!drop
jancsobalage
#4570
Hallgatom
!drop
jancsobalage
#4568
Ne csalj nem szép dolog xD
!drop
Pedig hasznos tud lenni a "végjátékban" az a sok money
Ítt vannak a 3. nap infói
Day 3: ECU and Turbo Kit/ PR wall: 732/ R: 7/ RR: 3Event 1: Thermosenser
Event 2: Thrust Sleeve [RR: Flywheel, Thermosenser, Credit]
Event 3: Thermosenser
Event 4: Thrust Sleeve [ RR: Thrust Sleeve, Valve, Credit]
Event 5: ECU Kit
Event 6: Flywheel [RR: Tread, Input Shaft, Credit]
Event 7: Turbo Kit -
!drop
Első nap érdemes csak az 1. pályát tolni drift/draft kombóval lehet vele keresni bőven
Első nap pr wall-ja 720 ami meglesz a dobott materialokból. 7 napos eventhez híven első két nap nincs újrajátszás
Day 1: None/ PR wall: 720/ R: 5/ RR: 0Event 1: Flywheel 4k- 5.5k Credit~
Event 2: Valve
Event 3: Flywheel
Event 4: Input Shaft
Event 5: Flywheel -
!drop
Hali akinek esetleg még nincs meg a diablo annak pár infó (nem saját)
Lamborghini Diablo SV Special Event. 29th November 2017
7 day Special event. days rolling startDetails:
Refresh ticket: 55mins costs 90 gold
Rush timer. Watch ad and reduce waiting time by 25%
Store:
BPs: Gold for 5 BP
Material Std cost:
Upgrade kits: 12,500 credit or 80 Gold
Common part: 4000 credit or 40 Gold
Uncommon part: 6000 credit or 60 GoldBP requirements:
25(4🌟), 30(5🌟), 40(6🌟), 40(7🌟), 65(8🌟)Finish SE: 6 🌟 with 10/40 BP
30 Blueprints for 7th ★
65 Blueprints for 8th ★_ Gold for 30 Blueprints
_ Gold for 90 BlueprintsRewards
Day 1: BP 15, Gold 5
Day 2: BP 15, Gold 10
Day 3: BP 20, Gold 15
Day 4: BP 20, Gold 20
Day 5: BP 20, Gold 25
Day 6: BP 15, Gold 30Event Details
(Upgrade kits available/PR wall/ No. of Races/ No. of RR)Wild Card
Day 1: None/ PR wall: 602/ R: 5/ RR: 0Event 1: Thrust Sleeve
Event 2: Input Shaft
Event 3: Thrust Sleeve
Event 4: Thermosensor
Event 5: Thrust SleeveSpeed Check
Day 2: None/ PR wall: 607/ R: 6/ RR: 0Event 1: Input Shaft
Event 2: Gearbox Kit
Event 3: Flywheel
Event 4: Tread
Event 5: Input Shaft
Event 6: ValveWarning Lights
Day 3: Nitro and Turbo Kit/ PR wall: 624/ R: 7/ RR: 3Event 1: Valve
Event 2: Flywheel [RR: Flywheel, Thermosensor, Credit]
Event 3: Valve
Event 4: Flywheel [RR: Tread, Input Shaft, Credit]
Event 5: Nitro Kit
Event 6: Thrust Sleeve [RR: Thrust Sleeve, Input Shaft, Credit]
Event 7: Turbo KitThe Chase
Day 4: Engine, ECU, and Wheels Kit/ PR wall: 632/ R: 9/ RR: 3Event 1: Tread
Event 2: ECU Kit [RR: Flywheel, Valve, Credit]
Event 3: Input Shaft
Event 4: Engine Kit
Event 6: Wheels Kit
Event 7: Thermosensor [RR: Thermosensor, Valve, Credit]
Event 8: Flywheel [RR: Intake, Clutch Plate, Credit]
Event 9: ValveCop Blockage
Day 5: Gearbox Kit/ PR wall: 654/ R: 10/ RR: 3Event 1: Flywheel
Event 2: Thrust Sleeve [RR: Credits, Credits, Credits]
Event 3: Gearbox Kit
Event 4: Tread
Event 5: Thermosensor [Backplate, Tank, Credit]
Event 7: Input Shaft
Event 8: Valve [Thrust Sleeve, Tread, Credit]
Event 9: Backplate
Event 10: TreadFast Break
Day 6: Turbo Kit/ PR wall: 675/ R: 14/ RR: 3Event 1: Flywheel
Event 2: Tread
Event 3: Thrust Sleeve [Harness, Brake Disc, Credit]
Event 4: Harness
Event 5: Flywheel
Event 6: Thermosensor
Event 7: Tank [Backplate, Tank, Credit]
Event 8: Input Shaft
Event 9: Brake Disc
Event 10: Intake [Brake Disc, Harness, Credit]
Event 11: Clutch Plate
Event 12: Thermosensor
Event 13: Intake
Event 14: Turbo KitStreet Legend
Day 7: Engine Kit/ PR wall: 716/ R: 16/ RR: 4Event 1: Tread
Event 2: Tank [Clutch Plate, Intake, Credit]
Event 3: Tread
Event 4: Engine Kit
Event 6: Input Shaft
Event 7: Backplate
Event 8: Input Shaft [Credit, Credit, Credit]
Event 9: Valve PR: 705
Event 10: Tank
Event 11: Harness [Flywheel, Thrust Sleeve, Input Shaft, Tread, Thermosensor, Vlave]
Event 12: Flywheel
Event 13: Tread
Event 14: Clutch Plate [Intake, Harness, Tank]
Event 15: Input Shaft
Event 16: 30 GoldYou need ECU, Wheels, and Nitro kit to complete second upgrade to 4★ Epic [Purple] Part.
Material requirement for every ★ part:
Green 3★: 3× Common
Blue 3★: 2× common + Upgrade KitBlue 4★: 3× Common + 1× Uncommon
Blue 5★: 2× Common + 2× Uncommon
Purple 4:★: 1× Common + 2× Uncommon + Upgrade KitPurple 5★: 2× Common + 3× Uncommon
Purple 6★: 1× Common + 4× Uncommon -
!drop
Candyman001
#4423
Nehezen hiszem el ha vip1es de legyen igazad
!drop
Candyman001
#4357
Hali rég voltam már de ez most engem is felb*szott xDD (ui elnézés a káromkodásért). Én az utolsó nap utolsó előtti előtti futamáig jutottam ahol a bot szó szerintfelb*szott.. Nem vagyok az az idegeskedő típus de mondom én mi a f*sz????? 180 goldot vertem el csak erre az egy futamra ami nem is lenne gond csak valaki mondja már hogy az nem tudatos hogy 12 ticketem úgy ment el hogy amint megelőztem az első autót az valahogy mindig útólért és az hót hogy kilökött persze nehogy útól lehessen érni? Értem én hogy z EA-nek kell a lóvé de ha nem lenne a játék unfair még talán költenék is rá.... Másrészt egy gyártó miért b*sztatja a játékosait? XDD
!drop
mombulllet
#4265
Szerintem az a r32es skyline te meg az r34est kaptad
!drop
mombulllet
#4226
Mert a nem upgradelt cuccokat elveszi róla.. Nem mintha nem lenne rohadtul mind1 xD
!drop
truzrtzurtzu
#4195
Nemnagyon.. esetleg Real Racing 3 nemtudom abban lehet e
!drop
truzrtzurtzu
#4191
Ez sajnos nem megoldható... :/
!drop
csaprilia
#4186
Upcoming events (thanks Philly):
Premium Crate Lamborghini Huracan June 6th
Replay Races Lamborghini Huracan June 6th
Tuner Trials All Access Pass June 12th
Replay Races Lamborghini Murciélago SV June 13th
Premium Crate Lamborghini Murciélago SV June 13th
Double Reputation June 19th
Premium Crate Hot Wheels Gazella GT June 20th
Replay Races Hot Wheels Gazella GT June 20th
Tuner Trials All Access Pass June 26th -
!drop
hattrickuser
#4159
Szia! 7napos event
!drop
Még gyerekkoromban gyűjtöttem azokat is.. Erre a piros taxira meg befizetek amint jön a fizu xD Kb 1 hónapja kezdtem el megint gyűjteni a hot wheels autókat amikor ráakadtam a kedvencemre ami igen az a nissan skyline volt
Sajnos a régi gyűjteményemet elajándékoztam egy családnak ahol sok a kisgyerek de nem bántam meg jó helyen van
(kb50 db) De most megint fellángolt bennem a gyűjtő xD. Ja ez a skyline volt az nem a piros
!drop
Köszi
Közben énis találtam egyet
NISSAN 180sx Type X. FASTLANE SE Rerun (2nd) 5th April, 2017
5 Day event. Rolling Start ? days entry.
NOTE: There is a 180sx RR running atm. It started 3rd April and it runs for 10 days.
The information below were taken from the 1st Run.You need the following to complete 2 sets of kits:
Turbo, Wheels, NitroDetails:
Refresh Tickets: 45mins. Cost 90 gold
Rush Timer: Watch Ad and reduce waiting time 25%
Store:
BPs: 325 Gold for 5 BPs
Materials: Std costs:
Upgrade kits: 12,500 credits
Grey Common 4,000 credits
Green Uncommon 6,000 creditsCar Details
Car Start: 2 Stars 0/15 PR: 276 Classic Sports
Car Finish: 4 stars 5/20. Need 15 BPs to reach 5 stars.
975 Gold for 5 stars
1625 Gold for 6 stars
Total: 2600 Gold to max
BP requirements: 35 (2⭐), 15, 20, 20, 25 (6⭐)
Rewards :
Day 1: 10 BPs, 10 Gold
Day 2: 10 BPs, 10 Gold
Day 3: 10 BPs, 10 Gold
Day 4: 10 BPs, 10 Gold
Day 5: 50 Gold
Series Reward:
NISSAN 180sx Type X
Total Rewards: 40 BPs, 90 Gold
Mech XP: Up to 1,150Event Info
(Upgrade Kits Available/PR wall/No. Races.)
Day 1: None / PR wall:276 / R:5
2x RR:
-flywheel
-thermosensor [RR: flywheel, thermosensor]
-Sleeve
-flywheel [RR: input shaft, tyre]
-thermosensor
Day 2: Engine, ECU / PR wall:299 / R:7
2x RR:
-Sleeve
-tyre
-valve [RR: input shaft, Sleeve]
-flywheel
-input shaft
-Engine Kit [RR: flywheel, valve]
-ECU Kit
Day 3: 3-3 Wheel, 3-9 Turbo/ PR wall:? / R:9
2x RR:
-input shaft
-valve [RR: thermosensor, valve]
-Gearbox Kit
-backplate [RR: intake, clutch plate]
-Wheel Kit
-Clutch plate
-Nitro Kit
-tyre
-Turbo Kit
Day 4: None / PR wall: ?/ R:14
4x RR
-intake
-thermosensor [RR: backplate, Tank]
-Sleeve
-valve
-input shaft [RR: Sleeve, tyre]
-tyre
-harness
-flywheel [RR: disc brake, harness]
-Tank
-tyre
-disc brake [RR: backplate, Tank]
-Sleeve
-tyre
-backplate
Day 5: Engine, ECU, Gearbox / PR wall:? / R:17
4x RR
-input shaft
-valve
-Tank [RR: disc brake, harness]
-harness
-flywheel
-tyre [RR: clutch plate, intake]
-Sleeve
-thermosensor
-clutch plate [RR: ??]
-thermosensor
-Engine kit
-input shaft [RR:All uncommon (green) materials]
-disc brake
-ECU kit
-intake
-Gearbox kit
-10K CreditsYou need the following to complete 2 sets of kits:
Turbo, Wheel & Nitro"Best RR:. "Lose to win"
One strategy:
If there are RR (Replayable Races) then complete them and leave 1 race to redo. Lose to win. Until the Race refreshes.
If there are no RR then stay on 1 race to redo.
If you know that you will have spare tickets, then race the RRs first before they refresh. That way you get more RRs the following day. -
!drop
hattrickuser
#4096
Nekem ilyen még nem fordult elő
!drop
Én nem azt mondom hogy küzdök érte de megpróbálom megszerezni xD persze csak ha van rá szabadidőm... Nekem nincs sok idom annyira játszani még nincs is mechanic szintem... :/ Majd idővel
Utobbi időben megtetszett ez a letisztult tuning stílus... Ennek örömére tolok is be pár nissant nektek ilyen stílusban
!drop
bukshyHUN
#4038
Én úgy szoktam, hogy első két max 3 nap (ha van időm) az újrajátszható eventeket mindig elrontom vagy ha van olyan amikor nincs újrajátszható akkor csak simán mindig elrontom azt ahol sokat lehet szerezni és azt a futamot végigdriftelem (pl nitro rush nitró nélkül driftelve). Nap vegére meg befejezem az újrajátszható eventeket a cuccokért
!drop
MaxXimilian
#4012
!drop
Egy kis angol talpaló a taxihoz:
Time Attaxi SE. 9th March, 2017
7 Day event. Rolling Start 7 days entry.
Guide only. [EDIT] Added +Jackson Pang to the contributors.
Turbo, Wheel, NitroSince we have some Beta Testers on YouTube we have a lot more info.
Thanks to +Jackson Pang, +TarTon and +McCrea Ronnie
And Beta testers (Obi/TeenageTransporter, u/hellscaretaker /Touchgameplay)
Please make your comments below if you have info on BPs, PR walls, best RR on a certain Day etc...Thanks
If it is rumour than let us know and I mark it as such in this post.For this weekend's Community Challenge we will have a break:
e.g. No CCR
We will resume on the Saturday 18th March:Details:
Refresh Tickets: 55mins. Cost 90 gold
Store:
BPs: 400 Gold for 5 BPs
Car Start PR: 263: Sports
Car Finish: 6 stars 5/30. Need 25 BPs to reach 7 stars. (i.e. 2000 Gold)
BP requirements: 25 (3⭐), 15, 20, 20, 30, 60 (8⭐)
Event give: 60 BPs.
Rewards
Day 1: 10 BPs, 5 Gold
Day 3: 10 BPs, 15 Gold
Day 4: 10 BPs, 20 Gold
Day 5: 10 BPs, 20 Gold
Day 6: 10 BPs, 25 Gold
Day 7: 30 Gold
Series Reward:
Time Attaxi
Total Rewards: 60 BPs, 125 GoldUpgrade Kits Available/PR wall/No. Races.
Day 1: None / PR wall:271. / R:5
Day 2: Gearbox / PR wall:282. / R:6
Day 3: ECU, Turbo / PR wall:344. / R:7
Day 4: Engine, Nitro, Wheel / PR wall: 393 / R:9
Day 5: None / PR wall:496. / R:10
Day 6: Gearbox, Engine / PR wall: 566 / R:14
Day 7: ECU / PR wall: 643 / R:16
Turbo, Wheel, Nitro"Best RR:. "Lose to win"
One strategy:
Day 1 Test run [Chapter final wall PR 271, 10 BP’s, 5 Gold]
-Event 1 Time attack: flywheel
-Event 2 Airborne: valve (lose tickets to earn 2.8k+)
-Event 3 Hunter: flywheel
-Event 4 Rush hour: input shaft (lose tickets to earn 2.5k+)
-Event 5 Time attack: flywheel
Day 2 Initiation [Chapter final wall PR 282, 10 BP’s, 10 Gold]
-Event 1 Rush hour: input shaft
-Event 2 Hunter: thrust sleeve
-Event 3 Airborne: tread
-Event 4 Rush hour: input shaft (lose tickets to earn 2k+)
-Event 5 Nitro Rush: Gearbox upgrade kit (lose tickets to earn 2.5k+)
-Event 6 Time attack: thermosensor
Stage 4 upgrade available
Day 3 Group stage [Chapter final wall PR 344, 10 BP’s, 15 Gold]
-Event 1 thermosensor
-Event 2 thrust [RR: thermo, valve & cash]
-Event 3 thermisensor
-Event 4 thrust [RR: flywheel, thrust & cash]
-Event 5 ECU upgrade kit
-Event 6 flywheel [RR: input shaft, tread & cash]
-Event 7 Turbo upgrade kit
Day 4 Elimination [Chapter final wall PR 394, 10 BP’s, 20 Gold]
-Event 1 input shaft
-Event 2 Engine upgrade kit
-Event 3 valve [RR: Input shaft, tyre, cash]
-Event 4 Nitro upgrade kit
-Event 5 thrust [RR: thrust, flywheel, cash]
-Event 6 tread
-Event 7 Wheel upgrade kit
-Event 8 flywheel [RR: thermo, valve, cash]
-Event 9 thermosensor
Stage 5 upgrade available
Day 5 Admonishment [Chapter final wall PR 496, 10 BP’s, 20 gold]
-Event 1 Rush hour: flywheel
-Event 2 Airborne: thrust sleeve
-Event 3 Rush hour: thermosensor [RR brake disc, clutch plate & cash]
-Event 4 Hunter: input shaft
-Event 5 Airborne: valve [RR: intake, backplate & cash]
-Event 6 Rush hour: thrust sleeve
-Event 7 Nitro rush: tread
-Event 8 Hunter: thermosensor [RR: nitro, harness & cash]
-Event 9 Rush hour: intake
-Event 10 Time attack: input shaft
Day 6 Defiance [Chapter wall PR 531, final wall PR 566 10 BP’s, 25 gold]
-Event 1 Airborne: flywheel
-Event 2 Rush hour: clutch plate
-Event 3 Airborne: valve [RR: ??]
-Event 4 Hunter: harness
-Event 5 Rush hour: intake
-Event 6 Nitro rush: thermosensor
-Event 7 Time attack (Chapter wall PR 531): harness
-Event 8 Rush hour: tread
-Event 9 Airborne: clutch plate
-Event 10 Hunter: backplate [RR: nitro, harness & cash]
-Event 11 Nitro rush: valve
-Event 12 Rush hour: Gearbox upgrade kit [RR: intake, backplate & cash]
-Event 13 Hunter: intake
-Event 14 Time attack (Chapter final wall PR 566): Engine upgrade kit
Stage 6 upgrade available
Day 7 Chaos [Chapter wall PR 617, final wall PR 643, no BP’s, 30 gold]
-Event 1 Rush hour: tread
-Event 2 Nitro rush: ECU upgrade kit
-Event 3 Airborne: input shaft
-Event 4 Rush hour: valve [RR: all cash]
-Event 5 Hunter: thermosensor
-Event 6 Airborne: clutch plate [RR: brake disc, clutch plate & cash]
-Event 7 Nitro rush: harness
-Event 8 Time attack (Chapter wall PR 617): intake
-Event 9 Hunter: harness
-Event 10 Airborne: clutch plate
-Event 11 Rush hour: flywheel [RR: nitro, harness & cash]
-Event 12 Airborne: brake disc
-Event 13 Rush hour: intake
-Event 14 Nitro rush: clutch plate [RR: intake, backplate & cash]
-Event 15 Hunter: harness
-Event 16 Time attack (race skip 115 gold): 30 gold -
!drop
Féve mondom de nem értem lényegét ennek az updatenak majd xDD Annyi minden bele férne a játékba (körverseny, akár drag racing) Blackridge rivals is ha már azt mondták online akkor lehetne egymás ellen
stbstb. Tetszik így is a game de most komoly? Hot Wheels?
Rakhatnának bele akkor valamy rally modot vagy nemtudom xD -
!drop
Üdv mindenki! Next updateról van valahol már infó?
!drop
Valaki esetleg nem tudja hogy az m2-es cupé fastlane eventjéhez mennyi a pr limit? (utolsó futamhoz) mert csak annyira húznám fel
!drop
Egy kis helyzetjelentés: Car Series: -toyota corolla, nissan 370z, chevrolette corvette. Megkaptuk az előző kocsikhoz xDD
joe007 ajánlom figyelmedbe ezt: https://www.youtube.com/watch?v=q_X36EDjNZ0
!drop
Merci event: ujrajatszas nincs. 2. Palyat nitro rush rontani és farmolni!!!
- talmida: Változások 2. rész
- Parkside szerszám kibeszélő
- Milyen okostelefont vegyek?
- Futás, futópályák
- Hardcore café
- Lexus, Toyota topik
- Elektromos rásegítésű kerékpárok
- Telefon felváráslás!! Samsung Galaxy S22/Samsung Galaxy S22+/Samsung Galaxy S22 Ultra
- GYÖNYÖRŰ iPhone 13 Pro Max 128GB Silver -1 ÉV GARANCIA - Kártyafüggetlen, MS4160
- Törött, Hibás iPhone felvásárlás!!
- HP EliteBook 840 G7 i5-10210U 16GB 256GB FHD 400nit 1 év garancia
- iPhone 14 Pro 128GB Space Black -1 ÉV GARANCIA - Kártyafüggetlen, MS4266
. 7 napos eventeknél a nitros eventet mindig el kell rontani és úgy lehet sok pénzt farmolni "későbbre" és akkor tudsz venni alkatrészeket
Ha 1 hónappal előbb kezdem a játékot....
