moli.hu
moli.hu
#7979
Megirtam az elso nodejs kodomat, kerem, aki ert hozza, nezze at, hogy
--biztonsagos? nem csinaltam marhasagot?
--az async jol van irva, nem elozi be valamelyik sor amit nem kene?
--stilusos, igy kell-e kodolni nodejs-t?
--a timeoutok jo helyre vannak irva? (20 process, 10 transfer, 30 egyutt)
--a "httpd stopped" szoveg miert nem jon soha?http_createserver = require("http").createServer;
crypto_randombytes = require("crypto").pseudoRandomBytes;
url_parse = require("url").parse;
child_process_exec = require("child_process").exec;
os_hostname = require("os").hostname;
console.info (new Date().toISOString() + "\thttpd started");
var server = http_createserver (
function (IncomingMessage, ServerResponse) {
crypto_randombytes (16,
function (exception, buffer) {
if (exception) throw exception;
uniqueid = buffer.toString ("hex");
console.info (uniqueid + "\tdate: " + new Date().toISOString());
console.info (uniqueid + "\tremoteaddr: " + IncomingMessage.connection.remoteAddress);
ServerResponse.on ("close",
function () {
console.info (uniqueid + "\taborted");
ServerResponse.on ("finish",
function () {
console.info (uniqueid + "\tsent");
var querystring = url_parse(IncomingMessage.url, true).query;
if ("secret" && querystring.auth != "secret") {
ServerResponse.writeHead (404);
ServerResponse.end ();
console.info (uniqueid + "\tnoauth: " + IncomingMessage.url);
} else {
label = uniqueid + "\tgenerated";
if (querystring.hostname) console.info (uniqueid + "\thostname: " + querystring.hostname);
console.time (label);
child_process_exec ("rrd.sh graph '" + (querystring.hostname ? querystring.hostname : "") + "'", { encoding: "binary", maxBuffer: 10000000, timeout: 20000 },
function (error, stdout, stderr) {
console.timeEnd (label);
if (error !== null) {
ServerResponse.writeHead (500);
ServerResponse.end (error + stderr);
console.info (uniqueid + "\tnoexec: " + error.toString().replace (/[\r\n\t]+/gm, " "));
} else {
ServerResponse.setTimeout (10000);
ServerResponse.writeHead (200, { "content-type": "image/png", "content-length": stdout.length, "content-disposition": "inline; filename=\"" + (querystring.hostname ? querystring.hostname : os_hostname ()) + ".png\"" } );
ServerResponse.end (stdout, "binary");
console.info (uniqueid + "\tlength: " + stdout.length);
).listen (8000);
server.setTimeout (30000);
server.on ("close",
function () {
console.info (new Date().toISOString() + "\thttpd stopped");
);--ha nem irnek az elejere kulon sorba require-t, hanem a require-ket bele irnam a kod kozepebe, akkor az at jelentene, hogy ahanyszor odaer a kod, behuz egy ujabb instance-t a library-bol?
--a http 404 helyett tudok valahogy manualis timeout-ra futtatast csinalni vagy valami olyan valaszt szimulalni, mintha nem lenne ott a szerver?
--ugy olvastam, hogy az encoding binary deprecated, ezert mar bufferrel csinaltam meg a crypto-reszt, de mikor az exec-bol atadom a response-nak, azt a reszt hogy lehet atirni? -
moli.hu
koszonom a valaszokat! Mivel nagyon tetszett a netcat-es megoldas, lehet engedek, nyitok portot es nodejs-sel oldom meg. igy legalabb lehet csak requestre rajzolni grafikont is. A v0.10 ellenere eleg mature? Egy require('http')-re nem huz be feleslegesen tul sok mindent?
moli.hu
@Karma: igen, miutan kiprobaltam 4 packaget, monitorx, stb, ugy dontottem, jobb lesz, ha feltalalom a kereket. ettol fuggetlenul a muninnal is gond lenne a fenti, hisz nyitnom kene httpd portot.
@Sk8erPeter: megis joval egyszerubb volt egy twitter-klienst felrakni, regisztralni es oathot csinalni, mint az snmp-vel lett volna.
"aztán nagyon sok köze van a Twitterhez"
hat, twitteren allapotjelent a worm-ok tobbsege.
"hogy tanácsot kérsz, hogy aztán pont a javasolt megoldásokat jó nagy ívben elkerüld"
ez azt jelenti, hogy az elso tanacsot kellene implementalnom?
most komolyan kerdezem. tehat az elso tanacsot kellene implementalni?
masreszt a folyamatosan adott akadalyok sarkaljak az embert ujabb varatlan otletekre.
"az elzárkózást a szélesebb látókörű megoldásoktól"
nem zarkoztam el, mindre reagaltam. de nem varhato el, hogy az elso adando otletet implementaljam. nem 5 perc utanajaras utan kerdeztem a forumon, hanem tobb napnyi utan, valoszinu ez szokatlan. -
moli.hu
ugy erzem, tulbonyolitod. es nem csak a kvantumteleportacioval.
egy hintet adok: a multkori statusz-ertesitos kerdest, amire peldaul az snmp-t es egyeb ugyes otletek jottek, vegul twitterrel oldottam meg, jol mukodik.
nincs it-felelos, az en home-szerverem (a fiataloknak: private cloud
) es a nagymamam gepe tarsalogna.a meglévő démonok érettségét
mint az openssl erettseget? -
moli.hu
moli.hu
sracok, otletet szeretnek kerni arra, hogy hogyan lehetne megoldani, hogy a B gep ertesitse az A gepet egy esemenyrol - anelkul, hogy webszervert raknek az A gepre. A project ugyanis joval kisebb annal, mint amennyi bajt okoznek egy teljes webszerver telepitesevel, biztonsagilag. Egyszeru, kis eroforrasigenyu megoldast keresek (ssh, irc), otletek?
- Apple MacBook
- Házimozi belépő szinten
- Gitáros topic
- Milyen egeret válasszak?
- MWC 2026: Kezünkben a minden tekintetben európai okostelefon
- Warhammer 40,000: Boltgun II – Slaanesh is beszáll a folytatásba
- Honor 400 512GB, Kártyafüggetlen, 1 Év Garanciával
- L13 Yoga Gen3 13.3" FHD+ IPS érintő i5-1245U 16GB 256GB NVMe ujjlolv IR kam aktív toll gar
- Iphone 13 128GB Rózsaszin, Független, 100% új akku, garanciával, üzlet
- I7 9700k + msi Rtx 2080 komplett gép eladó
- L13 Yoga Gen3 13.3" FHD+ IPS érintői5-1245U 16GB 256GB NVMe ujjlolv IR kam aktív toll gar
- ÚRIS10!!! RAMÁRON! LEGION 5 i7-13650HX 32GB RAM 1000GB SSD RTX 5070 8GB
- AKCIÓ! Sony Playstation 5 PRO 2TB Digital játékkonzol garanciával extrákkal hibátlan működéssel
- Apple iPhone 14 / 128GB / Kártyafüggetlen / 12Hó Garancia / Akku: 87%
- Keresünk Galaxy S22/S22+/S22 Ultra
- Dell Latitude 9420 i5-1145G7 14" FHD+ 16GB 256GB 1 év garancia
