erzol
Üdv Urak!
Cseréltem a jó kis padavanos 3G-t egy ax3600-ra.
Az öreget beállítanám a kis épületbe mintnegy wifi repeater.
Tud nekem valaki segíteni a hogyanban? -
erzol
A routerem heti rendszerességgel "elfeljti" a PPPoE beállítást és a Dns címeket.
Hogyan tudnám ezt orvosolni?
3.4.3.9L-100_430518f padawan fut a vason.
System log ezt írja, mikor elmegy a net:Jun 6 12:14:45 pppd[833]: Terminating on signal 15
Jun 6 12:14:45 pppd[833]: Connect time 3379.2 minutes.
Jun 6 12:14:45 pppd[833]: Sent 1127811128 bytes, received 2425623634 bytes.
Jun 6 12:14:45 MI-R3G: WAN down (ppp0)
Jun 6 12:14:45 dnsmasq[474]: read /etc/hosts - 3 addresses
Jun 6 12:14:45 dnsmasq[474]: read /etc/storage/dnsmasq/hosts - 0 addresses
Jun 6 12:14:45 dnsmasq-dhcp[474]: read /etc/dnsmasq/dhcp/dhcp-hosts.rc
Jun 6 12:14:45 dnsmasq[474]: using nameserver 185.117.74.100#53
Jun 6 12:14:45 dnsmasq[474]: using nameserver 185.117.74.101#53
Jun 6 12:14:45 PPPoE: Disconnected
Jun 6 12:14:45 pppd[833]: Connection terminated.
Jun 6 12:14:45 pppd[833]: Sent PADT
Jun 6 12:14:45 pppd[833]: Exit.
Jun 6 12:14:45 DHCP MAN Client: deconfig (eth3): lease is lost
Jun 6 12:14:45 MI-R3G: MAN down (eth3)
Jun 6 12:14:46 kernel: eth3: ===> VirtualIF_close
Jun 6 12:14:46 kernel: eth3: ===> VirtualIF_open
Jun 6 12:14:46 MI-R3G: Hardware NAT/Routing: Enabled, IPoE/PPPoE offload [WAN]<->[LAN/WLAN]
Jun 6 12:14:46 MI-R3G: Hardware NAT/Routing: IPv4 UDP flow offload - ON
Jun 6 12:14:46 MI-R3G: Hardware NAT/Routing: IPv6 routes offload - OFF
Jun 6 12:14:46 dnsmasq[474]: read /etc/hosts - 3 addresses
Jun 6 12:14:46 dnsmasq[474]: read /etc/storage/dnsmasq/hosts - 0 addresses
Jun 6 12:14:46 dnsmasq-dhcp[474]: read /etc/dnsmasq/dhcp/dhcp-hosts.rc
Jun 6 12:14:46 dnsmasq[474]: using nameserver 185.117.74.100#53
Jun 6 12:14:46 dnsmasq[474]: using nameserver 185.117.74.101#53
Jun 6 12:14:46 miniupnpd[777]: shutting down MiniUPnPd
Jun 6 12:14:46 DHCP WAN Client: starting on eth3 ... -
erzol
woodworm, vargalex nagyon köszönöm!
Délután frissítem is.
erzol
Padavanon openvpnnel ezt írja a system log:Sep 29 16:58:20 openvpn-cli[583]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep 29 17:04:20 openvpn-cli[583]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Sep 29 17:04:20 openvpn-cli[583]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep 29 17:10:20 openvpn-cli[583]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Sep 29 17:10:20 openvpn-cli[583]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep 29 17:16:20 openvpn-cli[583]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Sep 29 17:16:20 openvpn-cli[583]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep 29 17:22:21 openvpn-cli[583]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Sep 29 17:22:21 openvpn-cli[583]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep 29 17:28:26 openvpn-cli[583]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Sep 29 17:28:26 openvpn-cli[583]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep 29 17:34:26 openvpn-cli[583]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Sep 29 17:34:26 openvpn-cli[583]: NOTE: the current --script-security setting may allow this configuration to call user-defined scriptsMit nem állítottam be jól?
erzol
Elégedetten használom a routert padavannal.
Egy hdd-vel remekül megy a transmission és az itthoni hálozaton nézem róla a filmeket mindegyik eszközömmel.
Mit és hogyan kell beállítani, hogy a távoli elérés is működjön.
Annyi a célom, hogy a transmissionban tudjak letöltést indítani és a hdd-n lévő filmeket akár mobilnettel is nézhessem akárhonnan.
Segítségetek előre is köszönöm!
erzol
Szias ztok!
Ma figyeltem fel rá, hogy a router közepén egy halvány piros fény látszik a burkolat alól a MI logónál.
Minden rendben működik, de ez normális? -
erzol
Nekem nemrég érkezett a gearbesttől minden gond nélkül.
Van némi változás áfa téren.
45$-ig nem kell fizetni.
Kicsit hosszú, de beteszem:
Az uniós vámjog végrehajtásáról szóló 2017. évi CLII. törvény 162 § (5) bekezdése alapján a rendelt küldeményben lévő termék értéke a 22 € forintra számított összértékét meghaladja, de nem éri el a 150 € értéket, úgy a termékbehozatal során általános forgalmi adó fizetési kötelezettség keletkezik, amely összeget az ügyfélnek nem kell megfizetnie akkor, ha a kiszámolt – és így az ügyfél által fizetendő – összeg a 10 € értéket nem haladja meg.
A Nemzeti Adó- és Vámhivatal Vámeljárási Osztálya azt a tájékoztatást adta, hogy februárban 45,69 $-ig adómentes a küldemény.
Ha a vásárolt dolog értéke 45,69 $ körüli, akkor emlékeztetve a fenti jogszabályi helyre az értékigazolást bekérőt, kérni kell az áfa kiszabás, a vámeljárás vámmenteskénti elbírálását.
Mivel ennek a szabálynak alkalmazása már vámeljárás keretében történik, így a vámolási szolgáltatást végző cég felszámolhatja a vámeljárási költségét.Ezek szerint az általunk mindenhol olvasható 22 €-os határ így lenne helyes:
22 €-ig áfa és vámmentes, a 22 € fölötti összeg esetén, ha a meghatározott közteher (áfa, vám) mértéke nem haladja meg a 10 €-nak megfelelő összeget, akkor azt nem kell megfizetni a 2017. évi CLII. törvény 162.§.(5) bekezdése alapján. -
erzol
Köszönöm ezt a szuper leírást!
Pár napja toltam fel a padavant.
Ahol lakom még csak mobilnet van (Digi már az oszlopon), amit egy éve használok a szolgáltatótól kapott dlink dwr 116 - dlink dwr 222 kombóval. Eddig heti szinten kellett újraindítanom, hogy legyen net hellyel - közzel 40-es tempóval.
Mióta beizzitottam ezt a csodát megszakítás nélkül jön a net 90-es sebességgel.
Nem is gondoltam volna, hogy ilyen is tud lenni egy megfelelő eszközzel.
- Samsung Galaxy S20 / 8/128GB / Kártyafüggetlen / 12HÓ Garancia
- iPhone 17 256 GB Levander - Bontatlan !! www.stylebolt.hu - Apple eszközök és tartozékok !!
- BESZÁMÍTÁS! GIGABYTE A520M R5 5500 16GB DDR4 512GB SSD GTX 1660 Super 6GB Zalman T3 Plus 400W
- HP Dell, Fujitsu, üzleti kategóriás notebook kiárusítás - frissítve: 01.03
- 100/100% 500GB SSHD, 500GB HDD - több db - 2,5"
