szigmat
#49000
OMFG.
Ilyen létezik? Lehet mégse várom meg a MK-ot az xbox vásárlással.(#49008) Morden24: Ha gondolod a szívesen segítek, és elmagyarázom, mennyivel jobb a PS3. Pl. szebbek rajta a játékok.
A Natalról nem is szólva.... Te tényleg a levegőben akarsz hadonászni nemlétező piros labdákat kergetve?
franyóbácsi
#48243
Drót-drót, csak az ára más.
MOD: nem csak a konzolnál mindegy.
(#48244) kabalthenbk: Ajánlottak már nekem műszaki áruházban halogén-LED világítású kislámpát.
Esetleg:
Set a Family Settings Pass Code
When you create a Family Settings pass code, anyone who wants to change family settings on your console will need to enter the pass code first.You can also use your Family Settings pass code to override game and movie settings if you (or those with whom you share your pass code) want to play games or watch DVD movies that your console settings normally block.
For example, you could give the pass code to your 18-year-old so that she can watch R-rated movies that your younger child is not allowed to see.
To set a pass code for your console:
Go to My Xbox and open System Settings.
Select Family Settings, Console Controls.
Select Set Pass Code.
Select Pass Code, then enter a four-button code using the X and Y buttons, triggers, bumpers, and directional pad on your controller.
Confirm your code by entering it again.
Choose a pass code reset question.
Select Pass Code Reset Answer and enter your answer using either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console.
Select Done from the Set Pass Code screen, then select Done once more from the Console Controls screen. When prompted, select Yes, save changes to put your new settings into effect.
To reset your pass code, repeat this procedure at any time.Reset a Forgotten Pass Code
To reset your pass code after you've forgotten it:
Enter an incorrect pass code.
You'll be told that your pass code is incorrect. SelectReset pass code.
You'll then be shown your pass code question and asked to answer it.
Set a new pass code, following the directions in the previous section.
gyáliSanyi
#48131
Ez sztem erősen függ a használati körülményektől.
Ugyanúgy mint egy bill/egér/bármi. -
Na akkor most mondja meg valaki, milyen TV-t érdemes venni boxhoz, mert kezdek összezavarodni.
Az xbox milyen felbontású TV-t szeret?
Most vagy én vagyok a láma, vagy tényleg eltűnt a korábbi kérdésem?
'reggelt!
Az igaz, hogy az Xbox360-nál lehetséges feltámasztani a vinyót, miután banolták a gépet?
Ha ez igaz, hogy lehet leellenőrizni?
- Elektromos cigaretta 🔞
- Windows 11
- Proxmox VE
- Kezdő Gamer PC-Számítógép! I5 6500 / GTX 1050Ti / 8GB DDR4 / 240GB SSD
- HP 430 G5 Intel CEL 3865U laptop (kijelző hibás)
- GEN5!!! 14/12GB/s 1TB Gen5x4 NVMe SSD, 1 év gar
- Telefon felvásárlás!! iPhone 14/iPhone 14 Plus/iPhone 14 Pro/iPhone 14 Pro Max
- ÚJ/BONTATLAN Microsoft Surface Laptop 7 X Elite 16GB 512GB
