crab
Kár hogy az Nforce3-nak már nem része a SoundStorm.:(((
crab
Bubu Kapitány
#20
igen.:)
crab
Bubu Kapitány
#14
A VRM a DPS része, így már érhthető.
Nemtudom ki találta ki, de a Gigabyte használja.:)
Örülök, hogy segíthettem!:P -
crab
Bubu Kapitány
#12
Akkor ez: VRM_CONN
Ennek: Voltage Regulator Module Connector a rövidítése.:) -
crab
hehehe:B, itt mégjobban látszik: [L]http://img.neoseeker.com/a/gasinxp1394/DSCF0008_640.jpg[/L]
crab
Bubu Kapitány
#7
Ha a proci foglalat melletti slotra gondolsz akkor az a DPS foglalata, azaz a dual power system-é.
Dual Power System (DPS)
Driven by strong design philosophies and innovation, GIGABYTE new developed technology known as the Dual Power System (DPS) is introduced for 6-Dual series motherboard. The DPS technology is an ingenious design that gives you a power circuit with a total of 6 phases - providing 3 extra phases power circuits which is twice the amount recommended by the standard motherboard design guideline. In a DPS (Dual Power System) designed motherboard, an additional 3-phase power circuit DPVRM (Dual Power Voltage Regulator Module) daughter card is added on the motherboard. This effectively provides a more durable and stable power circuit to sustain a larger electric current of up to 150A. The DPS (Dual Power System) technology is conceived and specially designed for future processors that demand a higher working frequency and a more stable and durable power circuit.
- Kedvenc zene a mai napra
- Star Wars rajongók
- Anno 117: Pax Romana teszt
- Milyen okostelefont vegyek?
- Ingatlanos topic!
- Corsair 2x16Gb 6400 cl32 hynix a-die eladó ( cl34 7800!!!)
- Asus x870 rog strixx F-gaming Wifi garanciával
- Kingston FURY 64GB (2x32GB) KIT DDR5 6000MHz CL36 Beast Black XMP/EXPO - 1 év bolti garival! -
- Kingston FURY Beast 16GB (2x8GB) DDR4 3200MHz
- Új, felbontott Kingston FURY 32GB (2x16GB) KIT DDR5 5600MHz CL40 Beast Black RGB XMP - 8 év gari! -
- GYÖNYÖRŰ iPhone 14 Pro Max 128GB Deep Purple-1 ÉV GARANCIA - Kártyafüggetlen, MS3913
- Apple iPhone 17 Pro Silver 256 GB Használt, karcmentes 100% akku / 0 ciklus 1 év gari!
- Apple iPhone 13 Pro 256GB, Kártyafüggetlen, 1 Év Garanciával
- Bomba ár! HP Probook 440 G10 - i3-1315U I 16GB I 256SSD I 14" FHD I W11 I Cam I Garancia!
- Keresek Galaxy S21/S21+/S21 Ultra/S21 FE
