Xiaomi AX3600 WiFi 6 AIoT Router
netcore
pszihopata85
#6380
Hello, mit szeretnél kapin így a routerért?
netcore
kép itt volt...
#5498
rendszernaló:
Sun Jan 29 08:26:30 2023 daemon.notice hostapd: phy1-ap0: AP-STA-DISCONNECTED 28:c7:09:5f:1a:4c
Sun Jan 29 08:26:30 2023 daemon.notice hostapd: phy2-ap0: AP-STA-CONNECTED 28:c7:09:5f:1a:4c auth_alg=open
Sun Jan 29 08:26:30 2023 daemon.info hostapd: phy2-ap0: STA 28:c7:09:5f:1a:4c WPA: pairwise key handshake completed (RSN)
Sun Jan 29 08:26:30 2023 daemon.notice hostapd: phy2-ap0: EAPOL-4WAY-HS-COMPLETED 28:c7:09:5f:1a:4c
Sun Jan 29 08:26:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:26:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:27:00 2023 daemon.info hostapd: phy1-ap0: STA 28:c7:09:5f:1a:4c IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sun Jan 29 08:27:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:27:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:27:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:27:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:28:13 2023 authpriv.info dropbear[13944]: Exit before auth from <61.177.173.53:43015>: Timeout before auth
Sun Jan 29 08:28:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:28:17 2023 authpriv.info dropbear[13957]: Child connection from 61.177.173.48:10327
Sun Jan 29 08:28:20 2023 authpriv.info dropbear[13957]: Exit before auth from <61.177.173.48:10327>: Disconnect received
Sun Jan 29 08:28:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:28:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:29:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:29:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:29:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:29:51 2023 authpriv.info dropbear[14092]: Child connection from 61.177.172.124:37175
Sun Jan 29 08:29:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:29:52 2023 authpriv.info dropbear[14092]: Exit before auth from <61.177.172.124:37175>: Disconnect received
Sun Jan 29 08:29:57 2023 daemon.info hostapd: phy1-ap0: STA 28:c7:09:5f:1a:4c IEEE 802.11: associated (aid 1)
Sun Jan 29 08:29:57 2023 daemon.notice hostapd: phy2-ap0: Prune association for 28:c7:09:5f:1a:4c
Sun Jan 29 08:29:57 2023 daemon.notice hostapd: phy2-ap0: AP-STA-DISCONNECTED 28:c7:09:5f:1a:4c
Sun Jan 29 08:29:57 2023 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED 28:c7:09:5f:1a:4c auth_alg=sae
Sun Jan 29 08:29:57 2023 daemon.info hostapd: phy1-ap0: STA 28:c7:09:5f:1a:4c WPA: pairwise key handshake completed (RSN)
Sun Jan 29 08:29:57 2023 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED 28:c7:09:5f:1a:4c
Sun Jan 29 08:30:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:30:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:30:27 2023 daemon.info hostapd: phy2-ap0: STA 28:c7:09:5f:1a:4c IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sun Jan 29 08:30:33 2023 authpriv.info dropbear[14093]: Child connection from 61.177.173.53:53372
Sun Jan 29 08:30:34 2023 authpriv.info dropbear[14093]: Exit before auth from <61.177.173.53:53372>: Disconnect received
Sun Jan 29 08:30:35 2023 authpriv.info dropbear[13946]: Exit before auth from <61.177.173.47:30583>: Timeout before auth
Sun Jan 29 08:30:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:30:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:31:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:31:18 2023 authpriv.info dropbear[14094]: Child connection from 61.177.173.50:23928
Sun Jan 29 08:31:19 2023 authpriv.info dropbear[14094]: Exit before auth from <61.177.173.50:23928>: Disconnect received
Sun Jan 29 08:31:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:31:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:31:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:32:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:32:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:32:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:33:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:33:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:33:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:33:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:34:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:34:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:34:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:34:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:35:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:35:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:35:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:35:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:36:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:36:21 2023 authpriv.info dropbear[14096]: Child connection from 220.134.113.234:53573
Sun Jan 29 08:36:24 2023 authpriv.warn dropbear[14096]: User 'ftp' has invalid shell, rejected
Sun Jan 29 08:36:27 2023 authpriv.info dropbear[14096]: Exit before auth from <220.134.113.234:53573>: (user 'ftp', 3 fails): Max auth tries reached - user 'ftp'
Sun Jan 29 08:36:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:36:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:37:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:37:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:37:19 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.196 78:bd:bc:f2:9d:a0
Sun Jan 29 08:37:19 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.196 78:bd:bc:f2:9d:a0
Sun Jan 29 08:37:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:37:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:37:54 2023 daemon.info hostapd: phy1-ap0: STA 60:35:73:f5:8a:d9 IEEE 802.11: authenticated
Sun Jan 29 08:37:54 2023 daemon.notice hostapd: phy1-ap0: STA-OPMODE-N_SS-CHANGED 60:35:73:f5:8a:d9 1
Sun Jan 29 08:37:54 2023 daemon.info hostapd: phy1-ap0: STA 60:35:73:f5:8a:d9 IEEE 802.11: associated (aid 2)
Sun Jan 29 08:37:54 2023 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED 60:35:73:f5:8a:d9 auth_alg=open
Sun Jan 29 08:37:54 2023 daemon.info hostapd: phy1-ap0: STA 60:35:73:f5:8a:d9 WPA: pairwise key handshake completed (RSN)
Sun Jan 29 08:37:54 2023 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED 60:35:73:f5:8a:d9
Sun Jan 29 08:37:55 2023 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 60:35:73:f5:8a:d9
Sun Jan 29 08:37:55 2023 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.1.154 60:35:73:f5:8a:d9
Sun Jan 29 08:37:55 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.154 60:35:73:f5:8a:d9
Sun Jan 29 08:37:55 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.154 60:35:73:f5:8a:d9
Sun Jan 29 08:38:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:38:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:38:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:38:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:39:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:39:15 2023 authpriv.info dropbear[14186]: Child connection from 61.177.172.104:38932
Sun Jan 29 08:39:17 2023 authpriv.info dropbear[14186]: Exit before auth from <61.177.172.104:38932>: Disconnect received
Sun Jan 29 08:39:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:39:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:39:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:40:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:40:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:40:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:41:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:41:12 2023 authpriv.info dropbear[14188]: Child connection from 61.177.173.51:33640
Sun Jan 29 08:41:14 2023 authpriv.info dropbear[14188]: Exit before auth from <61.177.173.51:33640>: Disconnect received
Sun Jan 29 08:41:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:41:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:41:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:42:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:42:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:42:31 2023 authpriv.info dropbear[14190]: Child connection from 61.177.173.48:39504
Sun Jan 29 08:42:33 2023 authpriv.info dropbear[14190]: Exit before auth from <61.177.173.48:39504>: Disconnect received
Sun Jan 29 08:42:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:42:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:43:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:43:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:43:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:43:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:44:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:44:16 2023 authpriv.info dropbear[14191]: Child connection from 61.177.172.114:16876
Sun Jan 29 08:44:17 2023 authpriv.info dropbear[14191]: Exit before auth from <61.177.172.114:16876>: Disconnect received
Sun Jan 29 08:44:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:44:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:45:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:45:18 2023 authpriv.info dropbear[14192]: Child connection from 61.177.173.46:54352
Sun Jan 29 08:45:19 2023 authpriv.info dropbear[14192]: Exit before auth from <61.177.173.46:54352>: Disconnect received
Sun Jan 29 08:45:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:45:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:45:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:46:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:46:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:46:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:46:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:47:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:47:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:47:29 2023 authpriv.info dropbear[14194]: Child connection from 61.177.173.49:34722
Sun Jan 29 08:47:31 2023 authpriv.info dropbear[14194]: Exit before auth from <61.177.173.49:34722>: Disconnect received
Sun Jan 29 08:47:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:47:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:48:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:48:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:48:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:49:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:49:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:49:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:49:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:50:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:50:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:50:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:50:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:51:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:51:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:51:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:51:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:52:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:52:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:52:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:53:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:53:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:53:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:53:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:54:06 2023 authpriv.info dropbear[14284]: Child connection from 167.94.138.120:39666
Sun Jan 29 08:54:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:54:21 2023 authpriv.info dropbear[14284]: Exit before auth from <167.94.138.120:39666>: Exited normally
Sun Jan 29 08:54:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:54:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:54:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:55:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:55:26 2023 authpriv.info dropbear[14285]: Child connection from 61.177.173.49:31683
Sun Jan 29 08:55:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:55:27 2023 authpriv.info dropbear[14285]: Exit before auth from <61.177.173.49:31683>: Disconnect received
Sun Jan 29 08:55:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:55:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:56:06 2023 authpriv.info dropbear[14286]: Child connection from 61.177.173.47:61106
Sun Jan 29 08:56:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:56:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:56:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:56:55 2023 authpriv.info dropbear[14287]: Child connection from 61.177.173.48:12933
Sun Jan 29 08:56:56 2023 authpriv.info dropbear[14288]: Child connection from 61.177.173.35:37145
Sun Jan 29 08:56:57 2023 authpriv.info dropbear[14287]: Exit before auth from <61.177.173.48:12933>: Disconnect received
Sun Jan 29 08:56:58 2023 authpriv.info dropbear[14288]: Exit before auth from <61.177.173.35:37145>: Disconnect received
Sun Jan 29 08:57:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:57:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:57:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:57:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:58:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:58:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:58:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:58:51 2023 authpriv.info dropbear[14296]: Child connection from 61.177.172.98:46423
Sun Jan 29 08:58:53 2023 authpriv.info dropbear[14296]: Exit before auth from <61.177.172.98:46423>: Disconnect received
Sun Jan 29 08:58:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:58:56 2023 authpriv.info dropbear[14297]: Child connection from 61.177.173.35:59512
Sun Jan 29 08:58:57 2023 authpriv.info dropbear[14297]: Exit before auth from <61.177.173.35:59512>: Disconnect received
Sun Jan 29 08:59:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:59:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:59:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 08:59:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:00:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:00:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:00:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:01:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:01:06 2023 authpriv.info dropbear[14286]: Exit before auth from <61.177.173.47:61106>: Timeout before auth
Sun Jan 29 09:01:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:01:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:01:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:02:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:02:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:02:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:02:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:03:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:03:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:03:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:03:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:04:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:04:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:04:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:05:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:05:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:05:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:05:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:06:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:06:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:06:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:06:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:07:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:07:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:07:35 2023 authpriv.info dropbear[14382]: Child connection from 188.95.76.7:48071
Sun Jan 29 09:07:39 2023 authpriv.warn dropbear[14382]: Login attempt for nonexistent user
Sun Jan 29 09:07:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:07:46 2023 authpriv.info dropbear[14382]: Exit before auth from <188.95.76.7:48071>: Exited normally
Sun Jan 29 09:07:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:08:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:08:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:08:37 2023 authpriv.info dropbear[14389]: Child connection from 61.177.173.52:59830
Sun Jan 29 09:08:38 2023 authpriv.info dropbear[14389]: Exit before auth from <61.177.173.52:59830>: Disconnect received
Sun Jan 29 09:08:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:09:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:09:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:09:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:09:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:10:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:10:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:10:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:10:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:11:03 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.230 d8:1f:12:fb:ff:df
Sun Jan 29 09:11:03 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.230 d8:1f:12:fb:ff:df wlan0
Sun Jan 29 09:11:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:11:14 2023 authpriv.info dropbear[14473]: Child connection from 61.177.172.98:23066
Sun Jan 29 09:11:15 2023 authpriv.info dropbear[14473]: Exit before auth from <61.177.172.98:23066>: Disconnect received
Sun Jan 29 09:11:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:11:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:11:46 2023 authpriv.info dropbear[14474]: Child connection from 61.177.173.49:44929
Sun Jan 29 09:11:48 2023 authpriv.info dropbear[14474]: Exit before auth from <61.177.173.49:44929>: Disconnect received
Sun Jan 29 09:11:48 2023 authpriv.info dropbear[14475]: Child connection from 61.177.173.48:50589
Sun Jan 29 09:11:49 2023 authpriv.info dropbear[14475]: Exit before auth from <61.177.173.48:50589>: Disconnect received
Sun Jan 29 09:11:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:12:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:12:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:12:34 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.205 28:c7:09:5f:1a:4c
Sun Jan 29 09:12:34 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.205 28:c7:09:5f:1a:4c LaszloiPhoneja
Sun Jan 29 09:12:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:13:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:13:15 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.229 de:3e:d9:f9:72:a5
Sun Jan 29 09:13:15 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.229 de:3e:d9:f9:72:a5
Sun Jan 29 09:13:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:13:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:13:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:14:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:14:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:14:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:14:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:15:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:15:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:15:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:15:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:16:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:16:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:16:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:17:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:17:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:17:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:17:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:18:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:18:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:18:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:18:47 2023 authpriv.info dropbear[14483]: Child connection from 61.177.173.47:26516
Sun Jan 29 09:18:48 2023 authpriv.info dropbear[14483]: Exit before auth from <61.177.173.47:26516>: Disconnect received
Sun Jan 29 09:18:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:19:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:19:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:19:40 2023 authpriv.info dropbear[14558]: Child connection from 61.177.172.19:19401
Sun Jan 29 09:19:42 2023 authpriv.info dropbear[14558]: Exit before auth from <61.177.172.19:19401>: Disconnect received
Sun Jan 29 09:19:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:19:47 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.145 dc:4f:22:ab:c0:51
Sun Jan 29 09:19:47 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.145 dc:4f:22:ab:c0:51 tasmota-ABC051-0081
Sun Jan 29 09:19:58 2023 authpriv.info dropbear[14559]: Child connection from 61.177.172.108:46343
Sun Jan 29 09:19:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:20:00 2023 authpriv.info dropbear[14559]: Exit before auth from <61.177.172.108:46343>: Disconnect received
Sun Jan 29 09:20:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:20:17 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.161 48:a2:e6:2f:5d:b9
Sun Jan 29 09:20:17 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.161 48:a2:e6:2f:5d:b9 Tstat-2F5DB9
Sun Jan 29 09:20:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:20:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:21:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:21:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:21:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:21:45 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.213 c4:4f:33:e9:be:2c
Sun Jan 29 09:21:45 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.213 c4:4f:33:e9:be:2c Tasmota-3d-giga
Sun Jan 29 09:21:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:22:03 2023 authpriv.info dropbear[14561]: Child connection from 61.177.173.49:58248
Sun Jan 29 09:22:05 2023 authpriv.info dropbear[14561]: Exit before auth from <61.177.173.49:58248>: Disconnect received
Sun Jan 29 09:22:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:22:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:22:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:22:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:23:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:23:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:23:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:23:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:24:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:24:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:24:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:25:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:25:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:25:24 2023 authpriv.info dropbear[14571]: Child connection from 61.177.173.53:36805
Sun Jan 29 09:25:25 2023 authpriv.info dropbear[14571]: Exit before auth from <61.177.173.53:36805>: Disconnect received
Sun Jan 29 09:25:28 2023 authpriv.info dropbear[14572]: Child connection from 61.177.173.46:31489
Sun Jan 29 09:25:29 2023 authpriv.info dropbear[14572]: Exit before auth from <61.177.173.46:31489>: Disconnect received
Sun Jan 29 09:25:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:25:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:26:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:26:12 2023 authpriv.info dropbear[14573]: Child connection from 61.177.173.39:28631
Sun Jan 29 09:26:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:26:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:26:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:27:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:27:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:27:42 2023 authpriv.info dropbear[14574]: Child connection from 61.177.172.114:62379
Sun Jan 29 09:27:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:27:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:28:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:28:22 2023 authpriv.info dropbear[14575]: Child connection from 89.248.163.219:40312
Sun Jan 29 09:28:22 2023 authpriv.info dropbear[14575]: Exit before auth from <89.248.163.219:40312>: Exited normally
Sun Jan 29 09:28:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:28:39 2023 authpriv.info dropbear[14581]: Child connection from 61.177.172.19:28890
Sun Jan 29 09:28:41 2023 authpriv.info dropbear[14581]: Exit before auth from <61.177.172.19:28890>: Disconnect received
Sun Jan 29 09:28:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:29:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:29:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:29:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:29:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:30:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:30:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:30:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:30:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:31:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:31:12 2023 authpriv.info dropbear[14573]: Exit before auth from <61.177.173.39:28631>: Timeout before auth
Sun Jan 29 09:31:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:31:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:31:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:32:06 2023 authpriv.info dropbear[14657]: Child connection from 61.177.173.47:16742
Sun Jan 29 09:32:08 2023 authpriv.info dropbear[14657]: Exit before auth from <61.177.173.47:16742>: Disconnect received
Sun Jan 29 09:32:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:32:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:32:42 2023 authpriv.info dropbear[14574]: Exit before auth from <61.177.172.114:62379>: Timeout before auth
Sun Jan 29 09:32:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:33:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:33:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:33:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:33:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:34:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:34:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:34:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:34:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:35:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:35:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:35:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:35:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:36:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:36:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:36:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:36:54 2023 authpriv.info dropbear[14668]: Child connection from 61.177.172.19:35527
Sun Jan 29 09:36:56 2023 authpriv.info dropbear[14668]: Exit before auth from <61.177.172.19:35527>: Disconnect received
Sun Jan 29 09:37:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:37:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:37:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:37:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:38:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:38:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:38:32 2023 authpriv.info dropbear[14674]: Child connection from 61.177.173.35:42779
Sun Jan 29 09:38:34 2023 authpriv.info dropbear[14674]: Exit before auth from <61.177.173.35:42779>: Disconnect received
Sun Jan 29 09:38:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:38:54 2023 authpriv.info dropbear[14675]: Child connection from 61.177.173.46:42137
Sun Jan 29 09:38:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:38:56 2023 authpriv.info dropbear[14675]: Exit before auth from <61.177.173.46:42137>: Disconnect received
Sun Jan 29 09:39:08 2023 authpriv.info dropbear[14677]: Child connection from 141.98.11.26:55874
Sun Jan 29 09:39:08 2023 authpriv.info dropbear[14677]: Exit before auth from <141.98.11.26:55874>: Exited normally
Sun Jan 29 09:39:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:39:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:39:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:39:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:40:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:40:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:40:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:41:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:41:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:41:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:41:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:42:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:42:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:42:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:42:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:43:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:43:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:43:28 2023 authpriv.info dropbear[14752]: Child connection from 175.205.189.111:62478
Sun Jan 29 09:43:32 2023 authpriv.warn dropbear[14752]: Login attempt for nonexistent user
Sun Jan 29 09:43:34 2023 authpriv.info dropbear[14752]: Exit before auth from <175.205.189.111:62478>: Max auth tries reached - user 'is invalid'
Sun Jan 29 09:43:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:43:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:44:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:44:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:44:32 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.247 b8:74:24:31:89:23
Sun Jan 29 09:44:32 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.247 b8:74:24:31:89:23 Viessmann-8229
Sun Jan 29 09:44:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:44:57 2023 authpriv.info dropbear[14762]: Child connection from 61.177.173.50:19597
Sun Jan 29 09:44:58 2023 authpriv.info dropbear[14762]: Exit before auth from <61.177.173.50:19597>: Disconnect received
Sun Jan 29 09:45:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:45:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:45:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:45:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:46:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:46:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:46:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:46:47 2023 authpriv.info dropbear[14764]: Child connection from 220.132.194.155:53824
Sun Jan 29 09:46:52 2023 authpriv.info dropbear[14764]: Exit before auth from <220.132.194.155:53824>: Error reading: Connection reset by peer
Sun Jan 29 09:46:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:47:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:47:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:47:31 2023 authpriv.info dropbear[14765]: Child connection from 61.177.173.37:43750
Sun Jan 29 09:47:33 2023 authpriv.info dropbear[14765]: Exit before auth from <61.177.173.37:43750>: Disconnect received
Sun Jan 29 09:47:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:47:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:48:02 2023 authpriv.info dropbear[14766]: Child connection from 61.177.173.35:24041
Sun Jan 29 09:48:05 2023 authpriv.info dropbear[14766]: Exit before auth from <61.177.173.35:24041>: Disconnect received
Sun Jan 29 09:48:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:48:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:48:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:49:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:49:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:49:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:49:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:50:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:50:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:50:37 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.112 32:c0:ed:2e:37:c2
Sun Jan 29 09:50:37 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.112 32:c0:ed:2e:37:c2 Zsanett-S20-FE-eszkoze
Sun Jan 29 09:50:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:50:43 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.182 56:b5:b5:ff:66:d5
Sun Jan 29 09:50:43 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.182 56:b5:b5:ff:66:d5 Galaxy-A03
Sun Jan 29 09:50:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:51:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:51:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:51:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:51:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:52:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:52:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:52:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:53:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:53:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:53:25 2023 authpriv.info dropbear[14903]: Child connection from 61.177.172.124:13746
Sun Jan 29 09:53:27 2023 authpriv.info dropbear[14903]: Exit before auth from <61.177.172.124:13746>: Disconnect received
Sun Jan 29 09:53:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:53:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:54:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:54:10 2023 authpriv.info dropbear[14904]: Child connection from 61.177.173.51:33958
Sun Jan 29 09:54:11 2023 authpriv.info dropbear[14904]: Exit before auth from <61.177.173.51:33958>: Disconnect received
Sun Jan 29 09:54:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:54:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:54:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:55:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:55:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:55:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:55:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:56:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:56:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:56:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:57:01 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.146 3c:61:05:84:da:ee
Sun Jan 29 09:57:01 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.146 3c:61:05:84:da:ee ESP_84DAEE
Sun Jan 29 09:57:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:57:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:57:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:57:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:58:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:58:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:58:37 2023 authpriv.info dropbear[14920]: Child connection from 69.112.204.55:46960
Sun Jan 29 09:58:37 2023 authpriv.info dropbear[14920]: Exit before auth from <69.112.204.55:46960>: Unexpected packet type 0, expected 20
Sun Jan 29 09:58:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:58:46 2023 authpriv.info dropbear[14921]: Child connection from 61.177.173.35:61915
Sun Jan 29 09:58:47 2023 authpriv.info dropbear[14921]: Exit before auth from <61.177.173.35:61915>: Disconnect received
Sun Jan 29 09:58:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:59:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:59:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:59:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 09:59:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:00:14 2023 authpriv.info dropbear[14997]: Child connection from 61.177.173.37:30629
Sun Jan 29 10:00:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:00:17 2023 authpriv.info dropbear[14997]: Exit before auth from <61.177.173.37:30629>: Disconnect received
Sun Jan 29 10:00:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:00:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:01:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:01:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:01:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:01:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:02:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:02:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:02:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:02:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:03:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:03:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:03:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:03:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:04:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:04:27 2023 authpriv.info dropbear[14998]: Child connection from 61.177.173.51:50728
Sun Jan 29 10:04:29 2023 authpriv.info dropbear[14998]: Exit before auth from <61.177.173.51:50728>: Disconnect received
Sun Jan 29 10:04:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:04:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:05:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:05:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:05:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:05:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:05:59 2023 daemon.err uhttpd[2343]: [info] luci: accepted login on / for root from 192.168.1.205
Sun Jan 29 10:06:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:06:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:06:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:06:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:07:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:07:21 2023 daemon.info hostapd: phy1-ap0: STA d8:fc:93:9f:59:de IEEE 802.11: authenticated
Sun Jan 29 10:07:21 2023 daemon.info hostapd: phy1-ap0: STA d8:fc:93:9f:59:de IEEE 802.11: associated (aid 4)
Sun Jan 29 10:07:22 2023 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED d8:fc:93:9f:59:de auth_alg=open
Sun Jan 29 10:07:22 2023 daemon.info hostapd: phy1-ap0: STA d8:fc:93:9f:59:de WPA: pairwise key handshake completed (RSN)
Sun Jan 29 10:07:22 2023 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED d8:fc:93:9f:59:de
Sun Jan 29 10:07:27 2023 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 192.168.1.238 d8:fc:93:9f:59:de
Sun Jan 29 10:07:27 2023 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.1.238 d8:fc:93:9f:59:de
Sun Jan 29 10:07:27 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.238 d8:fc:93:9f:59:de
Sun Jan 29 10:07:27 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.238 d8:fc:93:9f:59:de Dell_E7440
Sun Jan 29 10:07:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:07:37 2023 daemon.notice hostapd: phy1-ap0: AP-STA-DISCONNECTED d8:fc:93:9f:59:de
Sun Jan 29 10:07:42 2023 daemon.info hostapd: phy1-ap0: STA d8:fc:93:9f:59:de IEEE 802.11: authenticated
Sun Jan 29 10:07:42 2023 daemon.info hostapd: phy1-ap0: STA d8:fc:93:9f:59:de IEEE 802.11: associated (aid 4)
Sun Jan 29 10:07:42 2023 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED d8:fc:93:9f:59:de auth_alg=open
Sun Jan 29 10:07:42 2023 daemon.info hostapd: phy1-ap0: STA d8:fc:93:9f:59:de WPA: pairwise key handshake completed (RSN)
Sun Jan 29 10:07:42 2023 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED d8:fc:93:9f:59:de
Sun Jan 29 10:07:42 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.238 d8:fc:93:9f:59:de
Sun Jan 29 10:07:42 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.238 d8:fc:93:9f:59:de Dell_E7440
Sun Jan 29 10:07:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:07:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:08:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:08:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:08:46 2023 daemon.notice hostapd: phy1-ap0: AP-STA-DISCONNECTED d8:fc:93:9f:59:de
Sun Jan 29 10:08:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:09:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:09:05 2023 daemon.info hostapd: phy1-ap0: STA d8:fc:93:9f:59:de IEEE 802.11: authenticated
Sun Jan 29 10:09:05 2023 daemon.info hostapd: phy1-ap0: STA d8:fc:93:9f:59:de IEEE 802.11: associated (aid 4)
Sun Jan 29 10:09:05 2023 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED d8:fc:93:9f:59:de auth_alg=open
Sun Jan 29 10:09:05 2023 daemon.info hostapd: phy1-ap0: STA d8:fc:93:9f:59:de WPA: pairwise key handshake completed (RSN)
Sun Jan 29 10:09:05 2023 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED d8:fc:93:9f:59:de
Sun Jan 29 10:09:05 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.238 d8:fc:93:9f:59:de
Sun Jan 29 10:09:05 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.238 d8:fc:93:9f:59:de Dell_E7440
Sun Jan 29 10:09:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:09:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:09:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:10:04 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.196 78:bd:bc:f2:9d:a0
Sun Jan 29 10:10:04 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.196 78:bd:bc:f2:9d:a0
Sun Jan 29 10:10:05 2023 daemon.info hostapd: phy1-ap0: STA 60:35:73:f5:8a:d9 IEEE 802.11: disconnected due to excessive missing ACKs
Sun Jan 29 10:10:05 2023 daemon.notice hostapd: phy1-ap0: AP-STA-DISCONNECTED 60:35:73:f5:8a:d9
Sun Jan 29 10:10:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:10:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:10:35 2023 daemon.info hostapd: phy1-ap0: STA 60:35:73:f5:8a:d9 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sun Jan 29 10:10:38 2023 daemon.info hostapd: phy1-ap0: STA 60:35:73:f5:8a:d9 IEEE 802.11: authenticated
Sun Jan 29 10:10:38 2023 daemon.notice hostapd: phy1-ap0: STA-OPMODE-N_SS-CHANGED 60:35:73:f5:8a:d9 1
Sun Jan 29 10:10:38 2023 daemon.info hostapd: phy1-ap0: STA 60:35:73:f5:8a:d9 IEEE 802.11: associated (aid 2)
Sun Jan 29 10:10:38 2023 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED 60:35:73:f5:8a:d9 auth_alg=open
Sun Jan 29 10:10:38 2023 daemon.info hostapd: phy1-ap0: STA 60:35:73:f5:8a:d9 WPA: pairwise key handshake completed (RSN)
Sun Jan 29 10:10:38 2023 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED 60:35:73:f5:8a:d9
Sun Jan 29 10:10:39 2023 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-lan) 60:35:73:f5:8a:d9
Sun Jan 29 10:10:39 2023 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-lan) 192.168.1.154 60:35:73:f5:8a:d9
Sun Jan 29 10:10:39 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.154 60:35:73:f5:8a:d9
Sun Jan 29 10:10:39 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.154 60:35:73:f5:8a:d9
Sun Jan 29 10:10:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:10:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:11:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:11:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:11:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:11:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:12:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:12:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:12:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:13:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:13:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:13:35 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:13:51 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:13:56 2023 authpriv.info dropbear[15146]: Child connection from 61.177.173.48:46588
Sun Jan 29 10:13:57 2023 authpriv.info dropbear[15147]: Child connection from 61.177.172.90:62446
Sun Jan 29 10:14:01 2023 authpriv.info dropbear[15147]: Exit before auth from <61.177.172.90:62446>: Disconnect received
Sun Jan 29 10:14:02 2023 authpriv.info dropbear[15146]: Exit before auth from <61.177.173.48:46588>: Disconnect received
Sun Jan 29 10:14:07 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:14:23 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:14:39 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:14:55 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:15:11 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:15:27 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:15:43 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:15:59 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:16:15 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:16:21 2023 authpriv.info dropbear[15174]: Child connection from 61.177.173.51:59234
Sun Jan 29 10:16:23 2023 authpriv.info dropbear[15174]: Exit before auth from <61.177.173.51:59234>: Disconnect received
Sun Jan 29 10:16:24 2023 daemon.err uhttpd[2343]: [info] luci: accepted login on / for root from 192.168.1.238
Sun Jan 29 10:16:31 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:16:47 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:17:03 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)
Sun Jan 29 10:17:19 2023 daemon.err odhcpd[2210]: Failed to send to ff02::1%lan@br-lan (Network unreachable)Kernel log:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.15.90 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 12.2.0 r21917-cfb296b79a) 12.2.0, GNU ld (GNU Binutils) 2.39) #0 SMP Wed Jan 25 23:32:36 2023
[ 0.000000] Machine model: Xiaomi AX3600
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000040ffffff]
[ 0.000000] node 0: [mem 0x0000000041000000-0x000000004a3fffff]
[ 0.000000] node 0: [mem 0x000000004a400000-0x000000004a4fffff]
[ 0.000000] node 0: [mem 0x000000004a500000-0x000000004a5fffff]
[ 0.000000] node 0: [mem 0x000000004a600000-0x000000004e8fffff]
[ 0.000000] node 0: [mem 0x000000004e900000-0x000000005fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] psci: OSI mode supported.
[ 0.000000] percpu: Embedded 17 pages/cpu s30808 r8192 d30632 u69632
[ 0.000000] pcpu-alloc: s30808 r8192 d30632 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129024
[ 0.000000] Kernel command line: ubi.mtd=rootfs root=mtd:ubi_rootfs rootfstype=squashfs rootwait uart_en=1 root=/dev/ubiblock0_0
[ 0.000000] Unknown kernel command line parameters "uart_en=1", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack
ff, heap alloc
ff, heap free
ff
[ 0.000000] Memory: 415412K/524288K available (7744K kernel code, 866K rwdata, 2132K rodata, 1280K init, 286K bss, 108876K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv2m: range[mem 0x0b00a000-0x0b00affc], SPI[448:479]
[ 0.000000] arch_timer: cp15 and mmio timer(s) running at 19.20MHz (virt/virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000000] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000122] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000139] pid_max: default: 32768 minimum: 301
[ 0.000292] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.000309] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.001955] rcu: Hierarchical SRCU implementation.
[ 0.002122] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.002672] smp: Bringing up secondary CPUs ...
[ 0.003289] Detected VIPT I-cache on CPU1
[ 0.003355] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.003983] Detected VIPT I-cache on CPU2
[ 0.004024] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.004607] Detected VIPT I-cache on CPU3
[ 0.004644] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.004710] smp: Brought up 1 node, 4 CPUs
[ 0.004737] SMP: Total of 4 processors activated.
[ 0.004745] CPU features: detected: 32-bit EL0 Support
[ 0.004752] CPU features: detected: CRC32 instructions
[ 0.004802] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.004812] CPU: All CPU(s) started at EL1
[ 0.004834] alternatives: patching kernel code
[ 0.012545] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.012581] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.012743] pinctrl core: initialized pinctrl subsystem
[ 0.014033] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.014508] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 0.014551] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.014589] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.014922] thermal_sys: Registered thermal governor 'step_wise'
[ 0.016296] cpuidle: using governor menu
[ 0.016517] ASID allocator initialised with 65536 entries
[ 0.069464] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 0.078155] SCSI subsystem initialized
[ 0.078337] usbcore: registered new interface driver usbfs
[ 0.078380] usbcore: registered new interface driver hub
[ 0.078417] usbcore: registered new device driver usb
[ 0.078652] CPUidle PSCI: failed to enable OSI mode: -95
[ 0.078976] qcom_scm: convention: smc arm 64
[ 0.080384] clocksource: Switched to clocksource arch_sys_counter
[ 0.081092] NET: Registered PF_INET protocol family
[ 0.081224] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.081893] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.081919] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.081934] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.081984] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.082065] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.082146] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.082174] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.082328] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.082362] PCI: CLS 0 bytes, default 64
[ 0.083480] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[ 0.087235] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.087252] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.088053] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.090140] qcom-qmp-phy 84000.phy: Registered Qcom-QMP phy
[ 0.092371] qcom-pcie 20000000.pci: host bridge /soc/pci@20000000 ranges:
[ 0.092434] qcom-pcie 20000000.pci: IO 0x0020200000..0x002020ffff -> 0x0020200000
[ 0.092465] qcom-pcie 20000000.pci: MEM 0x0020220000..0x002fffffff -> 0x0020220000
[ 0.221937] qcom-pcie 20000000.pci: iATU unroll: enabled
[ 0.221954] qcom-pcie 20000000.pci: Detected iATU regions: 8 outbound, 8 inbound
[ 0.322019] qcom-pcie 20000000.pci: Link up
[ 0.322164] qcom-pcie 20000000.pci: PCI host bridge to bus 0000:00
[ 0.322179] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.322198] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x20200000-0x2020ffff])
[ 0.322210] pci_bus 0000:00: root bus resource [mem 0x20220000-0x2fffffff]
[ 0.322255] pci 0000:00:00.0: [17cb:1002] type 01 class 0x060400
[ 0.322284] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x00000fff]
[ 0.322368] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 0.325581] pci 0000:01:00.0: [168c:0050] type 00 class 0x028000
[ 0.325727] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
[ 0.325945] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 0.326406] pci 0000:01:00.0: supports D1
[ 0.326417] pci 0000:01:00.0: PME# supported from D0 D1 D3hot
[ 0.329441] pci 0000:00:00.0: BAR 8: assigned [mem 0x20300000-0x205fffff]
[ 0.329464] pci 0000:00:00.0: BAR 9: assigned [mem 0x20600000-0x207fffff 64bit pref]
[ 0.329479] pci 0000:00:00.0: BAR 0: assigned [mem 0x20220000-0x20220fff]
[ 0.329493] pci 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 0.329509] pci 0000:01:00.0: BAR 0: assigned [mem 0x20400000-0x205fffff 64bit]
[ 0.329581] pci 0000:01:00.0: BAR 6: assigned [mem 0x20300000-0x2030ffff pref]
[ 0.329595] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 0.329606] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 0.329619] pci 0000:00:00.0: bridge window [mem 0x20300000-0x205fffff]
[ 0.329631] pci 0000:00:00.0: bridge window [mem 0x20600000-0x207fffff 64bit pref]
[ 0.331575] pcieport 0000:00:00.0: PME: Signaling with IRQ 82
[ 0.331899] pcieport 0000:00:00.0: AER: enabled with IRQ 82
[ 0.335230] bam-dma-engine 704000.dma-controller: num-channels unspecified in dt
[ 0.335254] bam-dma-engine 704000.dma-controller: num-ees unspecified in dt
[ 0.339061] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.340918] msm_serial 78b3000.serial: msm_serial: detected port #0
[ 0.340967] msm_serial 78b3000.serial: uartclk = 3686400
[ 0.341017] 78b3000.serial: ttyMSM0 at MMIO 0x78b3000 (irq = 22, base_baud = 230400) is a MSM
[ 0.341050] msm_serial: console setup on port #0
[ 1.163350] printk: console [ttyMSM0] enabled
[ 1.168484] msm_serial: driver initialized
[ 1.176575] loop: module loaded
[ 1.176654] Loading iSCSI transport class v2.0-870.
[ 1.181212] nand: device found, Manufacturer ID: 0xc8, Chip ID: 0xaa
[ 1.184170] nand: ESMT GD9FS2G8F2A
[ 1.190778] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 128
[ 1.194262] 13 fixed-partitions partitions found on MTD device qcom_nand.0
[ 1.201586] OF: Bad cell count for /soc/nand-controller@79b0000/nand@0/partitions
[ 1.208497] OF: Bad cell count for /soc/nand-controller@79b0000/nand@0/partitions
[ 1.216659] Creating 13 MTD partitions on "qcom_nand.0":
[ 1.223505] 0x000000000000-0x000000100000 : "0:sbl1"
[ 1.230135] 0x000000100000-0x000000200000 : "0:mibib"
[ 1.235157] 0x000000200000-0x000000500000 : "0:qsee"
[ 1.241587] 0x000000500000-0x000000580000 : "0:devcfg"
[ 1.244590] 0x000000580000-0x000000600000 : "0:rpm"
[ 1.249523] 0x000000600000-0x000000680000 : "0:cdt"
[ 1.254344] 0x000000680000-0x000000700000 : "0:appsblenv"
[ 1.259167] 0x000000700000-0x000000800000 : "0:appsbl"
[ 1.265155] 0x000000800000-0x000000880000 : "0:art"
[ 1.269801] 0x000000880000-0x000000900000 : "bdata"
[ 1.274570] 0x000000900000-0x000000a00000 : "pstore"
[ 1.279772] 0x000000a00000-0x000002dc0000 : "ubi_kernel"
[ 1.311630] 0x000002dc0000-0x000010000000 : "rootfs"
[ 1.473198] mtd: setting mtd12 (rootfs) as root device
[ 1.473491] mtdsplit: no squashfs found in "rootfs"
[ 1.481685] spmi spmi-0: PMIC arbiter version v2 (0x20010000)
[ 1.484995] s1: supplied by regulator-dummy
[ 1.488083] s2: supplied by regulator-dummy
[ 1.492075] vdd_s3: supplied by regulator-dummy
[ 1.496383] vdd_s4: supplied by regulator-dummy
[ 1.500906] s5: supplied by regulator-dummy
[ 1.505269] l1: supplied by regulator-dummy
[ 1.509414] l2: supplied by regulator-dummy
[ 1.513609] l3: supplied by regulator-dummy
[ 1.517763] l4: supplied by regulator-dummy
[ 1.521934] l5: supplied by regulator-dummy
[ 1.526084] l6: supplied by regulator-dummy
[ 1.530270] l7: supplied by regulator-dummy
[ 1.534435] l8: supplied by regulator-dummy
[ 1.538585] l9: supplied by regulator-dummy
[ 1.542898] l11: supplied by regulator-dummy
[ 1.546925] l12: supplied by regulator-dummy
[ 1.551448] l13: supplied by regulator-dummy
[ 1.569359] i2c_dev: i2c /dev entries driver
[ 1.573495] sdhci: Secure Digital Host Controller Interface driver
[ 1.573546] sdhci: Copyright(c) Pierre Ossman
[ 1.578690] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.586577] remoteproc remoteproc0: releasing cd00000.q6v5_wcss
[ 1.590982] NET: Registered PF_INET6 protocol family
[ 1.595413] Segment Routing with IPv6
[ 1.599732] In-situ OAM (IOAM) with IPv6
[ 1.603369] NET: Registered PF_PACKET protocol family
[ 1.607299] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.612230] 8021q: 802.1Q VLAN Support v1.8
[ 1.641408] qcom,cpr4-apss-regulator b018000.cpr4-ctrl: CPR valid fuse count: 4
[ 1.641708] cpr4_ipq807x_apss_read_fuse_data: apc_corner: speed bin = 0
[ 1.647532] cpr4_ipq807x_apss_read_fuse_data: apc_corner: CPR fusing revision = 1
[ 1.654149] cpr4_ipq807x_apss_read_fuse_data: apc_corner: CPR misc fuse value = 0
[ 1.661802] cpr4_ipq807x_apss_read_fuse_data: apc_corner: Voltage boost fuse config = 0 boost = disable
[ 1.669301] cpr3_mem_acc_init: apc: not using memory accelerator regulator
[ 1.678446] cpr4_ipq807x_apss_calculate_open_loop_voltages: apc_corner: fused SVS: open-loop= 704000 uV
[ 1.685393] cpr4_ipq807x_apss_calculate_open_loop_voltages: apc_corner: fused NOM: open-loop= 808000 uV
[ 1.695375] cpr4_ipq807x_apss_calculate_open_loop_voltages: apc_corner: fused TURBO: open-loop= 864000 uV
[ 1.705185] cpr4_ipq807x_apss_calculate_open_loop_voltages: apc_corner: fused STURBO: open-loop= 936000 uV
[ 1.715044] cpr4_ipq807x_apss_calculate_target_quotients: apc_corner: fused SVS: quot[ 7]= 764, quot_offset[ 7]= 0
[ 1.724805] cpr4_ipq807x_apss_calculate_target_quotients: apc_corner: fused NOM: quot[ 7]= 970, quot_offset[ 7]= 205
[ 1.735656] cpr4_ipq807x_apss_calculate_target_quotients: apc_corner: fused TURBO: quot[ 7]=1068, quot_offset[ 7]= 95
[ 1.746592] cpr4_ipq807x_apss_calculate_target_quotients: apc_corner: fused STURBO: quot[ 7]=1208, quot_offset[ 7]= 140
[ 1.757672] cpr3_regulator_init_ctrl: apc: Default CPR mode = closed-loop
[ 1.759828] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 19200 KHz, changing to: 1017600 KHz
[ 1.776348] remoteproc remoteproc0: cd00000.q6v5_wcss is available
[ 1.786497] ubi0: attaching mtd12
[ 2.420395] random: crng init done
[ 2.724935] ubi0: scanning is finished
[ 2.731750] ubi0: attached mtd12 (name "rootfs", size 210 MiB)
[ 2.731785] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.736477] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.743354] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.750193] ubi0: good PEBs: 1682, bad PEBs: 0, corrupted PEBs: 0
[ 2.756969] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
[ 2.763221] ubi0: max/mean erase counter: 7/5, WL threshold: 4096, image sequence number: 1435886178
[ 2.770336] ubi0: available PEBs: 0, total reserved PEBs: 1682, PEBs reserved for bad PEB handling: 40
[ 2.779639] ubi0: background thread "ubi_bgt0d" started, PID 474
[ 2.780391] block ubiblock0_0: created from ubi0:0(rootfs)
[ 2.798379] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
[ 2.799021] Freeing unused kernel memory: 1280K
[ 2.860463] Run /sbin/init as init process
[ 2.860485] with arguments:
[ 2.860488] /sbin/init
[ 2.860490] with environment:
[ 2.860492] HOME=/
[ 2.860494] TERM=linux
[ 2.860497] uart_en=1
[ 3.029890] init: Console is alive
[ 3.030027] init: - watchdog -
[ 3.511161] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 3.661723] ssdk_switch_device_num_init[1335]:INFO:ess-switch dts node number: 1
[ 3.661846] ssdk_dt_get_switch_node[1124]:INFO:ess-switch DT exist!
[ 3.668201] ssdk_dt_parse_access_mode[999]:INFO:switch_access_mode: local bus
[ 3.674200] ssdk_dt_parse_access_mode[1012]:INFO:switchreg_base_addr: 0x3a000000
[ 3.681485] ssdk_dt_parse_access_mode[1013]:INFO:switchreg_size: 0x1000000
[ 3.688942] ssdk_dt_parse_mac_mode[327]:INFO:mac mode = 0x0
[ 3.695630] ssdk_dt_parse_mac_mode[336]:INFO:mac mode1 = 0xff
[ 3.701100] ssdk_dt_parse_mac_mode[345]:INFO:mac mode2 = 0xff
[ 3.707056] ssdk_dt_parse_uniphy[364]:INFO:ess-uniphy DT exist!
[ 3.713225] ssdk_dt_parse_intf_mac[942]:INFO:dp2 MAC 28:d1:27:fc:22:f3
[ 3.718512] ssdk_dt_parse_intf_mac[942]:INFO:dp3 MAC 9c:9d:7e:74:f2:51
[ 3.725122] ssdk_dt_parse_intf_mac[942]:INFO:dp4 MAC 9c:9d:7e:74:f2:51
[ 3.731627] ssdk_dt_parse_intf_mac[942]:INFO:dp5 MAC 9c:9d:7e:74:f2:51
[ 3.738137] ssdk_plat_init[1692]:INFO:ssdk_plat_init start
[ 3.862261] ssdk_gcc_clock_init[1275]:INFO:SSDK gcc clock init successfully!
[ 3.863480] malibu_phy_api_ops_init[2846]:INFO:qca probe malibu phy driver succeeded!
[ 3.868534] hsl_phy_phydev_get[773]:ERROR:phy_addr 0 phydev is NULL
[ 3.882164] regi_init[3953]:INFO:Initializing HPPE!!
[ 4.120408] ssdk_ppe_reset_init[1535]:INFO:ppe reset successfully!
[ 4.124004] qca_hppe_portctrl_hw_init[126]:INFO:Hawkeye PPE port initializing
[ 4.125532] hsl_phy_phydev_get[773]:ERROR:phy_addr 0 phydev is NULL
[ 4.132826] hsl_phy_phydev_get[773]:ERROR:phy_addr 0 phydev is NULL
[ 4.366506] adpt_hppe_port_mux_mac_type_set[2787]
ARN:port 6 need not to configure mux and mac type
[ 4.366570] ssdk_switch_register[2017]:INFO
hip version 0x1500
[ 4.374710] qca_link_polling_select[1487]:INFO:link-polling-required node does not exist
[ 4.380341] ssdk_switch_register[2043]:INFO:polling is selected
[ 4.388684] regi_init[3957]:INFO:Initializing HPPE Done!!
[ 4.394405] ssdk_genl_init[211]:INFO:ssdk genl family register success.
[ 4.399875] regi_init[4020]:INFO:qca-ssdk module init succeeded!
[ 4.408781] EDMA ver 1 hw init
[ 4.412777] EDMA HW Reset completed succesfully
[ 4.415435] Num rings - TxDesc:1 (23-23) TxCmpl:1 (7-7)
[ 4.419831] RxDesc:1 (15-15) RxFill:1 (7-7)
[ 4.425650] Generic PHY 90000.mdio-1:01: attached PHY driver (mii_bus:phy_addr=90000.mdio-1:01, irq=POLL)
[ 4.429861] nss-dp 3a001200.dp2 wan: Registered netdev wan(qcom-id:2)
[ 4.439333] Generic PHY 90000.mdio-1:02: attached PHY driver (mii_bus:phy_addr=90000.mdio-1:02, irq=POLL)
[ 4.445988] nss-dp 3a001400.dp3 lan1: Registered netdev lan1(qcom-id:3)
[ 4.455297] Generic PHY 90000.mdio-1:03: attached PHY driver (mii_bus:phy_addr=90000.mdio-1:03, irq=POLL)
[ 4.461982] nss-dp 3a001600.dp4 lan2: Registered netdev lan2(qcom-id:4)
[ 4.471460] Generic PHY 90000.mdio-1:04: attached PHY driver (mii_bus:phy_addr=90000.mdio-1:04, irq=POLL)
[ 4.478132] nss-dp 3a001800.dp5 lan3: Registered netdev lan3(qcom-id:5)
[ 4.487431] **********************************************************
[ 4.493628] * NSS Data Plane driver
[ 4.500208] **********************************************************
[ 4.511730] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 4.513087] init: - preinit -
[ 6.975614] UBIFS (ubi0:1): Mounting in unauthenticated mode
[ 6.975756] UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 649
[ 7.009834] UBIFS (ubi0:1): recovery needed
[ 7.102360] UBIFS (ubi0:1): recovery completed
[ 7.102453] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "rootfs_data"
[ 7.105703] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 7.113623] UBIFS (ubi0:1): FS size: 199860224 bytes (190 MiB, 1574 LEBs), max 1586 LEBs, journal size 10031104 bytes (9 MiB, 79 LEBs)
[ 7.123514] UBIFS (ubi0:1): reserved for root: 4952683 bytes (4836 KiB)
[ 7.135480] UBIFS (ubi0:1): media format: w5/r0 (latest is w5/r0), UUID 3E0C2822-ACC8-4E30-B361-560605FEA5C1, small LPT model
[ 7.148874] mount_root: switching to ubifs overlay
[ 7.158737] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 7.163001] urandom-seed: Seeding with /etc/urandom.seed
[ 7.217359] procd: - early -
[ 7.217464] procd: - watchdog -
[ 7.764431] procd: - watchdog -
[ 7.766012] procd: - ubus -
[ 7.820301] procd: - init -
[ 8.231461] urngd: v1.0.2 started.
[ 8.273014] kmodloader: loading kernel modules from /etc/modules.d/*
[ 8.332291] tun: Universal TUN/TAP device driver, 1.6
[ 8.335273] Loading modules backported from Linux version v6.1-rc8-0-g76dcd734eca2
[ 8.336335] Backport generated by backports.git v5.15.81-1-41-g02e352527db5
[ 8.349478] NET: Registered PF_QIPCRTR protocol family
[ 8.357437] xt_time: kernel timezone is -0000
[ 8.399703] PPP generic driver version 2.4.2
[ 8.400863] NET: Registered PF_PPPOX protocol family
[ 8.411547] ath10k 5.15 driver, optimized for CT firmware, probing pci device: 0x50.
[ 8.412032] ath10k_pci 0000:01:00.0: enabling device (0000 -> 0002)
[ 8.418754] ath10k_pci 0000:01:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 9.164972] ath10k_pci 0000:01:00.0: qca9887 hw1.0 target 0x4100016d chip_id 0x004000ff sub 0000:0000
[ 9.165028] ath10k_pci 0000:01:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[ 9.173339] ath10k_pci 0000:01:00.0: firmware ver 10.1-ct-87-__fW-022-ecad3248 api 2 features wmi-10.x,has-wmi-mgmt-tx,mfp,txstatus-noack,wmi-10.x-CT,ratemask-CT,txrate-CT,get-temp-CT,tx-rc-CT,cust-stats-CT,retry-gt2-CT,txrate2-CT,beacon-cb-CT,wmi-block-ack-CT crc32 61a92df5
[ 9.208642] ath10k_pci 0000:01:00.0: Loading BDF type 0
[ 9.225482] ath10k_pci 0000:01:00.0: board_file api 2 bmi_id N/A crc32 b4ce36fa
[ 10.092041] ath10k_pci 0000:01:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
[ 10.098587] ath10k_pci 0000:01:00.0: wmi print 'P 128 V 8 T 410'
[ 10.098636] ath10k_pci 0000:01:00.0: wmi print 'msdu-desc: 1424 sw-crypt: 0 ct-sta: 0'
[ 10.104812] ath10k_pci 0000:01:00.0: wmi print 'alloc rem: 25560 iram: 24780'
[ 10.148817] ath10k_pci 0000:01:00.0: htt-ver 2.1 wmi-op 2 htt-op 2 cal nvmem max-sta 128 raw 0 hwcrypto 1
[ 10.149171] ath10k_pci 0000:01:00.0: NOTE: Firmware DBGLOG output disabled in debug_mask: 0x10000000
[ 10.261453] ath: EEPROM regdomain: 0x0
[ 10.261461] ath: EEPROM indicates default country code should be used
[ 10.261464] ath: doing EEPROM country->regdmn map search
[ 10.261470] ath: country maps to regdmn code: 0x3a
[ 10.261474] ath: Country alpha2 being used: US
[ 10.261477] ath: Regpair used: 0x3a
[ 10.272545] ath11k c000000.wifi: ipq8074 hw2.0
[ 10.272583] ath11k c000000.wifi: FW memory mode: 1
[ 10.276181] remoteproc remoteproc0: powering up cd00000.q6v5_wcss
[ 10.280902] remoteproc remoteproc0: Booting fw image IPQ8074/q6_fw.mdt, size 668
[ 11.421341] remoteproc remoteproc0: remote processor cd00000.q6v5_wcss is now up
[ 11.422766] ath11k c000000.wifi: qmi ignore invalid mem req type 3
[ 11.428361] ath11k c000000.wifi: chip_id 0x0 chip_family 0x0 board_id 0xff soc_id 0xffffffff
[ 11.433830] ath11k c000000.wifi: fw_version 0x250a04a5 fw_build_timestamp 2021-12-20 07:09 fw_build_id WLAN.HK.2.5.0.1-01208-QCAHKSWPL_SILICONZ-1
[ 11.445163] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 13.927657] br-lan: port 1(lan1) entered blocking state
[ 13.927707] br-lan: port 1(lan1) entered disabled state
[ 13.932021] device lan1 entered promiscuous mode
[ 13.943945] nss-dp 3a001600.dp4 lan2: PHY Link up speed: 100
[ 13.944873] br-lan: port 2(lan2) entered blocking state
[ 13.948694] br-lan: port 2(lan2) entered disabled state
[ 13.953952] device lan2 entered promiscuous mode
[ 13.961939] nss-dp 3a001800.dp5 lan3: PHY Link up speed: 1000
[ 13.964553] br-lan: port 3(lan3) entered blocking state
[ 13.969372] br-lan: port 3(lan3) entered disabled state
[ 13.974731] device lan3 entered promiscuous mode
[ 13.984888] nss-dp 3a001200.dp2 wan: PHY Link up speed: 1000
[ 14.351399] pppoe-wan: renamed from ppp0
[ 14.950733] br-lan: port 2(lan2) entered blocking state
[ 14.950783] br-lan: port 2(lan2) entered forwarding state
[ 14.955092] br-lan: port 3(lan3) entered blocking state
[ 14.960335] br-lan: port 3(lan3) entered forwarding state
[ 14.965733] IPv6: ADDRCONF(NETDEV_CHANGE): wan: link becomes ready
[ 15.677177] br-lan: port 4(phy1-ap0) entered blocking state
[ 15.677219] br-lan: port 4(phy1-ap0) entered disabled state
[ 15.681891] device phy1-ap0 entered promiscuous mode
[ 15.727621] br-lan: port 5(phy2-ap0) entered blocking state
[ 15.727669] br-lan: port 5(phy2-ap0) entered disabled state
[ 15.732446] device phy2-ap0 entered promiscuous mode
[ 17.030658] nss-dp 3a001400.dp3 lan1: PHY Link up speed: 1000
[ 17.030759] br-lan: port 1(lan1) entered blocking state
[ 17.035408] br-lan: port 1(lan1) entered forwarding state
[ 22.847464] br-lan: port 4(phy1-ap0) entered blocking state
[ 22.847516] br-lan: port 4(phy1-ap0) entered forwarding state
[ 24.085703] br-lan: port 5(phy2-ap0) entered blocking state
[ 24.085761] br-lan: port 5(phy2-ap0) entered forwarding state
[ 33.110434] l11: disabling
[26504.949349] nss-dp 3a001200.dp2 wan: PHY Link is down
[26508.069398] nss-dp 3a001200.dp2 wan: PHY Link up speed: 1000 -
netcore
Más is tapasztalja hogy az utolsó 2-3 fw verzió felrakás után minden frankó, de eltelik 1-2 nap és semmit sem enged telepíteni mert szerinte read-only a fájlrendszer?
Ilyenkor az ssh is elköszön:
Server refused to allocate pty
Server refused to start a shell/command -
netcore
Egy másik valószínűleg ugyanoda mutató hiba, hiába szeretnék egy uj port továbbítási szabályt létrehozni nem menti el, csak irja h van 2 mentetlen vááltozás, hiába mentem ott is el nem hozza létre.
netcore
pár nap és kiderül, ami nekem furcsa hogy egyesített partíció után most "csak" ~170mb körül van a szabad hely, ha jól rémlett több volt régen
a wolfssl-t milyen csomagokra érdemes cserélni? ha jól sejtem kell az uj csomag(ok) és utánna mehet a wolfssl remove ( minden ilyen nevű csomagot törölni kell)? -
netcore
Létezik olyan app openwrt alá ami kilistázza az összes hálózatra csatlakozott ezközt és ott egyből lehet kitiltani a netről mint a gyári fw alatt?
a arp-scan --interface br-lan --localnet mutat mindent de csak terminálban és egyszerűbb lenne webes felületen -
netcore
Éjjel/hajnalban annyira bosszantott hogy ezt tettem, és magam sem értem de elsőre felment minden ahogy a leírás írja, mostmár mindkét partíción ott pihen az openwrt.
Az normális hogy ha felteszek egy sysupdate frissítést minden előtte telepített programot kukázik? ez nem csak egy update lenne így? -
netcore
Hiába próbálom itt is a másik partíciót indítani valamiért itt sem hajlandó
netcore
Így van, átállítom és akkor is a másik bootol, már azon is fent kell lennie, legalánnis a
ubiformat /dev/mtd12 -f /tmp/openwrt-ipq807x-generic-xiaomi_ax3600-squashfs-factory.ubi -s 2048 -O 2048
minden hiba nélkül végigfut, de hiába állítom át onnan nem akar vagy valamiért nem tud bootolni. -
netcore
Mit rontok el ha a ezt a hibaüzenetet kapom:
root@Router:~# ubiformat /dev/mtd13 -y -f /tmp/openwrt-ipq807x-generic-xiaomi_ax3600-squashfs-nand-factory.ubi
ubiformat: error!: please, first detach mtd13 (/dev/mtd13) from ubi0
root@Router:~#
A rendszer elindul jön-megy de frissíteni nem hajlandó, gondolom valamiért nincs fent mindekét partíción minden ami kellene neki. -
netcore
Openwrt alatt hol lehet megadni hogy csak az én általam beállított dns szerver címekről(pihole) lehessen kérni bármit is? hiába irom be a lan résznél azzól még valamiért megy olyan oldal ami a dns szerveren tiltva van.
netcore
Arra van lehetőség Openwrt alatt hogy ne külön hálózat legyen a 2,4 és az 5ghz?( egy wifi legyen mint a gyári fw alatt)
netcore
Ma megérkezett a 3600 mellé egy 3200, mesh megy kábellel pikkpakk, 3600cn 3200 gyári rom.
A 3200 is okosítható valahogy ( láttam van openwrt de az nem tudom menne e meshben)?
A cél a max wifi adóteljesítmény aktiválása és a cn szerver ping offolás lenne. -
netcore
A global fw-ről mentett beállításokat vissza lehet tölteni a kínai fw-be?
- Új Steelseries Arctis Nova pro vezeték nélküli gamer fejhallgató
- Thinkpad L14 Gen1 14" FHD IPS i5-10210U 16GB 256GB NVMe ujjolv IR kam gar
- JBL Authenics 200 bluetooth hangszóró garanciális
- Gigabyte RTX 2070 Super Windforce OC
- ThinkPad P15 Gen2i 15.6" FHD IPS i7-11800H RTX A2000 32GB 1TB NVMe magyarított bill ujjolv gar
- Lenovo T14 Thinkpad Gen3 WUXGA IPS i5-1245U vPro 10mag 16GB 512GB Intel Iris XE Win11 Pro Garancia
- Azonnali készpénzes Sony Playstation 5 lemezes és digitális felvásárlás személyesen/csomagküldéssel
- HP ProDesk 600 G4 i5-8100 8GB 256GB 1 év garancia
- BESZÁMÍTÁS! MSI B450M R5 5600X 32GB DDR4 512GB SSD RTX 4060 TI 16GB ZALMAN Z1 Plus A-Data 650W
- HIBÁTLAN iPhone 15 Pro 256GB Black Titanium -1 ÉV GARANCIA - Kártyafüggetlen, MS3503
ff, heap alloc
hip version 0x1500
jó lenne ha menne ugyanazon a ssid néven mindegyik freki mint a gyári fw-el , de egyenlőre nem találtam meg hogy hogyan is fog működni
