Keresés
  • helike13
    válasz Mankó #40324 üzenetére
    Hát már én sem költök PC-re egy fillért sem. Vettem egy Xbox 360-at, Sajna Falconost, reméljük nem lesz baja, én monitoron nyomom, és teljesen jó. Aztán a PC árából vettem egy MSI netbookot, azon intézem a PC-s intéznivalókat. A konzolon meg játszom
  • helike13
    válasz T.Peter #40252 üzenetére
    E01: possibly a power supply problem
    E02: possibly a Network Interface problem (might be fixed by loosening the x-clamps)
    E03: possibly Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
    E04: Unconfirmed: There is a problem with the Southbridge Chip usually dealing with how it connects to the mainboard (cold solder joint/bridged solder joints)
    E05: CPU over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsinc screws are tightened securely to the board/heatsink holes.
    E06: GPU over heating -ensure your x-clamps are installed properly.
    E07: RAM over heating
    E08: Unconfirmed: General I/O Malfunction, could be caused by an error with any of the I/O devies such as A/V port, USB, Hard drive, DVD drive, etc. over torquing of the AV or heatsync bolts can cause this error.
    E09: Unconfirmed: This can be caused by two completely different things either:
    A. DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard based on how it connects to the DVD drive.
    B. GPU error, generally caused by a poor connection to the mainboard (cold solder joints/bridged solder joints) See error E18 for more information
    E10: Unconfirmed: CPU error, generally caused by a poor connection to the mainboard (cold solder joints/bridged solder joints). This can also be triggered by an error with the TSOP.
    E11: (not yet known)
    E12: Possibly a problem with temperature control
    E13: Unknown: could be caused by a short between the heatsink and surrounding capacitors
    E14: (not yet known)
    E15: (not yet known)
    E16: Unknown: Likely a cold solder join in GPU or Ram chips (see error E18)
    E17: (not yet known)
    E18: Error in the "Digital Backbone" (CPU/GPU/RAM), this is usually caused by a cold solder joint between the GPU and the mainboard.
    There are two theories to fixing this one deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced.
    E19: Unknown: GPU Error this is usually caused by bridged solder points where the GPU connects to the mainboard. see error E18 for more detailed information
    E20: likely a Ram error, this can be caused by a cold or bridged solder joint on one of the Ram chips.
    E32: (not yet known)
    E33: (not yet known)
    E34: (not yet known)
    E35: over heating GPU possibly due to lack of thermal compound.
    E45: Unknown (possibly dashboard update related)
    E64: DVD Drive Error - Dvd drive timed out during reset :Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot. also it could mean that the Kernel can't be launched/signature in NAND Flash chip is broken It could be possible after bad update. http://forums.xbox-scene.com/index.php?sho...p;#entry4156375 This might also be caused by a bad SATA cable.
    E65: DVD Drive Error - Dvd drive is not DMA configured :Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
    E66: DVD Drive Error - Dvd drive pairing failure: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer. if drive can eject, read, and write under windows but errors on console, replacing original firmware should fix issue.
    E67: Hard Drive Error - Hard drive timed out during reset: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
    E68: Hard Drive Error - Hard drive not DMA configured: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. Also this can be caused by a problem with the fans that make them draw too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
    E69: Hard Drive Error - Reading the HD Security sector failed: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
    E70: Hard Drive Error - Hard drive not found
    E71: Dashboard Error - Error within Xam.xex: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
    E72: Dashboard Error - Error within Xam.xex: Like a problem with the NAND flash
    E73: I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices
    E74: I/O Hardware Error - HSIO related, could be crc error, or many things: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. Microsoft covers this error under their 3-year warranty, this is availble to anyone who hasn't modified their console. contact MS to get a free replacement console before attempting to fix this yourself. Failing that this error In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement (see error 0102)
    E75: Ethernet Error - Couldn't read ethernet phy vendor: Strange but sometimes caused by the DVD drive not being connected properly.
    E76: Ethernet Error - Couldn't complete ethernet reset: This error is usually cased by the Ethernet port's controller chip, a dead chip may not cause the error but removing the Ethernet controller chip does, it may also be caused by other Ethernet related problems.
    E77: Ethernet Error - phy request is already processing/reading reg failed/Failed to write reg: This error is sometimes caused by power problems with the RAM chips. It might be cause by a short between the heat sink and resistors or by more serious problems with the RAM. [more info]
    E78: Dashboard Error - AsicId check failed
    E79: Dashboard Error - Couldn't start xam.xex: probably a file system corruption, it could also be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
    E80: Dashboard Error - Wrong LDV version in NAND Flash: This is in new dashboard. You have the update but haven't R3T6 resistor. You can:
    -Downgrade to old dashboard, solder back the resistor and then update your xbox
    -If you have CPU Key, get current NAND Flash image and fix LDV (just add 1 up to latest kernel). (See error 1100)
    * All four lights flashing - 0
    * One light flashing - 1
    * Two Lights flashing - 2
    * Three lights flashing - 3
    0001 See Error E01
    0002 See Error E02
    0003 See Error E03
    0010 See Error E04
    0011 See Error E05
    0012 See Error E06
    0013 See Error E07
    0020 See Error E08
    0021 See Error E09
    0022 See Error E10
    0023 (not yet known)
    0030 See Error E12
    0031 See Error E13
    0032 (not yet known)
    0033 (not yet known)
    0100 See Error E16
    0101 (not yet known)
    0102 See Error E18
    0103 See Error E19
    0110 See Error E20
    0200 (not yet known)
    0201 (not yet known)
    0202 (not yet known)
    0203 See Error E35
    1000 See Error E64
    1001 See Error E65
    1002 See Error E66
    1003 See Error E67
    1010 See Error E68
    1011 See Error E69
    1012 See Error E70
    1013 See Error E71
    1020 See Error E72
    1021 See Error E73
    1022 See Error E74
    1023 See Error E75
    1030 See Error E76
    1031 See Error E77
    1032 See Error E78
    1033 See Error E79
    1100 See Error E80
  • helike13
    Szerváltam egy 2008. áprilisi Elitet. Az még asszem Falconos. Mennyire megbízható? Azt mondják, hogy az Elitek kevésbé lesznek 3 ledesek, mint a többi....... Ez igaz?
