dnielr
Transmissiont próbálom felrakni, a pi4-emre kb 3 napja.
OS: Raspbian(fríssített)
Guide, amit használok(a videó tünik pontosabbnak), de startra mindig hibát dob. A config fileok jók.
https://pimylifeup.com/raspberry-pi-transmission/Előre is köszönöm!
Logom:
pi@raspberrypi:~ $ sudo nano /etc/transmission-daemon/settings.json pi@raspberrypi:~ $ sudo service transmission-daemon reload
pi@raspberrypi:~ $ sudo service transmission-daemon stop pi@raspberrypi:~ $ sudo nano /etc/init.d/transmission-daemon
pi@raspberrypi:~ $ sudo chown -R pi:pi /etc/transmission-daemon/settings.json pi@raspberrypi:~ $ sudo chown -R pi:pi /etc/init.d/transmission-daemon
pi@raspberrypi:~ $ sudo chown -R pi:pi /var/lib/transmission-daemon pi@raspberrypi:~ $ sudo service transmission-daemon start
Job for transmission-daemon.service failed because the control process exited with error code. See "systemctl status transmission-daemon.service" and "journalctl -xe" for details.
pi@raspberrypi:~ $ ls -l /media/pi/'My Book'/PiDL/ingprog ls: cannot access '/media/pi/My Book/PiDL/ingprog': No such file or directory
pi@raspberrypi:~ $ ls -l /media/pi/'My Book'/PiDL/inprog total 0
pi@raspberrypi:~ $ systemctl status transmission-daemon.service ● transmission-daemon.service - Transmission BitTorrent Daemon
Loaded: loaded (/lib/systemd/system/transmission-daemon.service; enabled; vendor preset: enabled Active: failed (Result: exit-code) since Tue 2020-01-21 11:54:11 CET; 5min ago
Process: 16869 ExecStart=/usr/bin/transmission-daemon -f --log-error (code=exited, status=1/FAILU
Main PID: 16869 (code=exited, status=1/FAILURE)
Jan 21 11:54:11 raspberrypi systemd[1]: Starting Transmission BitTorrent Daemon...
Jan 21 11:54:11 raspberrypi transmission-daemon[16869]: [2020-01-21 11:54:11.659] transmission-daem
Jan 21 11:54:11 raspberrypi systemd[1]: transmission-daemon.service: Main process exited, code=exit
Jan 21 11:54:11 raspberrypi systemd[1]: transmission-daemon.service: Failed with result 'exit-code'
Jan 21 11:54:11 raspberrypi systemd[1]: Failed to start Transmission BitTorrent Daemon.
pi@raspberrypi:~ $
Jan 21 12:02:56 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA
Jan 21 12:03:27 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:03:27 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA
Jan 21 12:04:17 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:04:17 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA
Jan 21 12:05:07 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:05:07 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA
Jan 21 12:06:02 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:06:02 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA
Jan 21 12:06:37 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:06:37 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA
Jan 21 12:07:13 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:07:13 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA
Jan 21 12:07:46 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:07:46 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA
Jan 21 12:08:20 raspberrypi rngd[363]: stats: bits received from HRNG source: 140064
Jan 21 12:08:20 raspberrypi rngd[363]: stats: bits sent to kernel pool: 93824
Jan 21 12:08:20 raspberrypi rngd[363]: stats: entropy added to kernel pool: 93824
Jan 21 12:08:20 raspberrypi rngd[363]: stats: FIPS 140-2 successes: 7
Jan 21 12:08:20 raspberrypi rngd[363]: stats: FIPS 140-2 failures: 0
Jan 21 12:08:20 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Jan 21 12:08:20 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Poker: 0
Jan 21 12:08:20 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Runs: 0
Jan 21 12:08:20 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Long run: 0
Jan 21 12:08:20 raspberrypi rngd[363]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Jan 21 12:08:20 raspberrypi rngd[363]: stats: HRNG source speed: (min=117.824; avg=318.450; max=507
Jan 21 12:08:20 raspberrypi rngd[363]: stats: FIPS tests speed: (min=11.943; avg=12.291; max=12.581
Jan 21 12:08:20 raspberrypi rngd[363]: stats: Lowest ready-buffers level: 2
Jan 21 12:08:20 raspberrypi rngd[363]: stats: Entropy starvations: 0
Jan 21 12:08:20 raspberrypi rngd[363]: stats: Time spent starving for entropy: (min=0; avg=0.000; m
Jan 21 12:08:32 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:08:32 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA Jan 21 12:09:03 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:09:03 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA Jan 21 12:10:01 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:10:01 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA Jan 21 12:10:38 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:10:38 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA Jan 21 12:11:17 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:11:17 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA Jan 21 12:12:01 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:12:01 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA Jan 21 12:12:39 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:12:39 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA Jan 21 12:13:25 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:13:25 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA Jan 21 12:14:25 raspberrypi dhcpcd[396]: eth0: Router Advertisement from fe80::f66b:efff:febb:36e0
Jan 21 12:14:25 raspberrypi dhcpcd[396]: eth0: invalid prefix in RA
- Xbox tulajok OFF topicja
- MasterDeeJay: Egy nem átlagos Asus videókártya (GTX950M 2GB GDDR3)
- Arc Raiders
- Nintendo DS-sel pózol egy OnePlus
- BestBuy topik
- Milyen okostelefont vegyek?
- Büszke apukák és anyukák topikja
- PC Játékok
- BESZÁMÍTÁS! AsRock H510M i5 11400 16GB DDR4 512GB SSD RX 6600 8GB Zalman T4 Plus ADATA 600W
- BESZÁMÍTÁS! Gigabyte B760M i3 12100F 16GB DDR4 512GB SSD RTX 2060 Super 8GB ADATA XPG Valor Air 600W
- BESZÁMÍTÁS! Asrock Z270 i7 6700K 16GB DDR4 512GB SSD RTX 2060 6GB GameMax Storm 2 AB Adata 600W
- BESZÁMÍTÁS! Asrock B450M R5 5600X 16GB DDR4 512GB SSD RTX 3070 8GB Zalman T3 Plus FSP 650W
- IKEA Format lámpák eladóak (Egyben kedvezménnyel vihető!)
- RÉSZLETRE .OPCIONÁLIS. G.SKILL Trident Z5 Neo RGB 96GB (2x48GB) DDR5 6000MHz
- Apple iPhone 11 64GB Black használt 100% akku 6 hónap garancia
- Apple iPhone 11 Pro Max 64GB, Kártyafüggetlen, 1 Év Garanciával
- Gamer PC-Számítógép! Csere-Beszámítás! I3 14100F / RTX 3070 8GB / 16GB DDR4 / 512 Nvme SSD
wassermann
