clear: left;}" +
"#ytEmbedHDList input {float: left; width: 20px; border: 1px solid white; margin-top: 2px; font-size: 11px; padding: 3px; color: white; background: #666}");
var order = GM_getValue("qualityOrder", "1080p,720p,480p,360p,small").split(",");
var items = [];
var list = cel(settings, "div");
list.id = "ytEmbedHDList";
for(m=0;m<order.length;) {
ctn(cel(list, "div"), order[m]);
items[m] = cel(list, "input")
items[m].id = order[m];
items[m].value = ++m;
var sx = cel(settings, "br");
var sbmt = cel(settings, "input");
sbmt.type = "button";
sbmt.value = "Save";
sbmt.setAttribute("style", "margin: 20px auto 0 auto; display: block;");
var span = null;
sbmt.addEventListener("click", function() {
var ord = []
for(i in items)
ord[items[i].value-1] = items[i].id;
var err = false;
for(i=0;i < items.length; i++) {
if(ord[i]==null) {
err = true;
break;
if(err && span == null) {
span = cel(settings, "span");
span.style.color = "yellow";
span.style.marginLeft = "25px";
span.appendChild(document.createTextNode("Error invalid input"));
} else {
m = "";
for(i = 0; i < 4; i++) {
m += trim(ord[i]) + ",";
m += trim(ord[4]);
GM_setValue("qualityOrder", m);
YTEmbedHD.addScript("YT_EMBED_QUALTIY = '" + m + "'");
fill.parentNode.removeChild(fill);
settings.parentNode.removeChild(settings);
}, false);
fill.addEventListener("click", function() {
}, false);
document.body.appendChild(fill);
document.body.appendChild(settings);
settings.focus();
GM_registerMenuCommand("Set playback quality settings", createStuff);
setTimeout(YTEmbedHD.findPlayers, 500); -
BullZeye
WonderCSabo
#14539
Mint átlag felhasználó, nem számít, hogy mi miatt van, viszont az tény, hogy van screenshotom, ahol 900mb++ a memória felhasználása, ami miatt egy nagyon gagyi játéknak is alig jut elég memória a W7 szerint, és ilyenkor követeli, hogy zárjam be a programokat, különben...!!! (ki volt kapcsolva a Virtuális Memória)
BullZeye
WonderCSabo
#14536
És ezt a Memória problémát javították már FF4-ben? Csak mert van screenshotom, ahol épp 937.952 megabájt memóriát eszik Firefox
nem sajnálom tőle, nem arról van szó
csak hát na
BullZeye
WonderCSabo
#14522
Pontosan, pl betölt az oldal fele, és lejjebb már nem lehet görgőzni és ott megakad, mintha félbe vágták volna. És ha F5-t nyomok akkor betölti az egészet télleg pillanatok alatt, viszont ha nem nyomok F5-t akkor volt, hogy 5-6 órára is ott felejtettem, és akkor se töltött be
BullZeye
WonderCSabo
#14520
Nem konkrétan erre értettem, hanem amikor bejön a fehér háttér mondjuk, és bal alul csak számol felfele és már 5-6 percnél jár, de még mindig nem történik semmi és ilyenkor csak F5 és újra betölti az oldalt, de most már 1 másodperc alatt. Ez a hibaüzenet, hogy nem tud kapcsolódni ki se jön ilyenkor. O.o
BullZeye
Van olyan beállítás FF-ben, ha nem tudja betölteni a dolgokat elsőre, akkor próbálja meg 5 másodperccel később?
Kezd rettentő bosszantóvá válni, hogy ha szar az oldal szervere akkor akár órákig is otthagyhatnám, az FF még mindig csak "tölti" ami gyakorlatilag semmit se tesz, ha valahol megáll a betöltés, ő nem folytatja, és annyi esze nincs, hogy szóljon, hogy nem sikerült, vagy hogy újra próbálja. Erre kéne nekem valami kieg.Meg még1 ami a flash videók lejátszásánál ha megszakd a letöltés akkor ne az egészet kelljen újra betölteni, hanem folytassa MAGÁTÓL.
BullZeye
WonderCSabo
#14477
Eddig nem néztem eleget, hogy rájöjjek mire hasonlít
de így már minden világos. Nekem személy szerint semmi bajom nincs vele, de egy átlag usernek qrwara semmit sem fog mondani, hogy most épp mi van, és hogy mikor tölt be az oldal
Nem csoda, ha lassan elszakad a cérna Mozilla irányába, kaptunk ígéreteket annyit, hogy dunát lehetne rekeszteni, annak csak töredéke kerül be. És most az egyik legjobb újítást is dobnák, mert dolgozni kéne vele -.-
BullZeye
Mivel és hogy lehetne kizárni, hogy ha google-ben keresek akkor még véletlenül se dobjon ki bizonyos oldalak találatait?
Tele van a hócipőm, hogy az első 10 találatból néha 3-4 is kamu oldal. És általában ugyanazok.
Példának okáért http://www.financialvortex.com/, ezt szeretném kizárni az életemből egy életre. és még sok másikat is
BullZeye
Edween
#14409
Mióta WonderCSabo mondta, hogy pár érdekes dolgot nem raknak bele, én picit letettem róluk. Valahogy nem látom a fejlődést az egészen, gondolom kódot optimalizálnak, de 1-2 embert igazán rá állíthatnának pl a Tabok animálásra, hogy ne csak a motorház mögött legyen jó az FF, hanem igenis legyen az egész kellemes a szemnek, és legyen egy élmény a használata, és ne csak arra menjenek rá, hogy gyorsan behozzon egy oldalt (persze az is fontos, de számomra másodlagos).
Tényleg 2-3 naponta leszedem az aktuális hourly buildet, de semmi változást nem látok. Dx10 kihasználása végett nőtt a teljesítmény és nem is picit, de ez 1 dolog csak amit így meg tudnék nevezni az elmúlt 1 hónapban amit fejlődött ... mint már írtam én 2 dolgot várok nagyon, abból az egyikről egy az egyben le is tettem, mert "nincs rá elég emberük". -.-
Az, hogy átlépték a mágikus 400ms-es álomhatárt még engem nem győzött meg, hogy mitől lenne nekem, a felhasználónak jobb, mint amikor 500MS volt. Az oldalak így is nálam legalábbis amiatt lassúak, HA lassúak, mert a szerver ahol az oldalt tárolják bizony túl terhelt épp.
Én nem bánom, ha elhúzzák, és csak jövőre jön a végleges, de az iskoláját, lehessen már látni, hogy ők bizony ott keményen dolgoznak. Persze az aki bugzillát olvassa, és up-to-date hogy épp mi került be, annak persze hogy látszik, de én, aki csak felrakom kipróbálom lefuttatok pár tesztet, és használom 1-2 órát, nem igazán veszem észre.
BullZeye
WonderCSabo
#14370
Brief
Az összes FireFoxos RSS reader közül ez a legjobb. Van ennél szebb, de ez a leghasználhatóbb, és nem kell hozzá Google Reader account sem. Többet nem tudok mondani, kérem kapcsojjjja ki!
Compact Menu 2
A szokásos menüsort összetömöríti egyetlen Menü feliratba (vagy választható ikonba), amit aztán szépen el lehet helyezni mondjuk a bal oldalon az ELŐRE-HÁTRA gomb elé, így 1 sort megtakarítunk, és mégsem kell ALT-ot nyomni, ha szeretnénk elérni az Eszközök menüt.Quick Translator
Ennél van jobb, úgyhogy ezt akár el is lehet felejteni, a neve pedig Inline Translator, működik FF4-en is tökéletesen. És azért jobb az Inline Translator, mert nem kell hozzá nyomni semmit, automatikusan a kijelölt elemet, legyen az latin, orosz, kínai, japán, német angol (és még az összes nyelv amit a google translate ismer), szépen egy kis lebegő dobozkában lefordítja. Ha félre kattolsz akkor eltűnik ez a box. Automata nyelvfelismerés, és 5000 karakterig bármit lefordít.Dcurrency
Ez inkább csak tudásilag hasznos, és inkább csak annak, aki gyakran vásárol interneten külföldről (eBay). Status Baron mutatja az aktuális árfolyamot, túlképp bármelyik ország fizetőeszközét be lehet állítani. (USD-HUF, EURO-HUF, CHF-HUF ami épp hasznos).
Érdemes hozzá használni az Organize Status Bar kieget, mert alapból túl sok fölös dolgot rak ki, én spec így használom | (Amerikai zászló) = 197.75 HUF | ez így alig 3 centi helyet foglal a Status Baron.Organize Status Bar
Egyik leghasznosabb program, ha az ember szeret kényelmi extra funkciókat adni a Status Bar-nak. Ezzel eltüntetni és előhozni lehet dolgokat, amik a Status Bar-on vannak, és nem mellesleg elég könnyedén mozgatni is, amelyek aztán ott maradnak újraindítás után is.Saved Passwords Button
Ez túlképp kirakhatóvá teszi a Mentett Jelszavak gombot. Gondolom van más mód is, de én ezt használom, ha esetleg van jobb ötlete valakinek (amihez nem kell kieg) az szóljon. Persze ez csak annak jó, aki egymaga használja a FireFoxot, és gyakran nézi meg, hogy mi volt oda a jelszó, mert kell másik gépre.SkipScreen 0.5.7amo
Nagyon jó és hasznos kieg, must have! Arra jó, ha RapidShare-ről töltünk le (vagy 50 másik oldalról, pl. Megaupload), akkor kivárja a visszaszámlálást, sok oldalon beírja a Captcha-t, és magától letölti a fájlt nekünk. Így túlképp RapidShare-ről letölteni annyi erőfeszítésbe kerül, hogy rákattintunk a RapidShare linkre.SmoothWheel
Ez egy olyan dolog, amit a FF-nak alapból tartalmaznia kéne. FF4-ben ez már benne van, de ahhoz 0 beállítási lehetőségünk van. Ezzel be lehet állítani, hogy ha lassan görgőzünk akkor lassan scrolloz, míg ha 20-30 oldalas (képernyős, ahogy tetszik) oldalon középre szeretnénk menni, akkor gyorsabban görgőzve lényegesen gyorsabban is halad. És nem mellesleg az egész görgetés mintha szappanon csúszkálna, és nem olyan szaggatott mint az összes böngészőnél.Update Scanner
Egy olyan kiegészítő, ami szökőévente 1x kell, de akkor nagyon. Tegyük fel, hogy 2009-et írunk, és meg szeretnénk nézni az Avatar-t IMAX 3D-ben, de ahogy felkerül a jövőheti helyfoglaló lista, 1 óra alatt már az összes jó hely foglalt. NA ilyenkor jön képbe az Update Scanner, ahol beállítva 5 percenként frissíti az oldalt, szól, hogyha frissül, és ki is emeli sárga színnel a változásokat. Teljesen személyre szabható, azaz akár heti rendszerességgel is frissíthet, és akkor szól pl, ha 3000 karakter frissült, de akár akkor is, ha csak 1.Advanced Address Bar 1.05
Benne maradt listában, de túlképp fölösleges addon.Auto Shutdown 3.6.2D
Egyértelmű, letöltés befejeztével kikapcsolja a gépet, ha szeretnénk. De én mégis csak azért használom, mert tetszőleges hangot ad, ha a letöltés befejeződik. ^^ Sajnos ilyet se találtam FF beállításai között, pedig hasznos lenne.AutoPager 0.6.1.26
Legjobb, és legjobban használható kieg ebben a kategóriában. Automatikusan betölti a következő oldalt. Nagyon egyszerűen beállítható, és eléggé ügyesen is. Vannak oldalak, ahol van 50 kép, de egyenként kéne rákattintani, hogy nagyobban lássuk, de van egy NEXT gombocska? (vagy akármilyen nevű gomb ami a következő képet mutatja) Na ezzel pillanatok alatt betölti a képeket, nem sokszorozza az oldalt, csakis a képeket rakosgatja be egymás alá.BetterSearch 2.2
Sok mindent nem lehet erről írni, én Google-hez használom, picit megdobja a keresési élményt, mert bal oldalt kis képeket mutat az oldalról, így akár olvasás nélkül is megtalálja az ember amit keres, és gyorsan skippelheti a kamu oldalakat.Blank Your Monitor + Easy Reading 1.9
Havonta jó ha egyszer kell, mivel most már többnyire nem csinálnak olyan oldalakat amitől az ember szeme kisül, de még mindig hasznos, ha olyan oldalba botlunk, ahol fehér háttérre citromsárgával írnak, vagy esetleg gyönyörű GIF a háttérkép ami villog, és ellehetetleníti az olvasást. Fekete hátteret, Fehér szöveget, Zöld linkeket állít be 1 kattintásra.CuteMenus - Crystal SVG 1.9.3
Must have addon megint. Menüben való bóklászást gyorsítja fel drasztikusan, mert nem kell olvasni, elég az ikonokra figyelni. Jobb gombos menüben is a legtöbb menüpont mellé rak egy ikont.Easy DragToGo 1.1.2.4
Must have. Megint egy olyan addon, aminek benne kéne lennie alapból a FireFoxban! Arra jó, ha pl egy linket gyorsan szeretnénk megnyitni, de háttérben új tabon, akkor csak lehúzzuk a linket. Ha szeretnénk a képet új tabon megnyitni előtérben, akkor csak rákatt és felhúzni. Ha szeretnénk a képet lementeni akkor katt a képre és balra húzni, és máris az előre beállított helyre menti szó nélkül. Nagyon hasznos, és ha jól be van állítva és személyre szabva, akkor bizony meggyorsítja a netezést rendesen.Image Zoom 0.4.4
Must have. És ennek is alapból kéne FF-ben lennie. Akármilyen képre jobb gomb és görgő fel vagy le, és zoom in és zoom out lesz a jutalmunk. Akkor nagyon jó, amikor relatíve kicsi a kép, de lusták vagyunk közelebb hajolni a monitorhoz XD. Jah, és nagyon jó a nagyítás, sokkal jobb mint a legtöbb képnézegetőnél, mert nem pixelesedik, hanem szépen össze mossa a dolgokat.Inline Translator
Működik FF4-en is tökéletesen. Automatikusan a kijelölt elemet, legyen az latin, orosz, kínai, japán, német angol (és még az összes nyelv amit a Google Translate ismer), szépen egy kis lebegő dobozkába (ami nem is doboz végülis). Ha félre kattolsz akkor eltűnik ez a box. Automata nyelvfelismerés, és 5000 karakterig bármit lefordít.keyconfig 20080929
Must Have! Aki más böngészőben megszokta, hogy a CTRL+N az nem új ABLAK hanem új TAB, és nem akar erre rászokni, annak ez az addon kell. De túlképp új hotkeyeket is lehet vele készíteni elég egyszerűen, de a régieket is átszerkeszteni. Vagy ha ismételten csak rendkívül lusta, és nem akarja kitörni az ujjait, hogy CTRL+F4-et nyomjon a tab bezárásához, az átteheti simán F4-re
MR Tech Toolkit 6.0.4
Sokkal komplexebb addon kezelő. Ki lehet menteni vele egy URL-be az addonok nevét/linkjét pár kattintással, nem egy fontos addon, de sok hasznát vettem én már, mikor 100 addonból szerettem volna kideríteni, hogy melyik okozza a hibát.
Egyszerre lehet minden addont letiltani, engedélyezni, kompatibilissé tenni stb..Redirect Remover 2.6.4
Eltünteti az átirányításokat. Egyszerű, olyan oldalaknál, ahol az összes külső linknél átirányítja előbb egy másik oldalra, majd onnan tovább, és ezzel értékes másodperceket veszítve, kapásból az oldalra visz. Egy példa, ebből a linkből:
http://www.ize.hu/click.php?id=16404&url=http://egeszseg.eletcel.hu/szodabikarbonaval-a-rak-ellen/
ezt csinálja
http://egeszseg.eletcel.hu/szodabikarbonaval-a-rak-ellen/Reload 1.0
Nem találtam hozzá linket, de csak annyit csinál, hogy ha bal gombbal kattintok a Frissítés gombra, akkor újra tölti az aktív tabot, ha viszont jobb gombbal, akkor az összes tabot frissíti. Esetleg, ha valaki okos, és ezt kieg nélkül is megoldaná, az szóljon, elküldöm neki a kieget, hogy abból ötletet meríthessen, bár nem egy bonyolult kieg.ReminderFox 1.9.8.3
Ha már érezted kellemetlenül magad, mert elfelejtetted valaki fontosnak a névnapját esetleg szülinapját, akkor megtanulod értékelni ezt a kieget. Beállítva, FF indításkor, vagy akár egy nappal a szülinap előtt, és az adott napon X óránként szól, hogy bizony valakinek szülinapja van. Nagyon hasznos kis találmány!RightBar 0.5
Jobbra teszi a Bar-okat, könyvjelzőket, stb. Userchrome.css-be írva ugyanezt érjük el, így a kieg fölös hozzá, de a kódot onnan egyszerűbb ki copy pastelni
Ezt arra használom barbár módon, hogy balra rendezzem a középre rendezett honlapokat
annó erre a kérdésre jobb választ nem kaptam
így jobb oldalt megy egy videó, bal oldalt meg FF full screenben de mégis balra rendezve!Rights To Close 1.0.3
Dupla jobb kattal bezárja az aktuális tabot. Ez megint csak amiatt, hogy gyorsítsa picit a böngészést.Smart Middle Click 0.5.1.3
Okossá teszi a középső gombos kattintást, és ha csak egy lenyíló menüről van szó, azt nem nyitja meg új ablakban ERROR üzenettel.Sxipper 2.5.3.26130
A lehető legeslegeslegeslegjobb account manager, amit valaha csináltak FF-hez. Nem kell megkeresni a belépő boxot, hanem kijön automatikusan egy kis dizájnos menü, ahol az oldalhoz mentett felhasználónévre kattintva belép automatikusan. Ez nagyon hasznos, ha van 5 e-mail címe az embernek, és nem kell rákattintani a boxra, kiválasztani majd OKÉ-ra kattintani, hanem csak egyet kattintani, és már be is lépett
Text Link 3.1.2009110201
www.google.com, vagy google.hu, az ilyen linkekre dupla kattal megnyitja az oldalt új tabon. Nem alakítja őket linkké, hanem marad szöveg, viszont intelligens módon felismeri kattnál, hogy az egy link akart lenni.Ha kellenek a linkek, és a leírás, küldj privit, és elküldöm egy txt-ben. Szabadon felhasználhatod stb stb...
Majd kéne egy Stylish és Greasemonkey scriptes best of-ot csinálni
BullZeye
Kolléganődet úgy tudod rászoktatni, hogy letiltod, hogy több ablak nyitódjon meg, és átrakod még a hotkeyeket is. Én így csináltam valakinél, és bevált
(#14321) WonderCSabo
Amik ki vannak emelve azok a must have addonok, a többi csak kényelmi szempontból, vagy hogy mindenre fel legyen készülve FF.
BullZeye
WonderCSabo
#14300
Adblock Plus 1.2.2
Adblock Plus: Element Hiding Helper 1.0.6
AutoPager 0.6.1.26
BetterSearch 2.2
Brief 1.2.5
Compact Menu 2 4.0
Converter 0.9.3
Copy Link Name 1.3.1.1
Custom Download Manager 2.6.20091103
Dcurrency 0.4.0
Download Panel 2010.05.31
Download status 1.7.2
DownThemAll! 1.1.10
Fasterfox Extra 3.1.8
FireGestures 1.5.7
Flash and Video Download 0.1
Flash Game Maximizer 1.3.6
Forecastbar Enhanced 0.9.6
FoxClocks 2.6.18
Gmail Manager 0.6.1.1
Google Redesigned 0.5
Grab and Drag 2.7.6
Greasemonkey 0.8.20100408.6
Image Download 1.0.3
Image Zoom 0.4.4
Inline Translator 0.7
iReader 1.0.4
keyconfig 20080929
Memory Fox 1.4.6
Menu Editor 1.2.6
Organize Status Bar 0.6.4
Reload 1.0
ReminderFox 1.9.8.3
RightBar 0.5
Save Complete 1.0.1
Saved Passwords Button 1.1
Screengrab 0.96.3
Simple Timer 1.9
SkipScreen 0.5.7amo
SmoothWheel (AMO) 0.45.6.20100202.1
Stylish 1.0.11
Sxipper 2.5.3.26130
Tab Mix Plus 0.3.8.5pre.100925c
Update Scanner 3.1.3
Vacuum Places Improved 1.1 -
BullZeye
WonderCSabo
#14276
Ez konkrétan 3.6.10-nél jelentkezik.
BullZeye
Jah oké, így már világos. Nem ástam bele magam még, majd ha szükségem lesz rá
Egy kérdés, ez csak nálam van, hogy időnként a könyvjelzők ikonjai megváltoznak? Példának okáért failblog.org ikonja PH-s lesz (faviconról beszélek). De most érdekes módon, egy FFtől független program (lightscreen) ikonja került be a Comixed helyére O.o
Ez mitől lehet?
Nem állandóan jön elő, így sajna kitesztelni nem tudom, tök random, ha rákattolok akkor újra jó a favicon. -
BullZeye
WonderCSabo
#14270
Úgy, hogy feltételezem JS fogja működtetni a D2D tartalmakat, vagyis inkább az hívja meg. Tévedek? Vagy akkor JS nélkül is lehet D2D-t használni egy weboldalon? O.o
BullZeye
WonderCSabo
#14268
Na jó, de az hozzá tartozik. Gondolom JS nélküli D2D nem létezik, vagy igen? Ha nem, akkor végül is eszi a procit is, csak közvetetten
BullZeye
WonderCSabo
#14263
Akkor inkább úgy fogalmazok, hogy már a lehető legolcsóbb, belépő szintű DX10es VGA, ugyanarra képes mint egy csúcsmodell, legalábbis nálam tutira a proci limit miatt, de majd megnézem, hogy mi a helyzet ha felhúzom.
BullZeye
WonderCSabo
#14254
Áh VGAnak nem sok köze van hozzá, legalábbis nálam hd4890-nél 150/200on IS proci limites, ami 2.4Ghz de csak ugye 1 mag. Szóval 1000/1100 és 150/200Mhz között semmi FPS különbség nincs :\ de 25%on hajtja procit 1 magot 100%on...
BullZeye
WonderCSabo
#14250
Veszett gyors ez a D3D10, Fishtankban a 20-23 FPS helyett 30-47 FPS lett. Viszont azt vettem észre, hogy hiába megy 36FPSel mérő szerint, így meg megakad, mintha laggolna. Nálam lesz a hiba, vagy más is tapasztalja? Friss W7 (2 napos) 10.9 ati driver, és üres profil.
Tab animálást meg sajnálom, hogy senki se vállalta el, de az a fura, hogy a videó amit linkeltem pont FF, úgyhogy valakinek ez már kész, akkor hh nem teszik azt bele? :\
BullZeye
Tab animáláson azt értem, ami ie9-ben már benne van, azaz amikor a tabokat húzom jobbra balra, akkor animálva teszi jobbra balra, és csúszkálnak a tabok
remélem elég érhető
BullZeye
WonderCSabo
#14232
Akkor Béta7-ben sem lesz benne a Tab animálás és Dupla katt title barra, ezt azért sajnálattal hallom, remélem nem felejtették azért el őket
már csak ezek kellenének, és bepróbálnám elsődleges böngészőnek FF4-et. Bár a BING egy szar kereső, ha ezzel támogathatom Mozillát, akkor keresek vele majd néha
BullZeye
WonderCSabo
#14192
ASSIGNED státusz annyit tesz, hogy 4 hónap alatt elismerték a hibát, de még nem tudják mikor javítják? :S
BullZeye
WonderCSabo
#14190
köszönöm
BullZeye
FF4ben lesz azzal kezdve valami, hogy dupla kattnál title baron W7-el ne ugorjon kis ablakra? Mert annó olvastam itt erről, hogy javítják, meg bug, de azóta se változott.
BullZeye
WonderCSabo
#14164
Szóval a nightly-ban nincs még benne az új JS motor? O.o És mikor kerül bele?
Na meg a tab animáció mikor kerül be? És van hír arról, hogy Microsoft mikor javítja ezt a bugot a D2D-vel? -
BullZeye
WonderCSabo
#14162
Én most a 4.0ról beszélek, és a bétáiról, és arról, hogy nem veszem észre, hogy fejlődne, javulna, gyorsulna egy ideje. Mintha 1 helyben totyogna az egész project 1 hónapja.
BullZeye
WonderCSabo
#14160
Hourly build egész pontosan tegnapi, és ennyi volt 3-4 hete is, na jó, volt 460ms is.
BullZeye
WonderCSabo
#14153
Nem, egy fikarcnyit sem! 471ms
BullZeye
Annyira ne sürgessük ... annyira béta még ez a béta, hogy otthoni használatra még mindig nem jó. Egyébként én még mindig nem veszek észre semmi javulást, gyorsulást, még mindig 460ms körül mozog a benchmark. És még mindig nem rakták bele a tab animációkat. Egyszerűen nem halad előre a project látható módon (értem én, hogy új motor, javítják stb, de akkor is ...)
Fikarcnyit sem gyorsult már hetek óta a d2d, a megjelenítéssel is bajok vannak, mert ugye Microsoft nem lép semmit...úgyhogy szvsz még nem érett meg ez egy RC-re. -
BullZeye
WonderCSabo
#14021
Total Commanderbe érdekes módon nekem is jó, viszont ha MSNre húzom be akkor már a borred.jpg hirtelen jyixzv.BMP lesz
Btw van valami lehetőség arra, hogy a cookie-k lejárati idejét felülírjam? Régen kipróbáltam egy kieget, azzal megváltoztattam, viszont ahogy újraindítottam FF-et, vagy újra betöltöttem az oldalt, máris elfelejtette és az oldal felülírta magát, így egy-két oldalnál 1 óráig marad csak bejelentkezve -.-
BullZeye
Hülye kérdés tudom, de ha telepítem, és ha csak simán kicsomagolom az FFet van köztük gyorsaságban különbség? Soha nem telepítek FF-et, mindig csak zip, lehet ebből hátrányom?
BullZeye
Nézegettem ezt a benchmarkot, 2200 a 3.6.10 és 3600 az ff4, de szinte végig 25%on megy proci azaz 1 magot teljesen kihasznál ... és mivel alul van feszelve, ezért rohadtul idegesítő, és egyre jobban idegesít, hogy 1 magot használ csak ki ><
BullZeye
WonderCSabo
#13891
És a kiegészítők amik 32bitesre íródtak működni fognak 64 bitesen is?
BullZeye
WonderCSabo
#13881
D2D-t nem szidtam, vagy legalábbis azzal különösebben bajom nincs, de mint írtad az okát, az ie ha csak picivel is, de gyorsabb.
Én is megrögzött FF fan vagyok, nem véletlenül használom csak azt, IE-t csak akkor indítok, ha valami nagyon nem megy, Chrome pedig annyira megy, hogy kipróbálom minden másodikat portable-be v1-v3-v5 kb 20 perc erejéig, és szörnyülködök mennyire nincs rá addon (bár már lehet van).
És nekem kell az a kis plusz, hogy böngészés közben minden szép és smooth legyen, és csúszkáljanak a dolgok és legyen folyamatos és fusson 60FPS-el és ne sajnálja rá a procit, vagy a VGA-t. És télleg illett volna berakni a 4 magos támogatást már most. És pont ezért idegesít rettentő módon, hogy ott van 4 mag, 4 giga memória, hd4890, és ha csak egy pillanatra is, de néha néha beszaggat 3.6, és ahogy használtam most 4.0-t az is (addonok nincsenek fent, teljesen szűz profil így nem amiatt van, és ha ez még lassúlni is fog
). Szóval ezért bosszantó ez az egész.UI részében nem az elrendezése, hanem a gombok szépek, igaz picit gagyi hatása van annak a sötétszürke-világosszürke átmenetes bar-nak
és az UIban tényleg az tetszik, hogy akárhova kattintok, annak egy szép animációja van, és nem olyan win98 hatású odakattolok és ott terem.A fejlesztés valóban lehetne gyorsabb, de sajnos be kell látnom, hogy IE-t egy milliárdos vállalat fejleszti ahogy a chrome-t is, mozillát pedig nem
Viszont azt is megmondom őszintén, hogy nem nagyon veszek észre javulást már egy jó ideje. Javítgatják a dolgokat biztos, de egyik sem mondható túl szembetűnőnek. D2D és az AA dolog már kezd jó lenni, ékezetes betűk még mindig nem az igaziak, de azon látom, hogy javulgat, de más nem. Az UI ezer éve is pont ugyanígy nézett ki, status bar még mindig ott van, a csúszkás tab mozgatás még mindig nincs, ami újdonság, hogy a címsor alatt fut már egy kék csík a betöltődést jelezvén. -
BullZeye
WonderCSabo
#13869
Nah most használtam fél-fél órát mind2 újoncot, amit linkeltél, és a tegnapi ie9-et.
Piszok gyors mindkettő, mindent megjelenített amit néztem ugyanúgy mindkettő (IE-ben egy ismerősöm hot-dog profilja elbukott, nem volt háttér meg jó pár elem). Ami különbséget találtam, és bosszant, hogy az IE9-ben az ilyen lenyíló effektek, vagy az egér görgetése sokkal gördülékenyebbek, szebbek, jobbak. Az FF-nél viszont minden ilyen dolog darabos, mintha beakadna, de nem, viszont mégis zavarja az ember szemét, ha egymás mellett van a kettő. Pl az új tab nyitásánál amikor jobbra kinyílik az IE-nél sokkal szebb. Úgy tudnám az élményt leírni, mintha az egyik 120FPSel menne, a másik pedig 30, a 30FPS sem akad, viszont észrevehető a különbség a kettő között.
FFnél, ha a smooth scrollingot bepipálom, akkor olyan mint valami katasztrófa
legalábbis, ha a most használt SmoothWheel kieg tudásához, teljesítményéhez mérem ... szóval ilyen görgetés van, de minek ...
Ahol sok reklám van, ott IE észrevehetően szebben jobban görgőzik mint FF. És gyorsabban is.Indulásban ez az FF már picit gyorsabb mint amit tegnap néztem, de még így is le van maradva IE-től.
Remélem a Mozillának sikerül felzárkóznia, és berakják ezt a tab mozgatásos csilivili dolgot, amit már linkeltél korábban, és ami túlképp IEben már most bent van. Meg jó lenne, ha pár profi grafikust is alkalmaznának, és utolérnék végre IE-t meg Chrome-ot -.-
Nem kell elkezdeni szidni amiatt, mert van egy szubjektív véleményem, ahogy megéltem egymás után/mellett a 2 böngészőt FF párti vagyok, azt használok azt is fogok, de attól még baromira zavar, hogy IE jobb/szebb mint FF ebben a pillanatban.
BullZeye
BullZeye
#13829
Ahhoz képest, hogy mennyire rossz híre van alapvetően az Internet Explorernek (mert ugye menő szidni valamit amit mindenki szid). Azt kell mondjam, jobban tetszik mint az FF4. Értelemszerűen nem fogom használni, mert hiányoznának az addonjaim, viszont aki addon nélkül használja FF-et az elgondolkodhat, hogy vált IE-re, mert tényleg piszkosul gyors, és szép. Egyszerűen kellemes érzés használni, ahogy minden siklik elcsúszik eltűnik de tökéletesen. FF4-ben hát
azt hittem, hogy az jó és szép, de most már nem
De a címsor fura, hogy a tabok mellett van, vagy a tabok vannak a címsor mellett, nézőpont kérdése
A status-bar meg hát ja, így kéne megoldania FF-nek is. Akinek kell bekapcsolja, akinek nem, az meg eltűnteti, és csak akkor jön elő egy kis szöveg amikor feltétlen szüksége van rá
cserébe +20px amit lát az oldalakból...Még egy kis adalékinfó
IE9, 500ms alatt indul el
FF4, 2600ms alatt indul elMindkettő szűz install, mindkettő teljesen új profillal rendelkezik túlképp, mégis 5x gyorsabban elindul IE
BullZeye
Internet Explorer 9b1 elég gyors legalábbis a D2D gyorsabb mint eddig akármelyik FF volt. Bár néhol a teszteknél érezhetően csal, pl azt írja 1000 halnál, hogy 40 FPS, de 1-1 pillanatra néha beakad, és sztem nem több mint 25-26 FPS ahogy fut, mert nem folyamatos.
És a Javascript benchmark is gyorsabb: 408ms
És úgy alapvetően szebben, jobban jelennek meg a html5 oldalak (pl vannak hangok), javascript benchmark is normálisan látom hogy mit mér épp és hány ms, igaz pörög mint állat, de legalább nem csak egy üres téglalap.
Microsoft ezzel tényleg nagyot mutat. Jah és érdekes módon a D2D szöveg valamivel szebbek mint FF esetében, aztán lehet csak már kezd hozzá szokni a szemem, viszont itt is AA van rajta.
BullZeye
pete_21
#13771
Tulajdonképpen ez nem cleartype, hanem egyfajta AA - élsimítás. Azaz ahelyett hogy egy pixeles vonal lenne az A betű, most elmossa a szélét, hogy szép legyen. Ennek köszönhető, hogy ilyen rusnya lesz. Csak egyszerűbb volt elnevezni Cleartypenak, mert ugyanúgy néz ki, és mindenki tudja miről van szó
BullZeye
Azt valahogy be lehet állítani, hogy csak bizonyos oldalakon tiltsa az új tabon/lapon való megnyitást?
Mert amit találtam rá annó, az csak mindenre jó, viszont így a youtube beágyazott videóknál se nyitja meg új tabon, amikor indokolt lenne, és a flash-re hiába nyomok középső gombot
Vagy flashen kívül minden más esetben új lapon való megnyitás tiltva legyen, ennyi lenne a kérésem
BullZeye
A mai Trunks build (9.12) az eddigi legjobb ^^ több pontot ér el mindenben mint eddig még ha csak 2-3%al is de akkor is
1000 halnál 24-25 FPSel fut, eddig 18-19 volt
Ja és a javascript teszten is 430ms volt az átlag.
Btw, itt azt írja, hogy kell h264 codeck a böngészőbe, ezt vajon alapból belefogják rakni, vagy telepíteni kéne hozzá codeck packot? :\
BullZeye
Erről a betüsimítás dologról azt írták annó, hogy beta5-re kijavítják, de még a napi buildben is hibás. Teljesen mások a fontok mint lenniük kéne. Ugye ezt nem hagyták félbe, és dolgoznak rajta még....
BullZeye
Winner_hun
#13715
Ezt nekem akkor csinálta, mikor volt Profilom, de mappa nem volt meg
azaz volt default profile de az a mappa hiányzott.
Úgyhogy nézd meg mi a default mappa és csinálj oda egy olyan nevü mappát. Hátha segít, ha ez nem az a hiba, akkor passzolok, mert csak portable FFnél volt ilyen baj :\ -
BullZeye
WonderCSabo
#13701
Ha meg az a baj, amiket nézel, azt így is, úgy is megtudják nézni, ha akarod, ha nem
BullZeye
WonderCSabo
#13687
oké, én azt szeretném, ha megnyomom a spacet, akkor görgesse le az oldalt, erre van megoldás?
Na meg flashben amit lejátszik benne van, hogy milyen hotkeyekre reagál....és ctrl+n és ctrl+t nincs köztük, akkor azt miért nem képes FF rendesen használni?
Avant Browserben érdekes módon 4 évvel ezelőtt is tökéletesen jól meg volt ez oldva, és a mai napig működik ....
BullZeye
Arra van valami megoldás, ha véletlenül Youtube videóra kattintok, hogy play, akkor attól még működjenek a hotkeyek? pl új tab nyitása stb...
Ahogy valami flash tartalom lesz aktív, egy csomó hotkey megszűnik működni...
BullZeye
Ez a Frissítés + Leállítás + Ugrás gomb nem nyerte el a tetszésemet :\ az ötlet jó, viszont őszintén, hány ember kattint böngészés közben az ugrás gombra? :\
Csak én vagyok ennyire mamlasz, hogy ha beírok egy címet, akkor kisujjal megnyomom az entert? Ha lehetne egérrel gépelni, akkor megérteném a dolgot, de nem lehet. Így most csak azt érték el, hogy azt a gombot amit gyakran használok kissebbek, és elrejtették.
Lehet, ha tovább használok, akkor nem bal oldalt fogom keresni, de így most tönkre tették a törékeny Feng Shui-t XD
Abban reménykedek, hogy ahogy 3.6-ban egy kieggel a MENU-t lelehetett kicsinyíteni egy Gombra, vagy egy Menü szócskára, ezt megcsinálják FF4-ben is....Meg miért nem rendelnek a menüpontokhoz sose ikonokat? sokkal egyszerűbb lenne, ha csak az ábrákat nézné az ember elsősorban, ha keres valamit :\ ff3-ban van erre kieg, de egyenlőre ff4-ben nem müxik rendesen ... nem is értem ezeket, kicsinyítenek mindent, de ilyenekre nem gondolnak, pedig nem lenne hülyeség, főleg, hogy már van ilyen, csak bele kéne rakni FF-be.
Jah, az kimaradt, hogy 2-3 naponta Trunks buildet felrakom megnézen, és a D2D egyre rosszabb! eddig 1774 volt amit a psychedelik-kel elért, most már csak 800 :\
BullZeye
pete_21
#13572
Szó szoros értelmében napról napra szebb, nekem spec a honlapok már jók, viszont itt pl az xyz válasza szóban az á meg az l betű soxor túl közel vannak egymáshoz, DE nem mindig, ez a fura benne.
Nem mosódottak a betűk, egyszerűen csak a megjelenítésük picit fura, túl közel van 1-2 betű, és így összenőnek. Viszont naponta javítják ezeket, úgyhogy talán a mai már hibátlan is, utoljára 4.én raktam fel.
Ami még nem volt jó, az awesomebar-ban lévő szöveg még mindig homályos...meg a keresősávban, viszont a honlapok már alakulnak
BullZeye
Ejj ráér az ám, hátha upgradeli és megcsinálja rendesen az alkotója
Mert ahogy nézem picit több hiba is van benne, pl .hu-s google imagesnél nem hozza be a nagy képeket meg ilyenek ... Úgyhogy van, de mégsem.
Egeret meg már néztem, de ami alakra megtetszett 30k -.- annyit meg egy VGA-ért nem adnék most már
(na jó de, pont annyit
BullZeye
Szerintetek mennyi esélye van annak, ha kérek egy ilyen feature-t, hogy ha gyors egymás utáni görgetés van, akkor 3x sebességgel görgőzzön. (pl ha gyorsan a lap közepére akarok jutni, de nem akarom becélozni jobb oldalt a scrollt, vagy épp nincs is scroll) Akkor azzal foglalkozni is fognak..?
BullZeye
WonderCSabo
#13555
Kiléptem FFből, felraktam amit Matthewus linkelt, nekem még mindig azt írja ki, hogy hiányzó bővitmény, és hogy windows media player 11 kell hozzá. Más ötlet?
BullZeye
Gyurek
#13545
Nekem dettó ugyanez van. 5 esetből 3x csinálja ezt.
Bezárom, ott marad a firefox.exe, nem mellesleg 600-700 mega memóriát eszik, és 1 magot teljesen kihajt. És ezt csinálja percekig, vagy lenyomom feladatkezelőben...Ez akkor idegesítő, mikor csak újraindítom a firefoxot és kattolok az újraindítás gombra, de csak nem akar elindulni. Eddig azt hittem, hogy kieg miatt van
és csak nálam, de ennek "örülök" hogy nem vagyok egyedül
BullZeye
WonderCSabo
#13539
Ezen már alakul a D2D és a betűk elmosódása dolog. Nem mosódik el prohardver, viszont most meg 1-2 betű feltűnően közel áll egymáshoz
de legalább már látom a javuló tendenciát
Egyébként statusbar kiváltása szvsz nem lenne túl jó dolog. Nekem spec 13 dolog van rajta, pl gmail manager, vagy az aktuális USD ár, flash videó download, letöltés manager, RSS olvasó és ilyesmik.
Ha lent eltűntetik, és felülre jönne +1 sor bar akkor ugyanott lennének
legjobb lenne, ha 150 pixeles közelségbe kerül a kurzor, akkor elősiklik szépen. (azért 150px, mert ha valaki 2 sorba használja a tálcát, akkor is előjöjjön neki
BullZeye
WonderCSabo
#13534
trunk build ami naponta raknak fel
hourly amit óránkéntTudsz adni a trunk-hoz egy linket ahol lelehet tölteni az aktuálisat?
BullZeye
WonderCSabo
#13528
Na de mire megyek vele, ha pl google images-ben 100%osan kihasznál 1 magot, és be-be akad emiatt, mert alul van feszelve proci, és nem hajtom böngészésre 3.2 ghzen, pont a fogyasztás miatt.
És 4.0-ban is gyakran volt, hogy egy egy oldal scrollozásnál, vagy egyszerűen a sok betölteni való miatt görgetés közben akadozott...holott simán elég lenne hozzá a gépem fele is, de ha egyszer a tizedét SEM használja ki ...
Na meg mondjuk az emberek a gépnél töltőtt idő bő 80%ánál böngészőt használják, és még mindig nem egyértelmű, hogy kéne mind a 4 mag hozzá? Amikor 3 éves játékok, és több régi program már rég kihasználja a több mag adta lehetőségeket? És már sok sok éve jelen vannak a dual core procik?
Meg amikor ne adj isten csinálok valamit közben a háttérben, és 1-2 másodpercet kell várnom, hogy a rákattolt tab-ra menjen, mert mondjuk nem 2 addont használok, hanem többet ... és mondjuk a másik futó folyamat is pont azt a magot terheli. Én meg csak azon gondolkozom, hogy akkor most félre kattintottam, vagy nem reagált még rá? És akkor hirtelen bejön az oldal. Na EZ a frusztráló rész. (de ez 3.6nál van, 4.0át huzamosabb ideig nem tudtam használni, mert fáj tőle a szemem.)
És még sorolhatnám amikor beáll az egész pár másodpercre, holott lenne craft neki, csak baszik használni.
BullZeye
WonderCSabo
#13526
Na jó, de 2010et írunk, már a 3.0-ban is alapvető lett volna, hogy 4 magot használjon, hisz már hányadik generációs 2-4-6-8 magos processzorok jönnek ki most ... érted?
A GPU gyorsítás meg egy jó dolog, viszont ha nem használja ki azt sem rendesen, akkor megint csak 2-t előre, 1-t hátra. A 4.0 is még ezer éve mire kijön, és a tendenciájukat ismerve jövő ilyenkor lesz béta abból, ami használ több magot -.-
BullZeye
WonderCSabo
#13522
Persze hogy gyorsabb, de akkor is frusztráló, hogy nem használ több magot, csak 1-t, és hogy VGAnak is csak egy rendkívül kis részét ... és ez egy 2 éves gép, most gondolj bele akinek egy új erőműve van 6-8 maggal, és akkor még mindig akadnak neki dolgok FF4 bétában
frusztráló na ... -
BullZeye
WonderCSabo
#13518
Most kipróbáltam ezt én is, 1 egész magot megevett fishtank, és alig használta VGA-t :\ azaz hiába raktam fel 150/200ról 500/600-ra vagy 950/1050-re nem változott semmit az FPS, maradt 20-23.
Első HSZ-be meg rakd be a teszteket is d2d-re meg webgl-re. Állandóan elkeverem őket, és sose találom csak jó pár perces keresés után
BullZeye
Van valahol a hourly buildekhez leírás, hogy abban az órában épp miket javítottak ? Csak hogy ne kelljen naponta leszedni FF-et, hogy megtudjam berakták e a Cleartype nélküli d2d-t?
BullZeye
huskydog17
#13443
FF-ben kapcsold ki azt, és tedd fel ezt a kieget.
Ezen be lehet állítani, hogy ha lassan görgetsz milyen gyorsan menjen, ha gyorsan milyen gyorsan, és természetesen nem ugrálósan, hanem simán, ahogy azt kell, és ahogy be is rakták FF-be csak ugye itt eléggé lassúka
BullZeye
WebGL bekapcsolása
about:config
webgl.enabled_for_all_sites -> TrueItt pedig vannak hozzá tesztek
http://www.khronos.org/webgl/wiki/Demo_Repository -
BullZeye
WonderCSabo
#13426
köszi az infót, remélem hamarosan belekerül
Az mikor lesz FF-ben, hogy kihasználja mind a 4 magot procin? google images eléggé szipkázza procit, de abból csak 1 magot használ, így elég gáz, bár D2Dvel nem olyan rossz, de azért mégis. -
BullZeye
WonderCSabo
#13424
Remélem egy hourly buildben is javítva lesz a D2D, és nem kell heteket várni béta5-re
És amíg van IE6 addig FF sose lesz a legszarabb/leglassabb böngésző a piacon, és még van IE6 és lesz is sokáig. -
BullZeye
BullZeye
Meg lehet az oldani 4 bétában, hogy ha menüsort eltüntetem, akkor ne jöjjön elő a "Firefox Gomb" és maradjon meg legfelül a Windows headline-ja? Vagy hogy hívják?:S Ahol oda van írva, hogy RIOS:Hozzászólás írása - Téma: Mozilla Firefox - Mozilla Firefox.
Mert ha menüből kiveszem a pipát, akkor eltűnik, és ahelyett, hogy 1 sor eltűnne, eltűnik 2 ><2)
Avant-ban régen volt ilyen, ha Historyban ugráltam előre hátra, akkor pillanatok alatt tette, szóval 10 lapot simán visszatudtam menni 1-2 másodperc alatt. Viszont FF-ben ha backet nyomok akkor betölti az oldalt, és addig nem is tudok visszamenni. Ez ellen lehet tenni valamit?
Gyorsabb History Go-Back -
BullZeye
HZoli87
#13416
És még mindig szutyok a D2D, és még mindig kifolyik tőle az ember szeme, még mindig van rajta egy erős élsimítás, ami nem kéne. >(
Ez az egyetlen igazán látványos hiba benne, ami sokakat zavar, és emiatt nem lehet használni huzamosabb ideig -.- nem hiszem el, hogy még mindig nem csinálták meg...oké hogy béta, de bakker 4 béta és csomó prebéta után még mindig nem csinálják meg...félek, hogy ez marad is így , mint FEATURE, és nem BUG -.- -
BullZeye
pete_21
#13407
Az addon manager jelenleg TABon jelennek meg, nem külön ablakban. És Nem érdemes lecserélni, mert sajnos itt már nem müxik az ami 3.0->3.5nél volt, hogy csak átírom a MAX verzió számot az addonoknál és működik rendesen, egyszerűen csak nem megy.
10ből 3 régi kieg müxik, 2ből pedig a saját honlapján van egy új béta verzió az addonokból, de maradék 5höz még nincs semmi átlag.
Úgyhogy én is gondoltam áttérek, mert gyors és szép és jó, aztán 1 nap vele foglalkozás után maradt másodlagos böngésző.
BTW meg lehet az oldani, hogy ha menüsort eltüntetem, akkor ne jöjjön elő a "Firefox Gomb" és maradjon meg legfelül a Windows headline-ja? Vagy hogy hívják?:S Ahol oda van írva, hogy RIOS:Hozzászólás írása - Téma: Mozilla Firefox - Mozilla Firefox.
Mert ha menüből kiveszem a pipát, akkor eltűnik, és ahelyett, hogy 1 sor eltűnne, eltűnik 2 >< -
BullZeye
Steelmanus
#13392
nem ezt kérdezte, mmint ez eddig is engedélyezve volt, és MÉG MINDIG bugos, és még mindig el van mosódva minden.
BullZeye
Zsolteaa
#13381
Akkor hogy lenne okoska? Magyarázd meg kérlek, hogy az internet felhasználók 23%ából akik FF-t használnak hh csak neked és még pár hülyegyereknek nem megy rendesen ?
Ehhez mit szólsz? Egyébként vírus vagy trójai szerinted milyen, ha nem olyan, hogy egyszer csak elkezdi tönkre tenni a dolgokat? Úgy gondolod, hogy az ahogy telepíted a gépet már rögtön ott lapul? Kevesebb homopornót kéne nézned, és nem másznának fel az ilyen programok a gépedre!
BullZeye
Avant-ban régen volt ilyen, ha Historyban ugráltam előre hátra, akkor pillanatok alatt tette, szóval 10 lapot simán visszatudtam emnni 1-2 másodperc alatt. Viszont FF-ben ha backet nyomok akkor betölti az oldalt, és addig nem is tudok visszamenni. Ez ellen lehet tenni valamit?
BullZeye
Zsolteaa
#13377
Windows 7, x64-em van, és sok szerencsét az új böngésződhöz
és még 6 gépem amit én telepítettem, egyiken se crashel, úgyhogy ne a mozillát szidd amiért egyesek felraknak valami szutyok programot, esetleg vírus, trójai, vagy akármilyen kártevő miatt instabil lesz pár program. -
BullZeye
Zsolteaa
#13373
Ne a mozillát szidd, mert béna vagy, vagy nem értesz hozzá, esetleg szar a windowsot, vagy szar a géped
Nálam is meg van nyitva 10-15 tab, egyrészt nem crashel, másrészt ha kilépek ott figyel az összes tab. Úgyhogy ha legalább 1 embernél jó, akkor onnantól kezdve a hiba nálad van.Mellesleg 60 Addon van fent, amik egymásnak betesznek, mégis stabilan müxik
BullZeye
BullZeye
#13352
Sőt , most hogy így nézegetem nekem az is elég lenne, ha a menü bar-t eltüntetném, de minden más maradna, viszont ha menu-bart kiveszem a megjelenítettek közül, akkor meg eltűnik felül az a rész, ahol írja, hogy milyen oldalon vagyok, meg egy firefox ikon bal oldalt stb....
BullZeye
Hümm, egy problémám lenne, méghozzá W7 és az FF4 miatt. Eddig ugye az volt nálam, hogy ha dupla kattolok egy tabra, akkor az bezáródott, ha üres részre kattolok, megnyitja a legutóbb bezárt lapot.
Na, ha most oda kattintok, ahol nincs tab, azaz megnyitnám a legutóbb bezárt tabot, akkor egyszerűen csak összemegy az ablak, mert ugye most az a fejlécként szerepel
Ez ellen lehet tenni valamit? Pl valami + felületet fölé vinni, vagy nem tudom...
Mert számomra hasznos kis funkció volt ez
BullZeye
BullZeye
#13348
Na még1 amit be kéne rakni. Smart Middle Click
Ez pedig arra jó, hogy a Javascripteket ne akarja megnyitni új ablakban/tabban, ha középső gombbal kattint rá az ember. (értelemszerűen az üres lap megnyitását előzi meg pl ott, ahol lefelé nyílna meg a content a javascriptre kattintva)gBrowser = document.getElementById("content");
gBrowser.addEventListener("click", SMConClick, true);
function fixupAURL(aURL) {
var str = '^(https?\:|ftp\:|news\:|mailto\:|smb\:' +
'gopher\:|about\:|file\:|cache\:|javascript\:|' +
'x\-jsd\:|jar\:|resource\:|data\:)'
var re = new RegExp(str, 'i');
if (re.test(aURL)) {
return aURL;
else {
var urifix = Components.classes['@mozilla.org/docshell/urifixup;1'].getService(Components.interfaces.nsIURIFixup);
var loc = urifix.createFixupURI(getBrowser().currentURI.spec, 0);
var host = loc.host, path = loc.path, proto = loc.scheme;
if (aURL[0] == '/') {
path = '';
else {
path = path.replace(/(.+?\/?)[^\/]+?$/, "$1");
while (/\.\.\//i.test(aURL)) {
aURL = aURL.replace(/\.\.\//i, '');
path = path.replace(/(.+?\/?)[^\/]+?\/$|([^\/]+?\/?)$/, "$1");
if (path[0] != '/') {
path = '/' + path;
return proto + '://' + host + path + aURL;
function SMConClick(aEvent) {
if ( (aEvent.button == 1 || (aEvent.button == 0 && (aEvent.ctrlKey || aEvent.shiftKey)))
&& contentAreaClick2(aEvent) )
aEvent.stopPropagation();
function contentAreaClick2(event)
var target = event.target;
var linkNode;
if (target instanceof HTMLAnchorElement ||
target instanceof HTMLAreaElement ||
target instanceof HTMLLinkElement)
if (target.hasAttribute("href"))
linkNode = target;
else {
linkNode = event.originalTarget;
while (linkNode && !(linkNode instanceof HTMLAnchorElement))
linkNode = linkNode.parentNode;
// <a> cannot be nested. So if we find an anchor without an
// href, there is no useful <a> around the target
if (linkNode && !linkNode.hasAttribute("href"))
linkNode = null;
var wrapper = null;
if (linkNode) {
wrapper = linkNode;
var is_js = wrapper.href.indexOf('javascript:');
var pound = wrapper.href.charAt(wrapper.href.length-1);
// Check if URL has 'javascript:' in it
if (is_js != -1) {
var jsParts = wrapper.href.split("'");
rawHref = jsParts[1];
if (rawHref) {
newHref = unescape(fixupAURL(rawHref));
handleLinkClick(event, newHref, linkNode);
// If extraction fails, try the onclick attribute
else if (wrapper.getAttribute("onclick")) {
var ocParts = wrapper.getAttribute("onclick").split("'");
rawHref = ocParts[1];
if (rawHref) {
return true;
// Check if URL ends in '#'
else if (pound == '#') {
if (rawHref) {
return true;
return false;
BullZeye
x123456
#13346
greasemonkey van fent, de abból is szeretnék kivenni mindent ami nem muszáj, hogy ott legyen, hogy még véletlenül se lassítsa a böngészőt, mert ennyi kiegnél az az igazság, hogy rettentően belassul az egész.
Itt van még1 amit szeretnék kieg nélkül megoldani valahogy, hogy dupla jobb klikkel bárhol az oldalon bezárja a tabot.
Jelenleg 60 addon van fent, és pain in the ass kidereíteni, hogy mi mivel ugrik össze, egyenként letiltogatni, így most szeretném a felére redukálni, és kapásból FF-be integrálni azokat, amiket csak lehet.if(!net) var net={};
if(!net.shan) net.shan={};
if(!net.shan.developer) net.shan.developer={};
net.shan.developer.myActionDblClk = function (event) {
if (event.button == 2)
//close current tabl if available
if (getBrowser().mTabContainer.childNodes.length > 1)
document.getElementById("contentAreaContextMenu").hidePopup();
getBrowser().removeCurrentTab();
else
var prefSvc = Components.classes["@mozilla.org/preferences-service;1"]
.getService(Components.interfaces.nsIPrefService);
var prefBranch = prefSvc.getBranch("extensions.rigthstoclose.");
switch(prefBranch.getIntPref("lasttabclosure")) {
case 0:
getBrowser().addTab("");
break;
case 1:
BrowserTryToCloseWindow();
break;
default:
//start window event capturing
window.addEventListener('dblclick', net.shan.developer.myActionDblClk, true); -
BullZeye
FF-ben valahogy a userchrome.css-hez hasonlóan lehet használni scripteket?
Szeretném minimalizálni az addonok számát, és van 1-2 ami csak azért felel pl, hogy ha jobb gombot nyomok a reload gombra, akkor minden tabot frissít, ha bal gombbal akkor csak az aktívat. Meg más egyéb hasznos, de általam nem használt dolgot csempészik bele
Valami tipp, hogy hogy tudnám megoldani egyszerűbben, mint az Addon telepítése? Nekem télleg elég, ha jobb gombbal minden tabot frissít. Többi fölöslegesfunction reload(shift, ctrl, alt, button){
var nsIWebNavigation = Components.interfaces.nsIWebNavigation;
//ctrl and alt passed for completeness and to make any subsequent upgrades easier
if(shift){ //Reload pages from server
switch(button){
case 0:
//Left Button - Reload page
BrowserReloadSkipCache();
break;
case 1:
//Middle Button - Load page in new tab
var url = window._content.document.location.href;
var tab = gBrowser.addTab("about:blank");
gBrowser.selectedTab = tab;
gBrowser.loadURIWithFlags(url, nsIWebNavigation.LOAD_FLAGS_BYPASS_PROXY | nsIWebNavigation.LOAD_FLAGS_BYPASS_CACHE, null, null);
break;
case 2:
//Right Button - Reload all tabs
var l = gBrowser.mPanelContainer.childNodes.length;
for(var i = 0; i < l; i++) {
var b = gBrowser.getBrowserAtIndex(i);
try {
b.reloadWithFlags(nsIWebNavigation.LOAD_FLAGS_BYPASS_PROXY | nsIWebNavigation.LOAD_FLAGS_BYPASS_CACHE);
} catch(e) {}
break;
default:
break;
}else{ //Reload pages from cache
switch(button){
case 0:
BrowserReload();
break;
case 1:
var tab = gBrowser.addTab(window._content.document.location.href);
break;
case 2:
gBrowser.reloadAllTabs();
break;
default:
BrowserReload();
break;
BullZeye
huskydog17
#13342
Tudom azt jól, ki is lőttem addig, le is játssza, de nekem az kell, hogy letöltse, hogy húgom NE Flashplayerrel nézze meg, mert FF-ben Chrome-ban neki akad, viszont lejátszóban jó lenne. Szóval nekem olyan kéne amivel innen le lehetne tölteni.
BullZeye
huskydog17
#13336
És le is tudod vele tölteni? Mert nekem az istenért nem sikerül
BullZeye
Üdv
Húgom nézi ezt az oldalt, és eléggé akad nála a videó, 2500+os proci miatt. Ezért gondoltam letöltöm neki, viszont amit én használok flash-videó letöltő nem működik, azaz csak egy 17kbájtos fájlt tölt le ... vagy semmit.
Van aki ezt le tudja szedni? És ha igen, akkor melyik kieggel?
BullZeye
WonderCSabo
#13317
Csak ezt a HSZt olvastam amire válaszoltál azt nem, és hirtelen úgy megörültem, hogy végre a kiterjesztések is külön processként fut, és ha egyik befagy, akkor nem rántja az egészet magával, de ezexerint nem T_T
Erről lehet tudni valamit, hogy picit kompatibilisebbé tegyék az Addonokat? Mert egyrészt lassan indul ha sok van, másrészt rettentő mód belassul, harmadrészt meg ha kifagy valami akkor viszi az egészet, bár ez ritka...
BullZeye
Steelmanus
#13254
Használnám a CCC-t, ha fele annyi dolgot tudna mint az ATT, vagy legalább azokat amikre szükségem van, de nem. A Flash ugyanúgy lehet ludas, vagy egy másik komponens a gépén, mert nálam pl ilyen probléma nincs. Azaz Flash tökéletesen megy, és az overlay funkció is egyszerre. Egyetlen egy DirectX verzióval volt bajom, azzal amit usiteról szedtem le. Minden mással tökéletesen megy, azaz az ő DirectX-ük a ludas, nem az ATT.
CCC-vel nem volt semmi bajom, de pl nem lehet beállítani rajta külön 3D profilokat, hogy alapból 150/200on fusson hd4890, vagy hogy legyen egy köztes profil is ami 400/500, mert játékok jó részének nem kell 950/1100-as órajel, akkor meg minek hajtsam maximumon? Úgyhogy valszeg azért nem volt bajom, mert nem tudtam megfelelően használni.
(#13255) Koczka
Egyszerű, állítsd be mozbackup-ba hogy PORTABLE és add meg a profil helyét (user mappa stb) akkor onnan ki tudsz menteni bármit. -
BullZeye
Baboon
#13252
Ha neked is az a bajod, akkor írd le honnan szedted te le, mert érdekel
Egyébként ja, és a legbosszantóbb, hogy azt se mondja fapapucs, csak hogy appcrash. Hiába jó ez a W7, hajadra kenheted ha valami nem indul el, akkor sose fogod 100%ra megtudni, hogy a memóriáid haldokolnak, vagy a program hibája, vagy 2 program akad össze...
BullZeye
Baboon
#13250
Nekem ugyanez volt a probléma, és sose találnád ki, de a DirectX lesz a ludas. Usite.hu-ról töltöttem le, és egyszerűen fagyott mindenhogy, 5-6x raktam újra a win7-et és egyenként próbálgattam ki progikat, mire kijött, hogy a DirectX a hibás, szedd le máshonnan, vagy valami új játékból vagy webinstallerrel tedd fel.
(nekem ez 1 napos megfeszített tesztelés volt)
BullZeye
enginev3.0
#13215
lehet, pl beállítani, hogy alul legyen ...
BullZeye
Matthewus
#13202
De lehet, itt le is töltheti. Azért nem linkeltem eddig, hátha mondanak egy újabb megoldást
3.6.8 on tuti müxik 4en még nem próbáltam de 3.7pre-n ment. Viszont gáz, hogy még mindig nem raktak be ilyet FF-be. Nekem pl 1 a CTRL+N az új tab, mert nem használok soha, le is van tiltva, és így szoktam meg .... és gáz, hogy az emberre rá erőltetik a CTRL+T-t. -
BullZeye
Steelmanus
#13192
HD4890-el, ha 150/200 az órajel akkor 19 FPS, ha 950/1100 akkor pedig 39 FPS. De előző bétákban ez volt ennél sokkal gyorsabb is, 150/200on 60 FPS.
● Olvasd el az összefoglalót!
● Mozilla blog az ITcafé-n.
- Apple iPhone 17 Pro Cosmic Orange 256GB karcmentes 100% akku (49 ciklus) garancia 2026.12.29-ig
- 226 - Lenovo LOQ (15IRX10) - Intel Core i7-13650HX, RTX 5060
- HIBÁTLAN iPhone 13 Pro 128GB Alpine Green-1 ÉV GARANCIA - Kártyafüggetlen, MS4665, 100% AKKSI
- BESZÁMÍTÁS! Palit Gaming Pro RTX 3070 Ti 8GB videokártya garanciával hibátlan működéssel
- Akció! Apple iMac 19.2 i5-8500 Radeon Pro 560X 4GB 16GB 256GB SSD 21.5" 4K Retina
