alexy92
Sub All()
Windows("raw_invoice_riports.xlsx").Activate
Worksheets("Radler").Activate
Columns("K:K").Select
Selection.Replace What:="/", Replacement:="", LookAt:=xlPart, _
SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _
ReplaceFormat:=False
Columns("A:A").Select
Range("L1").Select
ActiveCell.Value = "Check if its in masterfile"
Range("L2").Select
ActiveCell.FormulaR1C1 = "=IFERROR(MATCH(RC[-1],[invoices_masterfile.xlsm]main!C13,0),""Not in file"")"
With Sheets("Radler")
LR = Range("K" & Rows.Count).End(xlUp).Row
Range("L1").End(xlDown).Offset(0, 0).Activate
ActiveCell.AutoFill Range(ActiveCell.Address, Cells(LR, ActiveCell.Column))
End With
Range("1:1").Select
Selection.AutoFilter
ActiveSheet.Range("$A:$L").AutoFilter Field:=12, Criteria1:= _
"Not in file"
Range("B1").Select
ActiveCell.Offset(1, 0).Select
Range(Selection, Selection.End(xlDown)).Select
On Error Resume Next
Selection.Copy
If Err.Number <> 0 Then
CevaBelgium
Else
VKtrans
End If
Windows("invoices_masterfile.xlsm").Activate
Worksheets("main").Activate
Range("G" & Rows.Count).End(xlUp).Offset(1).Select
Selection.PasteSpecial Paste:=xlPasteValues, operation:=xlNone, skipblanks _
:=False, Transpose:=False
Range("B1").Select
Selection.Copy
Range("H" & Rows.Count).End(xlUp).Offset(1).Select
Range("D1").Select
Selection.Copy
Range("I" & Rows.Count).End(xlUp).Offset(1).Select
Range("D1").Select
Selection.Copy
Range("J" & Rows.Count).End(xlUp).Offset(1).Select
Range("G1").Select
Selection.Copy
Range("M" & Rows.Count).End(xlUp).Offset(1, -1).Activate
Range("K1").Select
Selection.Copy
Range("M" & Rows.Count).End(xlUp).Offset(1, 0).Activate
Range("A" & Rows.Count).End(xlUp).Offset(1).Select
ActiveCell.FormulaR1C1 = "=vlookup(RC[1],vendor_codes!C1:C2,2,0)"
ActiveCell.Offset(0, 1).Select
ActiveCell.Value = "RADLER KFT."
ActiveCell.FormulaR1C1 = "=Year(RC[4])"
ActiveCell.FormulaR1C1 = "=Month(RC[3])"
ActiveCell.FormulaR1C1 = "=isoweeknum(RC[2])"
ActiveCell.FormulaR1C1 = "=vlookup(RC[-2],MOR!C1:C2,2,0)"
Range("K" & Rows.Count).End(xlUp).Offset(1).Select
ActiveCell.FormulaR1C1 = "=RC[-1]*RC[-5]"
With Sheets("main")
LR = Range("H" & Rows.Count).End(xlUp).Row
Range("A1").End(xlDown).Offset(0, 0).Activate
Range("B1").End(xlDown).Offset(0, 0).Activate
Range("C1").End(xlDown).Offset(0, 0).Activate
Range("D1").End(xlDown).Offset(0, 0).Activate
Range("E1").End(xlDown).Offset(0, 0).Activate
Range("F1").End(xlDown).Offset(0, 0).Activate
Range("K1").End(xlDown).Offset(0, 0).Activate
End With
Rows("1:1").Activate
Columns("L").Select
Selection.Delete Shift:=xlToLeft
Range("A1").Select
End Sub
Sub VKtrans()
Selection.Clear
Worksheets("VK Transport").Activate
Selection.Replace What:="-", Replacement:="", LookAt:=xlPart, _
Range("V1").Select
Range("V2").Select
ActiveCell.FormulaR1C1 = "=IFERROR(MATCH(RC[-21],[invoices_masterfile.xlsm]main!C13,0),""Not in file"")"
With Sheets("VK Transport")
LR = Range("A" & Rows.Count).End(xlUp).Row
Range("V1").End(xlDown).Offset(0, 0).Activate
End With
Range("1:1").Select
ActiveSheet.Range("$A:$V").AutoFilter Field:=22, Criteria1:= _
"Not in file"
Range("B1").Select
Selection.Copy
DSVROADNV
Else
CevaBelgium
End If
Range("B1").Select
Selection.Copy
Range("L1").Select
Selection.Copy
Range("J" & Rows.Count).End(xlUp).Offset(1, -1).Select
Range("L1").Select
Selection.Copy
Range("O2").End(xlDown).Offset(0, 2).Select
Range("Q2", "Q" & LR).Select
End With
Selection.Copy
Range("A1").Select
Selection.Copy
ActiveCell.Value = "VK Transport"
With Sheets("main")
End With
Columns("V:V").Select
Range("A1").Select
End Sub
Sub CevaBelgium()
Selection.Clear
Worksheets("Ceva Belgium").Activate
Columns("A:B").Select
Selection.Insert Shift:=xlToRight, CopyOrigin:=xlFormatFromLeftOrAbove
Range("A1").Select
ActiveCell.Value = "Invoice Date"
Range("B1").Select
ActiveCell.Value = "Service Date"
Range("A2").Select
ActiveCell.FormulaR1C1 = "=Date(Left(RC[3],4),mid(RC[3],5,2),right(RC[3],2))"
Range("B2").Select
ActiveCell.FormulaR1C1 = "=iferror(Date(Left(RC[20],4),mid(RC[20],5,2),right(RC[20],2)),RC[-1])"
Columns("C:C").Select
Selection.TextToColumns Destination:=Range("C1"), DataType:=xlDelimited, _
TextQualifier:=xlDoubleQuote, ConsecutiveDelimiter:=False, Tab:=True, _
Semicolon:=False, Comma:=False, Space:=False, Other:=False, FieldInfo _
:=Array(1, 1), TrailingMinusNumbers:=True
Range("CJ1").Select
ActiveCell.Value = "Check if its in the masterfile"
Range("CJ2").Select
ActiveCell.FormulaR1C1 = "=IFERROR(MATCH(RC[-85],[invoices_masterfile.xlsm]main!C13,0),""Not in file"")"
With Sheets("Ceva Belgium")
Range("CJ1").End(xlDown).Offset(0, 0).Activate
End With
Range("1:1").Select
ActiveSheet.Range("$A:$CJ").AutoFilter Field:=88, Criteria1:= _
"Not in file"
Range("A1").Select
Selection.Copy
Azkar
Else
DSVROADNV
End If
Range("H" & Rows.Count).End(xlUp).Offset(1, 0).Activate
Range("B1").Select
Selection.Copy
Range("G" & Rows.Count).End(xlUp).Offset(1, 0).Activate
Range("AN1").Select
Selection.Copy
Range("J" & Rows.Count).End(xlUp).Offset(1, -1).Activate
Range("AN1").Select
Selection.Copy
Range("J" & Rows.Count).End(xlUp).Offset(1, 0).Activate
Range("AL1").Select
Selection.Copy
Range("C1").Select
Selection.Copy
ActiveCell.Value = "CEVA FREIGHT BELGIUM N.V."
With Sheets("main")
End With
Range("1:1").Select
Columns("CJ:CJ").Select
Range("A1").Select
End Sub
Sub DSVROADNV()
Selection.Clear
Worksheets("DSV Road").Activate
Range("S1").Select
Range("S2").Select
ActiveCell.FormulaR1C1 = "=Iferror(match(RC[-18],[invoices_masterfile.xlsm]main!C13,0),""Not in file"")"
With Sheets("DSV Road")
Range("S1").End(xlDown).Offset(0, 0).Activate
End With
Range("1:1").Select
ActiveSheet.Range("$A:$S").AutoFilter Field:=19, Criteria1:= _
"Not in file"
Range("b1").Select
Selection.Copy
DachserBE
Else
Azkar
End If
Range("b1").Select
Selection.Copy
Range("L1").Select
Selection.Copy
Range("L1").Select
Selection.Copy
Range("M2").End(xlDown).Offset(0, 1).Select
Range("N2", "N" & LR).Select
End With
Selection.Copy
Range("M" & Rows.Count).End(xlUp).Offset(1, -1).Select
Range("A1").Select
Selection.Copy
Range("M" & Rows.Count).End(xlUp).Offset(1).Select
Range("B" & Rows.Count).End(xlUp).Offset(1).Select
ActiveCell.FormulaR1C1 = "DSV ROAD N V"
Range("C" & Rows.Count).End(xlUp).Offset(1).Select
ActiveCell.FormulaR1C1 = "=YEAR(RC[4])"
Range("D" & Rows.Count).End(xlUp).Offset(1).Select
ActiveCell.FormulaR1C1 = "=month(RC[3])"
Range("E" & Rows.Count).End(xlUp).Offset(1).Select
ActiveCell.FormulaR1C1 = "=Isoweeknum(RC[3])"
Range("F" & Rows.Count).End(xlUp).Offset(1).Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-2],MOR!C1:C2,2,0)"
With Sheets("main")
End With
Rows("1:1").Select
Columns("S").Select
Range("A1").Select
End Sub
Sub Azkar()
Selection.Clear
Worksheets("Azkar").Activate
Selection.TextToColumns Destination:=Range("A1"), DataType:=xlDelimited, _
Columns("P:P").Select
Selection.TextToColumns Destination:=Range("P1"), DataType:=xlDelimited, _
Range("Z1").Select
ActiveCell.Value = " Check if its in the matserfile"
Range("Z2").Select
ActiveCell.FormulaR1C1 = "=IFERROR(MATCH(RC[-25],[invoices_masterfile.xlsm]main!C13,0),""Not in file"")"
With Sheets("Azkar")
Range("Z1").End(xlDown).Offset(0, 0).Activate
End With
Rows("1:1").Select
ActiveSheet.Range("$A:$Z").AutoFilter Field:=26, Criteria1:= _
"Not in file"
Range("O1").Select
Selection.Copy
DachserHU
Else
DachserBE
End If
Range("O1").Select
Selection.Copy
Range("N1").Select
Selection.Copy
Range("N1").Select
Selection.Copy
Range("A1").Select
Selection.Copy
Range("O2").End(xlDown).Offset(0, 1).Select
Range("P2", "P" & LR).Select
End With
Selection.Copy
Range("K" & Rows.Count).End(xlUp).Offset(1, 1).Activate
ActiveCell.Value = "TRANSPORTES AZKAR, S.A"
With Sheets("main")
End With
Range("1:1").Select
Columns("Z:Z").Select
Range("A1").Select
End Sub
Sub DachserBE()
Selection.Clear
Worksheets("Dachser BE").Activate
Range("S1").Select
Range("s2").Select
ActiveCell.FormulaR1C1 = "=IFERROR(MATCH(RC[-2],[invoices_masterfile.xlsm]main!C13,0),""Not in file"")"
Range("t1").Select
ActiveCell.Value = "Date"
Range("t2").Select
ActiveCell.FormulaR1C1 = "=date(right(RC[-19],4),mid(RC[-19],4,2),left(RC[-19],2))"
With Sheets("Dachser BE")
LR = Range("Q" & Rows.Count).End(xlUp).Row
Range("T1").End(xlDown).Offset(0, 0).Activate
End With
Range("1:1").Select
ActiveSheet.Range("$A:$M").AutoFilter Field:=19, Criteria1:= _
"Not in file"
Range("T1").Select
Selection.Copy
WaberersINT
Else
DachserHU
End If
Selection.End(xlUp).Select
Range("P1").Select
Selection.Copy
Range("P1").Select
Selection.Copy
Range("F1").Select
Selection.Copy
Range("M" & Rows.Count).End(xlUp).Offset(0).Select
ActiveCell.Offset(1, -1).Activate
Range("Q1").Select
Selection.Copy
Application.CutCopyMode = False
Selection.Copy
ActiveCell.Offset(0, 0).Activate
Range(Selection, Selection.End(xlToLeft)).Select
ActiveCell.FormulaR1C1 = "DACHSER TRANSPORT BELGIE"
With Sheets("main")
End With
ActiveSheet.Range("1:1").AutoFilter
Rows("1:1").Select
Columns("S:T").Select
Range("A1").Select
End Sub
Sub DachserHU()
On Error GoTo 0
Selection.Clear
Worksheets("Dachser HU").Activate
Range("AJ1").Select
Range("AJ2").Select
With Sheets("Dachser HU")
LR = Range("AH" & Rows.Count).End(xlUp).Row
Range("AJ1").End(xlDown).Offset(0, 0).Activate
End With
Range("1:1").Select
ActiveSheet.Range("$A:$AJ").AutoFilter Field:=36, Criteria1:= _
"Not in file"
Range("V1").Select
Selection.Copy
Range("V1").Select
Selection.Copy
Vege
Else
WaberersINT
End If
Range("W1").Select
Selection.Copy
Range("W1").Select
Selection.Copy
Range("D1").Select
Selection.Copy
Range("K" & Rows.Count).End(xlUp).Offset(1, 1).Select
Range("AH1").Select
Selection.Copy
ActiveCell.Value = "LIEGL & DACHSER SZALLITMANYOZASI ES"
With Sheets("main")
End With
Columns("AJ").Select
Range("A1").Select
End Sub
Sub WaberersINT()
Selection.Clear
Worksheets("Waberers INT").Activate
Range("J1").Select
Range("J2").Select
ActiveCell.FormulaR1C1 = "=IFERROR(MATCH(RC[-8],[invoices_masterfile.xlsm]main!C13,0),""Not in file"")"
With Sheets("Waberers INT")
Range("J1").End(xlDown).Offset(0, 0).Activate
End With
Range("1:1").Select
ActiveSheet.Range("$A:$J").AutoFilter Field:=10, Criteria1:= _
"Not in file"
Range("C1").Select
Selection.Copy
Vege
Else
Vege
End If
Range("C1").Select
Selection.Copy
Range("F1").Select
Selection.Copy
Range("F1").Select
Selection.Copy
Range("B1").Select
Selection.Copy
ActiveCell.Value = "WABERERS INTERNATIONAL ZRT"
With Sheets("main")
End With
Columns("J:J").Select
Range("A1").Select
End Sub
Sub Vege()
Selection.Clear
MsgBox "Siker!", vbExclamation
End
End SubÍgy lenne, és a többit már tudjátok
alexy92
Szia,
Sajnos nem vagyok még expert, így tudnál segíteni a változóban? Illetve a változó minden sub elejére kell?
Azt látom, ott ahol hibára futok, oda kell majd berakjam az on error goto VÁLTOZÓ. ÉS a változóban lesz majd az iferror, a subok elején meg az Iserror-t false-á teszem.Köszi!
alexy92
Delila_1
#2846
A probléma az, hogy,
Sub1
művelet
művelet
művelet
Selection.Copy <- itt szokott kijönni az 1004-es hiba, mert sok a kijelölt cella
If Err.Number <> 0 Then sub3 Else sub2
művelet
művelet
művelet
endsub2
On error goto 0
művelet
műveletHa én a kövi sub elején nullázom le, akkor a kövi subot folytatja, az if err.number utáni részt elhagyja, ha hibára fut, ha nem. Értelemszerűen, ha hibára fut, akkor jól teszi, de nekem jelenleg hiba nélkül is átugorja.
alexy92
alexy92
Delila_1
#2817
Szia,
Most sikerült ténylegesen foglalkoznom vele, és a helyzet az, hogy szépen tovább lép a suboknál, de sajnos akkor is amikor nem dobna fel hibát. Mit ronthattam el ?
If Err.Number <> 0 Then kövi utáni sub Else Kövi subDe itt mindig a "kövi sub" jön ki.
Előre is köszönöm,
Viktor -
alexy92
alexy92
Egy olyan makrón dolgozom, ami több hasonló műveletet végez el, több sheetről. A kérdésem az lenne, hogy van-e olyan parancs ami közé be tudom illeszteni az egyes részeket, hogy ha azon belűl bármi hibára fut, akkor azt a részt ne futassa le, hanem egyből a következő hasábra menjen?
Előre is köszönöm!
- Apple MacBook
- Intel Core Ultra 3, Core Ultra 5, Ultra 7, Ultra 9 "Arrow Lake" LGA 1851
- Kuponkunyeráló
- Milyen okostelefont vegyek?
- Új termékkel és áremeléssel reagál a memóriahiányra a Raspberry Pi
- Xiaomi Redmi Note 8 Pro 64GB, Kártyafüggetlen, 1 Év Garanciával
- Apple iPhone 12 64GB, Kártyafüggetlen, 1 Év Garanciával
- Apple iPhone 13 Pro Max 128GB, Kártyafüggetlen, 1 Év Garanciával
- LG SN8Y 5.1.2 Dolby Atmos soundbar MERIDIAN technológiával hangprojektor
- Xiaomi Redmi Note 14 Pro 256GB,Újszerű,Dobozaval,12 hónap garanciával
- HIBÁTLAN iPhone 12 Pro Max 256GB Graphite -1 ÉV GARANCIA - Kártyafüggetlen, MS4520
- Honor 200 Pro 512GB, Kártyafüggetlen, 1 Év Garanciával
- GAMING PC! Ryzen 9 3900X / RX 6700 XT / B450 / 16GB 4000MHz / 500GB NVMe / 750w Gold! BezsámítOK
- iPhone 17 Pro Max 256GB 100% (1év Garancia)
