tlac
Ablakos
#4508
nem kötelezőek a snapshotok
én is úgy váltottam opensuse-ra, hogy minél kevesebb új dolgot kelljen megtanulni egyszerre és minél egyszerűbb legyen a váltáskorábban ext4-es kde neon-om volt a gépen és az egész fájlrendszer tartalmát átmozgattam egy backup mappába és formázás nélkül telepítettem az ext4-re az opensuse-t
a bootloader-nél is maradtam a sima grub-nál
tlac
na, épp most kavar be nekem packman, akkor ez egyelőre elhalasztva, hátha megoldják
opensuse:~ # zypper dist-upgrade
Loading repository data...
Reading installed packages...
Warning: You are about to do a distribution upgrade with all enabled repositories. Make sure these repositories are compatible before you continue. See 'man zypper' for more information about this command.
Computing distribution upgrade...
9 Problems:
Problem: 1: nothing provides 'this-is-only-for-build-envs' needed by the to be installed ffmpeg-8-mini-libs-8.0.1-3.2.x86_64
Problem: 2: nothing provides 'this-is-only-for-build-envs' needed by the to be installed ffmpeg-8-mini-libs-8.0.1-3.2.x86_64
Problem: 3: nothing provides 'this-is-only-for-build-envs' needed by the to be installed ffmpeg-8-mini-libs-8.0.1-3.2.x86_64
Problem: 4: nothing provides 'this-is-only-for-build-envs' needed by the to be installed ffmpeg-8-mini-libs-8.0.1-3.2.x86_64
Problem: 5: nothing provides 'this-is-only-for-build-envs' needed by the to be installed ffmpeg-8-mini-libs-8.0.1-3.2.x86_64
Problem: 6: nothing provides 'this-is-only-for-build-envs' needed by the to be installed ffmpeg-8-mini-libs-8.0.1-3.2.x86_64
Problem: 7: nothing provides 'this-is-only-for-build-envs' needed by the to be installed ffmpeg-8-mini-libs-8.0.1-3.2.x86_64
Problem: 8: nothing provides 'this-is-only-for-build-envs' needed by the to be installed ffmpeg-8-mini-libs-8.0.1-3.2.x86_64
Problem: 9: nothing provides 'this-is-only-for-build-envs' needed by the to be installed ffmpeg-8-mini-libs-8.0.1-3.2.x86_64
Solution 1: Following actions will be done:
deinstallation of chromium-146.0.7680.80-1.1.x86_64
deinstallation of pipewire-spa-plugins-0_2-1.6.2-1.1.x86_64
deinstallation of qt6-multimedia-6.10.2-1.2.x86_64
deinstallation of vlc-3.0.23-1699.9.pm.1.x86_64
deinstallation of audacious-plugins-4.5.1-1699.9.pm.23.x86_64
deinstallation of kpipewire6-imports-6.6.2-1.1.x86_64
deinstallation of kontact-25.12.3-1.1.x86_64
deinstallation of kmail-25.12.3-1.1.x86_64
deinstallation of khelpcenter-25.12.3-1.1.x86_64
deinstallation of kdeplasma6-addons-6.6.2-1.1.x86_64
deinstallation of kdepim-runtime-25.12.3-1.1.x86_64
deinstallation of discover6-backend-packagekit-6.6.2-1.1.x86_64
deinstallation of discover6-notifier-6.6.2-1.1.x86_64
deinstallation of libKPim6MailImporterAkonadi6-25.12.3-1.1.x86_64
deinstallation of libKF6PurposeWidgets6-6.24.0-1.1.x86_64
Solution 2: install libavcodec62-8.0.1-3.2.x86_64 from vendor openSUSE
replacing libavcodec62-8.0.1-1699.4.pm.104.x86_64 from vendor http://packman.links2linux.de
Solution 3: keep obsolete libavcodec62-8.0.1-1699.4.pm.104.x86_64
Solution 4: break ffmpeg-8-mini-libs-8.0.1-3.2.x86_64 by ignoring some of its dependencies
Choose from above solutions by number or skip, retry or cancel [1/2/3/4/s/r/c/d/?] (c): -
tlac
SUSE Reportedly May Be For Sale Yet Again
nem épp a legjobb hír, bizonytalanná válhat ezzel az opensuse jövője is szerintem
tlac
jól látom, hogy tumbleweed-en visszajöhetnek a korábban eltávolított csomagok egy dist-upgrade után?
pl. plymouth-ot, xscreensaver-t korábban leszedtem, most újra megjelentek -
tlac
urandom0
#4454
igen, azt látom
egyébként nem videokártya, mert az alaplapi kimenetet használom (asrock + 9800x3d, ami nem annyira jó párosítás, a reddit tele van vele, hogy meghalt benne a cpu)vicces lesz ez a rolling distro, mert egy korábbi hibám az úgy tűnik, hogy megjavult, amit itt írtam, hogy nem jön vissza a kép miután a monitor felébred
szóval csak remélni tudom, hogy csak szoftveres hiba
tlac
na belefutottam én is valami hibába, indításnál van némi probléma
csak a reset segített, érdekes módon másodjára jó lettfebr 24 20:27:33 opensuse kernel: amdgpu 0000:0b:00.0: [drm] *ERROR* [PLANE:201:plane-3] commit wait timed out
febr 24 20:27:33 opensuse kernel: amdgpu 0000:0b:00.0: [drm] *ERROR* flip_done timed out
febr 24 20:27:23 opensuse kernel: amdgpu 0000:0b:00.0: [drm] *ERROR* [CRTC:363:crtc-0] commit wait timed out
febr 24 20:27:23 opensuse kernel: amdgpu 0000:0b:00.0: [drm] *ERROR* flip_done timed out
febr 24 20:27:12 opensuse kernel: amdgpu 0000:0b:00.0: [drm] *ERROR* [CRTC:363:crtc-0] flip_done timed outpár napja is volt már egy hasonló jelenség, de akkor nem volt a logokban hiba, hanem csak 1 percre megállt, végül továbbment
tlac
értem, hogy hivatalosan nem lehet, de a karbantartó személyeket sem találtam meg
(persze magában a csomag leírásában lehet benne van, odáig nem mentem el egyelőre)közben megnéztem qemu-val az arch linux-ot is, hogy ott ott mit mond a gyári firefox
egy 6900xt van átpasszolva, szóval nem ugyanaz a gpu
egyébként vacillálok eléggé, hogy tumblweed vagy arch linux legyen a fő desktop os-em
más a filozófiájuk, azt már látom -
tlac
ohh, belefutottam egy probléma, hogy az opensuse ilyen-olyan jogi dolgok miatt nem támogat bizonyos video kodeket...
ez így nem lesz jóGPU: az, ami a 9800x3d-ben van
gyári firefox:
flatpak firefox:
sajnos ez így nekem elég súlyos probléma, mert lényegében minden programból, aminek köze van a videolejátszáshoz vagy valamilyen streaminghez, oda kell a flatpak verzió vagy hozzá kell adni valamilyen nem hivatalos külsős repository-t
utóbbit nem szívesen csinálnám, plusz nem is tudom, hogy tumbleweed-del hogyan tudhatnak szinkronban lenni
a flatpak-et meg nem szeretem.. -
tlac
urandom0
#4419
vagy nem
ha uefi volt korábban és azt kikapcsolod, akkor az nvram-ban lévő boot bejegyzések simán törlődhetnek, alaplaptól függ hogy van megvalósítva
win-t általában vissza tudják tenni, a többit márplusz legmodernebb videokártyák már nem is támogatják a legacy módot és simán lehet, hogy kép sem lesz amíg elindul egy oprendszer
na meg gpt-s fájlrendszerre feltelepíted a linux-ot úgy hogy nem uefi módban volt a gép, az is elég csúnya lesz
tlac
urandom0
#4394
úgy néztem, hogy szinte mindent is felpakol egy alaptelepítés, egy rakás firmware csomag felmegy
próbálgattam is korábban virtuális gépen, hogy mi történne ha már telepítés közben kikapcsolnám az ajánlott csomagokat, hát annak nem lenne olyan jó vége
hiába kapcsolom be olyankor a kde-t, meg kde appok-at, sddm-et sem tenne, de talán még a dolphin-t se
tlac
urandom0
#4385
desktop, full amd-s gép, 0 tuning
előtte kde neon volt a gépen, a kde ott is friss volt és voltak is problémák vele
ez a jelenség épp nem jelentkezett, de a kde ott is gyakran összeomlott jó sokáig
aztán a sokadik frissítés után eljutottak addig, hogy most már csak fél percre megfagyott, még a háttérben újraindultok a dolgok, miután a monitort kellett volna felébresztenie -
tlac
urandom0
#4382
úgy néz ki, hogy felébredtek, jött ma és tegnap is 1-1 adag frissítés
a yast-ot sajnálom, hogy nem támogatják tovább, az egy elég meghatározó tulajdonsága a suse/opensuse-énak már évtizedek óta lényegében
zypper-nek van egy tök jó tulajdonsága, amit eddig máshol nem láttam:
frissítés után szól, hogy meg lehet nézni, hogy milyen programok futnak, amiknek frissítette a fájljaitzypper ps -sViszont van egy idegesítő bug-om is. Miután a kde elaltatta a monitoromat, azt nem tudja visszahozni. Egy pillanatra visszakapcsol, aztán nem érzékel képet a monitor és ismét kikapcsol. Ha ekkor átváltok még gyorsan a ctrl+alt+f1-gyel a karakteres konzolra és utána vissza ctrl+alt+f2-vel a grafikus felületre, csak úgy lesz képem ismét.
AMD kártya, X11-gyel használom.
A journalctl-ben nem látok releváns hibát sem.. -
tlac
urandom0
#4380
Valóban, ma meg is lett a frissítés (tegnap nem volt, ki tudja milyen időzónában számítják).
Úgy nézem, hogy ez ilyen batch-ekben frissíthet?
[kép]Az új Firefox 147 egyébként alapból már a ~/.config/mozilla mappát használná, de az OpenSuse-ék nem álltak át, maradtak ~/.mozilla helynél.
A Myrlyn érdekes, mert lényegében nálam ugyanúgy néz ki, mint a Yast Sotfware:
Myrlyn vs. Yast Sotfware
Utóbbit nyomogattam, az átveszi a KDE-s témát, előbbi valamiért nem.A zypper-t eddig csak egy-egy csomag telepítésére használtam főként, plusz most az upgrade-re. Meg még egy nagyobb monstrumot, a virt-manager-t tettem fel vele. Úgy rémlik szépen felrakta a teljes függőségi láncot egyből mint, hogy libvirt -> qemu -> kvm.
Eddig nincs vele gondom.Viszont Debian/Ubuntu alatt vagy egy olyan parancs
dpkg-reconfigure csomagnév, amivel a csomag gyári beállításain lehet állítgatni (nem mindegyiken).
A Tumbleweed-en meg épp vagy benne van Yast-ban az a config vagy nincs.Pl. a karakteres terminál módosítása (betűtípus, locale) így néz ki, hogy
Debian alatt:
dpkg-reconfigure consolse-setupés egy menüből kiválaszthatom, amit szeretnék és utána beállítja rögtön.OpenSuse alatt:
kézzel kell szerkeszteni az /etc/vconsole.conf fájlt. -
tlac
Feltettem a gépre még múlt héten a Tumbleweed-et, hát vegyes a véleményem róla. Ubuntu/Debian és leszármazattairól jövök.
Egyrészt egész szépen össze van téve, az tetszik. Csomagok is frissek benne, elsősorban a rolling distro miatt választottam.
Viszont vannak ilyen dolgok benne, hogy erőlteti a telepítő, hogy min. 2 karakteres legyen a felhasználónév. Viszont én mindig 1 karaktert használok és ebből nem voltam hajlandó engedni. Ha létrehozok egy hosszabb felhasználót telepítés közben és utólag majd átnevezem, abba valamiért belepusztul a bejelentkező képernyő, meg az egész login folyamat (karakteres felületen is). De ha recovery-ben indítom és ott nem csinálok semmit, csak kilépek, mindegy megy rendesen.
Nem tudtam megfejteni, hogy mi volt a gond. A megoldás az lett telepítés közben nem hoztam létre user fiókot, hanem majd csak utána konzolból, így hibátlan lett.A másik még nagyobb hülyesége, hogy alapból telepíti a smart disk daemon-t. Eddig még rendben is lenne, de az úgy van config-olva, hogy automatikus futtasson egy rövid tesztet a lemezeken.
Így egyszer csak azt tapasztaltam, hogy teker a vinyó brutálisan és végül az egész rendszer kezd nem válaszolni semmire. Tálca megfagy, programot nem tudok sem indítani, sem bezárni, még egy újraindítás sem megy. Ki kellett az egész gépet reset-elni. Ekkor még nem tudtam, hogy mi történt, bejön a bios, na ez jól kezdődik, nem látja az SSD-met sem, de továbbra is villog a HDD led a házon. Oké, akkor power-off. Utána majd a csak logokat vizsgálva jöttem rá, hogy a rendszer SSD-re is elindult, csak amíg az futott, teljesen unresponsive lett a gép.
Megoldásként a configból kiszedtem a short test ütemezését. De egy kezdő erre nem igazán jönne rá.Meg még vannak ilyen apróságok, hogy Grub2-BLS az alapértelmezett bootloader-e (ami szerencsére cserélhető). Amiről alig találni valamit a neten. De ezt általános gondnak is látom, hogy nincs akkor közösség mögötte, mint a népszerűbb disztribúciók mögött, így a tudásanyag sem annyira jó.
Na meg, elvileg rolling distro, de ennek ellenére semmi nem frissült már pár napja. Hiába nyomkodom neki a refresh-t, konzolból is vagy akár yast-ból. (Firefox-ból is régebbi van benne, ami zavaró, mert nem tudtam rendesen áthozni a profilomat, csak úgy, hogy kézzel felraktam egy másik ff-t és ahhoz tettem át.)
tlac
Megjelent az openSUSE 11.2, [link]
tlac
leviske
#1691
Csomag alatt .rpm-re gondolsz?
igen
de ha így nem megy, akkor, amit már írtam, hogy tölts le egy ff-t a mozillától, csomagold ki és nagyjából kész is
És miután a Leadtek Helpsite-on külön le volt közölve, hogy jöttek/jönnek a Linux-os Leadtek driverek, gondoltam hátha ott lesz a gond.
általánosságban nem a gyártóval kell foglalkozni, hanem az ő általa használt chipekkel, tehát ne a leadtek-re keresgess rá, hanem a conexant vmire (pontosan ott van az lspci kimenetén)
tlac
leviske
#1689
a Firefoxot hogy tudom 3.5.2-re frissíteni egyszerűen.
MOD: Plusz a Thunderbird 3 telepítésében is kéne egy kis segítség.keresel csomagot, biztosan van
vagy letöltöd és kicsomagolod a home könyvtáradbaLeadtek TV2000 Expert
biztos, hogy nem működik vagy csak a hang van lenémítva?
tlac
leviske
#1678
még a yast-ban hardverinformációknál megnézheted, hogy mi van, főleg az érdekel, hogy milyen modult töltött be hozzá
az intel ich8 hda-t add be neki, egyébként ennek működnie kellene kapásból
(miért ilyen homályosak a képek, amiket felraktál?)
modra:
sehogy, de először a hangot oldd meg
tlac
leviske
#1661
én is debian/ubuntu-s vagyok, opensuse-t csak tesztelgetem, de
1. most itt a kde4 tálcáján van egy updater applet
(csak most néztem meg, hogy mi ez az ubuntuzilla, szerintem nem sok értelme van...)
2. alapból nem megy?
ha nem, akkor nem lesz egyszerű életre kelteni
alsa modult kell fordítanod -
tlac
Ezt melyik csomaggal tudom előhozni és melyik tárolóban van?
Ti hogyan állítjátok be a firefox-ot, hogy ne üssön el nagyon a kde4-től?
tlac
Nos a kde4 még igencsak béta. Bármit is mondanak.
igen, csodálkozik is, hogy az alapértelmezett kde nem a 3-as az opensuse-ban
mert így aki pl. kde-s livecd-ről telepít, az kap egy használhatatlan rendszert, amit rögtön hackelni kell...Ha unod a banánt - vagyis az uborkát
esetleg alternatíva lehet egy stabil debian. Az közelebb áll a megszokotthoz és garantáltan stabilabb.igen, debian sarge-ot használtam több, mint 1 évig, legjobb volt
aztán új gépet vettem és gyorsan kellett vmi, éppen ubuntu volt kéznél, aztán az is maradt
debian etch-re aztán próbáltam visszaváltani, de nem úgy működött a kernel benne, mint, amit elváltam volna tőle, fordítani meg semmi kedvem nem volt... -
tlac
már pár napja fent volt az opensuse 11, virtuális gépen tesztelgettem
a kde4.0 használhatlan benne, a 4.1-essel már jobbnak tűnt
az alap gnome is ok benne
viszont a dpkg alapú rendszereket ismerem régóta, ez teljesen más világ nekem
mivel eléggé beleuntam már a buguntu-ba, azt néztem, hogy megérné-e átváltani egy teljesen ismeretlen rendszerre, a válasz: nem -
tlac
Hova pakolja az opensuse a letöltött csomagokat?
- Apple iPhone 17 Pro Max – fennsík
- Suzuki topik
- Haditechnika, harcászat
- Google Pixel Watch 3 - képpontos idő
- Vicces képek
- Apple iPhone 13 Pro 256GB, Kártyafüggetlen, 1 Év Garanciával
- Lenovo ThinkPad L13 Gen 2 Yoga Ryzen3 5400U Refurbished - Garancia
- HIBÁTLAN iPhone 12 Pro 256GB Graphite-1 ÉV GARANCIA - Kártyafüggetlen, MS4518, 100% Akksi
- ÁRGARANCIA!Épített KomPhone Ryzen 7 7800X3D 32/64GB RAM RTX 5080 16GB GAMER PC termékbeszámítással
