Sonja
Intel Arc 140V vs Radeon 890M - Lunar Lake iGPU 1080p benchmarks!
Ez a HW most egész jóra sikerült, az SW viszont nem.
Sonja
Nézzétek a képet. Ennyiért volt hírdetve 1db 3080 Ti!
Igen, csak volt, mert ha megnézitek most a linket, akkor bizony már nincs.
Ez borzasztó.
Sonja
Sonja
Sonja
s.bala31
#34424
Update, thanks Nizzen for the hint. The performance loss is likely due to the way NVIDIA converts RGB to reduced chroma YCbCr 4:2:2 in HDR (we discussed that previously here) which was used for HDR testing. If they used 4:4:4 or RGB, the performance would be the same as SDR. Considering GSYNC Ultra HD monitors bog down to 4:2:2, this looks the be the most plausible explanation.
Sonja
Sonja
Nem rossz.
China's Top Server-Builders Adopt NVIDIA AI Design for Cloud Computing
Huawei, Inspur, Lenovo Select NVIDIA Volta HGX Architecture to Build AI Systems for Data Centers
Sonja
Sonja
Deus Ex: Mankind Divided - PC System Specs
PC System Specifications
Minimum:
OS: Windows 7.1SP1 or above (64-bit Operating System Required)
CPU: Intel Core i3-2100 or AMD equivalent
RAM: 8 GB
Graphics: AMD Radeon HD 7870 (2GB) or NVIDIA GeForce GTX 660 (2GB)
HDD/SSD: 45 GBRecommended:
OS: Windows 10 64-bit
CPU: Intel Core i7-3770K or AMD FX 8350 Wraith
RAM: 16 GB
Graphics: AMD Radeon RX 480 - 1920 x 1080 or NVIDIA GTX 970 - 1920 x 1080
HDD/SSD: 55GB (Including DLC) -
Sonja
Sonja
Sonja
GeForce GTX 1060 Guru3D Review - Ebben van 4db DX12 teszt is.
Sonja
Sonja
Sonja
Sonja
Sonja
Sonja
Dev Blog: Bringing DirectX 12 to Rise of the Tomb Raider
The above advantage we feel is the most important one for Rise of the Tomb Raider, but there are many more advantages that make us excited about DirectX 12. Another big feature, which we are also using on Xbox One, is asynchronous compute. This allows us to re-use GPU power that would otherwise go to waste, and do multiple tasks in parallel. And there is a never before seen level of control over NVIDIA SLI and AMD CrossFireX configurations, which means that as a developer we can take full control over those systems and ensure users get a great experience with them.
Sonja
Az "agyontuningolt" jelző nekem inkább egy pl. Kingpin féle LN2-es tuningra illik, de kinek hogy.
Sonja
Sonja
Állítólag nem működik jól a CF-se, tiltani kell. Legalábbis az alábbi NeoGAF bejegyzés szerint:
""Crossfire users be vary though, disable it or you are going to run into problems."
Yeah, it's exactly the same case as beta. Nothing has changed as far as Crossfire support. I meant to post about it last night, but I've been too busy playing.
Just disable CF if you have any issues. A single 7970 can run this on ultra @ 1080p just fine."
Sonja
Remélem elfér ide.
Sonja
Jó forró a VRM.
Megbízhatatlan oldalakat ahol nem mérnek (pl gamegpu) ne linkeljetek.
- Klaus Duran: RCS
- Assetto Corsa Rally
- Építő/felújító topik
- AliExpress tapasztalatok
- Okos Otthon / Smart Home
- MWC 2026: Meglepően jó áron jön a kicsi, de erős, illetve a nagy és fotós Xiaomi
- Arc Raiders
- Gainward Phoenix RTX 3080 10GB Megkímélt állapotban, dobozában!
- ASUS GeForce RTX 5060 Ti DUAL OC 16GB WHITE EDITION
- ASUS RTX5090 - TUF-RTX5090-32G-GAMING /ÚJ, BONTATLAN, MAGYAR KISKER GARANCIA, NEM CÉGES VÁSÁRLÁS/
- MSI GeForce RTX 5090 32G LIGHTNING Z /ÚJ, BONTATLAN, CSAK HÉTFŐIG/
- Eladó Sapphire AMD Radeon RX 7900 XTX NITRO+ Vapor-X 24GB videókártya
- új akku Ár/ÉRTÉK BAJNOK! Dell Latitude 5330 i3-1215U - 16GB 256GB 13.3" FHD 1 év garancia
- Bomba ár! Dynabook Portege X30-L-K - i7-1260P I 8GB I 256SSD I 13,3" FHD I Cam I W11 I Gari!
- LG 65G5 - 65" OLED Tandem - 4K 165Hz & 0.1ms - MLA Plus - 4000 Nits - NVIDIA G-Sync - FreeSync
- 3M füldugó 50 pár (100db) eladó
Ez borzasztó.
