Surfym@n
a laphoz a legujabb bios: v 1.5 Bővebben: link
idézem a gyártót:
- Added Auto-Shutdown function when CCMOS jumper is set to pins 2-3. The correct CCMOS jumper should be on pins 1-2; in case it is placed on 2-3, the CPU core voltage will be abnormally high, an the system will shut down automatically to protect the CPU from damage.
- Fixed an issue where USB-ZIP will be detected as a harddisk.
- Updated SI3112 SATA BIOS to v4.2.47.
- Revised the characters in ''Wakeup by Alarm''.
- Enhanced USB 2.0 device compatibility, ''Integrated Peripherals / OnChip PCI Device / USB 2.0 Device Compatible / Disabled -> Enabled''.
- Fixed an issue where SCSI boot ID cannot be selected when certain SCSI cards are installed.
- Fixed an issue where SATA HDD boot up will fail if a PS/2 mouse is not installed.
- Fixed an issue where the system will show 119 degrees under certain circumstances.
- BIOS compile date: 03/04/2004. -
Surfym@n
ahogy nézem a 266os ram-odat meg a tbredet tedd szinkronba... ez most a max amit kihozhatsz a lapodból. ha esetleg a procid nem lockos, akkor még a szorzón érdemes variálni. fsb-t ne változtass!
- Kedvenc zene a mai napra
- Építő/felújító topik
- Crimson Desert
- Renault, Dacia topik
- Xbox Series X|S
- Motorola Moto G06 Power – nagyfater új zakót vett
- Eladó Samsung Galaxy A53 5G 6/128GB fekete / 12 hónap jótállás
- Kingston FURY Impact 32GB DDR5 4800MHz KF548S38IB-32
- 27% - Erazer P20 GAMER PC! i7-14700F / RTX 4070 / 16GB DDR5 / 1TB NVMe / B760
- 27% - LG UltraGear 27GS95QE-B Monitor! 2560x1440 / 240Hz / 0.03ms / G-SYNC / FreeSync BeszámítOK!
- Samsung Galaxy A54 5G / 8/128GB / Kártyafüggetlen / 12Hó Garancia
