OpenWrt topic
H. Norbert
vargalex
#20677
Rendben, köszi.
beírtam a htop-ot, kép lentebb
cat ra ezt írja
root@ax3600:~# cat /proc/3595/stat
3595 (AdGuardHome) S 1 1 1 0 -1 4194560 35486 0 5740 0 2071 623 0 0 20 0 10 0 23 07 1299656704 9446 18446744073709551615 4194304 33806456 549194332960 0 0 0 1002 060288 0 2143420159 0 0 0 17 3 0 0 0 0 0 33880984 34446530 599650304 54919433400 3 549194334087 549194334087 549194334179 0
H. Norbert
vargalex
#20675
root@ax3600:~# top -b -n 1
Mem: 381536K used, 35784K free, 1688K shrd, 0K buff, 44340K cached
CPU: 0% usr 0% sys 0% nic 100% idle 0% io 0% irq 0% sirq
Load average: 0.00 0.00 0.00 2/109 4931
PID PPID USER STAT VSZ %VSZ %CPU COMMAND
4931 4923 root R 1332 0% 0% top -b -n 1
3595 1 root S 1239m 304% 0% /usr/bin/AdGuardHome -c /etc/adguardho me.yaml -w /var/adguardhome --no-check-update
1748 1745 network S 4776 1% 0% /usr/sbin/hostapd -s -g /var/run/hosta pd/global
1750 1746 network S 4476 1% 0% /usr/sbin/wpa_supplicant -n -s -g /var /run/wpa_supplicant/global
1296 1 root S 3768 1% 0% /sbin/rpcd -s /var/run/ubus/ubus.sock -t 30
2150 1 root S 2872 1% 0% /usr/sbin/uhttpd -f -h /www -r ax3600 -x /cgi-bin -u /ubus -t 60 -T 30 -k 20 -A 1 -n 3 -N 100 -R -p 0.0.0.0:80 -p [::] :80 -C /etc/uhttpd.crt -K /etc/uhttpd.key -s 0.0.0.0:443 -s [::]:443
2779 1 root S 2764 1% 0% {ntpd} /sbin/ujail -t 5 -n ntpd -U ntp -G ntp -C /etc/capabilities/ntpd.json -c -u -r /bin/ubus -r /usr/bin/env -r /us r/bin/jshn -r /usr/sbin/ntpd-hotplug -r /usr/share/libubox/jshn.sh -- /usr/sbin/ ntpd -n -N -S /usr/sbin/ntpd-hotplug -p 0.openwrt.pool.ntp.org -p 1.openwrt.pool .ntp.org -p 2.openwrt.pool.ntp.org -p 3.openwrt.pool.ntp.org
1746 1 root S 2764 1% 0% {wpa_supplicant} /sbin/ujail -t 5 -n w pa_supplicant -U network -G network -C /etc/capabilities/wpad.json -c -- /usr/sb in/wpa_supplicant -n -s -g /var/run/wpa_supplicant/global
3299 1 root S 2764 1% 0% {dnsmasq} /sbin/ujail -t 5 -n dnsmasq -u -l -r /bin/ubus -r /etc/TZ -r /etc/dnsmasq.conf -r /etc/ethers -r /etc/group -r /etc/hosts -r /etc/passwd -w /tmp/dhcp.leases -r /tmp/dnsmasq.d -r /tmp/hosts -r /usr/bin/jshn -r /usr/lib/dnsmasq/dhcp-script.sh -r /usr/share/dnsmasq/dhcpb ogushostname.conf -r /usr/share/dnsmasq/rfc6761.conf -r /usr/share/dnsmasq/trust -anchors.conf -r /usr/share/libubox/jshn.sh -r
1745 1 root S 2764 1% 0% {hostapd} /sbin/ujail -t 5 -n hostapd -U network -G network -C /etc/capabilities/wpad.json -c -- /usr/sbin/hostapd -s -g /var/run/hostapd/global
1810 1 root S 2212 1% 0% /sbin/netifd
1 0 root S 1880 0% 0% /sbin/procd
2037 1 root S 1744 0% 0% /usr/sbin/odhcpd
3303 3299 dnsmasq S 1536 0% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq. conf.cfg01411c -k -x /var/run/dnsmasq/dnsmasq.cfg01411c.pid
3236 1810 root S 1412 0% 0% /usr/sbin/pppd nodetach ipparam wan if name pppoe-wan lcp-echo-interval 1 lcp-echo-failure 5 lcp-echo-adaptive +ipv6 se t AUTOIPV6=1 nodefaultroute usepeerdns maxfail 1 user hargitajulia-zdg password ???????? ip-up-script /lib/netifd/ppp-up ipv6-up-script /lib/netifd/ppp6-up ip-d own-script /lib/netifd/ppp-down ipv6-down-script /lib/netifd/ppp-down mtu 1492 m ru 1492 plugin pppoe.so nic-wan
755 1 ubus S 1392 0% 0% /sbin/ubusd
1236 1 logd S 1332 0% 0% /sbin/logd -S 64
4923 4922 root S 1328 0% 0% -ash
2829 2779 ntp S 1316 0% 0% /usr/sbin/ntpd -n -N -S /usr/sbin/ntpd -hotplug -p 0.openwrt.pool.ntp.org -p 1.openwrt.pool.ntp.org -p 2.openwrt.pool.n tp.org -p 3.openwrt.pool.ntp.org
4922 1641 root S 1128 0% 0% /usr/sbin/dropbear -F -P /var/run/drop bear.1.pid -p 22 -K 300 -T 3 -W 262144 -2 9
1641 1 root S 1108 0% 0% /usr/sbin/dropbear -F -P /var/run/drop bear.1.pid -p 22 -K 300 -T 3 -W 262144
4058 1810 root S 1076 0% 0% odhcp6c -s /lib/netifd/dhcpv6.script - P0 -t120 pppoe-wan
791 1 root S 1064 0% 0% /sbin/urngd
756 1 root S 908 0% 0% /sbin/askfirst /usr/libexec/login.sh
227 2 root IW 0 0% 0% [kworker/u8:3-ev]
451 2 root IW 0 0% 0% [kworker/2:4-eve]
33 2 root IW 0 0% 0% [kworker/1:1-mm_]
13 2 root IW 0 0% 0% [rcu_sched]
12 2 root SW 0 0% 0% [ksoftirqd/0]
65 2 root IW 0 0% 0% [kworker/u8:2-ev]
1036 2 root IW 0 0% 0% [kworker/u8:4-ev]
9 2 root IW 0 0% 0% [kworker/u8:0-ev]
63 2 root IW 0 0% 0% [kworker/u8:1-ev]
3226 2 root IW 0 0% 0% [kworker/u8:5-ev]
4679 2 root IW 0 0% 0% [kworker/u8:7-ev]
4008 2 root IW 0 0% 0% [kworker/u8:6-ev]
162 2 root IW 0 0% 0% [kworker/0:4-mm_]
441 2 root SW 0 0% 0% [sugov:0]
37 2 root SW 0 0% 0% [kcompactd0]
52 2 root IW 0 0% 0% [kworker/3:1-mm_]
191 2 root IW 0 0% 0% [kworker/0:6-mld]
494 2 root IW 0 0% 0% [kworker/3:3-eve]
18 2 root SW 0 0% 0% [ksoftirqd/1]
4914 2 root IW 0 0% 0% [kworker/1:0-eve]
23 2 root SW 0 0% 0% [ksoftirqd/2]
28 2 root SW 0 0% 0% [ksoftirqd/3]
62 2 root SW 0 0% 0% [watchdogd]
60 2 root IW< 0 0% 0% [kblockd]
228 2 root IW< 0 0% 0% [iscsi_eh]
230 2 root IW< 0 0% 0% [iscsi_conn_clea]
421 2 root IW< 0 0% 0% [mld]
422 2 root IW< 0 0% 0% [ipv6_addrconf]
423 2 root IW< 0 0% 0% [kworker/1:1H-kb]
424 2 root IW< 0 0% 0% [kstrp]
433 2 root SW 0 0% 0% [irq/77-cpr3]
77 2 root IW< 0 0% 0% [kthrotld]
70 2 root SW 0 0% 0% [kswapd0]
104 2 root SW 0 0% 0% [irq/82-aerdrv]
366 2 root SW 0 0% 0% [irq/17-4a9000.t]
457 2 root SW 0 0% 0% [ubi_bgt0d]
445 2 root SW 0 0% 0% [irq/25-q6v5 wdo]
463 2 root IW< 0 0% 0% [kworker/3:1H-kb]
488 2 root SW 0 0% 0% [irq/88-keys]
574 2 root IW< 0 0% 0% [kworker/2:1H-kb]
656 2 root SW 0 0% 0% [ubifs_bgt0_1]
436 2 root SW 0 0% 0% [irq/16-smp2p]
61 2 root IW< 0 0% 0% [blkcg_punt_bio]
42 2 root IW 0 0% 0% [kworker/2:1-eve]
46 2 root IW< 0 0% 0% [pencrypt_serial]
35 2 root SW 0 0% 0% [oom_reaper]
31 2 root IW< 0 0% 0% [inet_frag_wq]
30 2 root IW< 0 0% 0% [kworker/3:0H-kb]
36 2 root IW< 0 0% 0% [writeback]
47 2 root IW< 0 0% 0% [pdecrypt_serial]
64 2 root IW< 0 0% 0% [kworker/0:1H-kb]
25 2 root IW< 0 0% 0% [kworker/2:0H-kb]
26 2 root SW 0 0% 0% [cpuhp/3]
21 2 root SW 0 0% 0% [cpuhp/2]
17 2 root SW 0 0% 0% [migration/1]
20 2 root IW< 0 0% 0% [kworker/1:0H-ev]
22 2 root SW 0 0% 0% [migration/2]
27 2 root SW 0 0% 0% [migration/3]
14 2 root SW 0 0% 0% [migration/0]
11 2 root SW 0 0% 0% [rcu_tasks_trace]
15 2 root SW 0 0% 0% [cpuhp/0]
8 2 root IW< 0 0% 0% [kworker/0:0H-ev]
6 2 root IW< 0 0% 0% [netns]
4 2 root IW< 0 0% 0% [rcu_par_gp]
2 0 root SW 0 0% 0% [kthreadd]
3 2 root IW< 0 0% 0% [rcu_gp]
5 2 root IW< 0 0% 0% [slub_flushwq]
10 2 root IW< 0 0% 0% [mm_percpu_wq]
16 2 root SW 0 0% 0% [cpuhp/1]
1057 2 root IW< 0 0% 0% [ath11k_wq]
1058 2 root IW< 0 0% 0% [ath11k_aux_wq]
915 2 root IW< 0 0% 0% [ath10k_aux_wq]
878 2 root IW< 0 0% 0% [cfg80211]
914 2 root IW< 0 0% 0% [ath10k_wq]
916 2 root IW< 0 0% 0% [ath10k_tx_compl]
4905 2 root IW 0 0% 0% [kworker/1:2-eve] -
H. Norbert
Sziasztok, xiaomi ax 3600-ra raktam a legfrissebb openwrt-t ssh-val
Elindításkor kb 40-60% a ram felhasználás, utána folyamatosan 90-92%
ez mitől lehet?
csak az adguard fut még a routerről, de ezt előtte is csinálta
- Samsung kuponkunyeráló
- DVB-T, DVB-S (2), DVB-C eszközök
- BMW topik
- Napelem
- Hitelkártyák használata, hitelkártya visszatérítés
- Battlefield 6
- Crimson Desert
- Creality HALOT ONE gyantás nyomtató
- OPPO Find X9 Pro Titanium Charcoal 512GB használt karcmentes 6 hónap garancia
- Bomba ár! Dell Latitude 5400 - i5-8265U I 16GB I 256SSD I 14" HD I HDMI I Cam I W11 I Gari
- HP EliteBook 650 G10 15,6" i5 -1335u, 16GB RAM, 512GB SSD, jó akku, számla, 6 hó gar
- ÁRGARANCIA!Épített KomPhone i5 14400F 32/64GB RAM RX 9060 XT 8GB GAMER PC termékbeszámítással
