The Eagle
mattheus
#108
Hi!
Ezek a kockák a régi gépemen nekem is többször bejöttek indításkor. De azóta is hibátlanul megy az öcsémnél. Igaz, abban nem ATI van, de dettó ez volt a jelenség. Így nem foglalkoztam vele. De hátha az okosabbak többet mondanak.
Szvsz használd nyugodtam, vagy tedd vissza a régi drivert, és bizonyosodj meg róla, hogy az új csinálja-e.
bye
The Eagle -
The Eagle
Hi!
Igen. Nekem az legújabb omega van, ami a Catalyst 4,5 re épül. Nálam nőtt a 3Dmark2001 pontszám is, meg mintha kicsit jobb lenne, de nézze meg más is.
http://www.omegacorner.com/index_ati.html
-----------------cut--------------------------
OMEGADRIVE here!
These are my ''optimized'' drivers for the ATI Radeon family of video cards.
What's New? (2k/XP 2.5.44)
* Based on the Catalyst 4.5 drivers.
* Updated the Omega version of RadLinker (1009), now the Profiler include options
to enable TAA modes and to establish the desired TAA Threshold for D3D apps.
* Added and removed a LOT of tweaks, ATI changed some internal settings and some
old tweaks won't work anymore from now on.
* Fixed support for Mobility 9700.
* Fixed the ''Hibernation not working'' problem in laptops.
* Added support for the Following laptop wide screen resolutions: 800x480,
960x600, 1024x600, 1024x480, 1280x600, 1280x768, 1280x800, 1680x1050, 1920x1200
* Re-enabled a desktop wide resolution: 1280x768
* Added an EXCLUSIVE new Omega utility which adds the ability to SWAP between
the soft-mod and the normal driver without the need to re-install the whole
drivers. (Thanks to Chris W, Author of RadLinker)
* Removed Artifact Tester 5 from the package. (Sorry Alberto)
* Included the latest version of ATITool. (Thanks W1zzard)
* Since the package has grown in size I will be distributing the installer in
compressed CAB format to save some bandwidth, it must be decompressed using one
of these tools (latest version): WinAce, WinRAR or WinZip. Then run the extracted
file to start installation of the drivers.
Important Notes:
1. If you are using an Omega soft-mod and you are experiencing crashes, black
screens, artifacts or the ''check board effect'' during game play, run the new
included Driver Swapper utility and select the Normal driver, the reason is
that your card is not accepting the soft-mod due to broken/incompatible
hardware.
REMINDERS:
1- If you have the normal ATI drivers installed, uninstall the ATI Control Panel
BEFORE upgrading to these drivers, the Omega Drivers already have the CP
integrated and another CP will cause conflicts or other problems.
2- There is no need to uninstall ANY previous drivers (ATI or OMEGA) when
installing these, the new ones will overwrite any previous settings, but if
you still want to uninstall them completely, is ok.
3- In Windows 2k/XP, ALWAYS disable DDC in the ATI ''Displays/Monitor'' CP after
installing drivers to be able to use ALL the refresh rates and resolutions
your monitor supports, also this is the best way to avoid the 60Hz RR bug.
4- The WDM drivers for VIVO and AIW cards are not included, but they can be
downloaded separately from a link in my drivers page.
5- The Radeon cards do support FastWrites and they will work with it on
(on some machines), but it is not recommended, there is NO SPEED gain
when using FW, and this option will affect your PC's stability a LOT,
most game crashes and problems are because FW is enabled.
6- Install the included Multires utility to have access to ALL the available
resolutions in the Omega Drivers, standard Windows doesn't show all of them.
7- Always uninstall the previous version of RadLinker before installing the new
one included in the latest Omega Drivers.
I don't recommend the use of ANY external tweakers with my drivers (specially
Rage3D Tweaker), as they override my special settings and will make my work
useless. The only time I recommend a tweaker is when you have a specific
problem with a specific tweak and need to change it in order to make the drivers
work correctly. Also if you use a tweaker for overclocking, FSAA, Gamma or
Aniso settings, is just fine, but you'll be better off using the integrated ATI
CP for that (which is ok by me if you change any setting in it).
If you have any problems with this drivers please go to my webpage and look in
the ATI help section for answers. If still have problems look for the drivers
thread in www.driverheaven.net forums and let me know what is going on.
If you happen to find a new tweak or fix for a specific game or many games
and it proves that it works then drop me an E-Mail (don't post it in the
forums), I'll make sure credit will be granted to that person in this INFO file.
IMPORTANT: Don't bother ATI about these drivers as they are unsupported by them!
May GOD bless everybody!
O M E G A D R I V E
---------------end cut--------------------------
Bocs az idézetért..
bye
The Eagle
- Viccrovat
- Teljesen M5 SoC-családra vált az Apple Macbook Air és Pro
- Lítium-ion/Li-ion akkumulátorok
- Amit látnod kell 80’ – 90’ évek, egész estét betöltő mozi filmjei.
- Apple iPhone 6S/6S Plus szerviz alkatrészek, készletről akár másnapra!
- iKing.Hu - Használt, karcmentes Google Pixel 9 Pro Fold Obsidian színben, 256 GB tárhellyel, 6 hónap
- AKCIÓ! LENOVO ThinkPad P15 Gen2 munkaállomás - i7 11800H 64GB DDR4 1TB SSD RTX A2000 4GB W
- HIBÁTLAN iPhone 13 128GB Blue-1 ÉV GARANCIA - Kártyafüggetlen, MS4453, 100% Akksi
- HIBÁTLAN iPhone 13 Pro 128GB Gold -1 ÉV GARANCIA -Kártyafüggetlen- MS4674, 100% AKKSI
