toto2700reg
Ezt csak gyári ROM-ra szabad feltenni, hogy pontosan idézzem: "One of the biggest advantages of GravityBox is that it is not bound to any specific device. Actually, it should run on any device having vanilla Android 4.1/4.2/4.3"
És olyan funkciók vannak benne, amivel CyanogenMod-ban találkoztam, továbbá MTK6589 specifikus hibajavítások (magyar nyelv is van benne):
GravityBox provides 2 main groups of features:
Fixes - help to fight typical MTK6589 bugs like:
--- Date&Time settings crash
--- Caller ID mismatch
--- Split conversation in messaging
--- Wakelock in calendar app periodically turning on the screen
--- Waelock in messaging app turning on the screen every time new message arrives
--- Missing TTS settings in Language&Input
--- Missing extended developer optionsMods - the set of additional useful features that make using the system more easy and fun
--- CyanogenMod Pie controls
--- Expanded Desktop
--- Statusbar QuickSettings tile management with tile reordering
--- Lockscreen targets
--- Statusbar color and transparency
--- Statusbar Brightness Control
--- Statusbar icon colors
--- Additional QuickSettings tiles:
------- Sync on/off, WiFi AP on/off, GravityBox shortcut, Torch, Network mode (2G/3G/2G+3G switch), Sleep, QuickRecord,
QuickApp, GPS on/off, Ringer mode, Volume tile
--- Quick pulldown - switches to QuickSettings when status bar is pulled down near edges
--- Auto-switch to QuickSettings when there are no notifications
--- Center clock in statusbar
--- Battery indicator style
--- Navigation bar tweaks
--- Low battery warning policy
--- Disable LED flashing when battery low
--- Disable LED while charging
--- Auto-hiding of signal icons for empty SIM Slots
--- Advanced power-off menu (reboot, recovery)
--- Volume key cursor control
--- Skip tracks by volume key long-press while screen off (thanks to rovo89)
--- More volume levels for music stream
--- Option to control safe headset media volume
--- Button for clearing all recent tasks at once
--- Fullscreen caller photo
--- CRT screen off animation
--- Minimal brightness setting
--- Autobrihtness levels adjustment
--- Lockscreen tweaks - show widgets maximized, lockscreen background style (color fill, custom image)
--- Lockscreen rotation
--- Phone tweaks - flip action, disable vibrate on call connect
--- Hardware key actions - menu long-press/double-tap, back long-press, home long-press
--- MasterKey vulnerabilities patched (thanks to @Tungstwenty)
--- Dithered Holo background
--- Option to use solid black Holo background
--- Expandable volume panel
--- Option to unlink ringtone and notifications volumes
--- Notification drawer style (background color, image for portait/landscape, transparency)
--- Button backlight modes (default, disabled, always on while screen is on)
--- Button backlight notifications (for devices that lack Notification LED) -
toto2700reg
Ezt a GravityBox-ot érdemes lehet feltenni, elvileg jó a telefonhoz, mert eredetileg MTK6589 processzorhoz készült, de már a fejlesztő kibővítette a támogatott telefonok körét.[link GravityBox]
toto2700reg
focalprice.com lett a kiszemelt. Nem tudom mennyire megbízható. Itt a prohardver-en ajánlották. Mindenesetre én is izgulok ... hogy épségben megjön-e?
toto2700reg
Na, én is rendeltem egy ilyen csoda kütyüt.
- Apple Iphone 16 pro max 256gb desert titanium eladó
- Honor 90 Lite 8/256GB Újszerű,Kártyafüggetlen,Dobozos,Tartozékaival. 1 Év Garanciával!
- 170 - Lenovo Legion Pro 7 (16IRX9H) - Intel Core i9-14900HX, RTX 4090
- iPhone SE 2020 128GB Black -1 ÉV GARANCIA - Kártyafüggetlen, MS4594
- 230 - Lenovo Legion 5 (15IRX10) - Intel Core i7-13650HX, RTX 5060
- BESZÁMÍTÁS! Asus B250M i3 6100T 8GB DDR4 240GB SSD GTX 1050 Ti 4GB Zalman T3 Plus DeepCool 400W
- Beszámítás! LG UltraGear 27GL850 144Hz QHD IPS 1ms monitor garanciával hibátlan működéssel
