Keresés
  • Pinocchio23
    válasz suste #1337 üzenetére
    Arra van esély, hogy ezt a bugot javították a 15.05 CC-ben? Mert ha igen akkor feltenném a CC-t és rá a ti mentéseiteket, a 9092-t. ;)
  • Pinocchio23
    válasz Pinocchio23 #1356 üzenetére
    Jelenleg bő 48 órája megy leszakadás nélkül.
    A Log-ban a következő jelent meg:
    Wed May 17 20:32:43 2017 kern.warn kernel: [176381.730000] net_ratelimit: 41 callbacks suppressed
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.770000] ---[ end trace 2ed9a34c70584e38 ]---
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.770000] [<86884e2c>] sta_info_move_state+0x580/0x604 [mac80211]
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.760000] [<8028dc1c>] warn_slowpath_null+0x18/0x24
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.750000] [<8028db64>] warn_slowpath_common+0x78/0xa8
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.750000] [<802240ac>] show_stack+0x48/0x70
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.750000] Call Trace:
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.710000] ...
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.710000] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 8489da58
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.710000] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.710000] 00000008 8027e59c 00000003 801e3404 868c95f0 00000000 802d9394 8489dacc
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.710000] 802d7d04 8031f37b 00000738 803939dc 84953c48 00000000 00000004 00000028
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.710000] Stack : 00000000 00000000 00000000 00000000 8039bf1e 00000037 84953c48 00000000
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.560000] Modules linked in: pppoe ppp_async option iptable_nat ath9k usb_wwan pppox ppp_generic nf_nat_pptp nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_ipv4 nf_conntrack_amanda ipt_MASQUERADE ath9k_common xt_time xt_tcpudp xt_tcpmss xt_string xt_statistic xt_state xt_recent xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_id xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TCPMSS xt_REDIRECWed May 17 20:32:41 2017 kern.warn kernel: [176379.700000] CPU: 0 PID: 1848 Comm: hostapd Not tainted 3.10.49 #145
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.540000] WARNING: at /home/suste/openwrt/BB/build_dir/target-mips_34kc_uClibc-0.9.33.2/linux-ar71xx_generic/compat-wireless-2014-05-22/net/mac80211/sta_info.c:897 sta_info_move_state+0x580/0x604 [mac80211]()
    Wed May 17 20:32:41 2017 kern.warn kernel: [176379.540000] ------------[ cut here ]------------
    Wed May 17 20:32:39 2017 kern.warn kernel: [176377.540000] ath10k: SWBA overrun on vdev 0
    Wed May 17 20:32:39 2017 kern.warn kernel: [176377.430000] ath10k: SWBA overrun on vdev 0
    Wed May 17 20:32:39 2017 kern.warn kernel: [176377.330000] ath10k: SWBA overrun on vdev 0
    Wed May 17 20:32:39 2017 kern.warn kernel: [176377.230000] ath10k: SWBA overrun on vdev 0
    Wed May 17 20:32:39 2017 kern.warn kernel: [176377.130000] ath10k: SWBA overrun on vdev 0
    Wed May 17 20:32:39 2017 kern.warn kernel: [176377.020000] ath10k: SWBA overrun on vdev 0
    Wed May 17 20:32:39 2017 kern.warn kernel: [176376.920000] ath10k: SWBA overrun on vdev 0
    Wed May 17 20:32:38 2017 kern.warn kernel: [176376.820000] ath10k: SWBA overrun on vdev 0
    Wed May 17 20:32:38 2017 kern.warn kernel: [176376.720000] ath10k: SWBA overrun on vdev 0
  • Pinocchio23
    válasz vargalex #1354 üzenetére
    Egy próbát megér.
    Délután kipróbálom.
    Csomag vesztés nem zavafhat be? Valahol olvastam az imént...
  • Pinocchio23
    válasz Headless #1352 üzenetére
    Kiegészítésnek:
    Az usbmode-t le szoktam tiltani. Ipv6 interfészt pedig törölni.
    A szolgálfatő cserélt vezetékef a lakásban és digitális elosztót.
  • Pinocchio23
    válasz vargalex #1349 üzenetére
    Szia. Nem tettem fel ilyesmit. Tudtommal. Volt egy factory reset. Beállítottam a wan-t. Pppoe. Meg a többi dolgot beállítottam, ddns, dlna, transmission. De csomagot nem telepítettem. :)
  • Pinocchio23
    válasz SztiviVander #1346 üzenetére
    Szia.
    Nincs másik szolgáltató, modem, stb. Csak a Telekom van a routeren.
    Nem pingeltem semmit!?
  • Pinocchio23
    Valamiért a routerem leszakad a netről random. Az alábbi bejegyzéseket látom a logban. Valakinek ötlete? Hogy lehet-e összefüggés a modem cserével, vagy router hiba, vagy szolgáltató, nem tudom :(
    Sun May 14 16:09:05 2017 daemon.info hostapd: wlan0: STA 9c:b2:b2:77:1c:a8 WPA: pairwise key handshake completed (RSN)
    Sun May 14 16:09:05 2017 kern.warn kernel: [867267.970000] ath10k: failed to delete peer 9c:b2:b2:77:1c:a8 for vdev 0: -145
    Sun May 14 16:09:02 2017 daemon.info hostapd: wlan0: STA 9c:b2:b2:77:1c:a8 IEEE 802.11: associated (aid 1)
    Sun May 14 16:09:02 2017 daemon.info hostapd: wlan0: STA 9c:b2:b2:77:1c:a8 IEEE 802.11: authenticated
    Sun May 14 15:59:38 2017 daemon.warn pppd[1443]: IPV6CP: timeout sending Config-Requests
    Sun May 14 15:59:13 2017 daemon.err miniupnpd[32613]: Why did you run me anyway?
    Sun May 14 15:59:13 2017 daemon.err miniupnpd[32613]: could not open lease file: /var/upnp.leases
    Sun May 14 15:59:13 2017 user.notice ddns-scripts-myddns: Update successful
    Sun May 14 15:59:12 2017 user.notice HotPlug - IFace - stat_res: '/tmp/pppoe-wan.stat' not exist.
    Sun May 14 15:59:12 2017 user.notice HotPlug - IFace - Knockd: Knockd restarted.
    Sun May 14 15:59:11 2017 user.notice ddns-scripts-myddns: Running IP check ...
    Sun May 14 15:59:10 2017 daemon.info dnsmasq[1925]: using nameserver 84.2.44.1#53
    Sun May 14 15:59:10 2017 daemon.info dnsmasq[1925]: using nameserver 84.2.46.1#53
    Sun May 14 15:59:10 2017 daemon.info dnsmasq[1925]: using local addresses only for domain lan
    Sun May 14 15:59:10 2017 daemon.info dnsmasq[1925]: reading /tmp/resolv.conf.auto
    Sun May 14 15:59:09 2017 user.notice firewall: Reloading firewall due to ifup of wan (pppoe-wan)
    Sun May 14 15:59:08 2017 user.info mwan3track: Lost 24 ping(s) on interface wan (pppoe-wan)
    Sun May 14 15:59:08 2017 user.notice mwan3: ifup interface wan (pppoe-wan)
    Sun May 14 15:59:08 2017 daemon.notice netifd: Interface 'wan' is now up
    Sun May 14 15:59:08 2017 daemon.notice netifd: Network device 'pppoe-wan' link is up
    Sun May 14 15:59:08 2017 daemon.notice pppd[1443]: secondary DNS address 84.2.44.1
    Sun May 14 15:59:08 2017 daemon.notice pppd[1443]: primary DNS address 84.2.46.1
    Sun May 14 15:59:08 2017 daemon.notice pppd[1443]: remote IP address 145.236.***.***
    Sun May 14 15:59:08 2017 daemon.notice pppd[1443]: local IP address 84.0.61.0
    Sun May 14 15:59:08 2017 daemon.notice pppd[1443]: peer from calling number 40:55:39:41:67:D2 authorized
    Sun May 14 15:59:08 2017 daemon.notice pppd[1443]: PAP authentication succeeded
    Sun May 14 15:59:08 2017 daemon.notice pppd[1443]: Connect: pppoe-wan <--> eth0
    Sun May 14 15:59:08 2017 daemon.info pppd[1443]: Using interface pppoe-wan
    Sun May 14 15:59:08 2017 daemon.warn pppd[1443]: Connected to 40:55:39:41:67:d2 via interface eth0
    Sun May 14 15:59:08 2017 daemon.info pppd[1443]: PPP session is 1734
    Sun May 14 15:59:01 2017 cron.info crond[1655]: crond: USER root pid 32023 cmd /bin/cstat 'memory'
    Sun May 14 15:59:01 2017 cron.info crond[1655]: crond: USER root pid 32022 cmd /bin/cstat 'storage_IO'
    Sun May 14 15:59:01 2017 cron.info crond[1655]: crond: USER root pid 32021 cmd /bin/cstat 'network_lan'
    Sun May 14 15:59:01 2017 cron.info crond[1655]: crond: USER root pid 32020 cmd /bin/cstat 'network_wan'
    Sun May 14 15:59:01 2017 cron.info crond[1655]: crond: USER root pid 32019 cmd /bin/cstat 'load'
    Sun May 14 15:58:47 2017 user.notice mwan3: ifdown interface wan (pppoe-wan)
    Sun May 14 15:58:47 2017 user.notice mwan3track: Interface wan (pppoe-wan) is offline
    Sun May 14 15:58:41 2017 daemon.warn dnsmasq[1925]: no servers found in /tmp/resolv.conf.auto, will retry
    Sun May 14 15:58:37 2017 user.notice mwan3: ifdown interface wan (unknown)
    Sun May 14 15:58:37 2017 daemon.notice netifd: Interface 'wan' has lost the connection
    Sun May 14 15:58:37 2017 daemon.notice pppd[1443]: Connection terminated.
    Sun May 14 15:58:36 2017 daemon.notice netifd: Network device 'pppoe-wan' link is down
    Sun May 14 15:58:35 2017 daemon.info pppd[1443]: Sent 1685411308 bytes, received 3574493451 bytes.
    Sun May 14 15:58:35 2017 daemon.info pppd[1443]: Connect time 2620.9 minutes.
    Sun May 14 15:58:35 2017 daemon.notice pppd[1443]: Serial link appears to be disconnected.
    Sun May 14 15:58:35 2017 daemon.info pppd[1443]: No response to 5 echo-requests
  • Pinocchio23
    Azt vettem észre, hogy a router a mac szűrő ellenére a jelszó ismeretében felengedi a hálózatra a készülékeket.
    [kép]
