lester
Hy!
Ezt a hibát miért írja ki a végén mindig a nokix, mikor be akarom rakni a flashbe a scripteket?
# Processing started
# Input flash: 6.39 N.fls
# Loading... OK
# Processing: anonymous_access.nrx
Patching...
Initialize SIM card with 'init_sim_card' 5E0 ID
Done!
# Processing: calendar.nrx
Inserting calendar functions...
Patching date setting dialog box...
Patching Reminders...
Calendar was integrated with Reminders function
Done!
# Processing: fade_leds.nrx
Configure with 'fade_leds/in' and 'fade_leds/out' definitions
Done!
# Processing: invert_lcd.nrx
Patching...
Configure with 'invert_lcd' definition
Toggle with 'invert_lcd/toggle' definition
Done!
# Processing: lcd_contrast.nrx
Done!
# Processing: light_settings.nrx
Done!
# Processing: mobile_unlocker15.nrx
Main menu created at: 0x336510
Access with 'mobile_unlocker' definition
Done!
# Processing: nokix_shot.nrx
Installing...
Done!
# Processing: reboot.nrx
Reboot with 'reboot' definition
Done!
# Processing: rhythmic_leds.nrx
Configure with 'rhythmic_leds' definition
Toggle with 'rhythmic_leds/toggle' definition
Done!
# Processing: send_flash_sms.nrx
Patching...
Done!
# Processing: show_free_space.nrx
I will display free space at the end of processing...
Done!
# Processing: CREATE_CONFIG_ID.rx THE_END
Number of IDs created: 8 nonvolatile and 2 volatile
Creating configs EEPROM table entry...
# ERROR: Not enough free EEPROM space, needed 5, found 5 bytes!
# 297 +++ fail ''Not enough free EEPROM space, needed ''len*idx'', found ''free'' bytes!''
# 138 +++ eeprom_id=eeprom(''create'',buffer_length)
# Error 4 running ''C:\NokiX\scripts\EEPROM.rx'', line 297: Program interrupted
# ERROR: Script failure!
lester
lester
Ilyenem van:
Ennek a kábelei jók a com portos m2bus fejegységhez?
Mert most com portos csak 3310-hez való fbus/mbus kábelem van. -
lester
Ez a szet jó faidelésre meg full factory resethez stb.külön MBUS/FBUS kábelek helyett?
[Szerkesztve] -
lester
Ez a leírás megfelelő?
lester
Arra gondoltam, hogy mindenféle ezirányú szaktudás nélkül megpróbálkoznék a 3310-esem tuningolásával.
Ma meg is érkezett a flash kábel hozzá, meg van fbus/mbus kábelem is, meg néhány szoftom is (flash fájlok, mados, g3nolite, dejan flasher, nokix, flash editor, rolis flasher, userport, ppmmaker stb.).
Végigolvastam a topicot, de még vannak homályos foltjaim, ezért a későbbiekben számítok a segítségetekre.
Előre is köszönöm!
UI.: Innen a DCT3 szekcióból mire lehet szükségem?
http://www.softgsm.pl/
- Milyen monitort vegyek?
- Melyik tápegységet vegyem?
- Gyúrósok ide!
- Geri Bátyó: Ezt pedig azért, mert...
- Xbox tulajok OFF topicja
- Okosóra felvásárlás!! Samsung Galaxy Watch 5 Pro, Samsung Galaxy Watch 6 Classic
- HP Elitebook 850 G8 15,6" i5 1135 G7, 8-16GB RAM, SSD, jó akku, számla, 6 hó gar
- BESZÁMÍTÁS! MSI B650 R7 7700 32GB DDR5 1TB SSD RX 9070XT 16GB LIAN LI LANCOOL 217 Wood 750W
- Lenovo Flex 5 - 14.0" Touch WUXGA - Ryzen 3 5300U - 8GB - 256GB - Win11 - Garancia - MAGYAR
- Apple iPhone 11 Pro Max 256GB - Kártyafüggetlen, Grafit, 100% Akku - 1 Év Garanciával
![[kép] [kép]](http://lester.fw.hu/pic/3310pinout.jpg)
