OpenWrt topic
tjsz
Intel fan11
#11692
Ipconfig-ra mi a válasz?
tjsz
vargalex
#11557
Ezt láttam:
[ 93.120000] wlan0: authenticate with d2:17:c2:63:97:89
[ 93.150000] wlan0: send auth to d2:17:xx:xx:xx:xx (try 1/3)
[ 93.160000] wlan0: d2:17:xx:xx:xx:xx denied authentication (status 1)
[ 153.840000] wlan0: authenticate with d2:17:xx:xx:xx:xx
[ 153.870000] wlan0: send auth to d2:17:xx:xx:xx:xx (try 1/3)
[ 153.880000] wlan0: d2:17:xx:xx:xx:xx denied authentication (status 1)
[ 214.560000] wlan0: authenticate with d2:17:xx:xx:xx:xx
[ 214.590000] wlan0: send auth to d2:17:xx:xx:xx:xx (try 1/3)
[ 214.600000] wlan0: d2:17:xx:xx:xx:xx denied authentication (status 1)
[ 305.290000] wlan0: authenticate with d2:17:xx:xx:xx:xx
[ 305.320000] wlan0: send auth to d2:17:xx:xx:xx:xx (try 1/3)
[ 305.330000] wlan0: d2:17:xx:xx:xx:xx denied authentication (status 1)
[ 396.010000] wlan0: authenticate with d2:17:xx:xx:xx:xx
[ 396.040000] wlan0: send auth to d2:17:xx:xx:xx:xx (try 1/3)
[ 396.050000] wlan0: d2:17:xx:xx:xx:xx denied authentication (status 1)
[ 487.730000] wlan0: authenticate with d2:17:xx:xx:xx:xx
[ 487.760000] wlan0: send auth to d2:17:xx:xx:xx:xx (try 1/3)
[ 487.770000] wlan0: d2:17:xx:xx:xx:xx denied authentication (status 1)
[ 578.460000] wlan0: authenticate with d2:17:xx:xx:xx:xx
[ 578.490000] wlan0: send auth to d2:17:xx:xx:xx:xx (try 1/3)
[ 578.500000] wlan0: d2:17:xx:xx:xx:xx denied authentication (status 1)A WR1043-asom a tomato vendég wifi-jére csatlakozott volna, amin nincs macfilter. Legalább is azt hittem... Ugyanis: amint felvettem a macfilter listába a WR1043-as mac-jét abban a pillanatban csatlakozott rá. A dolog azért érdekes, mert tegnap (10-én) délután vendégeink voltak, akiknek a mobiljuk szuperul tudott csatlakozni a tomato vendég wifi-re, mindenféle macfilter piszkálás nélkül. Este, amikor a WR1043-assal akartam csatlakozni erre a vendég wifi-re, akkor azt már nem engedte. És a további érdekesség: ezek után próbáltam egy teszt mobil telefonnal ugyanígy a vendég wifi-re csatlakozni és már azzal sem sikerült. Tehát mintha a tomato vendég wifi-jén valahogy bekapcsolódott volna a macfilter. Pedig ehhez tutira nem nyúltam.
tjsz
Az mennyire esélyes, hogy egy tomato-s Asus-ra nem tud felcsatlakozni egy Openwrt-s router client mode-ban?
Asus RT N18U, Tomato Firmware 1.28.0000 -140 K26ARM USB AIO-64K
TP Link WR1043ND, OpenWrt Chaos Calmer 15.05.1 -
tjsz
vargalex
#11542
DDWRT volt rajta és switchként használta a fiam: DHCP+wifi ki volt kapcsolva. Aztán egy áramszünet után csak azt látták, hogy villognak rajta a led-ek, de nem funkciónál. Ekkor hozta haza, szétszedtem, és soros porton keresztül láttam azt, amit feltöltöttem. Próbáltam Openwrt-t felrakni, de a hiba ugyanaz volt.
tjsz
Volt-van egy 1.8-as verziójú WR1043ND routerem. Korábban DDWRT ment rajta, sima switch-ként volt használva. Azt volt az érdekes, hogy egy áramszünet után folyamatosan villogtak rajta a led-ek. Gondoltam valami gond lehet a DDWRT-vel, ezért ma szétszedtem, rákötöttem soros (USB) portra és a putty-on keresztül ezt láttam:
Le akartam cserélni openwrt-re, úgy ahogy a nagy könyvben meg van írva, de a helyzet változatlan maradt: továbbra is csak autobooting-ot akar csinálni. Ez mitől van ill. hogyan lehet javítani?
- Pedzegeti az új Xbox irányát a Microsoft
- Autós kamerák
- Doky586: SecureBoot kulcsok frissítése (2026 nyara)
- Házimozi haladó szinten
- Micro Four Thirds
- EAFC 26
- Sütés, főzés és konyhai praktikák
- GoodSpeed: Daikin FTXF35E / RXF35F Sensira 3,3 kW Inverteres klíma - a Sztori
- ÚRIS10!!! RAMÁRON! LEGION 5 i7-13650HX 16GB RAM 512GB SSD RTX 5070 8GB 2K OLED 165Hz 500NIT
- Eladó Samsung S23 Ultra 8/256GB / 12 hó jótállás / ÚJ AKKUMULÁTORRAL!
- MICROSOFT Surface Book 2,13.5", i5-7200U,8GB RAM,256GB SSD,WIN11
- Magyarország piacvezető szoftver webáruháza
- 15,6" Dell Latitude laptopok: E5550, E5570, 5590, 5500, 5501, 5510, 5520 / SZÁMLA + GARANCIA
