(Frissítve: 2020.05.31.)
Воланд
1.: xp-vel, vistaval, nem eredeti win7-el, win8-al rendelkezo felhasznalok nem kapnak ingyen windows-t. az insider program kereteben az eula szerint csak tesztelesre lehet hasznalni az os-t.
2.: aki az elso egy evben frissit, annak az egy ev letelte utan sem kell fizetnie erte. nyilvan oem-et nem vihet at masik gepre.
3.: ne olvass tech temaban hvg-t. -
Воланд
Воланд
tatararpad
#7587
tobb, mint 300 bugfix.
Воланд
ha esetleg valaki sokallta volna eddig a ket build kozott eltelt idot.
Воланд
Milestone2
#7547
a kell azert az tulzas. olvasd el az insider program eulajat.
Воланд
dredjudge84
#7542
igen, igaz.
Воланд
JamesHun
#7522
"Microsoft Account notifications
If you don’t have your Microsoft Account (MSA) connected to your PC, starting in the next build you’ll start seeing notifications asking you to do so. You’ll need to connect the MSA that you registered for the Windows Insider Program with (and accepted the “Microsoft Windows Insider Program Agreement”) in order to continue receiving new Windows 10 Insider Preview builds (both Fast and Slow rings) from Windows Update. If you already have your MSA connected to your account on your PC, then you’re all set. We’re introducing new infrastructure in Windows Update to help us deliver new builds more effectively to Windows Insiders, and ensure that we’re flighting builds to people who have registered and opted in to the program. Connecting your MSA also allows seamless access to Windows Insider-only functionality in the Windows Feedback app and Insider Hub too.
This change is for the Windows Insider Program ONLY, and is specific to how we’re delivering the Insider Preview builds. Once available on July 29th, you do not need an MSA to upgrade Windows 10 on your Windows 7 or Windows 8.1 PCs if they are not receiving Insider Preview builds. You will not be required to use an MSA on new PCs that come with Windows 10 preinstalled or clean installed from media. Some features in Windows 10 do require an MSA to use, such as downloading apps in the Windows Store.
Воланд
Воланд
az van az osszefoglaloban, hogy "Minden Windows 7, Windows 8 és Windows 8.1 tulajdonos ingyenesen frissíthet Windows 10-re."
na ez igy nem igaz. windows 7 sp1-rol es windows 8.1 update-rol lehet ingyen frissiteni.
Воланд
Воланд
King Unique
#7383
az a szep a xxi-dik szazadban, hogy annyi adat erheto el/tarolhato, hogy mar keptelenseg annak feldolgozasa esszeru idon belul. megfigyelest csak es kizarolag celzottan lehet vegezni, vagy tomegesen, de akkor kulcsszavak alapjan. ha te azt hiszed, hogy azoknak a csunya, harombetus cegeknek van egy magikus adatbazisuk, melynek keresojebe beirjak random atlagpolgar nevet, majd a lekeres megadja a cipomeretet, meg az altala latogattot felnottfilmes oldalak listajat, akkor sulyosan tevedsz.
Воланд
FoxiestFox
#7353
akkor visszaallitod a win7-et.
Воланд
FoxiestFox
#7351
nem.
Воланд
King Unique
#7310
en amugy sose ertettem ezt az sfc futtatasi maniat...
Воланд
Bandi8bácsi
#7233
aztan szerintem van olyan tores, ami ezt is atveri.
Воланд
#7176
“I want to opt out of the Windows Insider Program on 7/29.”
If you decide to opt-out of the program and upgrade to the 7/29 build you will be subject to exactly the same terms and conditions that govern the offer* that was extended to all Genuine Windows 7 and 8.1 customers. This is not a path to attain a license for Windows XP or Windows Vista systems. If your system upgraded from a Genuine Windows 7 or Windows 8.1 license it will remain activated, but if not, you will be required to roll back to your previous OS version or acquire a new Windows 10 license. If you do not roll back or acquire a new license the build will eventually expire." [link] -
Воланд
"•Do you want to continue as a Windows Insider and keep getting preview builds after 7/29?
•Or do you want to upgrade your Genuine Windows 7 or Windows 8.1 system that has been getting Windows 10 Insider Preview builds to the 7/29 release and stop being an Insider?“I want to continue as a Windows Insider!” If you want to continue as a Windows Insider past 7/29 there is nothing you need to do. You’re already opted in and receiving builds in the Fast or Slow ring depending upon your selection. This is prerelease software and is activated with a prerelease key. Each individual build will expire after a time, but you’ll continue to receive new builds so by the time an older prerelease build expires you’ll have received a new one. Since we’re continuing the Windows Insider Program you’ll be able to continue receiving builds and those builds will continue to be activated under the terms of the Windows Insider Program. We provide ISOs for these builds for recovery from any significant problems, but they are still pre-release software. As part of the program we’ll upgrade Insiders to what is for all intents and purposes the same build as what other customers will get on 7/29, but that will be just another build for Insiders, and those who stay in the program will simply get the next build after as well.
“I want to opt out of the Windows Insider Program on 7/29.” If you decide to opt-out of the program and upgrade to the 7/29 build you will be subject to exactly the same terms and conditions that govern the offer* that was extended to all Genuine Windows 7 and 8.1 customers. This is not a path to attain a license for Windows XP or Windows Vista systems. If your system upgraded from a Genuine Windows 7 or Windows 8.1 license it will remain activated, but if not, you will be required to roll back to your previous OS version or acquire a new Windows 10 license. If you do not roll back or acquire a new license the build will eventually expire.
" [link] -
Воланд
#7095
a blogpostban nincs ilyen.
na mindegy, en reszemrol lezarom a temat. mindig is utaltam az ms licenceleset, legyen szo serverrol, vagy kliensrol, ez most sem fog valtozni.szerk.: ket dolog a biztos: legyen eredeti windows 7 vagy windows 8 a gepen, majd frissitse azt a user julius 29-en, vagy vegye meg, ha nincs eredeti vagy semmilyen windows-a. ennyi.
"Now you may be wondering why Microsoft went ahead and confused the situation by changing the way the announcement was worded in the first place. Well, in short, they did it to cover their backside. Soon after the original announcement, a number of media outlets began posting stories such as "How to get Windows 10 for free". This is not what Microsoft wants, and continues to advertise Windows 10 as being free for Windows 7 and Windows 8.1 users only.
It does appear that upgrading from the preview builds to RTM doesn't get you a valid license however. You will remain activated (and can clean install if you wish once upgrading), but you will not have a valid license. This isn't something normal users need to worry about though." [link]
Воланд
#7090
pont ezt irom, hogy ha oem-et frissitett valaki es tovabbra is oem-et ir, akkor a rendszer mar az elso build-tol kezdodoen letarolta a frissitett rendszer licencet. onnan mar technikailag nem nagy kaland megoldani, hogy az rtm-re valo frissites eseten ez alapjan aktivalva legyen a rendszer. viszont ha nincs letarolva, tehat oem verzio frissitese eseteben retailt ir, akkor buko van, mert mar az elejen elcseszte az ms azzal, hogy nem vette figyelembe az os a frissitett rendszer licencet.
Воланд
#7082
"Szóval az MS nem fogja tudni megkülönböztetni a 10074-ről és a 8.1-ről frissített 10130-at, tehát mindenképpen majd kell egy rendes frissítés 8.1-ről."
mondjuk ezt konnyen ki lehet deriteni, csak meg kell nezni egy oem win7-rol vagy win8-rol valo frissites utan, hogy mit ir az slmgr -dlv parancs, retailt, vagy oem-et. ha elobbi, akkor lehet visszarakni az elozo rendszert, ha utobbi, akkor nem kell.
Воланд
FollowTheORI
#7080
pedig benne van a blogpostban, hogy csak azoknak jar az ingyenes frissites, akiknek eredeti windows 7 vagy windows 8 van a gepen. innen mar nem nehez kitalalni, hogy frissites kell az aktivalt win10-hez, nem pedig tiszta telepites.
Воланд
FollowTheORI
#7076
"Mellesleg ha az RTM buildet kapja meg azon miért lenne exipration date?"
mert az is csak egy ujabb build, amire ramondjak, hogy az az rtm. de te azt meg mindig az insider program kereteben kapod meg.
"De akkoris, ha megkapom az RTM buildet akkor azt aktiválnom kell (pl a régi 7-8 kulcsommal) vagy hogy lesz?"
mas os-hez tartozo kulccsal nem fogod tudni aktivalni.
"Akik így mellébeszélnek azok mindig titkolnak valamit általában (cégek)."
az ms kommunikacioja mindig is ilyen elcseszett volt. en azon lepodtem volna meg, hogy ha egy ilyen program eseteben mindent lekommunikaltak volna normalisan.
Воланд
FollowTheORI
#7072
az evaluation end date bejegyzes megmarad (a jelenlegi az oktober masodika), szoval kap majd egy datumot, amikor lejar az aktivacio. ezt ugy lehet "kikerulni", ha benne marad a user az insider programban, akkor ugyis kapja majd az uj buildeket.
tehat tiszta telepitessel felraktad a preview-et, rtm telepitese utan kilepsz az insider programbol es a rendszer x nap elteltevel szolni fog, hogy lejart az aktivaciod.
Воланд
FollowTheORI
#7067
semmi. az insiderek eseteben is akkor lesz eredeti a rendszer, ha frissitessel tettek fel win7-rol, vagy win8-rol.
Воланд
#7066
"És azt jelen pillanatban honnan a rákból tudja/fogja tudni az MS, hogy én spec. legális 8.1 pro ról mentem a TP változatra,hogy kipróbáljam?"
ahhoz, hogy a szakmai hozzaertesem megkerdojelezd egy kicsit korabban kellene felkelned.
amugy a te esetedben nyilvan sehonnan nem fogja tudni a rendszer, hogy van legalis frissitesi alapod, mivel tiszta telepitest csinaltal. de az atmentem szavak helyett jo lenne az ide illo szakmai kifejezest hasznalni, mert nem vagyunk gondolatolvasok.
Воланд
#7058
HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/CurrentVersion/Setup/OOBE/
es itt szerintem az install type lesz. windows 8 eseteben a MediabootInstall kulcs volt, ami jelolte a tiszta telepitest, vagy a frissitest. upgrade mediarol ha tiszta telepitest csinaltal, akkor csak ugy lehetett aktivalni, ha ennek a kulcsnak az erteket megvaltoztattad. windows 10 eseteben meg pont azert kell egyszer lezongorazni a frissitest, mert nem fog senki kulcsot kapni es utana csak a megfelelo msa hasznalataval tudod majd aktivalni tiszta telepites eseteben.
Воланд
syler123
#6971
anno a privat tesztelok kaptak dobozos win-t, mondjuk az a kor szukebb volt. most meg negy millio tesztelo kap egy oem licencet. es akkor lehet matekolni, hogy van, akinek ugyis van frissitesi jogalapja, van, aki vm-en teszteli, stb. az insider program meg opt-in, szoval ha a user ki akar lepni a programbol, akkor ki kell tudnia vegleg lepni. technikailag meg tudtommal ugyan az az eszkoz gyujti az adatokat a preview rendszerben, mint a "veglegesben", csak a hozza tartozo eula es a gyujtott adatok kore mas.
Воланд
"Bele fog őrülni a microsoft szervere, hogyha gépcserének fogja érzékelni azt, hogy ugyanazzal az accounttal néha az asztali gépről lépek be, néha meg a gyerek laptopjáról (ami szintén az én nevem alatt van regisztrálva). Esetleg lesz később windowsos tabletem is, amin szintén win10 fut már."
ez viccnek jo, de ne nezzuk mar ennyire amatornek az ms-t. most sem orul bele aemmi, ha tobb, kulonbozo eszkozt hasznalok ugyan azzal a fiokkal. eddig a kulcsot hozzakotottek egy hw azonositohoz, most meg ehhez hozzajon meg az ms fiok is. ennyi a tortenet.
Воланд
tomboy0013
#6930
8.1-re ingyenes amugy is.
Воланд
DeathAdder
#6925
a gep az alaplapot jelenti, azt nem cserelheted. ujrarakasrol nincs szo, hogy mennyiszer lehet. de ugye a tengernyi biztonsagi mentest kinalo programok es a gyarilag beepitett megoldasok koraban egyebkent sem telepitjuk ujra az os-t.
Воланд
nah, ugy nez ki, hogy a regisztralt insidereknek tenyleg ingyen lesz a w10, viszont ez gephez kotodik.
Воланд
"As we’ve announced before, the Windows Insider Program will continue even after we release Windows 10 on July 29th. Windows Insiders will continue to receive future flights as we begin to work on the next release immediately after Windows 10 ships. You’ll get to see the latest Windows fixes, features, and updates and give us feedback. So stay with us! Of course, we’ll provide you an option to leave the program and stay on the final build if you choose: but we hope that we’ll continue to provide you great reasons to remain a Windows Insider." [link]
Воланд
ebben az a jo, hogy mostanaban hetente jelenik meg olyan blogpost az ms reszerol, ami valamilyen szinten erinti a telepitest/frissitest es mindegyik blogpost utan megy a kerdezoskodes, hogy akkor megis mi lesz pontosan. amikor bejelentettek, hogy juli 29-en jon, akkor kellett volna megirni, mert ez igy szanalmas, meg akkor is, hogy ha egy honap van hatra a megjelenesig.
Воланд
#6880
ugyan ugy kell frissitesi alapnak lennie, csak vannak annyira jofejek, hogy nem zaklatjak az insidereket azzal, hogy tegyek fel a win7-et, vagy 8-at, majd arrol frissitsenek win10-re. persze van aki mar alapbol frissitessel rakta fel. jah, es pc-hez kotodik, szoval nem tudja atrakni masik gepre, majd ott aktivalni. ahhoz mar az kell, hogy a dobozos win7-et, vagy win8-at atvigye, majd azt frissitheti. persze ezeket az infokat megint twitterrol kell osszeszedni, mert keptelen beleirni a postba....
Воланд
r92king
#6867
igen, tenyleg.
meg kell nezni a jogosultsagokat, meg a tulajdonost az adott fajloknal.szerk.: rakeresve a problema az, hogy ha egy alkalmazas emelt szintu jogosultsaggal fut, a masik pedig alacsonyabb szinten, akkor utobbi nem tud kapcsolatba lepni elobbivel. a desktop pl nem fog emelt szintu jogosultsaggal futni. szoval a run as admint kell elfelejteni az osszes alkalmazasnal. ami meg tovabbra sem mukodik normalisan azt ujratelepiteni.
Воланд
premete
#6726
ez a "julius 29-ig nem lesz kesz" azt jelenti, hogy meg van hatarozva, hogy mik kerulnek bele addig az os-be, milyen funkcioknak kell mukodniuk es majd osszel jonnek uj funkciok. aztan tavasszal ismet. nyilvan nem lesz olyan az os-ben, hogy rakattintasz valamire, aztan kiirja, hogy sorry, de ez meg nem erheto el.
Воланд
King Unique
#6678
mondjuk ez a resz nem veletlenul van athuzva.
• OFF topik
• TILOS a warez!
- Kés topik
- NVIDIA® driverek topikja
- Dreame Pilot - Álomhaj, ó!
- Milyen egeret válasszak?
- Samsung Galaxy S24+ - a személyi asszisztens
- GameSir G7 Pro Zenless Zone Zero Univerzális Bluetooth játékkontroller Xbox / PC / Android
- PCIe 5.0/4.0/3.0 Riser kábelek 90-os hajlított csatlakozóval (220mm/300mm)
- iPhone 12 Mini 128GB 100% (3 Hónap Garancia)
- Beszámítás! MSI Gaming Cyborg A15 FHD Gamer notebook - R5 240 16GB DDR5 512GB SSD RTX 5050 8GB
- PC RAM AKCIÓ 8/16GB DDR4, DDR5 // Számla, Garancia //
